[U-Boot] [PATCH v5 0/4] Implement "fastboot flash" for eMMC
This series implements the "fastboot flash" command for eMMC devices. It supports both raw and sparse images.
NOTES: - the support for the "fastboot flash" command is enabled with CONFIG_FASTBOOT_FLASH - the support for eMMC is enabled with CONFIG_FASTBOOT_FLASH_MMC_DEV - (future) the support for NAND would be enabled with CONFIG_FASTBOOT_FLASH_NAND(???)
This has been tested on ARMv7.
This series depends on: http://patchwork.ozlabs.org/patch/379438/ http://patchwork.ozlabs.org/patch/382443/ (to 382446)
Changes in v5: - use the common/aboot.c for the "sparse format" handling
Changes in v4: - rearranged this patchset so that "sparse_format.h" can be dropped (if we cannot resolve the copyright/licensing issues) - update mmc_get_dev(...) to get_dev("mmc",....) - update printf() to puts() where applicable - update debug string as per feedback - rearranged "sparse format" support in this patchset, in order to isolate...
Changes in v3: - remove most references to 'mmc', which leaves only one mmc specific function: mmc_get_dev()
Changes in v2: - split large function into three - improved handling of response messages - additional partition size checking when writing sparse image - update README.android-fastboot file - new in v2
Steve Rae (4): usb/gadget: fastboot: add eMMC support for flash command usb/gadget: fastboot: add support for flash command usb/gadget: fastboot: minor cleanup usb/gadget: fastboot: implement sparse format
README | 10 +++++ common/Makefile | 6 +++ common/cmd_fastboot.c | 7 +-- common/fb_mmc.c | 95 +++++++++++++++++++++++++++++++++++++++++ doc/README.android-fastboot | 5 ++- drivers/usb/gadget/f_fastboot.c | 44 +++++++++++++++++-- include/fb_mmc.h | 8 ++++ 7 files changed, 166 insertions(+), 9 deletions(-) create mode 100644 common/fb_mmc.c create mode 100644 include/fb_mmc.h
- add support for 'fastboot flash' command for eMMC devices
Signed-off-by: Steve Rae srae@broadcom.com ---
Changes in v5: None Changes in v4: - rearranged this patchset so that "sparse_format.h" can be dropped (if we cannot resolve the copyright/licensing issues) - update mmc_get_dev(...) to get_dev("mmc",....) - update printf() to puts() where applicable
common/Makefile | 5 ++++ common/fb_mmc.c | 82 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/fb_mmc.h | 8 ++++++ 3 files changed, 95 insertions(+) create mode 100644 common/fb_mmc.c create mode 100644 include/fb_mmc.h
diff --git a/common/Makefile b/common/Makefile index de5cce8..daebe39 100644 --- a/common/Makefile +++ b/common/Makefile @@ -266,4 +266,9 @@ obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
+# This option is not just y/n - it can have a numeric value +ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +obj-y += fb_mmc.o +endif + CFLAGS_env_embedded.o := -Wa,--no-warn -DENV_CRC=$(shell tools/envcrc 2>/dev/null) diff --git a/common/fb_mmc.c b/common/fb_mmc.c new file mode 100644 index 0000000..e559e2a --- /dev/null +++ b/common/fb_mmc.c @@ -0,0 +1,82 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fb_mmc.h> +#include <part.h> + +/* The 64 defined bytes plus the '\0' */ +#define RESPONSE_LEN (64 + 1) + +static char *response_str; + +static void fastboot_resp(const char *s) +{ + strncpy(response_str, s, RESPONSE_LEN); + response_str[RESPONSE_LEN - 1] = '\0'; +} + +static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, + const char *part_name, void *buffer, + unsigned int download_bytes) +{ + lbaint_t blkcnt; + lbaint_t blks; + + /* determine number of blocks to write */ + blkcnt = ((download_bytes + (info->blksz - 1)) & ~(info->blksz - 1)); + blkcnt = blkcnt / info->blksz; + + if (blkcnt > info->size) { + printf("%s: too large for partition: '%s'\n", __func__, + part_name); + fastboot_resp("FAILtoo large for partition"); + return; + } + + puts("Flashing Raw Image\n"); + + blks = dev_desc->block_write(dev_desc->dev, info->start, blkcnt, + buffer); + if (blks != blkcnt) { + printf("%s: failed writing to device %d\n", __func__, + dev_desc->dev); + fastboot_resp("FAILfailed writing to device"); + return; + } + + printf("........ wrote " LBAFU " bytes to '%s'\n", blkcnt * info->blksz, + part_name); + fastboot_resp("OKAY"); +} + +void fb_mmc_flash_write(const char *cmd, void *download_buffer, + unsigned int download_bytes, char *response) +{ + int ret; + block_dev_desc_t *dev_desc; + disk_partition_t info; + + /* initialize the response buffer */ + response_str = response; + + dev_desc = get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { + printf("%s: invalid mmc device\n", __func__); + fastboot_resp("FAILinvalid mmc device"); + return; + } + + ret = get_partition_info_efi_by_name(dev_desc, cmd, &info); + if (ret) { + printf("%s: cannot find partition: '%s'\n", __func__, cmd); + fastboot_resp("FAILcannot find partition"); + return; + } + + write_raw_image(dev_desc, &info, cmd, download_buffer, + download_bytes); +} diff --git a/include/fb_mmc.h b/include/fb_mmc.h new file mode 100644 index 0000000..1ad1d13 --- /dev/null +++ b/include/fb_mmc.h @@ -0,0 +1,8 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +void fb_mmc_flash_write(const char *cmd, void *download_buffer, + unsigned int download_bytes, char *response);
Hi Steve,
Changes in v3:
Changes in v2:
- Copyright 2014 Broadcom Corporation.
- strncpy(response_str, s, RESPONSE_LEN);
- response_str[RESPONSE_LEN - 1] = '\0';
- lbaint_t blkcnt;
- lbaint_t blks;
- /* determine number of blocks to write */
- blkcnt = ((download_bytes + (info->blksz - 1)) &
- blkcnt = blkcnt / info->blksz;
- if (blkcnt > info->size) {
__func__,
part_name);
I would opt for using error() here instead of printf().
return;
- puts("Flashing Raw Image\n");
- blks = dev_desc->block_write(dev_desc->dev, info->start,
blkcnt,
buffer);
- if (blks != blkcnt) {
dev_desc->dev);
printf() -> error()
return;
- printf("........ wrote " LBAFU " bytes to '%s'\n", blkcnt *
info->blksz,
part_name);
- fastboot_resp("OKAY");
- int ret;
- block_dev_desc_t *dev_desc;
- disk_partition_t info;
- /* initialize the response buffer */
- response_str = response;
- dev_desc = get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV);
- if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) {
printf() -> error()
return;
- ret = get_partition_info_efi_by_name(dev_desc, cmd, &info);
- if (ret) {
__func__, cmd);
printf() -> error()
return;
- write_raw_image(dev_desc, &info, cmd, download_buffer,
download_bytes);
On Tuesday, August 26, 2014 at 11:28:43 AM, Lukasz Majewski wrote:
Hi Steve,
If those are only small things, I think we can fix them up ourselves before applying, no? Let's do just that if Steve agrees, no ?
Best regards, Marek Vasut
Steve agrees!!! -- I have fixed them this time, see "v6", However, I have no issue with you cleaning up the minor issues.... THANKS, Steve
Hi Steve,
- implement 'fastboot flash' for eMMC devices
Signed-off-by: Steve Rae srae@broadcom.com Reviewed-by: Marek Vasut marex@denx.de ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - update README.android-fastboot file
README | 10 ++++++++++ doc/README.android-fastboot | 5 +++-- drivers/usb/gadget/f_fastboot.c | 31 +++++++++++++++++++++++++++++++ 3 files changed, 44 insertions(+), 2 deletions(-)
diff --git a/README b/README index 1d71359..ed26884 100644 --- a/README +++ b/README @@ -1623,6 +1623,16 @@ The following options need to be configured: downloads. This buffer should be as large as possible for a platform. Define this to the size available RAM for fastboot.
+ CONFIG_FASTBOOT_FLASH + The fastboot protocol includes a "flash" command for writing + the downloaded image to a non-volatile storage device. Define + this to enable the "fastboot flash" command. + + CONFIG_FASTBOOT_FLASH_MMC_DEV + The fastboot "flash" command requires addition information + regarding the non-volatile storage device. Define this to + the eMMC device that fastboot should use to store the image. + - Journaling Flash filesystem support: CONFIG_JFFS2_NAND, CONFIG_JFFS2_NAND_OFF, CONFIG_JFFS2_NAND_SIZE, CONFIG_JFFS2_NAND_DEV diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index 4045727..1677609 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -6,8 +6,9 @@ Overview The protocol that is used over USB is described in README.android-fastboot-protocol in same directory.
