[U-Boot-Users] Installation of ELDK 2.1.0 for MPC8xx,
I was installing ELDK-2.1.0 in my host ( kernel 2.4.20-8, Red Hat Linux Release 9.0). I was facing the following problem,while following the steps given in "The DENX U-Boot and Linux Guide (DULG) forTQM8xxL" document.
Initially i run install utility,it worked fine. Then i tried to install the rpm of ELDT :binutils-ppc_8xx-2.11.93.0.2-3b_2, it is showing like libc.so.6(GLIBC-2.0) libc.so.6(GLIBC-2.1) libc.so.6(GLIBC-2.1.3) libc.so.6(GLIBC-2.2.3) libc.so.2(GLIBC-2.0) libc.so.2(GLIBC-2.0) is needed by binutils-ppc_8xx-2.11.93.0.2-3b_2.
i will be very much thankful,if any one help in this regard.
Thank u Ramana
Why did you do that if the normal installation when fine? In this case this RPM is already installed on your system.
It seems your installtion is pretty corrupted. Please reinstall from scratch. And either read and follow the instructions at http://www.denx.de/twiki/bin/view/DULG/ELDKInstallationAborts or install the current release (ELDK 3.0).
RamanaYV
