[U-Boot] [PATCH] powerpc/83xx: increment malloc heap size for the MPC832x MDS boards
The malloc buffer is not large enough to hold a flash sector (0x20000 bytes) in addition to whatever else it normally holds, so double its size. This fixes a failure trying to save the environment:
=> save Saving Environment to Flash... Unable to save the rest of sector (122880) . done Protected 1 sectors
This problem probably surfaced from some other change that significantly increased the normal memory usage, thereby not leaving enough room for the saveenv command.
Signed-off-by: Timur Tabi timur@freescale.com --- include/configs/MPC832XEMDS.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 4ed5a97..6f8622c 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -181,7 +181,7 @@
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ #define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Reserved for malloc */
/* * Initial RAM Base Address Setup
Dear Timur Tabi,
Doubling it is kind of aggressive strategy. You know exactly how much free room needs to be guaranteed, so why don't you auto-adjust the size?
How about:
#define CONFIG_SYS_MALLOC_LEN (128 * 1024 + CONFIG_ENV_SECT_SIZE)
Yes, your board config file is kind of broken and will need more cleanup to facilitate this, but that should be done anyway.
Why exactly don't you support NOR flash for RAM-booting configurations?
How about:
That's the same thing. CONFIG_ENV_SECT_SIZE is 128KB. Plus, as you realized, this will not work if CONFIG_SYS_RAMBOOT is defined.
Well, I have no desire to do that. I'm just fixing one bug. A major cleanup of the board file is not on my to-do list.
I have no idea. I just noticed this one bug. I don't support the board.
Dear Tabi Timur-B04825,
In message CAOZdJXUem_-mgDSqF+p4R0npZQ6qu14G1yexQCBUe2G=nr2-1Q@mail.gmail.com you wrote:
-#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Res=
erved for malloc */
+#define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Res=
erved for malloc */
How about:
No, it's not the same thing. Your code is static an either wasted moemory on systems with smaller sector size, or needs to be readjusted on systems with bigger sectors.
Don;t just think about your current situation, but also what happens when you (or somebody else) copies that code for other systems.
Make your code more robust.
I consider this a bug that needs fixing anyway.
Well, fixing this bug has uncovered another shortcoming or bug (depending on point of view) of the code, so we should fix that one, too.
erved for malloc */
erved for malloc */
How about:
You really want CONFIG_SYS_MALLOC_LEN to be a list of everything that could be mallocked -- or worse, a list of just the things that people have noticed breaking in the past (even though other things could later be depending on that increase in size)? You want to answer questions about why NAND breaks on a board with a smaller NOR sector size? :-P
Come on, you're worried about a 128K increase in memory reserved for the use of the bootloader? It's not "wasted". The only thing that area of memory could otherwise be used for is loading images and such, and it is very unlikely that this small change is going to matter there.
The robust thing to do would be to not be stingy with the malloc size, and change all boards to have at least 1 MiB for malloc (except ones with very small amounts of RAM). Maybe have a debug command to print max memory usage since boot, to see if a board is getting anywhere near the limit.
-Scott
Dear Scott Wood,
Good idea. Patches are welcome, as usual.
I'm not sure it the malloc code keeps any such statics - if yes, and this can be done without any significant amount of code, this could even be added to the default bdinfo output.
applied, Thanks.
Kim
participants (5)
Kim Phillips
Scott Wood
Tabi Timur-B04825
Timur Tabi