-The current implementation does not yet support the flash and erase -commands. +The current implementation does not yet support the erase command or the +"oem format" command, and there is minimal support for the flash command; +it only supports eMMC devices.
Client installation =================== diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 7a1acb9..e2659fa 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -19,6 +19,9 @@ #include <linux/compiler.h> #include <version.h> #include <g_dnl.h> +#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +#include <fb_mmc.h> +#endif
#define FASTBOOT_VERSION "0.4"
@@ -469,6 +472,28 @@ static void cb_boot(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str("OKAY"); }
+#ifdef CONFIG_FASTBOOT_FLASH +static void cb_flash(struct usb_ep *ep, struct usb_request *req) +{ + char *cmd = req->buf; + char response[RESPONSE_LEN]; + + strsep(&cmd, ":"); + if (!cmd) { + printf("%s: missing partition name\n", __func__); + fastboot_tx_write_str("FAILmissing partition name"); + return; + } + + strcpy(response, "FAILno flash device defined"); +#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV + fb_mmc_flash_write(cmd, (void *)CONFIG_USB_FASTBOOT_BUF_ADDR, + download_bytes, response); +#endif + fastboot_tx_write_str(response); +} +#endif + struct cmd_dispatch_info { char *cmd; void (*cb)(struct usb_ep *ep, struct usb_request *req); @@ -488,6 +513,12 @@ static const struct cmd_dispatch_info cmd_dispatch_info[] = { .cmd = "boot", .cb = cb_boot, }, +#ifdef CONFIG_FASTBOOT_FLASH + { + .cmd = "flash", + .cb = cb_flash, + }, +#endif };
static void rx_handler_command(struct usb_ep *ep, struct usb_request *req)
Hi Steve,
writing
device. Define
^^^^ additional?
information
this to
the image. +
Client installation
- char *cmd = req->buf;
- char response[RESPONSE_LEN];
- strsep(&cmd, ":");
- if (!cmd) {
return;
- strcpy(response, "FAILno flash device defined");
- fb_mmc_flash_write(cmd, (void *)CONFIG_USB_FASTBOOT_BUF_ADDR,
- fastboot_tx_write_str(response);
+} +#endif
.cmd = "flash",
.cb = cb_flash,
+#endif };
Despite the minor misspelling.
Acked-by: Lukasz Majewski l.majewski@samsung.com
- update static function - additional debugging statements - update "fastboot command" information - add missing include file - update spelling
Changes in v5: None Changes in v4: - update debug string as per feedback
Changes in v3: None Changes in v2: - new in v2
common/cmd_fastboot.c | 7 ++++--- drivers/usb/gadget/f_fastboot.c | 13 +++++++++---- 2 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/common/cmd_fastboot.c b/common/cmd_fastboot.c index 83fa7bd..909616d 100644 --- a/common/cmd_fastboot.c +++ b/common/cmd_fastboot.c @@ -30,7 +30,8 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) }
U_BOOT_CMD( - fastboot, 1, 1, do_fastboot, - "fastboot - enter USB Fastboot protocol", - "" + fastboot, 1, 0, do_fastboot, + "use USB Fastboot protocol", + "\n" + " - run as a fastboot usb device" ); diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index e2659fa..3b588a9 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -10,6 +10,7 @@ * * SPDX-License-Identifier: GPL-2.0+ */ +#include <config.h> #include <common.h> #include <errno.h> #include <malloc.h> @@ -41,7 +42,7 @@ struct f_fastboot { struct usb_function usb_function;
- /* IN/OUT EP's and correspoinding requests */ + /* IN/OUT EP's and corresponding requests */ struct usb_ep *in_ep, *out_ep; struct usb_request *in_req, *out_req; }; @@ -293,7 +294,7 @@ static int fastboot_add(struct usb_configuration *c) } DECLARE_GADGET_BIND_CALLBACK(usb_dnl_fastboot, fastboot_add);
-int fastboot_tx_write(const char *buffer, unsigned int buffer_size) +static int fastboot_tx_write(const char *buffer, unsigned int buffer_size) { struct usb_request *in_req = fastboot_func->in_req; int ret; @@ -341,6 +342,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req)
strsep(&cmd, ":"); if (!cmd) { + printf("%s: missing variable\n", __func__); fastboot_tx_write_str("FAILmissing var"); return; } @@ -361,6 +363,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) else strcpy(response, "FAILValue not set"); } else { + printf("%s: unknown variable: %s\n", __func__, cmd); strcpy(response, "FAILVariable not implemented"); } fastboot_tx_write_str(response); @@ -534,10 +537,12 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) } }
