[U-Boot] [PATCH v6 0/7] cmd: add efidebug for efi environment
This patch set is a collection of patches to enhance efi user interfaces /commands. It will help improve user experience on efi boot and make it more usable *without* edk2's shell utility.
Let's see how it works: => efidebug boot add 1 SHELL scsi 1:1 /Shell.efi "" => efidebug boot add 2 HELLO scsi 1:1 /hello.efi "" => efidebug boot dump Boot0001: attributes: A-- (0x00000001) label: SHELL file_path: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(1,MBR,0x086246ba,0x800,0x40000)/\Shell.efi data: Boot0002: attributes: A-- (0x00000001) label: HELLO file_path: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(1,MBR,0x086246ba,0x800,0x40000)/\hello.efi data:
=> efidebug boot order 1 2 => efidebug boot order 1: Boot0001: SHELL 2: Boot0002: HELLO
=> run -e Boot0002 (or bootefi bootmgr - 2) ; '-' means no dtb specified WARNING: booting without device tree Booting: HELLO ## Starting EFI application at 000000007db8b040 ... Hello, world! ## Application terminated, r = 0
=> env set -e PlatformLang en ; important! => env print -e Boot0001: BS|RT, DataSize = 0x79 00000000: 01 00 00 00 66 00 53 00 48 00 45 00 4c 00 4c 00 ....f.S.H.E.L.L. 00000010: 00 00 01 04 14 00 b9 73 1d e6 84 a3 cc 4a ae ab .......s.....J.. 00000020: 82 e8 28 f3 62 8b 03 02 08 00 01 00 00 00 04 01 ..(.b........... 00000030: 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 *............... 00000040: 04 00 00 00 00 00 ba 46 62 08 00 00 00 00 00 00 .......Fb....... 00000050: 00 00 00 00 00 00 01 01 04 04 1c 00 5c 00 5c 00 .............. 00000060: 53 00 68 00 65 00 6c 00 6c 00 2e 00 65 00 66 00 S.h.e.l.l...e.f. 00000070: 69 00 00 00 7f ff 04 00 00 i........ Boot0002: BS|RT, DataSize = 0x79 00000000: 01 00 00 00 66 00 48 00 45 00 4c 00 4c 00 4f 00 ....f.H.E.L.L.O. 00000010: 00 00 01 04 14 00 b9 73 1d e6 84 a3 cc 4a ae ab .......s.....J.. 00000020: 82 e8 28 f3 62 8b 03 02 08 00 01 00 00 00 04 01 ..(.b........... 00000030: 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 *............... 00000040: 04 00 00 00 00 00 ba 46 62 08 00 00 00 00 00 00 .......Fb....... 00000050: 00 00 00 00 00 00 01 01 04 04 1c 00 5c 00 5c 00 .............. 00000060: 68 00 65 00 6c 00 6c 00 6f 00 2e 00 65 00 66 00 h.e.l.l.o...e.f. 00000070: 69 00 00 00 7f ff 04 00 00 i........ BootOrder: BS|RT, DataSize = 0x4 00000000: 01 00 02 00 .... PlatformLang: BS|RT, DataSize = 0x2 00000000: 65 6e en
=> run -e Boot0001 or bootefi bootmgr
(UEFI shell ...)
"env set" command now supports UEFI shell-like syntax:
=> env set -e foo =S"akashi" =0x012345 =Habcdef => env print -e foo foo: BS|RT, DataSize = 0xd 00000000: 61 6b 61 73 68 69 45 23 01 00 ab cd ef akashiE#.....
Other useful sub commands are: => efidebug devices ; print uefi devices => efidebug drivers ; print uefi drivers => efidebug dh ; print uefi handles => efidebug images ; print loaded images => efidebug memmap ; dump uefi memory map
Enjoy! -Takahiro Akashi
Changes in v6 (Jan 24, 2019) * re-organize the code so that we can compile in "env [set|print] -e" support with or without CONFIG_CMD_EFIDEBUG * remove "efidebug setvar" and "efidebug dumpvar" sub-commands * re-implement "env print -e" using GetNextVariableName API and print_hex_dump() * "env print -e" print more information, including attributes and size * change a header format at "devices" and "drivers" sub-commands
Changes in v5 (Jan 21, 2019) * rename the command name from efitool to efidebug again * add it to MAINTAINERS * follow a standard way of adding sub commands * allow "env -e" syntax without enabling CONFIG_CMD_EFIDEBUG (merging v4's patch#8 into patch#1) * change "_"-prefixed function names * change some internal variables' names * not print an efi driver's name at "efidebug drivers", yet showing a device path * change protocol name strings from char to u16 at "efidebug dh" * add a helper function to print efi memory attributes at "efidebug memmap"
Changes in v4 (Jan 15, 2019) * rename the command name from efishell to efitool * use efi_uintn_t for "size" if appropriate * correct a help text for "boot add" sub-command * "boot" sub-command always takes a hexadecimal number * use systab.boottime directly instead of a local variable, bs * fix a bug in "setvar" sub-command * fix a bug in "devices" and "dh" sub-command * fix a bug in "memmap" sub-command * add "boot next" sub-command to set BootNext variable * "drivers" sub-command prints more useful info, including a driver's name which originates from a corresponding u-boot efi driver * "dh" sub-commands prints more useful info, including a list of protocols which are bound to a given handle
