[U-Boot] [PATCH 1/9] mx6: Allow mx6 to access the IPUv3 registers
Adjust the IPUv3 registers, so that the IPUv3 driver can be extended for mx6 as well.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- This patch series apply against Anatolij's tree.
arch/arm/include/asm/arch-mx5/imx-regs.h | 2 -- arch/arm/include/asm/arch-mx6/imx-regs.h | 3 +++ drivers/video/ipu_regs.h | 12 +++++++++++- 3 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 88fb7cb..8117f4f 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -50,8 +50,6 @@ #error "CPU_TYPE not defined" #endif
-#define IPU_CTRL_BASE_ADDR IPU_SOC_BASE_ADDR + IPU_SOC_OFFSET - #define IRAM_SIZE 0x00020000 /* 128 KB */
/* diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index e165810..5d77603 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -73,6 +73,9 @@ #define MMDC1_ARB_BASE_ADDR 0x80000000 #define MMDC1_ARB_END_ADDR 0xFFFFFFFF
+#define IPU_SOC_BASE_ADDR IPU1_ARB_BASE_ADDR +#define IPU_SOC_OFFSET 0x00200000 + /* Defines for Blocks connected via AIPS (SkyBlue) */ #define ATZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR #define ATZ2_BASE_ADDR AIPS2_ARB_BASE_ADDR diff --git a/drivers/video/ipu_regs.h b/drivers/video/ipu_regs.h index 93b195f..874e009 100644 --- a/drivers/video/ipu_regs.h +++ b/drivers/video/ipu_regs.h @@ -47,14 +47,24 @@ #define IPU_SMFC_REG_BASE 0x00050000 #define IPU_DC_REG_BASE 0x00058000 #define IPU_DMFC_REG_BASE 0x00060000 +#define IPU_VDI_REG_BASE 0x00680000 +#if defined(CONFIG_MX51) || defined(CONFIG_MX53) #define IPU_CPMEM_REG_BASE 0x01000000 #define IPU_LUT_REG_BASE 0x01020000 #define IPU_SRM_REG_BASE 0x01040000 #define IPU_TPM_REG_BASE 0x01060000 #define IPU_DC_TMPL_REG_BASE 0x01080000 #define IPU_ISP_TBPR_REG_BASE 0x010C0000 -#define IPU_VDI_REG_BASE 0x00680000 +#elif defined(CONFIG_MX6Q) +#define IPU_CPMEM_REG_BASE 0x00100000 +#define IPU_LUT_REG_BASE 0x00120000 +#define IPU_SRM_REG_BASE 0x00140000 +#define IPU_TPM_REG_BASE 0x00160000 +#define IPU_DC_TMPL_REG_BASE 0x00180000 +#define IPU_ISP_TBPR_REG_BASE 0x001C0000 +#endif
+#define IPU_CTRL_BASE_ADDR (IPU_SOC_BASE_ADDR + IPU_SOC_OFFSET)
extern u32 *ipu_dc_tmpl_reg;
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/Makefile | 2 +- drivers/video/cfb_console.c | 2 +- include/configs/mx51evk.h | 2 +- include/configs/mx53loco.h | 2 +- include/configs/vision2.h | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 842cbdf..c78f002 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -41,7 +41,7 @@ COBJS-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o -COBJS-$(CONFIG_VIDEO_MX5) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o +COBJS-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o COBJS-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o COBJS-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 904caf7..4cdbbe9 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -164,7 +164,7 @@ /* * Defines for the i.MX31 driver (mx3fb.c) */ -#if defined(CONFIG_VIDEO_MX3) || defined(CONFIG_VIDEO_MX5) +#if defined(CONFIG_VIDEO_MX3) || defined(CONFIG_VIDEO_IPUV3) #define VIDEO_FB_16BPP_WORD_SWAP #endif
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 58b6f1c..8b04dc7 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -126,7 +126,7 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO -#define CONFIG_VIDEO_MX5 +#define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 99daafb..7a4a9ea 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -223,7 +223,7 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO -#define CONFIG_VIDEO_MX5 +#define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/vision2.h b/include/configs/vision2.h index f6904f3..6eebbb6 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -214,7 +214,7 @@ */ #define CONFIG_PREBOOT #define CONFIG_VIDEO -#define CONFIG_VIDEO_MX5 +#define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8
On Thu, 31 May 2012 14:23:56 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Applied to u-boot-video/next, thanks!
