[U-Boot] [PATCH v3] add new board nas62x0
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220.
Only difference between boards is number of SATA ports.
Signed-off-by: Luka Perkov uboot@lukaperkov.net Signed-off-by: Gerald Kerma dreagle@doukki.net ---
Changes from version v2:
* use defined() in macros for board selection for robustness
MAINTAINERS | 4 + board/Marvell/ib62x0/Makefile | 51 +++++++++++ board/Marvell/ib62x0/ib62x0.c | 114 ++++++++++++++++++++++++ board/Marvell/ib62x0/ib62x0.h | 41 +++++++++ board/Marvell/ib62x0/kwbimage.cfg | 167 +++++++++++++++++++++++++++++++++++ boards.cfg | 2 + include/configs/ib62x0.h | 176 +++++++++++++++++++++++++++++++++++++ 7 files changed, 555 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 46f63a0..11d023e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -782,6 +782,10 @@ Linus Walleij linus.walleij@linaro.org integratorap various integratorcp various
+Luka Perkov uboot@lukaperkov.net + + ib62x0 ARM926EJS + Dave Peverley dpeverley@mpc-data.co.uk
omap730p2 ARM926EJS diff --git a/board/Marvell/ib62x0/Makefile b/board/Marvell/ib62x0/Makefile new file mode 100644 index 0000000..3d82f27 --- /dev/null +++ b/board/Marvell/ib62x0/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := ib62x0.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/Marvell/ib62x0/ib62x0.c b/board/Marvell/ib62x0/ib62x0.c new file mode 100644 index 0000000..2b7762a --- /dev/null +++ b/board/Marvell/ib62x0/ib62x0.c @@ -0,0 +1,114 @@ +/* + * Copyright (C) 2011 Gérald Kerma dreagle@doukki.net + * + * Written-by: Gérald Kerma dreagle@doukki.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/kirkwood.h> +#include <asm/arch/mpp.h> +#include "ib62x0.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + kw_config_gpio(IB62x0_OE_VAL_LOW, + IB62x0_OE_VAL_HIGH, + IB62x0_OE_LOW, IB62x0_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, + MPP8_UART0_RTS, + MPP9_UART0_CTS, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, + MPP14_SD_D0, + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, /* Power LED red */ + MPP23_GPIO, + MPP24_GPIO, + MPP25_GPIO, /* Power LED green */ + MPP26_GPIO, + MPP27_GPIO, /* USB transfer LED */ + MPP28_GPIO, /* Reset button */ + MPP29_TSMP9, /* USB Copy button */ + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, + MPP35_GPIO, + MPP36_GPIO, + MPP37_GPIO, + MPP38_GPIO, + MPP39_GPIO, + MPP40_GPIO, + MPP41_GPIO, + MPP42_GPIO, + MPP43_GPIO, + MPP44_GPIO, + MPP45_GPIO, + MPP46_GPIO, + MPP47_GPIO, + MPP48_GPIO, + MPP49_GPIO, + 0 + }; + kirkwood_mpp_conf(kwmpp_config); + return 0; +} + +int board_init(void) +{ + /* + * arch number of board + */ + gd->bd->bi_arch_number = MACH_TYPE_NAS6210; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = kw_sdram_bar(0) + 0x100; + + return 0; +} diff --git a/board/Marvell/ib62x0/ib62x0.h b/board/Marvell/ib62x0/ib62x0.h new file mode 100644 index 0000000..b26a257 --- /dev/null +++ b/board/Marvell/ib62x0/ib62x0.h @@ -0,0 +1,41 @@ +/* + * Copyright (C) 2011 Gérald Kerma dreagle@doukki.net + * + * Written-by: Gérald Kerma dreagle@doukki.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __IB62x0_H +#define __IB62x0_H + +#define IB62x0_OE_LOW (~(0)) +#define IB62x0_OE_HIGH (~(0)) +#define IB62x0_OE_VAL_LOW (1 << 29) /* USB_PWEN low */ +#define IB62x0_OE_VAL_HIGH (1 << 17) /* LED pin high */ + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) + +#endif /* __IB62x0_H */ diff --git a/board/Marvell/ib62x0/kwbimage.cfg b/board/Marvell/ib62x0/kwbimage.cfg new file mode 100644 index 0000000..ffa3c18 --- /dev/null +++ b/board/Marvell/ib62x0/kwbimage.cfg @@ -0,0 +1,167 @@ +# +# Copyright (C) 2011 Gérald Kerma dreagle@doukki.net +# +# Written-by: Gérald Kerma dreagle@doukki.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM nand # change from nand to uart if building UART image +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1b1b1b9b + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000c30 # DDR Configuration register +# bit13-0: 0xc30 (3120 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x37543000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 7= CL+2, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000a33 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x000000CC # DDR Address Control +# bit1-0: 00, Cs0width=x8 +# bit3-2: 11, Cs0size=1Gb +# bit5-4: 00, Cs1width=x8 +# bit7-6: 11, Cs1size=1Gb +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000C52 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000004 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 1, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 0, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F17F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x0F, Size (i.e. 256MB) + +DATA 0xFFD01508 0x10000000 # CS[1]n Base address to 256Mb +DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled + +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00120012 # DDR ODT Control (Low) +# bit3-0: 2, ODT0Rd, MODT[0] asserted during read from DRAM CS1 +# bit7-4: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 +# bit19-16:2, ODT0Wr, MODT[0] asserted during write to DRAM CS1 +# bit23-20:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 + +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xFFD0149C 0x0000E40F # CPU ODT Control +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index 28cc345..a4e8852 100644 --- a/boards.cfg +++ b/boards.cfg @@ -147,6 +147,8 @@ netspace_max_v2 arm arm926ejs netspace_v2 LaCie netspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_V2 dreamplug arm arm926ejs - Marvell kirkwood guruplug arm arm926ejs - Marvell kirkwood +ib_nas6210 arm arm926ejs ib62x0 Marvell kirkwood ib62x0:BOARD_IS_IB_NAS6210 +ib_nas6220 arm arm926ejs ib62x0 Marvell kirkwood ib62x0:BOARD_IS_IB_NAS6220 mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE openrd_client arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_CLIENT diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h new file mode 100644 index 0000000..1609dd6 --- /dev/null +++ b/include/configs/ib62x0.h @@ -0,0 +1,176 @@ +/* + * Copyright (C) 2011-2012 + * Gérald Kerma dreagle@doukki.net + * Luka Perkov uboot@lukaperkov.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_IB62x0_H +#define _CONFIG_IB62x0_H + +/* + * Version number information + */ +#if defined(CONFIG_BOARD_IS_IB_NAS6210) +# define CONFIG_IDENT_STRING " RaidSonic ICY BOX IB-NAS6210" +#elif defined(CONFIG_BOARD_IS_IB_NAS6220) +# define CONFIG_IDENT_STRING " RaidSonic ICY BOX IB-NAS6220" +#else +# error Unknown RaidSonic ICY BOX board specified +#endif + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ +#define CONFIG_KIRKWOOD /* SOC Family Name */ +#define CONFIG_KW88F6281 /* SOC Name */ +#define CONFIG_MACH_NAS6210 /* Machine type */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ + +/* + * Other required minimal configurations + */ +#define CONFIG_DISPLAY_CPUINFO /* Display cpu info */ +#define CONFIG_SYS_ALT_MEMTEST + +/* + * Compression configuration + */ +#define CONFIG_BZIP2 +#define CONFIG_LZMA +#define CONFIG_LZO + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#define CONFIG_SYS_MVFS +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_IDE +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +#undef CONFIG_SYS_PROMPT +#if defined(CONFIG_BOARD_IS_IB_NAS6210) +# define CONFIG_SYS_PROMPT "IB-NAS6210 # " +#elif defined(CONFIG_BOARD_IS_IB_NAS6220) +# define CONFIG_SYS_PROMPT "IB-NAS6220 # " +#else +# error Unknown RaidSonic ICY BOX board specified +#endif + +/* + * Environment variables configurations + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SECT_SIZE 0x20000 +#else +#define CONFIG_ENV_IS_NOWHERE +#endif +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OFFSET 0x80000 + +/* + * Default environment variables + */ +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs ${console} ${mtdparts} ${bootargs_root}; " \ + "ubi part root; " \ + "ubifsmount root; " \ + "ubifsload 0x800000 ${kernel}; " \ + "ubifsload 0x1100000 ${initrd}; " \ + "bootm 0x800000 0x1100000" + +#define CONFIG_MTDPARTS \ + "mtdparts=orion_nand:" \ + "0x80000@0x0(uboot)," \ + "0x20000@0x80000(uboot_env)," \ + "-@0xa0000(root)\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=console=ttyS0,115200\0" \ + "mtdids=nand0=orion_nand\0" \ + "mtdparts="CONFIG_MTDPARTS \ + "kernel=/boot/uImage\0" \ + "initrd=/boot/uInitrd\0" \ + "bootargs_root=ubi.mtd=2 root=ubi0:root rootfstype=ubifs\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ +#define CONFIG_PHY_BASE_ADR 0 +#undef CONFIG_RESET_PHY_R +#endif /* CONFIG_CMD_NET */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_IDE_PREINIT +#define CONFIG_DOS_PARTITION +#define CONFIG_MVSATA_IDE_USE_PORT0 +# if defined(CONFIG_BOARD_IS_IB_NAS6210) +# undef CONFIG_SYS_IDE_MAXBUS +# define CONFIG_SYS_IDE_MAXBUS 1 +# undef CONFIG_SYS_IDE_MAXDEVICE +# define CONFIG_SYS_IDE_MAXDEVICE 1 +# elif defined(CONFIG_BOARD_IS_IB_NAS6220) +# define CONFIG_MVSATA_IDE_USE_PORT1 +# endif +#define CONFIG_SYS_ATA_IDE0_OFFSET KW_SATA_PORT0_OFFSET +# if defined(CONFIG_BOARD_IS_IB_NAS6220) +# define CONFIG_SYS_ATA_IDE1_OFFSET KW_SATA_PORT1_OFFSET +# endif +#endif /* CONFIG_CMD_IDE */ + +/* + * RTC driver configuration + */ +#ifdef CONFIG_CMD_DATE +#define CONFIG_RTC_MV +#endif /* CONFIG_CMD_DATE */ + +/* + * File system + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS + +#endif /* _CONFIG_IB62x0_H */
Luka Perkov