Changes in v3 (Dec 18, 2018) * split v2 into two separate patch series * add CONFIG_CMD_EFISHELL to enable/disable efishell command * add missing free() at several places in efishell command
Changes in v2 (Nov 5, 2018) * modify efi_dp_from_name() for use in efishell * rename efi_marshal_load_option() to efi_serialize_load_option(), taking a "struct efi_load_option" as an argument * improve a format in dumping uefi variables * enhance a setvar syntax as efi's shell does * change a syntax from "bootefi bootmgr -2" to "bootefi bootmgr - 2" * add -e option to run command * add -e option to env command * add more sub-commands
AKASHI Takahiro (7): cmd: env: add "-e" option for handling UEFI variables cmd: add efidebug command cmd: efidebug: add devices command cmd: efidebug: add drivers command cmd: efidebug: add dh command cmd: efidebug: add images command cmd: efidebug: add memmap command
MAINTAINERS | 2 + cmd/Kconfig | 16 + cmd/Makefile | 2 + cmd/efidebug.c | 869 ++++++++++++++++++++++++++++++++++++++++++++++ cmd/nvedit.c | 28 +- cmd/nvedit_efi.c | 319 +++++++++++++++++ include/command.h | 4 + 7 files changed, 1239 insertions(+), 1 deletion(-) create mode 100644 cmd/efidebug.c create mode 100644 cmd/nvedit_efi.c
"env [print|set] -e" allows for handling uefi variables without knowing details about mapping to corresponding u-boot variables.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- MAINTAINERS | 1 + cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/nvedit.c | 28 +++- cmd/nvedit_efi.c | 319 ++++++++++++++++++++++++++++++++++++++++++++++ include/command.h | 4 + 6 files changed, 358 insertions(+), 1 deletion(-) create mode 100644 cmd/nvedit_efi.c
diff --git a/MAINTAINERS b/MAINTAINERS index ae825014bda9..22ac686ab2d6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -438,6 +438,7 @@ F: lib/efi*/ F: test/py/tests/test_efi* F: test/unicode_ut.c F: cmd/bootefi.c +F: cmd/nvedit_efi.c F: tools/file2include.c
FPGA diff --git a/cmd/Kconfig b/cmd/Kconfig index ea1a325eb301..812a7eb9b74b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -53,6 +53,12 @@ config SYS_PROMPT This string is displayed in the command line to the left of the cursor.
+config CMD_NVEDIT_EFI + bool + depends on EFI_LOADER + default y if EFI_LOADER + imply HEXDUMP + menu "Autoboot options"
config AUTOBOOT diff --git a/cmd/Makefile b/cmd/Makefile index 15ae4d250f50..142e0ee222ca 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -98,6 +98,7 @@ obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o obj-$(CONFIG_CMD_NAND) += nand.o obj-$(CONFIG_CMD_NET) += net.o +obj-$(CONFIG_CMD_NVEDIT_EFI) += nvedit_efi.o obj-$(CONFIG_CMD_ONENAND) += onenand.o obj-$(CONFIG_CMD_OSD) += osd.o obj-$(CONFIG_CMD_PART) += part.o diff --git a/cmd/nvedit.c b/cmd/nvedit.c index ce746bbf1b3e..7973d7add5fc 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -119,6 +119,11 @@ static int do_env_print(cmd_tbl_t *cmdtp, int flag, int argc, int rcode = 0; int env_flag = H_HIDE_DOT;
+#if defined(CONFIG_CMD_NVEDIT_EFI) + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e') + return do_env_print_efi(cmdtp, flag, --argc, ++argv); +#endif + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'a') { argc--; argv++; @@ -216,6 +221,12 @@ static int _do_env_set(int flag, int argc, char * const argv[], int env_flag) ENTRY e, *ep;
debug("Initial value for argc=%d\n", argc); + +#if defined(CONFIG_CMD_NVEDIT_EFI) + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e') + return do_env_set_efi(NULL, flag, --argc, ++argv); +#endif + while (argc > 1 && **(argv + 1) == '-') { char *arg = *++argv;
@@ -1263,14 +1274,21 @@ static char env_help_text[] = "env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment\n" #endif "env print [-a | name ...] - print environment\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "env print -e [name ...] - print UEFI environment\n" +#endif #if defined(CONFIG_CMD_RUN) "env run var [...] - run commands in an environment variable\n" #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" #endif +#if defined(CONFIG_CMD_NVEDIT_EFI) + "env set [-e | -f] name [arg ...]\n"; +#else "env set [-f] name [arg ...]\n"; #endif +#endif