Anatolij
The following erratum :
"ENGcm08316 IPU: Clarification regarding the bypass mode registers setup for display and camera interfaces"
,only applies to mx51, so restrict its usage for this SoC only.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/ipu_common.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 9d20c86..4caad4f 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -401,6 +401,7 @@ void ipu_reset(void) int ipu_probe(void) { unsigned long ipu_base; +#if defined CONFIG_MX51 u32 temp;
u32 *reg_hsc_mcd = (u32 *)MIPI_HSC_BASE_ADDR; @@ -414,6 +415,7 @@ int ipu_probe(void)
temp = __raw_readl(reg_hsc_mxt_conf); __raw_writel(temp | 0x10000, reg_hsc_mxt_conf); +#endif
ipu_base = IPU_CTRL_BASE_ADDR; ipu_cpmem_base = (u32 *)(ipu_base + IPU_CPMEM_REG_BASE);
On Thu, 31 May 2012 14:23:57 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
The registers accessed inside clk_ipu_enable/disable are not present on MX6, so make sure they only run on MX51 and MX53.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/ipu_common.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 4caad4f..57b5195 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -163,6 +163,7 @@ int clk_set_parent(struct clk *clk, struct clk *parent)
static int clk_ipu_enable(struct clk *clk) { +#if defined(CONFIG_MX51) || defined(CONFIG_MX53) u32 reg;
reg = __raw_readl(clk->enable_reg); @@ -178,12 +179,13 @@ static int clk_ipu_enable(struct clk *clk) reg = __raw_readl(&mxc_ccm->clpcr); reg &= ~MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; __raw_writel(reg, &mxc_ccm->clpcr); - +#endif return 0; }
static void clk_ipu_disable(struct clk *clk) { +#if defined(CONFIG_MX51) || defined(CONFIG_MX53) u32 reg;
reg = __raw_readl(clk->enable_reg); @@ -202,6 +204,7 @@ static void clk_ipu_disable(struct clk *clk) reg = __raw_readl(&mxc_ccm->clpcr); reg |= MXC_CCM_CLPCR_BYPASS_IPU_LPM_HS; __raw_writel(reg, &mxc_ccm->clpcr); +#endif }
On Thu, 31 May 2012 14:23:58 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
Rename MXC_CCM_BASE to CCM_BASE_ADDR as this is already defined for MX6.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/ipu_common.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 7ef8742..84892dc 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -211,7 +211,7 @@ static void clk_ipu_disable(struct clk *clk) static struct clk ipu_clk = { .name = "ipu_clk", .rate = 133000000, - .enable_reg = (u32 *)(MXC_CCM_BASE + + .enable_reg = (u32 *)(CCM_BASE_ADDR + offsetof(struct mxc_ccm_reg, CCGR5)), .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET, .enable = clk_ipu_enable,
On Thu, 31 May 2012 14:23:59 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
Do not hardcode the ipu_clk frequency and let the board file pass this value.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/ipu_common.c | 2 +- include/configs/mx51evk.h | 1 + include/configs/mx53loco.h | 1 + include/configs/vision2.h | 1 + 4 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 84892dc..e43a6ec 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -210,7 +210,7 @@ static void clk_ipu_disable(struct clk *clk)
static struct clk ipu_clk = { .name = "ipu_clk", - .rate = 133000000, + .rate = CONFIG_IPUV3_CLK, .enable_reg = (u32 *)(CCM_BASE_ADDR + offsetof(struct mxc_ccm_reg, CCGR5)), .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET, diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 8b04dc7..755312f 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -133,6 +133,7 @@ #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 133000000
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 7a4a9ea..c9653a0 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -230,5 +230,6 @@ #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 133000000
#endif /* __CONFIG_H */ diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 6eebbb6..7ffe655 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -221,5 +221,6 @@ #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP +#define CONFIG_IPUV3_CLK 133000000
On Thu, 31 May 2012 14:24:00 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
Allow MX6Q I2C3 to work.
Cc: Heiko Schocher hs@denx.de Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/i2c/mxc_i2c.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index c88ac7c..d3c323e 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -78,6 +78,8 @@ struct mxc_i2c_regs { #define I2C_BASE I2C2_BASE_ADDR #elif defined(CONFIG_SYS_I2C_MX35_PORT3) #define I2C_BASE I2C3_BASE_ADDR +#elif defined(CONFIG_SYS_I2C_MX6Q_PORT3) +#define I2C_BASE I2C3_BASE_ADDR #else #error "define CONFIG_SYS_I2C_MX<Processor>_PORTx to use the mx I2C driver" #endif
Cc: Heiko Schocherhs@denx.de Signed-off-by: Fabio Estevamfabio.estevam@freescale.com
This conflicts with the patch that Stefano acked on May 6.
