[U-Boot] [PATCH] board/armltd/integrator/split_by_variant.sh: fix 'echo -n'
This patch fixes an error when running MAKEALL for ARM9.
On OS X /bin/sh uses builtin echo which does not utilise '-n' switch. GNU manual for builtins recomend to use here-document style to solve this portability issue.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com CC: Peter Pearse peter.pearse@arm.com --- board/armltd/integrator/split_by_variant.sh | 139 +++++++++++++-------------- 1 files changed, 67 insertions(+), 72 deletions(-)
diff --git a/board/armltd/integrator/split_by_variant.sh b/board/armltd/integrator/split_by_variant.sh index 702b436..0713fd1 100755 --- a/board/armltd/integrator/split_by_variant.sh +++ b/board/armltd/integrator/split_by_variant.sh @@ -10,12 +10,12 @@ then # --------------------------------------------------------- # Set the platform defines # --------------------------------------------------------- -echo -n "/* Integrator configuration implied " > ${config_file} -echo " by Makefile target */" >> ${config_file} -echo -n "#define CONFIG_INTEGRATOR" >> ${config_file} -echo " /* Integrator board */" >> ${config_file} -echo -n "#define CONFIG_ARCH_INTEGRATOR" >> ${config_file} -echo " 1 /* Integrator/AP */" >> ${config_file} +cat > ${config_file} << _EOF +/* Integrator configuration implied by Makefile target */ +#define CONFIG_INTEGRATOR /* Integrator board */ +#define CONFIG_ARCH_INTEGRATOR 1 /* Integrator/AP */ +_EOF + # --------------------------------------------------------- # Set the core module defines according to Core Module # --------------------------------------------------------- @@ -50,37 +50,42 @@ else
ap720t_config) cpu="arm720t" - echo -n "#define CONFIG_CM720T" >> ${config_file} - echo " 1 /* CPU core is ARM720T */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM720T 1 /* CPU core is ARM720T */ +_EOF variant="Core module CM720T" ;;
ap922_XA10_config) cpu="arm_intcm" variant="unported core module CM922T_XA10" - echo -n "#define CONFIG_CM922T_XA10" >> ${config_file} - echo " 1 /* CPU core is ARM922T_XA10 */" >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM922T_XA10 1 /* CPU core is ARM922T_XA10 */ +_EOF ;;
ap920t_config) cpu="arm920t" variant="Core module CM920T" - echo -n "#define CONFIG_CM920T" >> ${config_file} - echo " 1 /* CPU core is ARM920T */" >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM920T 1 /* CPU core is ARM920T */ +_EOF ;;
ap926ejs_config) cpu="arm926ejs" variant="Core module CM926EJ-S" - echo -n "#define CONFIG_CM926EJ_S" >> ${config_file} - echo " 1 /* CPU core is ARM926EJ-S */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM926EJ_S 1 /* CPU core is ARM926EJ-S */ +_EOF ;;
ap946es_config) cpu="arm946es" variant="Core module CM946E-S" - echo -n "#define CONFIG_CM946E_S" >> ${config_file} - echo " 1 /* CPU core is ARM946E-S */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM946E_S 1 /* CPU core is ARM946E-S */ +_EOF ;;
*) @@ -94,33 +99,26 @@ fi
