[PATCH] mx6cuboxi: Fix board revision detection
Currently, an i.MX6 Cuboxi board is incorrectly detected as the HummingBoard model:
U-Boot 2024.04-rc5 (Mar 26 2024 - 15:59:22 +0100)
CPU: Freescale i.MX6Q rev1.3 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 26C Reset cause: POR Model: SolidRun HummingBoard2 Dual/Quad (1.5som+emmc) gpio@20a4000: set_dir_flags: error: gpio GPIO3_8 not reserved gpio@20a4000: get_value: error: gpio GPIO3_8 not reserved gpio@20a8000: set_dir_flags: error: gpio GPIO4_4 not reserved gpio@20a8000: get_value: error: gpio GPIO4_4 not reserved gpio@20b0000: set_dir_flags: error: gpio GPIO6_9 not reserved gpio@20b0000: get_value: error: gpio GPIO6_9 not reserved Board: MX6 HummingBoard DRAM: 2 GiB ...
This error happens because request_detect_gpios() uses the GPIO DM API, but board_type() still uses the legacy non-DM GPIO API.
Fix it by using the GPIO DM API in board_type() to read the board revision pins in SPL.
Reported-by: Christian Gmeiner cgmeiner@igalia.com Signed-off-by: Fabio Estevam festevam@gmail.com --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 8edabf4404c2..7fe515f928a0 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -336,20 +336,17 @@ static enum board_type board_type(void) * HB 1 1 x */
- gpio_direction_input(IMX_GPIO_NR(2, 8)); - val3 = gpio_get_value(IMX_GPIO_NR(2, 8)); + val3 = !!dm_gpio_get_value(&board_detect_desc[0]);
if (val3 == 0) return HUMMINGBOARD2;
- gpio_direction_input(IMX_GPIO_NR(3, 4)); - val2 = gpio_get_value(IMX_GPIO_NR(3, 4)); + val2 = !!dm_gpio_get_value(&board_detect_desc[1]);
if (val2 == 0) return HUMMINGBOARD;
- gpio_direction_input(IMX_GPIO_NR(4, 9)); - val1 = gpio_get_value(IMX_GPIO_NR(4, 9)); + val1 = !!dm_gpio_get_value(&board_detect_desc[2]);
if (val1 == 0) { return CUBOXI; @@ -363,8 +360,8 @@ static bool is_rev_15_som(void) int val1, val2; SETUP_IOMUX_PADS(som_rev_detect);
- val1 = gpio_get_value(IMX_GPIO_NR(6, 0)); - val2 = gpio_get_value(IMX_GPIO_NR(6, 4)); + val1 = !!dm_gpio_get_value(&board_detect_desc[3]); + val2 = !!dm_gpio_get_value(&board_detect_desc[4]);
if (val1 == 1 && val2 == 0) return true;
Tested-by: Christian Gmeiner cgmeiner@igalia.com
Applied, thanks.
Christian Gmeiner
Fabio Estevam