[PATCH 1/3] mxc_i2c: specify i2c base address in config file
The following platforms had their config files changed flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd
Signed-off-by: Troy Kiskytroy.kisky@boundarydevices.com --- arch/arm/include/asm/arch-mx31/imx-regs.h | 7 +++++++ arch/arm/include/asm/arch-mx35/imx-regs.h | 2 +- drivers/i2c/mxc_i2c.c | 25 ++++--------------------- include/configs/flea3.h | 2 +- include/configs/imx31_phycore.h | 3 ++- include/configs/mx35pdk.h | 2 +- include/configs/mx53ard.h | 2 +- include/configs/mx53evk.h | 2 +- include/configs/mx53smd.h | 2 +- 9 files changed, 19 insertions(+), 28 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 6454acb..7ddbbd6 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -606,6 +606,13 @@ struct esdc_regs { #define UART4_BASE 0x43FB0000 #define UART5_BASE 0x43FB4000
+#define I2C1_BASE_ADDR 0x43f80000 +#define I2C1_CLK_OFFSET 26 +#define I2C2_BASE_ADDR 0x43F98000 +#define I2C2_CLK_OFFSET 28 +#define I2C3_BASE_ADDR 0x43f84000 +#define I2C3_CLK_OFFSET 30 + #define ESDCTL_SDE (1<< 31) #define ESDCTL_CMD_RW (0<< 28) #define ESDCTL_CMD_PRECHARGE (1<< 28) diff --git a/arch/arm/include/asm/arch-mx35/imx-regs.h b/arch/arm/include/asm/arch-mx35/imx-regs.h index e570ad1..3146006 100644 --- a/arch/arm/include/asm/arch-mx35/imx-regs.h +++ b/arch/arm/include/asm/arch-mx35/imx-regs.h @@ -39,7 +39,7 @@ #define MAX_BASE_ADDR 0x43F04000 #define EVTMON_BASE_ADDR 0x43F08000 #define CLKCTL_BASE_ADDR 0x43F0C000 -#define I2C_BASE_ADDR 0x43F80000 +#define I2C1_BASE_ADDR 0x43F80000 #define I2C3_BASE_ADDR 0x43F84000 #define ATA_BASE_ADDR 0x43F8C000 #define UART1_BASE 0x43F90000 diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index c88ac7c..416ffee 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -59,27 +59,10 @@ struct mxc_i2c_regs { #define I2SR_IIF (1<< 1) #define I2SR_RX_NO_AK (1<< 0)
-#if defined(CONFIG_SYS_I2C_MX31_PORT1) -#define I2C_BASE 0x43f80000 -#define I2C_CLK_OFFSET 26 -#elif defined (CONFIG_SYS_I2C_MX31_PORT2) -#define I2C_BASE 0x43f98000 -#define I2C_CLK_OFFSET 28 -#elif defined (CONFIG_SYS_I2C_MX31_PORT3) -#define I2C_BASE 0x43f84000 -#define I2C_CLK_OFFSET 30 -#elif defined(CONFIG_SYS_I2C_MX53_PORT1) -#define I2C_BASE I2C1_BASE_ADDR -#elif defined(CONFIG_SYS_I2C_MX53_PORT2) -#define I2C_BASE I2C2_BASE_ADDR -#elif defined(CONFIG_SYS_I2C_MX35_PORT1) -#define I2C_BASE I2C_BASE_ADDR -#elif defined(CONFIG_SYS_I2C_MX35_PORT2) -#define I2C_BASE I2C2_BASE_ADDR -#elif defined(CONFIG_SYS_I2C_MX35_PORT3) -#define I2C_BASE I2C3_BASE_ADDR +#ifdef CONFIG_SYS_I2C_BASE +#define I2C_BASE CONFIG_SYS_I2C_BASE #else -#error "define CONFIG_SYS_I2C_MX<Processor>_PORTx to use the mx I2C driver" +#error "define CONFIG_SYS_I2C_BASE to use the mxc_i2c driver" #endif
#define I2C_MAX_TIMEOUT 10000 @@ -114,7 +97,7 @@ static uint8_t i2c_imx_get_clk(unsigned int rate) (struct clock_control_regs *)CCM_BASE;
/* start the required I2C clock */ - writel(readl(&sc_regs->cgr0) | (3<< I2C_CLK_OFFSET), + writel(readl(&sc_regs->cgr0) | (3<< CONFIG_SYS_I2C_CLK_OFFSET), &sc_regs->cgr0); #endif
diff --git a/include/configs/flea3.h b/include/configs/flea3.h index f046a58..75330c4 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -68,7 +68,7 @@ */ #define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX35_PORT3 +#define CONFIG_SYS_I2C_BASE I2C3_BASE_ADDR #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe #define CONFIG_MXC_SPI diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 3153eb5..197cefa 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -54,7 +54,8 @@
#define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX31_PORT2 +#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR +#define CONFIG_SYS_I2C_CLK_OFFSET I2C2_CLK_OFFSET #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe
diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index de4b954..dfe39b8 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -59,7 +59,7 @@ */ #define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX35_PORT1 +#define CONFIG_SYS_I2C_BASE I2C1_BASE_ADDR #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe #define CONFIG_MXC_SPI diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index f48a41e..0bdf6a3 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -50,7 +50,7 @@ #define CONFIG_CMD_I2C #define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX53_PORT2 +#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index a77e5b2..3c7c329 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -53,7 +53,7 @@ #define CONFIG_CMD_I2C #define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX53_PORT2 1 +#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe
diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index a04db3f..a904130 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -50,7 +50,7 @@ #define CONFIG_CMD_I2C #define CONFIG_HARD_I2C #define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_MX53_PORT2 +#define CONFIG_SYS_I2C_BASE I2C2_BASE_ADDR #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_SYS_I2C_SLAVE 0xfe
-- 1.7.5.4
Hi Troy,
On Thu, May 31, 2012 at 7:24 PM, Troy Kisky troy.kisky@boundarydevices.com wrote:
Ok, I can rework this patch after your commit gets in.
