[PATCH v1] arm: dts: meson-axg: add NAND controller node for AXG
nfc: Synced from Linux commit 7ca2ef33179f ("Linux 6.6-rc1") nand_all_pins: Synced from Linux commit be18d53c32b2 ("Linux 6.7-rc3")
Signed-off-by: Arseniy Krasnov avkrasnov@salutedevices.com --- arch/arm/dts/meson-axg.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index 3f5254eeb4..4f6fdd5523 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -430,6 +430,27 @@ }; };
+ nand_all_pins: nand_all_pins { + mux { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "nand_ce0", + "nand_ale", + "nand_cle", + "nand_wen_clk", + "nand_ren_wr"; + function = "nand"; + input-enable; + bias-pull-up; + }; + }; + emmc_ds_pins: emmc_ds { mux { groups = "emmc_ds"; @@ -1906,6 +1927,21 @@ resets = <&reset RESET_SD_EMMC_C>; };
+ nfc: nand-controller@7800 { + compatible = "amlogic,meson-axg-nfc"; + reg = <0x0 0x7800 0x0 0x100>, + <0x0 0x7000 0x0 0x800>; + reg-names = "nfc", "emmc"; + pinctrl-0 = <&nand_all_pins>; + pinctrl-names = "default"; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 34 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "device"; + }; + usb2_phy1: phy@9020 { compatible = "amlogic,meson-gxl-usb2-phy"; #phy-cells = <0>;
No need to sync DT anymore, this is handled by OF_UPSTREAM and for next release it's already aligned with v6.9 DT.
Please try your patches with master or next branch of U-Boot repo.
Neil
mux {
"emmc_nand_d1",
"emmc_nand_d2",
"emmc_nand_d3",
"emmc_nand_d4",
"emmc_nand_d5",
"emmc_nand_d6",
"emmc_nand_d7",
"nand_ce0",
"nand_ale",
"nand_cle",
"nand_wen_clk",
"nand_ren_wr";
function = "nand";
input-enable;
bias-pull-up;
#size-cells = <0>;
Ok, so I can remove "Synced from" from commit description, thus make it empty, and test that patch applies correctly on uboot master/ next ?
Thanks
Neil
diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index 3f5254eeb4..4f6fdd5523 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -430,6 +430,27 @@ }; }; + nand_all_pins: nand_all_pins { + mux { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "nand_ce0", + "nand_ale", + "nand_cle", + "nand_wen_clk", + "nand_ren_wr"; + function = "nand"; + input-enable; + bias-pull-up; + }; + };
emmc_ds_pins: emmc_ds { mux { groups = "emmc_ds"; @@ -1906,6 +1927,21 @@ resets = <&reset RESET_SD_EMMC_C>; }; + nfc: nand-controller@7800 { + compatible = "amlogic,meson-axg-nfc"; + reg = <0x0 0x7800 0x0 0x100>, + <0x0 0x7000 0x0 0x800>; + reg-names = "nfc", "emmc"; + pinctrl-0 = <&nand_all_pins>; + pinctrl-names = "default"; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 34 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "device"; + };
It won't apply because arch/arm/dts/meson-axg.dtsi doesn't exist anymore, DT comes from dts/upstream, however if you need to add u-boot specific changes you can still update arch/arm/dts/meson-axgi-u-boot.dtsi
Neil
Thanks
Neil
Ahh ok, I see. Thanks. This patch must be dropped, as same code is already in uboot in dts/upstream
Thanks
Neil
Thanks
Neil
Arseniy Krasnov
Neil Armstrong
