[U-Boot] [PATCH] Blackfin: restore EVT1 handling in linker script
Sadly, the Blackfin linker script unification lost a small #ifdef logic needed on older parts. Restore that CONFIG_BFIN_BOOTROM_USES_EVT1 logic.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/u-boot.lds.S | 9 ++++++++- 1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/lib_blackfin/u-boot.lds.S b/lib_blackfin/u-boot.lds.S index 4755153..3604b78 100644 --- a/lib_blackfin/u-boot.lds.S +++ b/lib_blackfin/u-boot.lds.S @@ -46,12 +46,19 @@ # define L1_DATA_B_SRAM_SIZE 0 #endif
+/* The 0xC offset is so we don't clobber the tiny LDR jump block. */ +#ifdef CONFIG_BFIN_BOOTROM_USES_EVT1 +# define L1_CODE_ORIGIN L1_INST_SRAM +#else +# define L1_CODE_ORIGIN L1_INST_SRAM + 0xC +#endif + OUTPUT_ARCH(bfin)
MEMORY { ram : ORIGIN = CONFIG_SYS_MONITOR_BASE, LENGTH = CONFIG_SYS_MONITOR_LEN - l1_code : ORIGIN = L1_INST_SRAM, LENGTH = L1_INST_SRAM_SIZE + l1_code : ORIGIN = L1_CODE_ORIGIN, LENGTH = L1_INST_SRAM_SIZE l1_data : ORIGIN = L1_DATA_B_SRAM, LENGTH = L1_DATA_B_SRAM_SIZE }
Mike Frysinger
