[U-Boot-Users] (no subject)
Hello!
i'm starting to use u-boot for the first time. But i encounter a lot of dificulties. Is there someone who can help me?. please
The first problem is that i can't find my evaluation board in config files. how i can build u-boot withou this file? my board is a Memec Virtex II Pro, xc2vp20-ff1152.
Need i to write my board configuration?
what memery is needeed to uboot? i want to put it in flash memory. i want to load linux via Ethernet and write into Flash memory, how i do it?
Thanks to give me some explanations, because english is not my language, and it is very difficult to find documentations in french.
John!
I see. It seems your first problem is that you don't understand how to enter a subject in the mailer?
If ther eis no config file, then there is probably no port yet. In this case you will have to port U-Boot.
Yes, and all the rest which is necesary to complete a port.
memery = memory? U-Boot needs some ROM (flash is fine) and RAM to run.
Read the manual and the FAQ.
We will try to help independent of your language skills. However, you _are_ supposed to read the documentation (README, manual, FAQ). And before posting.
Bruce