case "$cpu" in arm_intcm) - echo "/* Core module undefined/not ported */" >> ${config_file} - echo "#define CONFIG_ARM_INTCM 1" >> ${config_file} - echo -n "#undef CONFIG_CM_MULTIPLE_SSRAM" >> ${config_file} - echo -n " /* CM may not have " >> ${config_file} - echo "multiple SSRAM mapping */" >> ${config_file} - echo -n "#undef CONFIG_CM_SPD_DETECT " >> ${config_file} - echo -n " /* CM may not support SPD " >> ${config_file} - echo "query */" >> ${config_file} - echo -n "#undef CONFIG_CM_REMAP " >> ${config_file} - echo -n " /* CM may not support " >> ${config_file} - echo "remapping */" >> ${config_file} - echo -n "#undef CONFIG_CM_INIT " >> ${config_file} - echo -n " /* CM may not have " >> ${config_file} - echo "initialization reg */" >> ${config_file} - echo -n "#undef CONFIG_CM_TCRAM " >> ${config_file} - echo " /* CM may not have TCRAM */" >> ${config_file} - echo -n " /* May not be processor " >> ${config_file} - echo "without cache support */" >> ${config_file} - echo "#define CONFIG_SYS_NO_ICACHE 1" >> ${config_file} - echo "#define CONFIG_SYS_NO_DCACHE 1" >> ${config_file} + cat >> ${config_file} << _EOF +/* Core module undefined/not ported */ +#define CONFIG_ARM_INTCM 1 +#undef CONFIG_CM_MULTIPLE_SSRAM /* CM may not have multiple SSRAM mapping */ +#undef CONFIG_CM_SPD_DETECT /* CM may not support SPD query */ +#undef CONFIG_CM_REMAP /* CM may not support remapping */ +#undef CONFIG_CM_INIT /* CM may not have initialization reg */ +#undef CONFIG_CM_TCRAM /* CM may not have TCRAM */ +/* May not be processor without cache support */ +#define CONFIG_SYS_NO_ICACHE 1 +#define CONFIG_SYS_NO_DCACHE 1 +_EOF ;;
arm720t) - echo -n " /* May not be processor " >> ${config_file} - echo "without cache support */" >> ${config_file} - echo "#define CONFIG_SYS_NO_ICACHE 1" >> ${config_file} - echo "#define CONFIG_SYS_NO_DCACHE 1" >> ${config_file} + cat >> ${config_file} << _EOF +/* May not be processor without cache support */ +#define CONFIG_SYS_NO_ICACHE 1 +#define CONFIG_SYS_NO_DCACHE 1 +_EOF ;; esac
@@ -129,12 +127,11 @@ else # --------------------------------------------------------- # Set the platform defines # --------------------------------------------------------- -echo -n "/* Integrator configuration implied " > ${config_file} -echo " by Makefile target */" >> ${config_file} -echo -n "#define CONFIG_INTEGRATOR" >> ${config_file} -echo " /* Integrator board */" >> ${config_file} -echo -n "#define CONFIG_ARCH_CINTEGRATOR" >> ${config_file} -echo " 1 /* Integrator/CP */" >> ${config_file} +cat >> ${config_file} << _EOF +/* Integrator configuration implied by Makefile target */ +#define CONFIG_INTEGRATOR /* Integrator board */ +#define CONFIG_ARCH_CINTEGRATOR 1 /* Integrator/CP */ +_EOF
cpu="arm_intcm" variant="unknown core module" @@ -163,37 +160,42 @@ else cp922_XA10_config) cpu="arm_intcm" variant="unported core module CM922T_XA10" - echo -n "#define CONFIG_CM922T_XA10" >> ${config_file} - echo " 1 /* CPU core is ARM922T_XA10 */" >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM922T_XA10 1 /* CPU core is ARM922T_XA10 */ +_EOF ;;
cp920t_config) cpu="arm920t" variant="Core module CM920T" - echo -n "#define CONFIG_CM920T" >> ${config_file} - echo " 1 /* CPU core is ARM920T */" >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM920T 1 /* CPU core is ARM920T */ +_EOF ;;
cp926ejs_config) cpu="arm926ejs" variant="Core module CM926EJ-S" - echo -n "#define CONFIG_CM926EJ_S" >> ${config_file} - echo " 1 /* CPU core is ARM926EJ-S */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM926EJ_S 1 /* CPU core is ARM926EJ-S */ +_EOF ;;
cp946es_config) cpu="arm946es" variant="Core module CM946E-S" - echo -n "#define CONFIG_CM946E_S" >> ${config_file} - echo " 1 /* CPU core is ARM946E-S */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM946E_S 1 /* CPU core is ARM946E-S */ +_EOF ;;