U_BOOT_CMD( env, CONFIG_SYS_MAXARGS, 1, do_env, @@ -1295,6 +1313,10 @@ U_BOOT_CMD_COMPLETE( printenv, CONFIG_SYS_MAXARGS, 1, do_env_print, "print environment variables", "[-a]\n - print [all] values of all environment variables\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "printenv -e [<name> ...]\n" + " - print UEFI variable 'name' or all the variables\n" +#endif "printenv name ...\n" " - print value of environment variable 'name'", var_complete @@ -1322,7 +1344,11 @@ U_BOOT_CMD_COMPLETE( U_BOOT_CMD_COMPLETE( setenv, CONFIG_SYS_MAXARGS, 0, do_env_set, "set environment variables", - "[-f] name value ...\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "-e <name> [<value> ...]\n" + " - set UEFI variable 'name' to 'value' ...'\n" +#endif + "setenv [-f] name value ...\n" " - [forcibly] set environment variable 'name' to 'value ...'\n" "setenv [-f] name\n" " - [forcibly] delete environment variable 'name'", diff --git a/cmd/nvedit_efi.c b/cmd/nvedit_efi.c new file mode 100644 index 000000000000..58c92009e8db --- /dev/null +++ b/cmd/nvedit_efi.c @@ -0,0 +1,319 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Integrate UEFI variables to u-boot env interface + * + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#include <charset.h> +#include <common.h> +#include <command.h> +#include <efi_loader.h> +#include <exports.h> +#include <hexdump.h> +#include <malloc.h> +#include <linux/kernel.h> + +static const struct { + u32 mask; + char *text; +} efi_var_attrs[] = { + {EFI_VARIABLE_NON_VOLATILE, "NV"}, + {EFI_VARIABLE_BOOTSERVICE_ACCESS, "BS"}, + {EFI_VARIABLE_RUNTIME_ACCESS, "RT"}, + {EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS, "AW"}, + {EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS, "AT"}, +}; + +static int print_variable_info(u16 *name, efi_guid_t *guid) +{ + u32 attributes; + u8 *data; + efi_uintn_t size; + int count, i; + efi_status_t ret; + + data = NULL; + size = 0; + ret = efi_get_variable(name, guid, &attributes, &size, data); + if (ret == EFI_BUFFER_TOO_SMALL) { + data = malloc(size); + if (!data) + return -1; + + ret = efi_get_variable(name, guid, &attributes, &size, data); + } + if (ret == EFI_NOT_FOUND) { + printf("Error: "%ls" not defined\n", name); + goto out; + } + if (ret != EFI_SUCCESS) + goto out; + + printf("%ls:", name); + for (count = 0, i = 0; i < ARRAY_SIZE(efi_var_attrs); i++) + if (attributes & efi_var_attrs[i].mask) { + if (count) + putc('|'); + else + putc(' '); + count++; + puts(efi_var_attrs[i].text); + } + printf(", DataSize = 0x%lx\n", size); + print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, data, size, true); + + return 0; +out: + free(data); + return -1; +} + +/* + * From efi_variable.c, + * + * Mapping between UEFI variables and u-boot variables: + * + * efi_$guid_$varname = {attributes}(type)value + */ +static int efi_dump_var(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + u16 *var_name16, *p; + efi_uintn_t buf_size, size; + efi_guid_t guid; + efi_status_t ret; + + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) + return CMD_RET_FAILURE; + + if (argc > 1) { + argc--; + argv++; + + for (; argc > 0; argc--, argv++) { + size = (strlen(argv[0]) + 1) * 2; + if (buf_size < size) { + buf_size = size; + p = realloc(var_name16, buf_size); + if (!p) { + free(var_name16); + return CMD_RET_FAILURE; + } + var_name16 = p; + } + + p = var_name16; + utf8_utf16_strcpy(&p, argv[0]); + guid = efi_global_variable_guid; + + print_variable_info(var_name16, &guid); + } + + free(var_name16); + + return CMD_RET_SUCCESS; + } + + var_name16[0] = 0; + for (;;) { + size = buf_size; + ret = efi_get_next_variable_name(&size, var_name16, &guid); + if (ret == EFI_NOT_FOUND) + break; + if (ret == EFI_BUFFER_TOO_SMALL) { + buf_size = size; + p = realloc(var_name16, buf_size); + if (!p) { + free(var_name16); + return CMD_RET_FAILURE; + } + var_name16 = p; + ret = efi_get_next_variable_name(&size, var_name16, + &guid); + } + if (ret != EFI_SUCCESS) { + free(var_name16); + return CMD_RET_FAILURE; + } + + print_variable_info(var_name16, &guid); + } + + free(var_name16); + + return CMD_RET_SUCCESS; +} + +int do_env_print_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + efi_status_t r; + + /* Initialize EFI drivers */ + r = efi_init_obj_list(); + if (r != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + r & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + return efi_dump_var(cmdtp, flag, argc, argv); +} + +static int append_value(char **bufp, unsigned long *sizep, char *data) +{ + char *tmp_buf = NULL, *new_buf = NULL, *value; + unsigned long len = 0; + + if (!strncmp(data, "=0x", 2)) { /* hexadecimal number */ + union { + u8 u8; + u16 u16; + u32 u32; + u64 u64; + } tmp_data; + unsigned long hex_value; + void *hex_ptr; + + data += 3; + len = strlen(data); + if ((len & 0x1)) /* not multiple of two */ + return -1; + + len /= 2; + if (len > 8) + return -1; + else if (len > 4) + len = 8; + else if (len > 2) + len = 4; + + /* convert hex hexadecimal number */ + if (strict_strtoul(data, 16, &hex_value) < 0) + return -1; + + tmp_buf = malloc(len); + if (!tmp_buf) + return -1; + + if (len == 1) { + tmp_data.u8 = hex_value; + hex_ptr = &tmp_data.u8; + } else if (len == 2) { + tmp_data.u16 = hex_value; + hex_ptr = &tmp_data.u16; + } else if (len == 4) { + tmp_data.u32 = hex_value; + hex_ptr = &tmp_data.u32; + } else { + tmp_data.u64 = hex_value; + hex_ptr = &tmp_data.u64; + } + memcpy(tmp_buf, hex_ptr, len); + value = tmp_buf; + + } else if (!strncmp(data, "=H", 2)) { /* hexadecimal-byte array */ + data += 2; + len = strlen(data); + if (len & 0x1) /* not multiple of two */ + return -1; + + len /= 2; + tmp_buf = malloc(len); + if (!tmp_buf) + return -1; + + if (hex2bin((u8 *)tmp_buf, data, len) < 0) + return -1; + + value = tmp_buf; + } else { /* string */ + if (!strncmp(data, "="", 2) || !strncmp(data, "=S"", 3)) { + if (data[1] == '"') + data += 2; + else + data += 3; + value = data; + len = strlen(data) - 1; + if (data[len] != '"') + return -1; + } else { + value = data; + len = strlen(data); + } + } + + new_buf = realloc(*bufp, *sizep + len); + if (!new_buf) + goto out; + + memcpy(new_buf + *sizep, value, len); + *bufp = new_buf; + *sizep += len; + +out: + free(tmp_buf); + + return 0; +} + +static int efi_set_var(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + char *var_name, *value = NULL; + efi_uintn_t size = 0; + u16 *var_name16 = NULL, *p; + efi_guid_t guid; + efi_status_t ret; + + if (argc == 1) + return CMD_RET_SUCCESS; + + var_name = argv[1]; + if (argc == 2) { + /* remove */ + value = NULL; + size = 0; + } else { /* set */ + argc -= 2; + argv += 2; + + for ( ; argc > 0; argc--, argv++) + if (append_value(&value, &size, argv[0]) < 0) { + ret = CMD_RET_FAILURE; + goto out; + } + } + + var_name16 = malloc((strlen(var_name) + 1) * 2); + p = var_name16; + utf8_utf16_strncpy(&p, var_name, strlen(var_name) + 1); + + guid = efi_global_variable_guid; + ret = efi_set_variable(var_name16, &guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, size, value); + ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); +out: + free(value); + free(var_name16); + + return ret; +} + +int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + efi_status_t r; + + /* Initialize EFI drivers */ + r = efi_init_obj_list(); + if (r != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + r & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + return efi_set_var(cmdtp, flag, argc, argv); +} diff --git a/include/command.h b/include/command.h index feddef300ccc..efc4dfc457c1 100644 --- a/include/command.h +++ b/include/command.h @@ -51,6 +51,10 @@ extern int do_run(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #if defined(CONFIG_CMD_BOOTEFI) extern int do_bootefi_run(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #endif +#if defined(CONFIG_CMD_NVEDIT_EFI) +int do_env_print_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +#endif
/* common/command.c */ int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int
- bool
- depends on EFI_LOADER
- default y if EFI_LOADER
No need for the "if EFI_LOADER" here. You only ever get to run the default path when EFI_LOADER is set due to the depends on line before.
- imply HEXDUMP
- if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e')
- if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'a') { argc--; argv++;
- while (argc > 1 && **(argv + 1) == '-') { char *arg = *++argv;
- "env print -e [name ...] - print UEFI environment\n"
- "env set [-e | -f] name [arg ...]\n";
- "printenv -e [<name> ...]\n"
- " - print UEFI variable 'name' or all the variables\n"
- "-e <name> [<value> ...]\n"
- " - set UEFI variable 'name' to 'value' ...'\n"
- "setenv [-f] name value ...\n" " - [forcibly] set environment variable 'name' to 'value ...'\n" "setenv [-f] name\n" " - [forcibly] delete environment variable 'name'",
- Integrate UEFI variables to u-boot env interface
- Copyright (c) 2018 AKASHI Takahiro, Linaro Limited
- u32 mask;
- char *text;
- {EFI_VARIABLE_NON_VOLATILE, "NV"},
- {EFI_VARIABLE_BOOTSERVICE_ACCESS, "BS"},
- {EFI_VARIABLE_RUNTIME_ACCESS, "RT"},
- {EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS, "AW"},
- {EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS, "AT"},
- u32 attributes;
- u8 *data;
- efi_uintn_t size;
- int count, i;
- efi_status_t ret;
- data = NULL;
- size = 0;
- ret = efi_get_variable(name, guid, &attributes, &size, data);
- if (ret == EFI_BUFFER_TOO_SMALL) {
if (!data)
return -1;
Just goto out.