Thanks,
Fabio Estevam
On 01.06.2012 00:48, Fabio Estevam wrote:
Hi Troy,
It seems this patch can be dropped completely and instead rework patch 9 like
https://github.com/dirkbehme/u-boot-imx6/commit/451422a40532a9d4f86c50c57190...
Best regards
Dirk
Add ldb_clk for use in parenting the pixel clock.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/video/ipu_common.c | 12 ++++++++++-- drivers/video/ipu_disp.c | 3 ++- 2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 47d8232..706fddc 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -219,8 +219,15 @@ static struct clk ipu_clk = { .usecount = 0, };
+static struct clk ldb_clk = { + .name = "ldb_clk", + .rate = 65000000, + .usecount = 0, +}; + /* Globals */ struct clk *g_ipu_clk; +struct clk *g_ldb_clk; unsigned char g_ipu_clk_enabled; struct clk *g_di_clk[2]; struct clk *g_pixel_clk[2]; @@ -343,7 +350,7 @@ static int ipu_pixel_clk_set_parent(struct clk *clk, struct clk *parent)
if (parent == g_ipu_clk) di_gen &= ~DI_GEN_DI_CLK_EXT; - else if (!IS_ERR(g_di_clk[clk->id]) && parent == g_di_clk[clk->id]) + else if (!IS_ERR(g_di_clk[clk->id]) && parent == g_ldb_clk) di_gen |= DI_GEN_DI_CLK_EXT; else return -EINVAL; @@ -429,7 +436,8 @@ int ipu_probe(void)
g_ipu_clk = &ipu_clk; debug("ipu_clk = %u\n", clk_get_rate(g_ipu_clk)); - + g_ldb_clk = &ldb_clk; + debug("ldb_clk = %u\n", clk_get_rate(g_ldb_clk)); ipu_reset();
clk_set_parent(g_pixel_clk[0], g_ipu_clk); diff --git a/drivers/video/ipu_disp.c b/drivers/video/ipu_disp.c index fa8fb2c..b4116df 100644 --- a/drivers/video/ipu_disp.c +++ b/drivers/video/ipu_disp.c @@ -64,6 +64,7 @@ static int dmfc_size_28, dmfc_size_29, dmfc_size_24, dmfc_size_27, dmfc_size_23; int g_di1_tvout;
extern struct clk *g_ipu_clk; +extern struct clk *g_ldb_clk; extern struct clk *g_di_clk[2]; extern struct clk *g_pixel_clk[2];
@@ -941,7 +942,7 @@ int32_t ipu_init_sync_panel(int disp, uint32_t pixel_clk, udelay(10000); } } - clk_set_parent(g_pixel_clk[disp], g_di_clk[disp]); + clk_set_parent(g_pixel_clk[disp], g_ldb_clk); } else { if (clk_get_usecount(g_pixel_clk[disp]) != 0) clk_set_parent(g_pixel_clk[disp], g_ipu_clk);
On Thu, 31 May 2012 14:24:02 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
Add splaschscreen support.
It was used a Hannstar 1024 x 768 LVDS panel that can be connected to the mx6qsabrelite board.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- I understand this patch will need to be improved, but I am posting it now, so that others can possibly test it.
board/freescale/mx6qsabrelite/mx6qsabrelite.c | 112 +++++++++++++++++++++++++ include/configs/mx6qsabrelite.h | 21 +++++- 2 files changed, 132 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 29cbfed..6aff947 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -33,6 +33,9 @@ #include <micrel.h> #include <miiphy.h> #include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <i2c.h> DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ @@ -55,6 +58,11 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
+#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -143,6 +151,25 @@ static iomux_v3_cfg_t button_pads[] = { MX6Q_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), };
+iomux_v3_cfg_t lcd_gpio[] = { + MX6Q_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t i2c3_pads[] = { + MX6Q_PAD_GPIO_5__I2C3_SCL | MUX_PAD_CTRL(I2C_PAD_CTRL), + MX6Q_PAD_GPIO_16__I2C3_SDA | MUX_PAD_CTRL(I2C_PAD_CTRL), +}; + +static void setup_iomux_i2c3(void) +{ +#define CLKCTL_CCGR2 0x70 + imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads)); + /* Enable i2c clock */ + int reg = readl(CCM_BASE_ADDR + CLKCTL_CCGR2); + reg |= 0xC00; + writel(reg, CCM_BASE_ADDR + CLKCTL_CCGR2); +} + static void setup_iomux_enet(void) { gpio_direction_output(87, 0); /* GPIO 3-23 */ @@ -320,10 +347,85 @@ int setup_sata(void) } #endif
