[U-Boot] [PATCH] imx-common: remove extraneous semicolon from macro
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- This was clearly a typo.
arch/arm/imx-common/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 0cd2538..9231649 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -51,9 +51,9 @@ char *get_reset_cause(void)
#if defined(CONFIG_MX53) || defined(CONFIG_MX6) #if defined(CONFIG_MX53) -#define MEMCTL_BASE ESDCTL_BASE_ADDR; +#define MEMCTL_BASE ESDCTL_BASE_ADDR #else -#define MEMCTL_BASE MMDC_P0_BASE_ADDR; +#define MEMCTL_BASE MMDC_P0_BASE_ADDR #endif static const unsigned char col_lookup[] = {9, 10, 11, 8, 12, 9, 9, 9}; static const unsigned char bank_lookup[] = {3, 2};
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Eric Nelson
Stefano Babic