- if (!func_cb) + if (!func_cb) { + printf("%s: unknown command: %s\n", __func__, cmdbuf); fastboot_tx_write_str("FAILunknown command"); - else + } else { func_cb(ep, req); + }
if (req->status == 0) { *cmdbuf = '\0';
Hi Steve,
- update spelling
- new in v2
U_BOOT_CMD(
- fastboot, 1, 0, do_fastboot,
- "use USB Fastboot protocol",
- "\n"
- " - run as a fastboot usb device"
- /* IN/OUT EP's and corresponding requests */ struct usb_ep *in_ep, *out_ep; struct usb_request *in_req, *out_req;
-int fastboot_tx_write(const char *buffer, unsigned int buffer_size) +static int fastboot_tx_write(const char *buffer, unsigned int buffer_size) { struct usb_request *in_req = fastboot_func->in_req; int ret; @@ -341,6 +342,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) strsep(&cmd, ":"); if (!cmd) {
It is up to you if you would consider changing printf() to error().
printf() -> error()
- if (!func_cb)
- if (!func_cb) {
- else
- add capability to "fastboot flash" with sparse format images
Changes in v4: - rearranged "sparse format" support in this patchset, in order to isolate...
common/Makefile | 1 + common/fb_mmc.c | 33 +++++++++++++++++++++++---------- 2 files changed, 24 insertions(+), 10 deletions(-)
diff --git a/common/Makefile b/common/Makefile index daebe39..bc53078 100644 --- a/common/Makefile +++ b/common/Makefile @@ -268,6 +268,7 @@ obj-y += stdio.o
# This option is not just y/n - it can have a numeric value ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +obj-y += aboot.o obj-y += fb_mmc.o endif
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index e559e2a..c2e896f 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -7,16 +7,24 @@ #include <common.h> #include <fb_mmc.h> #include <part.h> +#include <aboot.h> +#include <sparse_format.h>
/* The 64 defined bytes plus the '\0' */ #define RESPONSE_LEN (64 + 1)
-static void fastboot_resp(const char *s) +void fastboot_fail(const char *s) { - strncpy(response_str, s, RESPONSE_LEN); - response_str[RESPONSE_LEN - 1] = '\0'; + strncpy(response_str, "FAIL", 4); + strncat(response_str, s, RESPONSE_LEN - 4 - 1); +} + +void fastboot_okay(const char *s) +{ + strncpy(response_str, "OKAY", 4); + strncat(response_str, s, RESPONSE_LEN - 4 - 1); }
static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, @@ -33,7 +41,7 @@ static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, if (blkcnt > info->size) { printf("%s: too large for partition: '%s'\n", __func__, part_name); - fastboot_resp("FAILtoo large for partition"); + fastboot_fail("too large for partition"); return; }
@@ -44,13 +52,13 @@ static void write_raw_image(block_dev_desc_t *dev_desc, disk_partition_t *info, if (blks != blkcnt) { printf("%s: failed writing to device %d\n", __func__, dev_desc->dev); - fastboot_resp("FAILfailed writing to device"); + fastboot_fail("failed writing to device"); return; }
printf("........ wrote " LBAFU " bytes to '%s'\n", blkcnt * info->blksz, part_name); - fastboot_resp("OKAY"); + fastboot_okay(""); }
void fb_mmc_flash_write(const char *cmd, void *download_buffer, @@ -66,17 +74,22 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, dev_desc = get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { printf("%s: invalid mmc device\n", __func__); - fastboot_resp("FAILinvalid mmc device"); + fastboot_fail("invalid mmc device"); return; }
ret = get_partition_info_efi_by_name(dev_desc, cmd, &info); if (ret) { printf("%s: cannot find partition: '%s'\n", __func__, cmd); - fastboot_resp("FAILcannot find partition"); + fastboot_fail("cannot find partition"); return; }
- write_raw_image(dev_desc, &info, cmd, download_buffer, - download_bytes); + if (is_sparse_image(download_buffer)) { + write_sparse_image(dev_desc, &info, cmd, download_buffer, + download_bytes); + } else { + write_raw_image(dev_desc, &info, cmd, download_buffer, + download_bytes); + } }
Hi Steve,
Changes in v5:
Changes in v4:
isolate...