- if (ret == EFI_NOT_FOUND) {
printf("Error: \"%ls\" not defined\n", name);
goto out;
- if (ret != EFI_SUCCESS)
goto out;
- printf("%ls:", name);
- for (count = 0, i = 0; i < ARRAY_SIZE(efi_var_attrs); i++)
if (count)
putc('|');
else
putc(' ');
count++;
- printf(", DataSize = 0x%lx\n", size);
- print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, data, size, true);
+out:
- free(data);
- return -1;
- From efi_variable.c,
- Mapping between UEFI variables and u-boot variables:
- efi_$guid_$varname = {attributes}(type)value
- u16 *var_name16, *p;
- efi_uintn_t buf_size, size;
- efi_guid_t guid;
- efi_status_t ret;
- buf_size = 128;
- var_name16 = malloc(buf_size);
- if (!var_name16)
- if (argc > 1) {
Missing a comment on what this does. Also, I think it makes sense to extract the 2 cases (dump 1 var, dump all vars) into separate functions. They share almost no code and just make indentation hard.
argc--;
argv++;
(utf8_utf16_strlen() + 1) * sizeof(u16)?
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
p = var_name16;
Why do you need to copy the guid into a stack variable? Can't you just pass the pointer?
Not checking return value?
free(var_name16);
- var_name16[0] = 0;
- for (;;) {
size = buf_size;
break;
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
&guid);
free(var_name16);
Alex
- bool
Right.
- imply HEXDUMP
- u32 mask;
- char *text;
- u32 attributes;
- u8 *data;
- efi_uintn_t size;
- int count, i;
- efi_status_t ret;
- data = NULL;
- size = 0;
if (!data)
return -1;
Just goto out.
Sure.
goto out;
goto out;
if (count)
putc('|');
else
putc(' ');
count++;
+out:
- free(data);
- return -1;
- efi_guid_t guid;
- efi_status_t ret;
- buf_size = 128;
- if (!var_name16)
- if (argc > 1) {
Okay.
argc--;
argv++;
Okay.
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
p = var_name16;
You're right.
This is in an iteration loop and the case that a variable doesn't exist is also handled in print_variable_info(). So we don't care a return value. I will change a return value to void to clarify this.
free(var_name16);
- for (;;) {
size = buf_size;
break;
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
&guid);
free(var_name16);
ditto.
Unless you have any comments on other patches (than patch#1), I'd like to send out only this one as v6.1 (or v7) since changes here don't affect other patches.
Thanks, -Takahiro Akashi
Alex
Currently, there is no easy way to add or modify UEFI variables. In particular, bootmgr supports BootOrder/BootXXXX variables, it is quite hard to define them as u-boot variables because they are represented in a complicated and encoded format.
The new command, efidebug, helps address these issues and give us more friendly interfaces: * efidebug boot add: add BootXXXX variable * efidebug boot rm: remove BootXXXX variable * efidebug boot dump: display all BootXXXX variables * efidebug boot next: set BootNext variable * efidebug boot order: set/display a boot order (BootOrder)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- MAINTAINERS | 1 + cmd/Kconfig | 10 ++ cmd/Makefile | 1 + cmd/efidebug.c | 461 +++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 473 insertions(+) create mode 100644 cmd/efidebug.c
diff --git a/MAINTAINERS b/MAINTAINERS index 22ac686ab2d6..7ad8c01a3b93 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -438,6 +438,7 @@ F: lib/efi*/ F: test/py/tests/test_efi* F: test/unicode_ut.c F: cmd/bootefi.c +F: cmd/efidebug.c F: cmd/nvedit_efi.c F: tools/file2include.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 812a7eb9b74b..f0405a490635 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1403,6 +1403,16 @@ config CMD_DISPLAY displayed on a simple board-specific display. Implement display_putc() to use it.
