[PATCH] cmd: sf: Support unaligned flash updates with 'sf update'
Currently 'sf update' supports only offsets that are aligned to the erase block size of the serial flash. Unaligned offsets result in something like:
=> sf update ${kernel_addr_r} 0x400 ${filesize} device 0 offset 0x400, size 0x11f758 SPI flash failed in erase step
In order to support unaligned updates, we simply read the first full block and check only the requested part of the block for changes. If necessary, the block is erased, the first (unchanged) part of the block is written back together with the second part of the block (updated data).
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- cmd/sf.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/cmd/sf.c b/cmd/sf.c index eac27ed2d7..c54b4b10bb 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -171,30 +171,32 @@ static int do_spi_flash_probe(int argc, char *const argv[]) static const char *spi_flash_update_block(struct spi_flash *flash, u32 offset, size_t len, const char *buf, char *cmp_buf, size_t *skipped) { + u32 offset_aligned = ALIGN_DOWN(offset, flash->sector_size); + u32 sector_offset = offset - offset_aligned; char *ptr = (char *)buf;
debug("offset=%#x, sector_size=%#x, len=%#zx\n", offset, flash->sector_size, len); /* Read the entire sector so to allow for rewriting */ - if (spi_flash_read(flash, offset, flash->sector_size, cmp_buf)) + if (spi_flash_read(flash, offset_aligned, flash->sector_size, cmp_buf)) return "read"; /* Compare only what is meaningful (len) */ - if (memcmp(cmp_buf, buf, len) == 0) { + if (memcmp(cmp_buf + sector_offset, buf, len) == 0) { debug("Skip region %x size %zx: no change\n", offset, len); *skipped += len; return NULL; } /* Erase the entire sector */ - if (spi_flash_erase(flash, offset, flash->sector_size)) + if (spi_flash_erase(flash, offset_aligned, flash->sector_size)) return "erase"; /* If it's a partial sector, copy the data into the temp-buffer */ if (len != flash->sector_size) { - memcpy(cmp_buf, buf, len); + memcpy(cmp_buf + sector_offset, buf, len); ptr = cmp_buf; } /* Write one complete sector */ - if (spi_flash_write(flash, offset, flash->sector_size, ptr)) + if (spi_flash_write(flash, offset_aligned, flash->sector_size, ptr)) return "write";
return NULL; @@ -230,7 +232,10 @@ static int spi_flash_update(struct spi_flash *flash, u32 offset, ulong last_update = get_timer(0);
for (; buf < end && !err_oper; buf += todo, offset += todo) { - todo = min_t(size_t, end - buf, flash->sector_size); + if (offset % flash->sector_size) + todo = flash->sector_size - (offset % flash->sector_size); + else + todo = min_t(size_t, end - buf, flash->sector_size); if (get_timer(last_update) > 100) { printf(" \rUpdating, %zu%% %lu B/s", 100 - (end - buf) / scale,
Am 2021-09-30 18:19, schrieb Frieder Schrempf:
I'm not sure what I should think of this. You might loose that unchanged part if there is an power loss in the middle, even worse, you likely don't have this part anymore because it isn't part of the data you want to write to the flash.
Maybe add an parameter for allow (unsafe) unaligned updates?
Now you might argue, that with "sf erase, sf write" you can do the same harm, to which i reply: but then it is intentional ;) Because "sf erase" just works on sector boundaries (which isn't really checked in the command, i just realized, but at least my driver returns EINVAL) and then the user has to include the "unchanged part" for the arguments on the commandline.
-michael
True, but "sf update" already is "unsafe" even without supporting unaligned start offsets. The code already handles partial sector writes for the last sector in the same way (read, erase, write), which is also prone to data loss in case of power loss.
So this patch in fact just adds support for partial sector updates for the first sector. It is slightly more probable to loose data, but it doesn't introduce new "unsafe" behavior.
Maybe we could cover this by adding a warning to the documentation, or even printing a warning?
Am 2021-09-30 19:17, schrieb Frieder Schrempf:
Ah, I missed that. Yes, in this case, we don't loose anything. Agreed.
Heh, although I was using "sf update" all the time, I wasn't aware of the read - "partly modify" - write cycle. Maybe it's just me being over cautious.
Printing a warning might scare users, though. I'd prefer to fix the online help, where only "erase and write" is mentioned.
-michael
Which document are you referring to? I don't really see the "sf" command documented anywhere.
Am 2021-10-04 12:31, schrieb Frieder Schrempf:
the "sf update" online help:
"sf update addr offset|partition len - erase and write `len' bytes from memory\n" " at `addr' to flash at `offset'\n" " or to start of mtd `partition'\n"
-michael
- if (spi_flash_read(flash, offset_aligned, flash->sector_size,
- if (memcmp(cmp_buf + sector_offset, buf, len) == 0) { debug("Skip region %x size %zx: no change\n", offset, len); *skipped += len; return NULL; } /* Erase the entire sector */
- if (spi_flash_erase(flash, offset_aligned, flash->sector_size)) return "erase"; /* If it's a partial sector, copy the data into the temp-buffer */ if (len != flash->sector_size) {
ptr = cmp_buf; } /* Write one complete sector */memcpy(cmp_buf + sector_offset, buf, len);
return NULL;
do_div() to avoid linking errors on some archs, I guess.
This is missing the end-buf calculation, no? I.e. if you update just one sector at an offset and the data you write is smaller than "sector_size - offset".
else
-michael
Ok, will fix it.
- offset".
Indeed, thanks for catching this.
-michael
Hi Frieder,
<insert motivation for patch here>
Frieder Schrempf
Frieder Schrempf
Michael Walle
