[PATCH 1/2] tqma6: Convert to PMIC and I2C driver model
Currently, the power_init_board() function is not executed because CONFIG_POWER_LEGACY is not selected.
Convert to PMIC driver model, which allows removing board I2C code in favor of the I2C driver model.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/tq/tqma6/tqma6.c | 61 +++++++---------------------------------- include/configs/tqma6.h | 8 ------ 2 files changed, 10 insertions(+), 59 deletions(-)
diff --git a/board/tq/tqma6/tqma6.c b/board/tq/tqma6/tqma6.c index 92142c10ae5a..02a2022c3c84 100644 --- a/board/tq/tqma6/tqma6.c +++ b/board/tq/tqma6/tqma6.c @@ -19,11 +19,9 @@ #include <linux/errno.h> #include <asm/gpio.h> #include <asm/io.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/spi.h> #include <fsl_esdhc_imx.h> #include <linux/libfdt.h> -#include <i2c.h> #include <mmc.h> #include <power/pfuze100_pmic.h> #include <power/pmic.h> @@ -48,10 +46,6 @@ DECLARE_GLOBAL_DATA_PTR; #define SPI_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_80ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - int dram_init(void) { gd->ram_size = imx_ddr_size(); @@ -170,38 +164,6 @@ int board_spi_cs_gpio(unsigned bus, unsigned cs) #endif #endif
-#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) -static struct i2c_pads_info tqma6_i2c3_pads = { - /* I2C3: on board LM75, M24C64, */ - .scl = { - .i2c_mode = NEW_PAD_CTRL(MX6_PAD_GPIO_5__I2C3_SCL, - I2C_PAD_CTRL), - .gpio_mode = NEW_PAD_CTRL(MX6_PAD_GPIO_5__GPIO1_IO05, - I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(1, 5) - }, - .sda = { - .i2c_mode = NEW_PAD_CTRL(MX6_PAD_GPIO_6__I2C3_SDA, - I2C_PAD_CTRL), - .gpio_mode = NEW_PAD_CTRL(MX6_PAD_GPIO_6__GPIO1_IO06, - I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(1, 6) - } -}; - -static void tqma6_setup_i2c(void) -{ - int ret; - /* - * use logical index for bus, e.g. I2C1 -> 0 - * warn on error - */ - ret = setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &tqma6_i2c3_pads); - if (ret) - printf("setup I2C3 failed: %d\n", ret); -} -#endif - int board_early_init_f(void) { return tqma6_bb_board_early_init_f(); @@ -215,10 +177,6 @@ int board_init(void) #ifndef CONFIG_DM_SPI tqma6_iomuxc_spi(); #endif -#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) - tqma6_setup_i2c(); -#endif - tqma6_bb_board_init();
return 0; @@ -246,21 +204,22 @@ static const char *tqma6_get_boardname(void) }; }
-#if CONFIG_IS_ENABLED(POWER_LEGACY) +#if CONFIG_IS_ENABLED(DM_PMIC) /* setup board specific PMIC */ int power_init_board(void) { - struct pmic *p; + struct udevice *dev; u32 reg, rev; + int ret;
- power_pfuze100_init(TQMA6_PFUZE100_I2C_BUS); - p = pmic_get("PFUZE100"); - if (p && !pmic_probe(p)) { - pmic_reg_read(p, PFUZE100_DEVICEID, ®); - pmic_reg_read(p, PFUZE100_REVID, &rev); - printf("PMIC: PFUZE100 ID=0x%02x REV=0x%02x\n", reg, rev); - } + ret = pmic_get("pmic@8", &dev); + if (ret < 0) + return 0; + + reg = pmic_reg_read(dev, PFUZE100_DEVICEID); + rev = pmic_reg_read(dev, PFUZE100_REVID);
+ printf("PMIC: PFUZE100 ID=0x%02x REV=0x%02x\n", reg, rev); return 0; } #endif diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 2da76f154313..b4a06a75c538 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -26,14 +26,6 @@
#define TQMA6_SPI_FLASH_SECTOR_SIZE SZ_64K
-/* I2C Configs */ -#define CFG_I2C_MULTI_BUS - -#if !defined(CONFIG_DM_PMIC) -#define CFG_POWER_PFUZE100_I2C_ADDR 0x08 -#define TQMA6_PFUZE100_I2C_BUS 2 -#endif - /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR 0
Currently, the devicetree model as well as the board variant name are shown: ... Model: TQ TQMa6S/DL on MBa6x Board: TQMa6DL on a MBa6x ...
Unselect the CONFIG_DISPLAY_BOARDINFO option so that the board name is printed only once in board_late_init() instead.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/tq/tqma6/tqma6.c | 5 ----- configs/tqma6dl_mba6_mmc_defconfig | 1 + 2 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/board/tq/tqma6/tqma6.c b/board/tq/tqma6/tqma6.c index 02a2022c3c84..445ce987b683 100644 --- a/board/tq/tqma6/tqma6.c +++ b/board/tq/tqma6/tqma6.c @@ -230,11 +230,6 @@ int board_late_init(void)
tqma6_bb_board_late_init();
- return 0; -} - -int checkboard(void) -{ printf("Board: %s on a %s\n", tqma6_get_boardname(), tqma6_bb_get_boardname()); return 0; diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index be891d24537f..d0c5db65177c 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -17,6 +17,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run mmcboot; run netboot; run panicboot" CONFIG_DEFAULT_FDT_FILE="imx6dl-mba6x.dtb" CONFIG_SYS_PBSIZE=532 +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_CMD_BOOTZ=y
Applied both, thanks.
Fabio Estevam