+config CMD_EFIDEBUG + bool "efidebug - display/configure UEFI environment" + depends on EFI_LOADER + default n + help + Enable the 'efidebug' command which provides a subset of UEFI + shell utility with simplified functionality. It will be useful + particularly for managing boot parameters as well as examining + various EFI status for debugging. + config CMD_LED bool "led" default y if LED diff --git a/cmd/Makefile b/cmd/Makefile index 142e0ee222ca..48f2742168be 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -51,6 +51,7 @@ obj-$(CONFIG_CMD_ECHO) += echo.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_CMD_EEPROM) += eeprom.o obj-$(CONFIG_EFI_STUB) += efi.o +obj-$(CONFIG_CMD_EFIDEBUG) += efidebug.o obj-$(CONFIG_CMD_ELF) += elf.o obj-$(CONFIG_HUSH_PARSER) += exit.o obj-$(CONFIG_CMD_EXT4) += ext4.o diff --git a/cmd/efidebug.c b/cmd/efidebug.c new file mode 100644 index 000000000000..d836576cf6e0 --- /dev/null +++ b/cmd/efidebug.c @@ -0,0 +1,461 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * UEFI Shell-like command + * + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#include <charset.h> +#include <common.h> +#include <command.h> +#include <efi_loader.h> +#include <environment.h> +#include <exports.h> +#include <malloc.h> +#include <search.h> +#include <linux/ctype.h> + +static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int id; + char *endp; + char var_name[9]; + u16 var_name16[9], *p; + efi_guid_t guid; + size_t label_len, label_len16; + u16 *label; + struct efi_device_path *device_path = NULL, *file_path = NULL; + struct efi_load_option lo; + void *data = NULL; + efi_uintn_t size; + int ret; + + if (argc < 6 || argc > 7) + return CMD_RET_USAGE; + + id = (int)simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0' || id > 0xffff) + return CMD_RET_FAILURE; + + sprintf(var_name, "Boot%04X", id); + p = var_name16; + utf8_utf16_strncpy(&p, var_name, 9); + + guid = efi_global_variable_guid; + + /* attributes */ + lo.attributes = 0x1; /* always ACTIVE */ + + /* label */ + label_len = strlen(argv[2]); + label_len16 = utf8_utf16_strnlen(argv[2], label_len); + label = malloc((label_len16 + 1) * sizeof(u16)); + if (!label) + return CMD_RET_FAILURE; + lo.label = label; /* label will be changed below */ + utf8_utf16_strncpy(&label, argv[2], label_len); + + /* file path */ + ret = efi_dp_from_name(argv[3], argv[4], argv[5], &device_path, + &file_path); + if (ret != EFI_SUCCESS) { + ret = CMD_RET_FAILURE; + goto out; + } + lo.file_path = file_path; + lo.file_path_length = efi_dp_size(file_path) + + sizeof(struct efi_device_path); /* for END */ + + /* optional data */ + lo.optional_data = (u8 *)(argc == 6 ? "" : argv[6]); + + size = efi_serialize_load_option(&lo, (u8 **)&data); + if (!size) { + ret = CMD_RET_FAILURE; + goto out; + } + + ret = efi_set_variable(var_name16, &guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, size, data); + ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); +out: + free(data); + efi_free_pool(device_path); + efi_free_pool(file_path); + free(lo.label); + + return ret; +} + +static int do_efi_boot_rm(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_guid_t guid; + int id, i; + char *endp; + char var_name[9]; + u16 var_name16[9]; + efi_status_t ret; + + if (argc == 1) + return CMD_RET_USAGE; + + guid = efi_global_variable_guid; + for (i = 1; i < argc; i++, argv++) { + id = (int)simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0' || id > 0xffff) + return CMD_RET_FAILURE; + + sprintf(var_name, "Boot%04X", id); + utf8_utf16_strncpy((u16 **)&var_name16, var_name, 9); + + ret = efi_set_variable(var_name16, &guid, 0, 0, NULL); + if (ret) { + printf("cannot remove Boot%04X", id); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} + +static void show_efi_boot_opt_data(int id, void *data) +{ + struct efi_load_option lo; + char *label, *p; + size_t label_len16, label_len; + u16 *dp_str; + + efi_deserialize_load_option(&lo, data); + + label_len16 = u16_strlen(lo.label); + label_len = utf16_utf8_strnlen(lo.label, label_len16); + label = malloc(label_len + 1); + if (!label) + return; + p = label; + utf16_utf8_strncpy(&p, lo.label, label_len16); + + printf("Boot%04X:\n", id); + printf("\tattributes: %c%c%c (0x%08x)\n", + /* ACTIVE */ + lo.attributes & 0x1 ? 'A' : '-', + /* FORCE RECONNECT */ + lo.attributes & 0x2 ? 'R' : '-', + /* HIDDEN */ + lo.attributes & 0x8 ? 