+static struct fb_videomode lvds_xga = { + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +}; + +void lcd_iomux(void) +{ + int reg; + /* Turn on GPIO backlight */ + imx_iomux_v3_setup_multiple_pads(lcd_gpio, ARRAY_SIZE(lcd_gpio)); + gpio_direction_output(18, 1); + +#define CLKCTL_CGR3 0x38 +#define CLKCTL_CS2CDR 0x2C +#define CLKCTL_CSCMR2 0x20 +#define CLKCTL_CHSCCDR 0x34 +#define CLKCTL_CCGR3 0x74 + /* Turn on IPU clock */ + reg = readl(CCM_BASE_ADDR + CLKCTL_CCGR3); + reg |= 0x300F; + writel(reg, CCM_BASE_ADDR + CLKCTL_CCGR3); + + reg = readl(ANATOP_BASE_ADDR + 0xF0); + reg &= ~0x00003F00; + reg |= 0x00001300; + writel(reg, ANATOP_BASE_ADDR + 0xF4); + + reg = readl(CCM_BASE_ADDR + CLKCTL_CS2CDR); + reg &= ~0x00007E00; + reg |= 0x00003600; + writel(reg, CCM_BASE_ADDR + CLKCTL_CS2CDR); + + reg = readl(CCM_BASE_ADDR + CLKCTL_CSCMR2); + reg |= 0x00000C00; + writel(reg, CCM_BASE_ADDR + CLKCTL_CSCMR2); + + reg = 0x0002A953; + writel(reg, CCM_BASE_ADDR + CLKCTL_CHSCCDR); + + writel(0x201, IOMUXC_BASE_ADDR + 0x8); +} + +void lcd_enable(void) +{ + + int ret = ipuv3_fb_init(&lvds_xga, 0, IPU_PIX_FMT_RGB666); + if (ret) + printf("LCD cannot be configured: %d\n", ret); +} + +void setup_lvds_poweron(void) +{ + uchar value; + + i2c_read(0x1f, 3, 1, &value, 1); + value &= ~0x2; + i2c_write(0x1f, 3, 1, &value, 1); + i2c_read(0x1f, 1, 1, &value, 1); + value |= 0x2; + i2c_write(0x1f, 1, 1, &value, 1); +} + int board_early_init_f(void) { setup_iomux_uart(); setup_buttons(); + lcd_iomux(); + setup_iomux_i2c3();
return 0; } @@ -341,9 +443,19 @@ int board_init(void) setup_sata(); #endif
+#ifdef CONFIG_VIDEO + lcd_enable(); +#endif return 0; }
+int board_late_init(void) +{ + setup_lvds_poweron(); + setenv("stdout", "serial"); + return 0; +} + int checkboard(void) { puts("Board: MX6Q-Sabre Lite\n"); diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index feabc05..79b7db7 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -38,10 +38,11 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_ARCH_CPU_INIT #define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT #define CONFIG_MISC_INIT_R #define CONFIG_MXC_GPIO
@@ -111,6 +112,24 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
+/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 + +/* I2C Configs */ +#define CONFIG_HARD_I2C +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_MX6Q_PORT3 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x1f + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Hi Dirk,
On Sat, Jun 2, 2012 at 3:46 AM, Dirk Behme dirk.behme@googlemail.com wrote:
Here and in the subject a typo? splaschscreen -> splashscreen?
Thanks, I will fix this and rework this patch according to your I2C suggestion.
Regards,
Fabio Estevam
On 02.06.2012 20:22, Fabio Estevam wrote:
Hi Dirk,
Maybe you could check [1]
-#define CONFIG_SYS_I2C_SLAVE 0xfe +#define CONFIG_SYS_I2C_SLAVE 0x1f
then? I'm no I2C expert and I wasn't sure what to use for CONFIG_SYS_I2C_SLAVE.
Best regards
Dirk
[1] https://github.com/dirkbehme/u-boot-imx6/commit/451422a40532a9d4f86c50c57190...
Hi Dirk,
Yes, 0x1f is the correct address for the Hannstar LVDS I2C slave address.
I was doing:
,which was actually using the 0x1f value and discarded the CONFIG_SYS_I2C_SLAVE definition.
I can use CONFIG_SYS_I2C_SLAVE instead, which makes the code cleaner.
Thanks,
Fabio Estevam
On 6/2/2012 3:36 PM, Fabio Estevam wrote:
Hi Dirk,
If 0x1f is the Hannstar LVDS address, then you definitely should NOT use 0x1f for the
CONFIG_SYS_I2C_SLAVE value.
CONFIG_SYS_I2C_SLAVE is meant to define which address the processor will respond to in a multi-master bus environment. However, as mxc_i2c does not support slave mode the entire discussion is moot.
Troy
On Sat, Jun 2, 2012 at 9:12 PM, Troy Kisky troy.kisky@boundarydevices.com wrote:
Thanks for the clarification, Troy.
So it means I can safely drop the CONFIG_SYS_I2C_SLAVE definition in the board config file.
According to include/i2c.h:
"/* * Many boards/controllers/drivers don't support an I2C slave interface so * provide a default slave address for them for use in common code. A real * value for CONFIG_SYS_I2C_SLAVE should be defined for any board which does * support a slave interface. */ #ifndef CONFIG_SYS_I2C_SLAVE #define CONFIG_SYS_I2C_SLAVE 0xfe #endif "
Will submit a patch removing CONFIG_SYS_I2C_SLAVE from imx boards.
