[U-Boot] [RFC PATCH v1] usb: spl: fix USB errata for FSL SPL targets
Commit 9262367 moved USB errata workaround to a C file but didn't build it for SPL targets.
Signed-off-by: York Sun york.sun@nxp.com CC: Sriram Dash sriram.dash@nxp.com CC: Rajesh Bhagat rajesh.bhagat@nxp.com
--- Please review this patch. It fixed the compiling errors introduced by 9262367. Not sure if this is the way USB errata should be handled.
drivers/Makefile | 7 +++++++ drivers/usb/common/Makefile | 8 ++++++-- include/configs/km/kmp204x-common.h | 1 + 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/Makefile b/drivers/Makefile index 1723958..88774ba 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -39,6 +39,13 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ +ifdef CONFIG_USB_EHCI_FSL +CONFIG_SPL_USB_ERRATA = y +endif +ifdef CONFIG_USB_XHCI_FSL +CONFIG_SPL_USB_ERRATA = y +endif +obj-$(CONFIG_SPL_USB_ERRATA) += usb/common/
else
diff --git a/drivers/usb/common/Makefile b/drivers/usb/common/Makefile index aee7e32..f073e1c 100644 --- a/drivers/usb/common/Makefile +++ b/drivers/usb/common/Makefile @@ -4,5 +4,9 @@ #
obj-$(CONFIG_DM_USB) += common.o -obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o fsl-errata.o -obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o fsl-errata.o +obj-$(CONFIG_USB_EHCI_FSL) += fsl-errata.o +obj-$(CONFIG_USB_XHCI_FSL) += fsl-errata.o +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o +obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o +endif diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 028623d..5bdda22 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -406,6 +406,7 @@ int get_scl(void); #endif
#define __USB_PHY_TYPE utmi +#define CONFIG_USB_EHCI_FSL
/* * Environment Configuration
I really dislike the naming here, I'd say just do
obj-$(CONFIG_USB_EHCI_FSL) += usb/common/ obj-$(CONFIG_USB_XHCI_FSL) += usb/common/
else
Either the filename is misnamed or this is real broken design. I would expect that a filename with -dt- in it's name should depend on CONFIG_*FDT* , but not on CONFIG_SPL_BUILD.
- Environment Configuration
From: Marek Vasut [mailto:marex@denx.de] On 06/28/2016 01:02 AM, York Sun wrote:
Hello York/Marek,
IMO, the build for SPL is failing in PPC as the cmd_errata is not getting the definition of the has_erratum_aNNNNNN functions. So, instead of EHCI or XHCI flags, i think we can use CONFIG_CMD_ERRATA for SPL build for the errata applicability.
+obj-$(CONFIG_CMD_ERRATA) += usb/common/fsl-errata.o
What is your opinion?
Regards, Sriram
else
obj-$(CONFIG_DM_USB) += common.o -obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o fsl-errata.o -obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o fsl-errata.o +obj-$(CONFIG_USB_EHCI_FSL) += fsl-errata.o +obj-$(CONFIG_USB_XHCI_FSL) += fsl-errata.o ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o +obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o endif
-- Best regards, Marek Vasut
Hello York/Marek,
I think naming macro which is NOT enabling a command CONFIG_CMD_ERRATA is horrible and needs renaming in near future. Otherwise, I'll just wait for York's opinion on the above.
Better.
Hello York/Marek,
Sriram,
I think it is not a good idea. CONFIG_CMD_ERRATA has nothing to do with USB errata specifically. It means to enable the command "errata", and nothing more.
What's broken here is the mechanism to detect if an erratum applies to a particular SoC version. Before your change, the functions were included from the header file. You moved those functions into a C file. That's fine. We need to build this file for both normal image and SPL. I don't think the workarounds are optional, unless USB is not used at all for SPL.
I think Marek's comments make sense. 1) obj-$(CONFIG_USB_EHCI_FSL) += usb/common/ obj-$(CONFIG_USB_XHCI_FSL) += usb/common/ For this to work, we need to fix kmp204x-common.h, which I noticed CONFIG_USB_EHCI_FSL is not defined. Please examine if this macro should be defined at SoC level, instead of board level. 2) Use a proper macro for fsl-dt-fixup.o The entry point is fdt_fixup_dr_usb(), which is only called by ft_board_setup() when CONFIG_OF_BOARD_SETUP is defined.
Please take the lead to fix this issue.
York
Better.
Hello York/Marek,
Sriram,
- obj-$(CONFIG_USB_EHCI_FSL) += usb/common/ obj-$(CONFIG_USB_XHCI_FSL) += usb/common/
OK. This looks generic also.
The kmp204x-common does not need to define CONFIG_USB_EHCI_FSL. Currently, the board is not using the USB. But, they are using CONFIG_CMD_ERRATA. So, instead of having a flag of CONFIG_USB_EHCI_FSL in the board specific file, drivers/usb/common/Makefile should include fsl-errata.o for the config CONFIG_CMD_ERRATA. What is your opinion?
- Use a proper macro for fsl-dt-fixup.o The entry point is fdt_fixup_dr_usb(), which
Yes. You are correct. fdt_fixup_dr_usb is only called when CONFIG_OF_BOARD_SETUP is defined. So, I guess it will be fine for drivers/usb/common/Makefile
obj-$(CONFIG_USB_EHCI_FSL) += fsl-errata.o obj-$(CONFIG_USB_XHCI_FSL) += fsl-errata.o obj-$( CONFIG_CMD_ERRATA) += fsl-errata.o obj-$(CONFIG_OF_BOARD_SETUP) += fsl-dt-fixup.o
York
Better.
Hello York/Marek,
Sriram,
If an SoC has the errata, it should implement the workaround, regardless if the U-Boot uses USB. Kernel may use it later. So we should treat it that way.
I don't agree. CMD_ERRATA is to enable the command to show which erratum workaround has been implemented. It shouldn't gate if the actual workaround code runs. Even kmp204x boards doesn't use USB, the workaround still needs to be implemented, in case kernel uses USB later. I was suggesting to put a macro in SoC config file if that fits the purpose.
That looks reasonable. Please test some targets with and without SPL, powerpc and ARM.
York
Better.
Hello York/Marek,
Sriram,
This is a NAK
This is also a NAK, how the heck can this depend on OF_BOARD_SETUP?
York
Sriram Dash
York Sun
york sun
