[U-Boot] [PATCH-OMAP3] OMAP3: Remove BITx magic
Subject: [PATCH-OMAP3] OMAP3: Remove BITx magic
Remove bits.h and it's macros usage. Requested by Wolfgang Denk.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
--- cpu/arm_cortexa8/omap3/board.c | 3 -- cpu/arm_cortexa8/omap3/clock.c | 25 +++++++++--------- cpu/arm_cortexa8/omap3/interrupts.c | 18 ++++--------- cpu/arm_cortexa8/omap3/mem.c | 3 -- cpu/arm_cortexa8/omap3/sys_info.c | 14 ---------- cpu/arm_cortexa8/omap3/syslib.c | 1 include/asm-arm/arch-omap3/bits.h | 48 ------------------------------------ include/asm-arm/arch-omap3/cpu.h | 40 ++++++++++++++++++++++++------ 8 files changed, 53 insertions(+), 99 deletions(-)
Index: u-boot-arm/include/asm-arm/arch-omap3/bits.h =================================================================== --- u-boot-arm.orig/include/asm-arm/arch-omap3/bits.h +++ /dev/null @@ -1,48 +0,0 @@ -/* bits.h - * Copyright (c) 2004 Texas Instruments - * - * This package is free software; you can redistribute it and/or - * modify it under the terms of the license found in the file - * named COPYING that should have accompanied this file. - * - * THIS PACKAGE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR - * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED - * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE. - */ -#ifndef __bits_h -#define __bits_h 1 - -#define BIT0 (1 << 0) -#define BIT1 (1 << 1) -#define BIT2 (1 << 2) -#define BIT3 (1 << 3) -#define BIT4 (1 << 4) -#define BIT5 (1 << 5) -#define BIT6 (1 << 6) -#define BIT7 (1 << 7) -#define BIT8 (1 << 8) -#define BIT9 (1 << 9) -#define BIT10 (1 << 10) -#define BIT11 (1 << 11) -#define BIT12 (1 << 12) -#define BIT13 (1 << 13) -#define BIT14 (1 << 14) -#define BIT15 (1 << 15) -#define BIT16 (1 << 16) -#define BIT17 (1 << 17) -#define BIT18 (1 << 18) -#define BIT19 (1 << 19) -#define BIT20 (1 << 20) -#define BIT21 (1 << 21) -#define BIT22 (1 << 22) -#define BIT23 (1 << 23) -#define BIT24 (1 << 24) -#define BIT25 (1 << 25) -#define BIT26 (1 << 26) -#define BIT27 (1 << 27) -#define BIT28 (1 << 28) -#define BIT29 (1 << 29) -#define BIT30 (1 << 30) -#define BIT31 (1 << 31) - -#endif Index: u-boot-arm/include/asm-arm/arch-omap3/cpu.h =================================================================== --- u-boot-arm.orig/include/asm-arm/arch-omap3/cpu.h +++ u-boot-arm/include/asm-arm/arch-omap3/cpu.h @@ -39,7 +39,8 @@ #define PRODUCTION_ID (OMAP34XX_TAP_BASE + 0x208)
/* device type */ -#define DEVICE_MASK (BIT8 | BIT9 | BIT10) +#define DEVICE_MASK (0x7 << 8) +#define SYSBOOT_MASK 0x1F #define TST_DEVICE 0x0 #define EMU_DEVICE 0x1 #define HS_DEVICE 0x2 @@ -104,7 +105,7 @@ #define SMS_SYSCONFIG (OMAP34XX_SMS_BASE + 0x10) #define SMS_RG_ATT0 (OMAP34XX_SMS_BASE + 0x48) #define SMS_CLASS_ARB0 (OMAP34XX_SMS_BASE + 0xD0) -#define BURSTCOMPLETE_GROUP7 BIT31 +#define BURSTCOMPLETE_GROUP7 (0x1 << 31)
/* SDRC */ #define SDRC_SYSCONFIG (OMAP34XX_SDRC_BASE + 0x10) @@ -115,13 +116,13 @@ #define SDRC_DLLA_STATUS (OMAP34XX_SDRC_BASE + 0x64) #define SDRC_DLLB_CTRL (OMAP34XX_SDRC_BASE + 0x68) #define SDRC_DLLB_STATUS (OMAP34XX_SDRC_BASE + 0x6C) -#define DLLPHASE BIT1 -#define LOADDLL BIT2 +#define DLLPHASE (0x1 << 1) +#define LOADDLL (0x1 << 2) #define DLL_DELAY_MASK 0xFF00 -#define DLL_NO_FILTER_MASK (BIT8 | BIT9) +#define DLL_NO_FILTER_MASK ((0x1 << 9) | (0x1 << 8))