Thanks,
Fabio Estevam
Hi Fabio,
Just fyi: On the ALKML there are IPU patches from Sascha Hauer for the kernel. Applying Sascha's patches to the kernel and this patch to U-Boot makes the kernel crash with a NULL pointer [1].
I haven't looked into the details, wild guessing is that the U-Boot patch enables some interrupts the IPU driver isn't ready to handle before he's done his own initialization.
Note that this is only fyi.
Best regards
Dirk
[1]
... imx-ipuv3 2800000.ipu: DI1 base: 0x02a48000 remapped to c08ee000 Unable to handle kernel NULL pointer dereference at virtual address 0000000c pgd = 80004000 [0000000c] *pgd=00000000 Internal error: Oops: 5 [#1] SMP ARM Modules linked in: CPU: 0 Not tainted PC is at imx_drm_handle_vblank+0xc/0x20 LR is at ipu_irq_handler+0x1c/0xdc ...
Series includes one patch to fix a register name in imx6/crm_regs.h and a second that's a re-base of Fabio's patch from 5/31. http://patchwork.ozlabs.org/patch/162206/
Note that I'm not sure whether this should have been based on u-boot-video because it's video-related or u-boot imx because the bulk of the patch set is board-specific.
arch/arm/include/asm/arch-mx6/crm_regs.h | 6 ++- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 90 +++++++++++++++++++++++++ include/configs/mx6qsabrelite.h | 14 ++++- 3 files changed, 108 insertions(+), 2 deletions(-)
Register CCM_CHSCCDR (offset 0x34 in CCM) is named CCM_CHSCCDR in reference manual, but was named chscdr in struct mxc_ccm_reg.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/include/asm/arch-mx6/crm_regs.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 0e605c2..8388e38 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -34,7 +34,7 @@ struct mxc_ccm_reg { u32 cs1cdr; u32 cs2cdr; u32 cdcdr; /* 0x0030 */ - u32 chscdr; + u32 chsccdr; u32 cscdr2; u32 cscdr3; u32 cscdr4; /* 0x0040 */
Adds support for the Hannstar 1024 x 768 LVDS panel (Freescale part number MCIMX-LVDS1) to SABRE-Lite board.
This commit is a rebase Fabio Estevan's patch from 5/31 to u-boot-video/master: http://patchwork.ozlabs.org/patch/162206/
Modifications include: removal of i2c setup (unneeded) cleanup of lcd_iomux to use struct mxc_ccm_reg and anatop_regs and associated constants
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/include/asm/arch-mx6/crm_regs.h | 4 + board/freescale/mx6qsabrelite/mx6qsabrelite.c | 90 +++++++++++++++++++++++++ include/configs/mx6qsabrelite.h | 14 ++++- 3 files changed, 107 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 8388e38..cffc0a1 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -294,6 +294,10 @@ struct mxc_ccm_reg { #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK (0x7) #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET 0
+#define CHSCCDR_CLK_SEL_LDB_DI0 3 +#define CHSCCDR_PODF_DIVIDE_BY_3 2 +#define CHSCCDR_IPU_PRE_CLK_540M_PFD 5 + /* Define the bits in register CSCDR2 */ #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK (0x3F << 19) #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET 19 diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 909ccca..22943b1 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -36,6 +36,9 @@ #include <micrel.h> #include <miiphy.h> #include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ @@ -195,6 +198,10 @@ static iomux_v3_cfg_t button_pads[] = { MX6Q_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), };
+iomux_v3_cfg_t lcd_gpio[] = { + MX6Q_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + static void setup_iomux_enet(void) { gpio_direction_output(87, 0); /* GPIO 3-23 */ @@ -372,10 +379,84 @@ int setup_sata(void) } #endif
+static struct fb_videomode lvds_xga = { + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +}; + +void lcd_iomux(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + + int reg; + /* Turn on GPIO backlight */ + imx_iomux_v3_setup_multiple_pads(lcd_gpio, ARRAY_SIZE(lcd_gpio)); + gpio_direction_output(18, 1); + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + reg = __raw_readl(&mxc_ccm->CCGR3); + reg |= 0x300F; + writel(reg, &mxc_ccm->CCGR3); + + /* set PFD3_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ + writel(0x00003F00, &anatop->pfd_480_clr); + writel(0x00001300, &anatop->pfd_480_set); + + /* set LDB0, LDB1 clk select to 011/011 */ + reg = readl(&mxc_ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->cs2cdr); + + reg = readl(&mxc_ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &mxc_ccm->cscmr2); + + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + /* derive clock from LDB_DI0 */ + /* divide by 3 */ + /* derive clock from 540M PFD */ + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) + |(CHSCCDR_PODF_DIVIDE_BY_3 + <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); + + writel(0x201, IOMUXC_BASE_ADDR + 0x8); /* 16 bpp */ +} + +void lcd_enable(void) +{ + + int ret = ipuv3_fb_init(&lvds_xga, 0, IPU_PIX_FMT_RGB666); + if (ret) + printf("LCD cannot be configured: %d\n", ret); +} + int board_early_init_f(void) { setup_iomux_uart(); setup_buttons(); + lcd_iomux();
return 0; } @@ -396,9 +477,18 @@ int board_init(void) setup_sata(); #endif
+int board_late_init(void) +{ + setenv("stdout", "serial"); + return 0; +} + int checkboard(void) { puts("Board: MX6Q-Sabre Lite\n"); diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 72d0154..af249fa 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -39,9 +39,10 @@ #define CONFIG_REVISION_TAG
@@ -121,6 +122,17 @@ /* Miscellaneous commands */ #define CONFIG_CMD_BMODE
+/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Hi Eric,
On Mon, Sep 17, 2012 at 5:20 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
I was told not to do this way.
