[U-Boot] [PATCH v2 1/2] sunxi: Fix sorting of boards in MAINTAINERS
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/MAINTAINERS | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index c6371ea..dd27487 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -29,11 +29,11 @@ F: configs/mk802_a10s_defconfig F: configs/q8_a13_tablet_defconfig F: configs/r7-tv-dongle_defconfig F: configs/UTOO_P66_defconfig +F: configs/Wobo_i5_defconfig F: include/configs/sun6i.h F: configs/CSQ_CS908_defconfig F: configs/Mele_A1000G_quad_defconfig F: configs/Mele_M9_defconfig -F: configs/Wobo_i5_defconfig F: include/configs/sun7i.h F: configs/A20-OLinuXino_MICRO_defconfig F: configs/Bananapi_defconfig
The Sinovoip BPI-M2 is a SBC board based on the A31s SoC it features 1G RAM, a microsd slot, Gbit ethernet, 4 usb-a USB-2 ports, ir receiver, stereo headphone jack and hdmi video output.
The dts changes are identical to the dts files submitted upstream.
A few notes on the use if dldo and aldo regulators. DLDO1 is used for Vdd for the ethernet phy, ALDO2 is used for AVdd for the ethernet phy. ALDO1 is used to power the sdio wifi module.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun6i-a31.dtsi | 18 +++ arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts | 194 ++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 1 + configs/Sinovoip_BPI_M2_defconfig | 18 +++ 5 files changed, 233 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts create mode 100644 configs/Sinovoip_BPI_M2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3538553..8b656e9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -124,7 +124,8 @@ dtb-$(CONFIG_MACH_SUN6I) += \ sun6i-a31-mele-a1000g-quad.dtb \ sun6i-a31-mixtile-loftq.dtb \ sun6i-a31s-cs908.dtb \ - sun6i-a31s-primo81.dtb + sun6i-a31s-primo81.dtb \ + sun6i-a31s-sinovoip-bpi-m2.dtb dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-ainol-aw1.dtb \ sun7i-a20-bananapi.dtb \ diff --git a/arch/arm/dts/sun6i-a31.dtsi b/arch/arm/dts/sun6i-a31.dtsi index 39953e7..44f889f 100644 --- a/arch/arm/dts/sun6i-a31.dtsi +++ b/arch/arm/dts/sun6i-a31.dtsi @@ -659,6 +659,24 @@ allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
+ mmc2_pins_a: mmc2@0 { + allwinner,pins = "PC6", "PC7", "PC8", "PC9", + "PC10", "PC11"; + allwinner,function = "mmc2"; + allwinner,drive = <SUN4I_PINCTRL_30_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + mmc2_8bit_emmc_pins: mmc2@1 { + allwinner,pins = "PC6", "PC7", "PC8", "PC9", + "PC10", "PC11", "PC12", + "PC13", "PC14", "PC15", + "PC24"; + allwinner,function = "mmc2"; + allwinner,drive = <SUN4I_PINCTRL_30_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + gmac_pins_mii_a: gmac_mii@0 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA8", "PA9", "PA11", diff --git a/arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts b/arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts new file mode 100644 index 0000000..db7fa13 --- /dev/null +++ b/arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dts @@ -0,0 +1,194 @@ +/* + * Copyright 2015 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun6i-a31s.dtsi" +#include "sunxi-common-regulators.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Sinovoip BPI-M2"; + compatible = "sinovoip,bpi-m2", "allwinner,sun6i-a31s"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_bpi_m2>; + + blue { + label = "bpi-m2:blue:usr"; + gpios = <&pio 6 11 GPIO_ACTIVE_HIGH>; /* PG11 */ + }; + + green { + label = "bpi-m2:green:usr"; + gpios = <&pio 6 10 GPIO_ACTIVE_HIGH>; /* PG10 */ + }; + + red { + label = "bpi-m2:red:usr"; + gpios = <&pio 6 5 GPIO_ACTIVE_HIGH>; /* PG5 */ + }; + }; + + mmc2_pwrseq: mmc2_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pwrseq_pin_bpi_m2>; + reset-gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 WIFI_EN */ + }; +}; + +&ehci0 { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii_a>, <&gmac_phy_reset_pin_bpi_m2>; + phy = <&phy1>; + phy-mode = "rgmii"; + snps,reset-gpio = <&pio 0 21 GPIO_ACTIVE_HIGH>; /* PA21 */ + snps,reset-active-low; + snps,reset-delays-us = <0 10000 30000>; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bpi_m2>; + vmmc-supply = <®_vcc3v0>; + bus-width = <4>; + cd-gpios = <&pio 0 4 GPIO_ACTIVE_HIGH>; /* PA4 */ + cd-inverted; + status = "okay"; +}; + +&mmc0_pins_a { + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_a>; + vmmc-supply = <®_vcc3v0>; + mmc-pwrseq = <&mmc2_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: bcrmf@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 5 IRQ_TYPE_LEVEL_LOW>; /* PL5 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2_pins_a { + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; +}; + +&ohci0 { + status = "okay"; +}; + +&pio { + gmac_phy_reset_pin_bpi_m2: gmac_phy_reset_pin@0 { + allwinner,pins = "PA21"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + led_pins_bpi_m2: led_pins@0 { + allwinner,pins = "PG5", "PG10", "PG11"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + mmc0_cd_pin_bpi_m2: mmc0_cd_pin@0 { + allwinner,pins = "PA4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; +}; + +&r_pio { + mmc2_pwrseq_pin_bpi_m2: mmc2_pwrseq_pin@0 { + allwinner,pins = "PL8"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index dd27487..99f29d3 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -34,6 +34,7 @@ F: include/configs/sun6i.h F: configs/CSQ_CS908_defconfig F: configs/Mele_A1000G_quad_defconfig F: configs/Mele_M9_defconfig +F: configs/Sinovoip_BPI_M2_defconfig F: include/configs/sun7i.h F: configs/A20-OLinuXino_MICRO_defconfig F: configs/Bananapi_defconfig diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig new file mode 100644 index 0000000..17c30a8 --- /dev/null +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN6I=y +CONFIG_DRAM_CLK=432 +CONFIG_USB1_VBUS_PIN="" +CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_ETH_DESIGNWARE=y +CONFIG_AXP_DLDO1_VOLT=3000 +CONFIG_AXP_ALDO1_VOLT=3300 +CONFIG_AXP_ALDO2_VOLT=1800 +CONFIG_USB_EHCI_HCD=y
Acked-by: Ian Campbell ijc@hellion.org.uk
and for the 1/2 as well, which hardly needs an ack IMHO.
Hans de Goede
Ian Campbell