#define SDRC_POWER (OMAP34XX_SDRC_BASE + 0x70) -#define WAKEUPPROC BIT26 +#define WAKEUPPROC (0x1 << 26)
#define SDRC_MCFG_0 (OMAP34XX_SDRC_BASE + 0x80) #define SDRC_MR_0 (OMAP34XX_SDRC_BASE + 0x84) @@ -141,7 +142,7 @@ #define CMD_ENTR_SRFRSH 0x5 #define CMD_CKE_HIGH 0x6 #define CMD_CKE_LOW 0x7 -#define SOFTRESET BIT1 +#define SOFTRESET (0x1 << 1) #define SMART_IDLE (0x2 << 3) #define REF_ON_IDLE (0x1 << 6)
@@ -162,7 +163,7 @@ #define TSICR 0x40 /* rw */ #define TCAR2 0x44 /* r */ /* enable sys_clk NO-prescale /1 */ -#define GPT_EN ((0 << 2) | BIT1 | BIT0) +#define GPT_EN ((0x0 << 2) | (0x1 << 1) | (0x1 << 0))
/* Watchdog */ #define WWPS 0x34 /* r */ @@ -210,6 +211,29 @@ #define PRM_CLKSEL 0x48306d40 #define PRM_RSTCTRL 0x48307250 #define PRM_CLKSRC_CTRL 0x48307270 +#define SYSCLKDIV_1 (0x1 << 6) +#define SYSCLKDIV_2 (0x1 << 7) + +#define CLKSEL_GPT1 (0x1 << 0) + +#define EN_GPT1 (0x1 << 0) +#define EN_32KSYNC (0x1 << 2) + +#define ST_WDT2 (0x1 << 5) + +#define ST_MPU_CLK (0x1 << 0) + +#define ST_CORE_CLK (0x1 << 0) + +#define ST_PERIPH_CLK (0x1 << 1) + +#define ST_IVA2_CLK (0x1 << 0) + +#define RESETDONE (0x1 << 0) + +#define TCLR_ST (0x1 << 0) +#define TCLR_AR (0x1 << 1) +#define TCLR_PRE (0x1 << 5)
/* SMX-APE */ #define PM_RT_APE_BASE_ADDR_ARM (SMX_APE_BASE + 0x10000) Index: u-boot-arm/cpu/arm_cortexa8/omap3/clock.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/clock.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/clock.c @@ -27,7 +27,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/bits.h> #include <asm/arch/clocks.h> #include <asm/arch/clocks_omap3.h> #include <asm/arch/mem.h> @@ -46,17 +45,17 @@ u32 get_osc_clk_speed(void) val = readl(PRM_CLKSRC_CTRL);
/* If SYS_CLK is being divided by 2, remove for now */ - val = (val & (~BIT7)) | BIT6; + val = (val & (~SYSCLKDIV_2)) | SYSCLKDIV_1; writel(val, PRM_CLKSRC_CTRL);
/* enable timer2 */ - val = readl(CM_CLKSEL_WKUP) | BIT0; + val = readl(CM_CLKSEL_WKUP) | CLKSEL_GPT1; writel(val, CM_CLKSEL_WKUP); /* select sys_clk for GPT1 */
/* Enable I and F Clocks for GPT1 */ - val = readl(CM_ICLKEN_WKUP) | BIT0 | BIT2; + val = readl(CM_ICLKEN_WKUP) | EN_GPT1 | EN_32KSYNC; writel(val, CM_ICLKEN_WKUP); - val = readl(CM_FCLKEN_WKUP) | BIT0; + val = readl(CM_FCLKEN_WKUP) | EN_GPT1; writel(val, CM_FCLKEN_WKUP);
writel(0, OMAP34XX_GPT1 + TLDR); /* start counting at 0 */ @@ -160,7 +159,7 @@ void prcm_init(void)
/* Unlock MPU DPLL (slows things down, and needed later) */ sr32(CM_CLKEN_PLL_MPU, 0, 3, PLL_LOW_POWER_BYPASS); - wait_on_value(BIT0, 0, CM_IDLEST_PLL_MPU, LDELAY); + wait_on_value(ST_MPU_CLK, 0, CM_IDLEST_PLL_MPU, LDELAY);
/* Getting the base address of Core DPLL param table */ dpll_param_p = (dpll_param *) get_core_dpll_param(); @@ -173,7 +172,7 @@ void prcm_init(void) * sr32(CM_CLKSEL2_EMU) set override to work when asleep */ sr32(CM_CLKEN_PLL, 0, 3, PLL_FAST_RELOCK_BYPASS); - wait_on_value(BIT0, 0, CM_IDLEST_CKGEN, LDELAY); + wait_on_value(ST_CORE_CLK, 0, CM_IDLEST_CKGEN, LDELAY);