Please follow this approach instead:
commit 3e0773708dd4e502c127a589be5779708eb7ba69 Author: Stefano Babic sbabic@denx.de Date: Sun Aug 5 00:18:53 2012 +0000
MX5: mx53loco: do not overwrite the console
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com Tested-by: Fabio Estevam fabio.estevam@freescale.com
Regards,
Fabio Estevam
Hi Eric,
On Mon, 17 Sep 2012 13:20:49 -0700 Eric Nelson eric.nelson@boundarydevices.com wrote:
It should be based on u-boot-imx since it touches board files.
Thanks,
Anatolij
V2 rebased against u-boot-imx/master.
+#define CHSCCDR_CLK_SEL_LDB_DI0 3 +#define CHSCCDR_PODF_DIVIDE_BY_3 2 +#define CHSCCDR_IPU_PRE_CLK_540M_PFD 5 + /* Define the bits in register CSCDR2 */ #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK (0x3F << 19) #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET 19 diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 4b4e89b..1632e7b 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -36,6 +36,9 @@ #include <micrel.h> #include <miiphy.h> #include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> DECLARE_GLOBAL_DATA_PTR;
+iomux_v3_cfg_t lcd_gpio[] = { + MX6Q_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + static void setup_iomux_enet(void) { gpio_direction_output(IMX_GPIO_NR(3, 23), 0); @@ -372,10 +379,84 @@ int setup_sata(void) } #endif
Hi Eric,
On Mon, Sep 17, 2012 at 8:14 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
s/Estevan/Estevam
Please see my previous comment on v1 about this.
Wolfgang nacked this method and Stefano has proposed a nice way for keeping the console in serial. Check mx53loco and mx51evk.
Regards,
Fabio Estevam
Hi Fabio,
On 09/17/2012 04:43 PM, Fabio Estevam wrote:
Hi Eric,
s/Estevan/Estevam
Oops, sorry...
Thanks. I'll look into it.
I'll also look into this: http://lists.denx.de/pipermail/u-boot/2012-July/129556.html
Regards,
Eric
On 09/17/2012 05:08 PM, Eric Nelson wrote:
Hi Fabio,
Hi Eric,
<snip >
- setenv("stdout", "serial");
Like this? http://lists.denx.de/pipermail/u-boot/2012-August/129967.html
On Mon, Sep 17, 2012 at 9:43 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
Yes, correct.
Regards,
Fabio Estevam
Hi Eric,
s/Estevan/Estevam
Hi Fabio and Stefano,
While trying to understand this, I wonder whether the use of overwrite_console() addresses Wolfgang's original concern.
I think the suggestion was to set the preboot variable to change things:
#define CONFIG_PREBOOT "setenv stdout serial"
The has the benefit of allowing saveenv to completely overwrite the decision.
Am I over-thinking this?
Please advise,
Eric
Wolfgang's first concern was to avoid to hardcode variable inside the code, as it was done in the original mx51 / mx53 code (and not only in i.MX boards).
This makes sense if you want maintain the possibility that u-boot output is displayed on the LCD. Is this really the case ?
In most cases, we want to display a splashscreen, while the console is still managed by serial line.
If this is the case, adding overwrite_console() tells video subsystem to not change the stdout variable, and then it is not required to set it back to serial neither in code nor with the help of the preboot variable.
It depends if you want also U-Boot's output on the display or only a picture.
Best regards, Stefano Babic
Thanks Stefano,
Sometimes it is.
We have customers of SABRE Lite that are new to embedded who have had to purchase serial adapters upon receiving their boards, though this is rare.
The other main use case is simpler: a serial port isn't hooked up during boot (i.e. in a production environment). In production, it would be more convenient to hook up a USB keyboard if needed.
I'll rework the patch with overwrite_console() and keep these options in mind.
Thanks for the tips.
Regards,
Eric
On 18/09/2012 01:14, Eric Nelson wrote:
Hi Eric,
All this stuff should not be part of the commit message, because it is more or less a changelog. Should you also include Fabio's signed-off ?
