[U-Boot] [PATCH] imx8mq_evk: Staticize when appropriate
Staticize 'spl_dram_init' and 'i2c_pad_info1' to fix the following sparse warnings:
board/freescale/imx8mq_evk/spl.c:30:6: warning: symbol 'spl_dram_init' was not declared. Should it be static? board/freescale/imx8mq_evk/spl.c:41:22: warning: symbol 'i2c_pad_info1' was not declared. Should it be static?
Signed-off-by: Fabio Estevam festevam@gmail.com --- board/freescale/imx8mq_evk/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/imx8mq_evk/spl.c b/board/freescale/imx8mq_evk/spl.c index e6cbc34b0d..3c0ff0bb1b 100644 --- a/board/freescale/imx8mq_evk/spl.c +++ b/board/freescale/imx8mq_evk/spl.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR;
extern struct dram_timing_info dram_timing_b0;
-void spl_dram_init(void) +static void spl_dram_init(void) { /* ddr init */ if ((get_cpu_rev() & 0xfff) == CHIP_REV_2_1) @@ -38,7 +38,7 @@ void spl_dram_init(void)
#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) #define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -struct i2c_pads_info i2c_pad_info1 = { +static struct i2c_pads_info i2c_pad_info1 = { .scl = { .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC,
Subject: [PATCH] imx8mq_evk: Staticize when appropriate
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Staticize 'spl_dram_init' and 'i2c_pad_info1' to fix the following sparse warnings: board/freescale/imx8mq_evk/spl.c:30:6: warning: symbol 'spl_dram_init' was not declared. Should it be static? board/freescale/imx8mq_evk/spl.c:41:22: warning: symbol 'i2c_pad_info1' was not declared. Should it be static? Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Fabio Estevam
Peng Fan
sbabic@denx.de