'H' : '-', + lo.attributes); + printf("\tlabel: %s\n", label); + + dp_str = efi_dp_str(lo.file_path); + printf("\tfile_path: %ls\n", dp_str); + efi_free_pool(dp_str); + + printf("\tdata: %s\n", lo.optional_data); + + free(label); +} + +static void show_efi_boot_opt(int id) +{ + char var_name[9]; + u16 var_name16[9], *p; + efi_guid_t guid; + void *data = NULL; + efi_uintn_t size; + int ret; + + sprintf(var_name, "Boot%04X", id); + p = var_name16; + utf8_utf16_strncpy(&p, var_name, 9); + guid = efi_global_variable_guid; + + size = 0; + ret = efi_get_variable(var_name16, &guid, NULL, &size, NULL); + if (ret == (int)EFI_BUFFER_TOO_SMALL) { + data = malloc(size); + ret = efi_get_variable(var_name16, &guid, NULL, &size, data); + } + if (ret == EFI_SUCCESS) + show_efi_boot_opt_data(id, data); + else if (ret == EFI_NOT_FOUND) + printf("Boot%04X: not found\n", id); + + free(data); +} + +static int do_efi_boot_dump(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + char regex[256]; + char * const regexlist[] = {regex}; + char *variables = NULL, *boot, *value; + int len; + int id; + + if (argc > 1) + return CMD_RET_USAGE; + + snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_Boot[0-9A-F]+"); + + /* TODO: use GetNextVariableName? */ + len = hexport_r(&env_htab, '\n', H_MATCH_REGEX | H_MATCH_KEY, + &variables, 0, 1, regexlist); + + if (!len) + return CMD_RET_SUCCESS; + + if (len < 0) + return CMD_RET_FAILURE; + + boot = variables; + while (*boot) { + value = strstr(boot, "Boot") + 4; + id = (int)simple_strtoul(value, NULL, 16); + show_efi_boot_opt(id); + boot = strchr(boot, '\n'); + if (!*boot) + break; + boot++; + } + free(variables); + + return CMD_RET_SUCCESS; +} + +static int show_efi_boot_order(void) +{ + efi_guid_t guid; + u16 *bootorder = NULL; + efi_uintn_t size; + int num, i; + char var_name[9]; + u16 var_name16[9], *p16; + void *data; + struct efi_load_option lo; + char *label, *p; + size_t label_len16, label_len; + efi_status_t ret; + + guid = efi_global_variable_guid; + size = 0; + ret = efi_get_variable(L"BootOrder", &guid, NULL, &size, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) { + bootorder = malloc(size); + ret = efi_get_variable(L"BootOrder", &guid, NULL, &size, + bootorder); + } + if (ret == EFI_NOT_FOUND) { + printf("BootOrder not defined\n"); + ret = CMD_RET_SUCCESS; + goto out; + } else if (ret != EFI_SUCCESS) { + ret = CMD_RET_FAILURE; + goto out; + } + + num = size / sizeof(u16); + for (i = 0; i < num; i++) { + sprintf(var_name, "Boot%04X", bootorder[i]); + p16 = var_name16; + utf8_utf16_strncpy(&p16, var_name, 9); + + size = 0; + ret = efi_get_variable(var_name16, &guid, NULL, &size, NULL); + if (ret != EFI_BUFFER_TOO_SMALL) { + printf("%2d: Boot%04X: (not defined)\n", + i + 1, bootorder[i]); + continue; + } + + data = malloc(size); + if (!data) { + ret = CMD_RET_FAILURE; + goto out; + } + ret = efi_get_variable(var_name16, &guid, NULL, &size, data); + if (ret != EFI_SUCCESS) { + free(data); + ret = CMD_RET_FAILURE; + goto out; + } + + efi_deserialize_load_option(&lo, data); + + label_len16 = u16_strlen(lo.label); + label_len = utf16_utf8_strnlen(lo.label, label_len16); + label = malloc(label_len + 1); + if (!label) { + free(data); + ret = CMD_RET_FAILURE; + goto out; + } + p = label; + utf16_utf8_strncpy(&p, lo.label, label_len16); + printf("%2d: Boot%04X: %s\n", i + 1, bootorder[i], label); + free(label); + + free(data); + } +out: + free(bootorder); + + return ret; +} + +static int do_efi_boot_next(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + u16 bootnext; + efi_uintn_t size; + char *endp; + efi_guid_t guid; + efi_status_t ret; + + if (argc != 2) + return CMD_RET_USAGE; + + bootnext = (u16)simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0' || bootnext > 0xffff) { + printf("invalid value: %s\n", argv[1]); + ret = CMD_RET_FAILURE; + goto out; + } + + guid = efi_global_variable_guid; + size = sizeof(u16); + ret = efi_set_variable(L"BootNext", &guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, size, &bootnext); + ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); +out: + return ret; +} + +static int do_efi_boot_order(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + u16 *bootorder = NULL; + efi_uintn_t size; + int id, i; + char *endp; + efi_guid_t guid; + efi_status_t ret; + + if (argc == 1) + return show_efi_boot_order(); + + argc--; + argv++; + + size = argc * sizeof(u16); + bootorder = malloc(size); + if (!bootorder) + return CMD_RET_FAILURE; + + for (i = 0; i < argc; i++) { + id = (int)simple_strtoul(argv[i], &endp, 16); + if (*endp != '\0' || id > 0xffff) { + printf("invalid value: %s\n", argv[i]); + ret = CMD_RET_FAILURE; + goto out; + } + + bootorder[i] = (u16)id; + } + + guid = efi_global_variable_guid; + ret = efi_set_variable(L"BootOrder", &guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, size, bootorder); + ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); +out: + free(bootorder); + + return ret; +} + +static cmd_tbl_t cmd_efidebug_boot_sub[] = { + U_BOOT_CMD_MKENT(add, CONFIG_SYS_MAXARGS, 