/* * For OMAP3 ES1.0 Errata 1.50, default value directly doesn't @@ -194,7 +193,7 @@ void prcm_init(void) sr32(CM_CLKEN_PLL, 4, 4, dpll_param_p->fsel); /* FREQSEL */ sr32(CM_CLKEN_PLL, 0, 3, PLL_LOCK); /* lock mode */
- wait_on_value(BIT0, 1, CM_IDLEST_CKGEN, LDELAY); + wait_on_value(ST_CORE_CLK, 1, CM_IDLEST_CKGEN, LDELAY); } else if (is_running_in_flash()) { /* * if running from flash, jump to small relocated code @@ -223,7 +222,7 @@ void prcm_init(void)
/* PER DPLL */ sr32(CM_CLKEN_PLL, 16, 3, PLL_STOP); - wait_on_value(BIT1, 0, CM_IDLEST_CKGEN, LDELAY); + wait_on_value(ST_PERIPH_CLK, 0, CM_IDLEST_CKGEN, LDELAY);
/* Getting the base address to PER DPLL param table */ /* Set N */ @@ -253,7 +252,7 @@ void prcm_init(void) sr32(CM_CLKSEL2_PLL, 0, 7, dpll_param_p->n); /* set n */ sr32(CM_CLKEN_PLL, 20, 4, dpll_param_p->fsel); /* FREQSEL */ sr32(CM_CLKEN_PLL, 16, 3, PLL_LOCK); /* lock mode */ - wait_on_value(BIT1, 2, CM_IDLEST_CKGEN, LDELAY); + wait_on_value(ST_PERIPH_CLK, 2, CM_IDLEST_CKGEN, LDELAY);
/* Getting the base address to MPU DPLL param table */ dpll_param_p = (dpll_param *) get_mpu_dpll_param(); @@ -267,7 +266,7 @@ void prcm_init(void) sr32(CM_CLKSEL1_PLL_MPU, 0, 7, dpll_param_p->n); /* Set N */ sr32(CM_CLKEN_PLL_MPU, 4, 4, dpll_param_p->fsel); /* FREQSEL */ sr32(CM_CLKEN_PLL_MPU, 0, 3, PLL_LOCK); /* lock mode */ - wait_on_value(BIT0, 1, CM_IDLEST_PLL_MPU, LDELAY); + wait_on_value(ST_MPU_CLK, 1, CM_IDLEST_PLL_MPU, LDELAY);
/* Getting the base address to IVA DPLL param table */ dpll_param_p = (dpll_param *) get_iva_dpll_param(); @@ -277,13 +276,13 @@ void prcm_init(void)
/* IVA DPLL (set to 12*20=240MHz) */ sr32(CM_CLKEN_PLL_IVA2, 0, 3, PLL_STOP); - wait_on_value(BIT0, 0, CM_IDLEST_PLL_IVA2, LDELAY); + wait_on_value(ST_IVA2_CLK, 0, CM_IDLEST_PLL_IVA2, LDELAY); sr32(CM_CLKSEL2_PLL_IVA2, 0, 5, dpll_param_p->m2); /* set M2 */ sr32(CM_CLKSEL1_PLL_IVA2, 8, 11, dpll_param_p->m); /* set M */ sr32(CM_CLKSEL1_PLL_IVA2, 0, 7, dpll_param_p->n); /* set N */ sr32(CM_CLKEN_PLL_IVA2, 4, 4, dpll_param_p->fsel); /* FREQSEL */ sr32(CM_CLKEN_PLL_IVA2, 0, 3, PLL_LOCK); /* lock mode */ - wait_on_value(BIT0, 1, CM_IDLEST_PLL_IVA2, LDELAY); + wait_on_value(ST_IVA2_CLK, 1, CM_IDLEST_PLL_IVA2, LDELAY);
/* Set up GPTimers to sys_clk source only */ sr32(CM_CLKSEL_PER, 0, 8, 0xff); Index: u-boot-arm/cpu/arm_cortexa8/omap3/mem.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/mem.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/mem.c @@ -27,7 +27,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/bits.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> #include <command.h> @@ -177,7 +176,7 @@ void do_sdrc_init(u32 offset, u32 early) if (early) { /* reset sdrc controller */ writel(SOFTRESET, SDRC_SYSCONFIG); - wait_on_value(BIT0, BIT0, SDRC_STATUS, 12000000); + wait_on_value(RESETDONE, RESETDONE, SDRC_STATUS, 12000000); writel(0, SDRC_SYSCONFIG);
/* setup sdrc to ball mux */ Index: u-boot-arm/cpu/arm_cortexa8/omap3/sys_info.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/sys_info.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/sys_info.c @@ -27,7 +27,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/bits.h> #include <asm/arch/mem.h> /* get mem tables */ #include <asm/arch/sys_proto.h> #include <i2c.h> @@ -147,14 +146,6 @@ u32 get_board_type(void) return sysinfo.board_type_v1; }