cp1136_config) cpu="arm1136" variant="Core module CM1136EJF-S" - echo -n "#define CONFIG_CM1136EJF_S" >> ${config_file} - echo " 1 /* CPU core is ARM1136JF-S */ " >> ${config_file} + cat >> ${config_file} << _EOF +#define CONFIG_CM1136EJF_S 1 /* CPU core is ARM1136JF-S */ +_EOF ;;
*) @@ -208,22 +210,15 @@ fi
if [ "$cpu" = "arm_intcm" ] then - echo "/* Core module undefined/not ported */" >> ${config_file} - echo "#define CONFIG_ARM_INTCM 1" >> ${config_file} - echo -n "#undef CONFIG_CM_MULTIPLE_SSRAM" >> ${config_file} - echo -n " /* CM may not have " >> ${config_file} - echo "multiple SSRAM mapping */" >> ${config_file} - echo -n "#undef CONFIG_CM_SPD_DETECT " >> ${config_file} - echo -n " /* CM may not support SPD " >> ${config_file} - echo "query */" >> ${config_file} - echo -n "#undef CONFIG_CM_REMAP " >> ${config_file} - echo -n " /* CM may not support " >> ${config_file} - echo "remapping */" >> ${config_file} - echo -n "#undef CONFIG_CM_INIT " >> ${config_file} - echo -n " /* CM may not have " >> ${config_file} - echo "initialization reg */" >> ${config_file} - echo -n "#undef CONFIG_CM_TCRAM " >> ${config_file} - echo " /* CM may not have TCRAM */" >> ${config_file} + cat >> ${config_file} << _EOF +/* Core module undefined/not ported */ +#define CONFIG_ARM_INTCM 1 +#undef CONFIG_CM_MULTIPLE_SSRAM /* CM may not have multiple SSRAM mapping */ +#undef CONFIG_CM_SPD_DETECT /* CM may not support SPD query */ +#undef CONFIG_CM_REMAP /* CM may not support remapping */ +#undef CONFIG_CM_INIT /* CM may not have initialization reg */ +#undef CONFIG_CM_TCRAM /* CM may not have TCRAM */ +_EOF fi
fi # ap
- cat >> ${config_file} << _EOF
changing multiline echos to a cat makes sense, but using cat for a single line is overkill. a simple `echo "..."` is better. -mike
This patch removes the usage of 'echo -n' and replace by here-document style or a oneline echo command.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com CC: Peter Pearse peter.pearse@arm.com --- v1: first try, replace each occurrence of 'echo' by here-document v2: replace oneliners by single 'echo' as sugested by Mike
board/armltd/integrator/split_by_variant.sh | 129 ++++++++++++--------------- 1 files changed, 57 insertions(+), 72 deletions(-)
diff --git a/board/armltd/integrator/split_by_variant.sh b/board/armltd/integrator/split_by_variant.sh index 702b436..d869dd2 100755 --- a/board/armltd/integrator/split_by_variant.sh +++ b/board/armltd/integrator/split_by_variant.sh @@ -10,12 +10,12 @@ then # --------------------------------------------------------- # Set the platform defines # --------------------------------------------------------- -echo -n "/* Integrator configuration implied " > ${config_file} -echo " by Makefile target */" >> ${config_file} -echo -n "#define CONFIG_INTEGRATOR" >> ${config_file} -echo " /* Integrator board */" >> ${config_file} -echo -n "#define CONFIG_ARCH_INTEGRATOR" >> ${config_file} -echo " 1 /* Integrator/AP */" >> ${config_file} +cat > ${config_file} << _EOF +/* Integrator configuration implied by Makefile target */ +#define CONFIG_INTEGRATOR /* Integrator board */ +#define CONFIG_ARCH_INTEGRATOR 1 /* Integrator/AP */ +_EOF + # --------------------------------------------------------- # Set the core module defines according to Core Module # --------------------------------------------------------- @@ -50,37 +50,37 @@ else
ap720t_config) cpu="arm720t" - echo -n "#define CONFIG_CM720T" >> ${config_file} - echo " 1 /* CPU core is ARM720T */ " >> ${config_file} + echo "#define CONFIG_CM720T 1 /* CPU core is ARM720T */" \ + >> ${config_file} variant="Core module CM720T" ;;
