[PATCH] efi_loader: Disable devices before handing over control
U-Boot Driver Model is supposed to remove devices with either DM_REMOVE_ACTIVE_DMA or DM_REMOVE_OS_PREPARE flags set, before exiting. Our bootm command does that by explicitly calling calling "dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL);" and we also disable any USB devices.
The EFI equivalent is doing none of those at the moment. As a result probing an fTPM driver now renders it unusable in Linux. During our (*probe) callback we open a session with OP-TEE, which is supposed to close with our (*remove) callback. Since the (*remove) is never called, once we boot into Linux and try to probe the device again we are getting a busy error response. We also never free
So let's fix this by mimicking what bootm does and disconnect devices when efi_exit_boot_services() is called. Note that for the OP-TEE case and in particular any subsequent bootloader that wants to use a device (e.g GRUB) will need to call exit_boot_services() in order to close the session.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_boottime.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index bf78176217c6..25e6cf0fe719 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -18,6 +18,8 @@ #include <pe.h> #include <u-boot/crc.h> #include <watchdog.h> +#include <dm/device.h> +#include <dm/root.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -1994,7 +1996,10 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, list_del(&evt->link); }
+ if IS_ENABLED(CONFIG_USB_DEVICE) + udc_disconnect(); board_quiesce_devices(); + dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL);
/* Patch out unsupported runtime function */ efi_runtime_detach();
Hello Ilias,
thanks for the patch. Adding the function calls looks correct to me, but sandbox_spl_defconfig gives me a compile time error with this patch, cf. https://gitlab.denx.de/u-boot/custodians/u-boot-efi/-/jobs/166842
You might want to use Travis CI before resubmitting.
Best regards
Heinrich
udc_disconnect();
Hi Heinrich,
Hello Ilias,
Well the only doubt I have is what if GRUB has to extend some PCRs before calling Linux? Any idea if it's currently calling ExitBootSevices? I was considering if it would be a better idea to call the device unbinding during some kind of "exit" from U-boot's EFI code. (i.e before StartImage)
Ok will do.
Thanks /Ilias
Best regards
Heinrich
udc_disconnect();
On 21.10.20 13:41, Ilias Apalodimas wrote:
Hi Heinrich,
Hello Ilias,
ExitBootServices() is called by the Linux EFI stub in function allocate_new_fdt_and_exit_boot().
If GRUB would call ExitBootServices(), it would not be able to launch the EFI stub via StartImage().
Best regards
Heinrich
Ok will do.
Thanks /Ilias
Best regards
Heinrich
udc_disconnect();
Hi Heinrich,
Hi Heinrich,
Hello Ilias,
Yea that's my point. So with the current patch, you won't be able to access the fTPM driver from GRUB (or any other EFI application) until the Linux EFI stub calls exit boot services. Maybe calling those 2 functions in StartImage is a better idea?
/Ilias
Best regards
Heinrich
Ok will do.
Thanks /Ilias
Best regards
Heinrich
udc_disconnect();
Hi Heinrich
On Wed, 21 Oct 2020 at 15:42, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Heinrich,
Hi Heinrich,
Hello Ilias,
So as it seems (over irc discussion), GRUB expects an EFI protocol to use the fTPM device. So removing the device on ExitBootServices is fine, since GRUB never access the TPM directly. U-Boot still doesn't have support for EFI_TCG2_PROTOCOL , but if we add that GRUB will be able to access the device via the EFI protocol.
I'll send a v2 fixing the compilation error shortly
Cheers /Ilias
/Ilias
Best regards
Heinrich
Ok will do.
Thanks /Ilias
Best regards
Heinrich
udc_disconnect();
From: Ilias Apalodimas ilias.apalodimas@linaro.org Date: Wed, 21 Oct 2020 15:42:02 +0300
Hi Heinrich,
Hi Heinrich,
Hello Ilias,
Shouldn't an EFI application (such as GRUB) be using EFI protocols to access the TPM?
Hi Mark,
Hi Heinrich,
Hi Heinrich,
Hello Ilias,
Yea I already responded to myself on the previous mail. We don't have support for the EFI protocol in U-Boot (yet), but cleaning up in exit boot services makes more sense. So I'll fix the compilation error and send a V2 with the DM removal as-is. GRUB will be able to access the TPM once we add the EFI protocols in U-boot.
Cheers /Ilias
Ilias Apalodimas
Mark Kettenis