-/****************************************************************** - * get_sysboot_value() - get init word settings - ******************************************************************/ -inline u32 get_sysboot_value(void) -{ - return 0x0000003F & readl(CONTROL_STATUS); -} - /*************************************************************************** * get_gpmc0_base() - Return current address hardware will be * fetching from. The below effectively gives what is correct, its a bit @@ -318,10 +309,7 @@ u32 is_running_in_sdram(void) ***************************************************************/ u32 get_boot_type(void) { - u32 v; - - v = get_sysboot_value() & (BIT4 | BIT3 | BIT2 | BIT1 | BIT0); - return v; + return (readl(CONTROL_STATUS) & SYSBOOT_MASK); }
/************************************************************* Index: u-boot-arm/cpu/arm_cortexa8/omap3/board.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/board.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/board.c @@ -34,7 +34,6 @@ */ #include <common.h> #include <asm/io.h> -#include <asm/arch/bits.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mem.h>
@@ -251,7 +250,7 @@ void watchdog_init(void)
sr32(CM_FCLKEN_WKUP, 5, 1, 1); sr32(CM_ICLKEN_WKUP, 5, 1, 1); - wait_on_value(BIT5, 0x20, CM_IDLEST_WKUP, 5); /* some issue here */ + wait_on_value(ST_WDT2, 0x20, CM_IDLEST_WKUP, 5); /* some issue here */
writel(WD_UNLOCK1, WD2_BASE + WSPR); wait_for_command_complete(WD2_BASE); Index: u-boot-arm/cpu/arm_cortexa8/omap3/interrupts.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/interrupts.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/interrupts.c @@ -33,8 +33,7 @@ */
#include <common.h> -#include <asm/arch/bits.h> - +#include <asm/io.h> #include <asm/proc-armv/ptrace.h>
#define TIMER_LOAD_VAL 0 @@ -175,16 +174,11 @@ static ulong lastinc; /* nothing really to do with interrupts, just starts up a counter. */ int interrupt_init(void) { - int32_t val; - - /* - * Start the counter ticking up - * reload value on overflow - */ - *((int32_t *) (CONFIG_SYS_TIMERBASE + TLDR)) = TIMER_LOAD_VAL; - /* mask to enable timer */ - val = (CONFIG_SYS_PVT << 2) | BIT5 | BIT1 | BIT0; - *((int32_t *) (CONFIG_SYS_TIMERBASE + TCLR)) = val; /* start timer */ + /* start the counter ticking up, reload value on overflow */ + writel(TIMER_LOAD_VAL, CONFIG_SYS_TIMERBASE + TLDR); + /* enable timer */ + writel((CONFIG_SYS_PVT << 2) | TCLR_PRE | TCLR_AR | TCLR_ST, + CONFIG_SYS_TIMERBASE + TCLR);
reset_timer_masked(); /* init the timestamp and lastinc value */
Index: u-boot-arm/cpu/arm_cortexa8/omap3/syslib.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/syslib.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/syslib.c @@ -23,7 +23,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/bits.h> #include <asm/arch/mem.h> #include <asm/arch/clocks.h> #include <asm/arch/sys_proto.h>
Dear dirk.behme@googlemail.com,
That's a funny way to make code difficult to read. Why do you prefer "(0x7 << 8)" instead of "0x700" (which looks more obvious to me) ?
Ditto here - why not simply 0x300 ?
Why not 0x3 ?
Note: especially the "(0x0 << 2) | " part in the expression i really bogus.
dirk.behmeï¼ googlemail.com