ap922_XA10_config) cpu="arm_intcm" variant="unported core module CM922T_XA10" - echo -n "#define CONFIG_CM922T_XA10" >> ${config_file} - echo " 1 /* CPU core is ARM922T_XA10 */" >> ${config_file} + echo "#define CONFIG_CM922T_XA10 1 /* CPU core is ARM922T_XA10 */" \ + >> ${config_file} ;;
ap920t_config) cpu="arm920t" variant="Core module CM920T" - echo -n "#define CONFIG_CM920T" >> ${config_file} - echo " 1 /* CPU core is ARM920T */" >> ${config_file} + echo "#define CONFIG_CM920T 1 /* CPU core is ARM920T */" \ + >> ${config_file} ;;
ap926ejs_config) cpu="arm926ejs" variant="Core module CM926EJ-S" - echo -n "#define CONFIG_CM926EJ_S" >> ${config_file} - echo " 1 /* CPU core is ARM926EJ-S */ " >> ${config_file} + echo "#define CONFIG_CM926EJ_S 1 /* CPU core is ARM926EJ-S */" \ + >> ${config_file} ;;
ap946es_config) cpu="arm946es" variant="Core module CM946E-S" - echo -n "#define CONFIG_CM946E_S" >> ${config_file} - echo " 1 /* CPU core is ARM946E-S */ " >> ${config_file} + echo "#define CONFIG_CM946E_S 1 /* CPU core is ARM946E-S */" \ + >> ${config_file} ;;
*) @@ -94,33 +94,26 @@ fi
@@ -129,12 +122,11 @@ else # --------------------------------------------------------- # Set the platform defines # --------------------------------------------------------- -echo -n "/* Integrator configuration implied " > ${config_file} -echo " by Makefile target */" >> ${config_file} -echo -n "#define CONFIG_INTEGRATOR" >> ${config_file} -echo " /* Integrator board */" >> ${config_file} -echo -n "#define CONFIG_ARCH_CINTEGRATOR" >> ${config_file} -echo " 1 /* Integrator/CP */" >> ${config_file} +cat >> ${config_file} << _EOF +/* Integrator configuration implied by Makefile target */ +#define CONFIG_INTEGRATOR /* Integrator board */ +#define CONFIG_ARCH_CINTEGRATOR 1 /* Integrator/CP */ +_EOF
cpu="arm_intcm" variant="unknown core module" @@ -163,37 +155,37 @@ else cp922_XA10_config) cpu="arm_intcm" variant="unported core module CM922T_XA10" - echo -n "#define CONFIG_CM922T_XA10" >> ${config_file} - echo " 1 /* CPU core is ARM922T_XA10 */" >> ${config_file} + echo "#define CONFIG_CM922T_XA10 1 /* CPU core is ARM922T_XA10 */" \ + >> ${config_file} ;;
cp920t_config) cpu="arm920t" variant="Core module CM920T" - echo -n "#define CONFIG_CM920T" >> ${config_file} - echo " 1 /* CPU core is ARM920T */" >> ${config_file} + echo "#define CONFIG_CM920T 1 /* CPU core is ARM920T */" \ + >> ${config_file} ;;
cp926ejs_config) cpu="arm926ejs" variant="Core module CM926EJ-S" - echo -n "#define CONFIG_CM926EJ_S" >> ${config_file} - echo " 1 /* CPU core is ARM926EJ-S */ " >> ${config_file} + echo "#define CONFIG_CM926EJ_S 1 /* CPU core is ARM926EJ-S */" \ + >> ${config_file} ;;
cp946es_config) cpu="arm946es" variant="Core module CM946E-S" - echo -n "#define CONFIG_CM946E_S" >> ${config_file} - echo " 1 /* CPU core is ARM946E-S */ " >> ${config_file} + echo "#define CONFIG_CM946E_S 1 /* CPU core is ARM946E-S */" \ + >> ${config_file} ;;
cp1136_config) cpu="arm1136" variant="Core module CM1136EJF-S" - echo -n "#define CONFIG_CM1136EJF_S" >> ${config_file} - echo " 1 /* CPU core is ARM1136JF-S */ " >> ${config_file} + echo "#define CONFIG_CM1136EJF_S 1 /* CPU core is ARM1136JF-S */" \ + >> ${config_file} ;;
*) @@ -208,22 +200,15 @@ fi
fi # ap
Dear =?UTF-8?q?Andreas=20Bie=C3=9Fmann?=,
In message 1285356041-95443-1-git-send-email-andreas.devel@googlemail.com you wrote:
Applied to u-boot-arm, thanks.
Andreas Bießmann
Mike Frysinger