- MX6Q_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL),
- .name = "Hannstar-XGA",
- .refresh = 60,
- .xres = 1024,
- .yres = 768,
- .pixclock = 15385,
- .left_margin = 220,
- .right_margin = 40,
- .upper_margin = 21,
- .lower_margin = 7,
- .hsync_len = 60,
- .vsync_len = 10,
- .sync = FB_SYNC_EXT,
- .vmode = FB_VMODE_NONINTERLACED
- struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR;
- int reg;
- /* Turn on GPIO backlight */
- imx_iomux_v3_setup_multiple_pads(lcd_gpio, ARRAY_SIZE(lcd_gpio));
- gpio_direction_output(18, 1);
- /* Turn on LDB0,IPU,IPU DI0 clocks */
- reg = __raw_readl(&mxc_ccm->CCGR3);
- reg |= 0x300F;
- writel(reg, &mxc_ccm->CCGR3);
I think we can add constants for these - at least for these constants, you could drop the not useful defines with offset like MXC_CCM_CCGR5_CGx_OFFSET. There is already a patch (not yet merged) for MX5, we should then doing the same for MX6.
- /* set PFD3_FRAC to 0x13 == 455 MHz (480*18)/0x13 */
- writel(0x00003F00, &anatop->pfd_480_clr);
- writel(0x00001300, &anatop->pfd_480_set);
Add constants for these. They are not already defined, but they are added when needed, see for example ehci-mx6.c
- /* set LDB0, LDB1 clk select to 011/011 */
- reg = readl(&mxc_ccm->cs2cdr);
- reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK
- reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET)
- writel(reg, &mxc_ccm->cs2cdr);
- reg = readl(&mxc_ccm->cscmr2);
- reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV;
- writel(reg, &mxc_ccm->cscmr2);
- reg = readl(&mxc_ccm->chsccdr);
- reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK
- /* derive clock from LDB_DI0 */
- /* divide by 3 */
- /* derive clock from 540M PFD */
Wrong style for a multiline comment
- reg |= (CHSCCDR_CLK_SEL_LDB_DI0
- writel(reg, &mxc_ccm->chsccdr);
- writel(0x201, IOMUXC_BASE_ADDR + 0x8); /* 16 bpp */
This is GPR2, right ? Nobody can easy understand. Use structure (not offset) and constants to set it.
- int ret = ipuv3_fb_init(&lvds_xga, 0, IPU_PIX_FMT_RGB666);
- if (ret)
lcd_iomux();
- lcd_enable();
+#endif return 0; }
This is wrong, we found a better way to do this. You should add a overwrite_console() function, see for example the MX5 boards.
...adding also CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
Thanks for the review, Stefano.
Hi Eric,
Okay. I'll take it out of V3.
I didn't include Fabio's sign off because he hadn't seen this yet and I changed a fair amount of code.
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com
- /* Define the bits in register CSCDR2 */ #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK (0x3F<< 19) #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET 19
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 4b4e89b..1632e7b 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -36,6 +36,9 @@ #include<micrel.h> #include<miiphy.h> #include<netdev.h> +#include<linux/fb.h> +#include<ipu_pixfmt.h> +#include<asm/arch/crm_regs.h> DECLARE_GLOBAL_DATA_PTR;
- static void setup_iomux_enet(void) { gpio_direction_output(IMX_GPIO_NR(3, 23), 0);
- .refresh = 60,
- .xres = 1024,
- .yres = 768,
- .hsync_len = 60,
- .vsync_len = 10,
- int reg;
- reg |= 0x300F;
- writel(reg,&mxc_ccm->CCGR3);
Do you have a reference to the patch so I can follow precedent?
- writel(0x00003F00,&anatop->pfd_480_clr);
- writel(0x00001300,&anatop->pfd_480_set);
Ok.
- reg&= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK
- writel(reg,&mxc_ccm->cs2cdr);
- writel(reg,&mxc_ccm->cscmr2);
- reg&= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK
- /* divide by 3 */
Noted. These are leftovers I used while hand decoding the bits.
- writel(reg,&mxc_ccm->chsccdr);
Yep.
- if (ret)
lcd_iomux();
return 0; }
- lcd_enable();
+#endif return 0; }
Fabio noted that as well.
I'll send a note under separate cover about this.
Regards,
Eric
See http://patchwork.ozlabs.org/patch/177403/
Check changes in .h.
Should I remove the un-named macros? MXC_CCM_CCGRx_CGy_OFFSET MXC_CCM_CCGRx_CGy_MASK
It appears that only arch/arm/cpu/armv7/mx6/clock.c is using them.
Please advise,
Eric
Any cleanup to make code better understandable is welcome !
As I see, most macros are named in clock.c, with the exception in enable_usboh3_clk().
Regards, Stefano Babic
Hi Fabio,
On Thu, 31 May 2012 14:23:55 -0300 Fabio Estevam fabio.estevam@freescale.com wrote:
Anatolij
participants (8)
Anatolij Gustschin
Dirk Behme
Dirk Behme
Eric Nelson
Fabio Estevam
Fabio Estevam
Stefano Babic
Troy Kisky
