[U-Boot] [PATCH 1/2] doc: README.fuse: Add an example on how to use the fuse API on mx6q
When using the fuse API in U-boot user must calculate the 'bank' and 'word' values.
Provide a real example on how to calculate such values for the mx6q.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- doc/README.fuse | 57 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 57 insertions(+)
diff --git a/doc/README.fuse b/doc/README.fuse index 1bc91c4..aca1e5e 100644 --- a/doc/README.fuse +++ b/doc/README.fuse @@ -65,3 +65,60 @@ Configuration:
CONFIG_CMD_FUSE Define this to enable the fuse commands. + +Example: + +For reading the MAC address fuses on a MX6Q: + +- The MAC address are stored in two fuse addresses (the fuse addresses are +described in the Fusemap Descriptions table from the mx6q Reference Manual): + +0x620[31:0] - MAC_ADDR[31:0] +0x630[15:0] - MAC_ADDR[47:32] + +In order to use the fuse API, we need to pass the bank and word values, which +are calculated as below: + +Fuse address for the lower MAC address: 0x620 +Base address for the fuses: 0x400 + +(0x620 - 0x400)/0x10 = 0x22 = 34 decimal + +As the fuses are arranged in banks of 8 words: + +34 / 8 = 4 and the remainder is 2, so in this case: + +bank = 4 +word = 2 + +And the U-boot command would be: + +=> fuse read 4 2 +Reading bank 4: + +Word 0x00000002: 9f027772 + +Doing the same for the upper MAC address: + +Fuse address for the upper MAC address: 0x630 +Base address for the fuses: 0x400 + +(0x630 - 0x400)/0x10 = 0x23 = 35 decimal + +As the fuses are arranged in banks of 8 words: + +35 / 8 = 4 and the remainder is 3, so in this case: + +bank = 4 +word = 3 + +And the U-boot command would be: + +=> fuse read 4 3 +Reading bank 4: + +Word 0x00000003: 00000004 + +,which matches the ethaddr value: +=> echo ${ethaddr} +00:04:9f:02:77:72
Add CONFIG_CMD_FUSE option, so that the fuse API can be used.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx6sabre_common.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index d52c9a8..63405aa 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -34,6 +34,11 @@
#define CONFIG_MXC_UART
+#define CONFIG_CMD_FUSE +#ifdef CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP +#endif + /* MMC Configs */ #define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC
Hi Fabio,
1.8.1.2
Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com
Best regards, Benoît
Hi Fabio,
+Example:
+bank = 4 +word = 2
+bank = 4 +word = 3
+00:04:9f:02:77:72
1.8.1.2
Note that the documentation in this file is also completed for i.MX6 by doc/README.mxc_ocotp and doc/README.imx6, as explained in each README. The information that you add here regarding the location of the MAC fuses for i.MX6Q is already present in doc/README.imx6.
Regarding the 'calculation' part, it is actually not needed since the values obtained with these calculations are already given by the reference manual in '46.5 OCOTP Memory Map/Register Definition'.
Examples could still be interesting though. What do you think? - Should the calculation part be removed and replaced with a reference to the RM §46.5 be added? - Should this example be moved to doc/README.imx6, or kept in doc/README.fuse as a generic example for the fuse API? - Should an example be added to show how to read the whole MAC address with a single fuse command (i.e. 'fuse read 4 2 2')?
Hi Benoît, hi Fabio,
On 17/12/2013 22:18, Benoît Thébaudeau wrote:
Hi Fabio,
+Example:
+bank = 4 +word = 2
+bank = 4 +word = 3
+00:04:9f:02:77:72
1.8.1.2
This is true, but the current documentation is poor. I like that Fabio adds a real example, providing a better understanding.
IMHO we should avoid to add a new file, if (as it is), this patch is only for i.MX6. Putting it in README.imx6 seems the best solution.
A reference is not bad, but of course documentation is changing. I was working with manual 04/2013, and there is not an example - only "empty example". Anyway, most people is searching exactly how to store in SOC the MAC address - not how to write another fuse. I think it is a good idea to add the MAC's example, because it is what most people are looking for.
I will add only a refererence, but I will let the example.
+1, as the example is only for i.MX6.
Best regards, Stefano Babic
Sounds good. Just sent v2 as suggested.
Regards,
Fabio Estevam
Benoît Thébaudeau
Fabio Estevam
Stefano Babic
