[U-Boot] [PATCH] serial: sh: Add Support R7S72100 of rmobile
The R7S72100 has same IP as serial with SH. This adds support R7S72100 to serial_sh.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/serial/serial_sh.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_sh.h b/drivers/serial/serial_sh.h index f5e9854..612e113 100644 --- a/drivers/serial/serial_sh.h +++ b/drivers/serial/serial_sh.h @@ -203,7 +203,7 @@ struct uart_port { # define SCSPTR7 0xfffeB820 /* 16 bit SCIF */ # endif # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ -#elif defined(CONFIG_CPU_SH7269) +#elif defined(CONFIG_CPU_SH7269) || defined(CONFIG_R7S72100) # define SCSPTR0 0xe8007020 /* 16 bit SCIF */ # define SCSPTR1 0xe8007820 /* 16 bit SCIF */ # define SCSPTR2 0xe8008020 /* 16 bit SCIF */ @@ -213,6 +213,7 @@ struct uart_port { # define SCSPTR6 0xe800a020 /* 16 bit SCIF */ # define SCSPTR7 0xe800a820 /* 16 bit SCIF */ # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ +# define SCIF_ORER 0x0001 /* overrun error bit */ #elif defined(CONFIG_CPU_SH7619) # define SCSPTR0 0xf8400020 /* 16 bit SCIF */ # define SCSPTR1 0xf8410020 /* 16 bit SCIF */
Nobuhiro Iwamatsu