- strncpy(response_str, "FAIL", 4);
- strncat(response_str, s, RESPONSE_LEN - 4 - 1);
- strncpy(response_str, "OKAY", 4);
return; }fastboot_fail("too large for partition");
return; }
- fastboot_okay("");
return; }
__func__, cmd);
return; }fastboot_fail("cannot find partition");
download_bytes);
- if (is_sparse_image(download_buffer)) {
download_buffer,
download_bytes);
- } else {
download_buffer,
download_bytes);
In the above if parenthesis are not needed.
Despite of this, Acked-by: Lukasz Majewski l.majewski@samsung.com
NOTES:
Lukasz, can you please pick this for this MW and send me a PR? Thanks!
Hi Marek,
NOTES:
No problem, I can pull this code to u-boot-dfu tree.
However, since I've been CCed to this patch series very recently I'd like to look into this code closely as it goes through my tree.
I hope that nobody minds this :-)
On Monday, August 25, 2014 at 09:19:26 AM, Lukasz Majewski wrote:
Hi Marek,
NOTES:
Sure. Btw. trimming the CC list ...
Hi Steve,
NOTES:
This patch is already applied.
Could you resend the above patch series one more time?
From the links it seems that in PATCH 1/4 you add the ./common/aboot.c file and at PATCH 2/4 you remove it.
Is this done on purpose?
(I've also trimmed down the CC list).
Changes in v5:
Changes in v4:
isolate...
Changes in v3:
Changes in v2:
- new in v2
On 14-08-25 07:57 AM, Lukasz Majewski wrote:
Hi Steve,
NOTES:
Correct (But it wasn't when I was preparing this....)
yes: done on purpose (in order to see the history of the changes to the file....) -- see the comments in the cover letter to that patch-series!!!
Changes in v5:
Changes in v4:
isolate...
Changes in v3:
Changes in v2:
- new in v2
Thanks, Steve
Hi Steve,
Hi Steve,
NOTES:
Ok, Now it is clear.
Is fair as I know bsd-3L-clause license is compatible with GPL.
However, to be 100% sure I'd like to ask Tom (as he has much more legal experience than me) to confirm that this code can be added to u-boot.
Changes in v5:
Changes in v4:
isolate...
Changes in v3:
Changes in v2:
- new in v2
Thanks, Steve
On 14-08-26 02:14 AM, Lukasz Majewski wrote:
Hi Steve,
Hi Steve,
NOTES:
OK -- note that this "bsd-3L-clause" clause is almost identical to the existing "bsd-3-clause".... Thanks, Steve
Changes in v5:
Changes in v4:
isolate...
Changes in v3:
Changes in v2:
- new in v2
Thanks, Steve
Hi Steve,
Hi Steve,
Hi Steve,
NOTES:
Tom, could you give your opinion on this?
Thanks, Steve
Changes in v5:
Changes in v4:
to isolate...
Changes in v3:
Changes in v2:
- new in v2
Thanks, Steve
On Wed, Aug 27, 2014 at 09:04:09AM +0200, Lukasz Majewski wrote:
Hi Steve,
Hi Steve,
Hi Steve,
NOTES:
So, upstream made a slight (and likely unintentional) change to the normal BSD 3 clause license and changed the last clause from "the copyright holders" to "The Linux Foundation". I've poked our legal dept about this but I suspect the best answer is to go back up to Android folks and ask them to fix this quite likely unintentional change.
Hi Steve,
Hi Steve,
[.. snip ...]
Actually, there are three diffs, and I am thinking that they were intentional (especially the last one!):
$ diff bsd-3-clause.txt bsd-3L-clause.txt 5,6c5 < notice, this list of conditions, and the following disclaimer, < without modification. ---
notice, this list of conditions and the following disclaimer.
10,12c9,12 < 3. The names of the above-listed copyright holders may not be used < to endorse or promote products derived from this software without < specific prior written permission. ---
- Neither the name of The Linux Foundation nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
16,17c16,17 < THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR < PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR ---
THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE AND
NON-INFRINGEMENT ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
So, would U-Boot accept this BSD-3L-Clause, or should I contact Colin Cross to attempt to get a BSD-3-Clause version, or ????
Thanks, Steve
Lukasz Majewski
Steve Rae