1, do_efi_boot_add, "", ""), + U_BOOT_CMD_MKENT(rm, CONFIG_SYS_MAXARGS, 1, do_efi_boot_rm, "", ""), + U_BOOT_CMD_MKENT(dump, CONFIG_SYS_MAXARGS, 1, do_efi_boot_dump, "", ""), + U_BOOT_CMD_MKENT(next, CONFIG_SYS_MAXARGS, 1, do_efi_boot_next, "", ""), + U_BOOT_CMD_MKENT(order, CONFIG_SYS_MAXARGS, 1, do_efi_boot_order, + "", ""), +}; + +static int do_efi_boot_opt(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + + if (argc < 2) + return CMD_RET_USAGE; + + argc--; argv++; + + cp = find_cmd_tbl(argv[0], cmd_efidebug_boot_sub, + ARRAY_SIZE(cmd_efidebug_boot_sub)); + if (!cp) + return CMD_RET_USAGE; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +static cmd_tbl_t cmd_efidebug_sub[] = { + U_BOOT_CMD_MKENT(boot, CONFIG_SYS_MAXARGS, 1, do_efi_boot_opt, "", ""), +}; + +/* Interpreter command to configure UEFI environment */ +static int do_efidebug(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + efi_status_t r; + + if (argc < 2) + return CMD_RET_USAGE; + + argc--; argv++; + + /* Initialize UEFI drivers */ + r = efi_init_obj_list(); + if (r != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + r & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + cp = find_cmd_tbl(argv[0], cmd_efidebug_sub, + ARRAY_SIZE(cmd_efidebug_sub)); + if (!cp) + return CMD_RET_USAGE; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +#ifdef CONFIG_SYS_LONGHELP +static char efidebug_help_text[] = + " - UEFI Shell-like interface to configure UEFI environment\n" + "\n" + "efidebug boot add <bootid> <label> <interface> <device>[:<part>] <file path> [<load options>]\n" + " - set UEFI BootXXXX variable\n" + " <load options> will be passed to UEFI application\n" + "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n" + " - delete UEFI BootXXXX variables\n" + "efidebug boot dump\n" + " - show all UEFI BootXXXX variables\n" + "efidebug boot next <bootid>\n" + " - set UEFI BootNext variable\n" + "efidebug boot order [<bootid#1> [<bootid#2> [<bootid#3> [...]]]]\n" + " - set/show UEFI boot order\n" + "\n"; +#endif + +U_BOOT_CMD( + efidebug, 10, 0, do_efidebug, + "Configure UEFI environment", + efidebug_help_text +);
- efidebug boot add: add BootXXXX variable
- efidebug boot rm: remove BootXXXX variable
- efidebug boot dump: display all BootXXXX variables
- efidebug boot next: set BootNext variable
- efidebug boot order: set/display a boot order (BootOrder)
I could not make this work on qemu_arm_defconfig:
Usage: efidebug boot add <bootid> <label> <interface> <device>[:<part>] <file path> [<load options>]
=> efidebug boot add 00AA 'fancy label' mmc 0:1 wonder.efi '--do-it' => efidebug boot dump =>
I would expect either an error or an output of `dump`.
As the UEFI spec teaches: "Each Boot#### variable is the name “Boot” appended with a unique four digit hexadecimal number." So 00AA should be a valid id.
Best regards
Heinrich
- bool "efidebug - display/configure UEFI environment"
- default n
- help
- UEFI Shell-like command
- int id;
- char *endp;
- char var_name[9];
- u16 var_name16[9], *p;
- efi_guid_t guid;
- size_t label_len, label_len16;
- u16 *label;
- struct efi_device_path *device_path = NULL, *file_path = NULL;
- struct efi_load_option lo;
- void *data = NULL;
- efi_uintn_t size;
- int ret;
- if (argc < 6 || argc > 7)
- id = (int)simple_strtoul(argv[1], &endp, 16);
- if (*endp != '\0' || id > 0xffff)
- sprintf(var_name, "Boot%04X", id);
- p = var_name16;
- utf8_utf16_strncpy(&p, var_name, 9);
- guid = efi_global_variable_guid;
- /* attributes */
- lo.attributes = 0x1; /* always ACTIVE */
- /* label */
- label_len = strlen(argv[2]);
- label_len16 = utf8_utf16_strnlen(argv[2], label_len);
- label = malloc((label_len16 + 1) * sizeof(u16));
- if (!label)
- lo.label = label; /* label will be changed below */
- utf8_utf16_strncpy(&label, argv[2], label_len);
- /* file path */
- ret = efi_dp_from_name(argv[3], argv[4], argv[5], &device_path,
&file_path);
- if (ret != EFI_SUCCESS) {
goto out;
- lo.file_path = file_path;
- lo.file_path_length = efi_dp_size(file_path)
- /* optional data */
- lo.optional_data = (u8 *)(argc == 6 ? "" : argv[6]);
- size = efi_serialize_load_option(&lo, (u8 **)&data);
- if (!size) {
goto out;
- ret = efi_set_variable(var_name16, &guid,
- ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE);
+out:
- free(data);
- efi_free_pool(device_path);
- efi_free_pool(file_path);
- free(lo.label);
- return ret;
- efi_guid_t guid;
- int id, i;
- char *endp;
- char var_name[9];
- u16 var_name16[9];
- efi_status_t ret;
- if (argc == 1)
- for (i = 1; i < argc; i++, argv++) {
if (ret) {
- return CMD_RET_SUCCESS;
- char *label, *p;
- size_t label_len16, label_len;
- u16 *dp_str;
- efi_deserialize_load_option(&lo, data);
- label_len16 = u16_strlen(lo.label);
- label_len = utf16_utf8_strnlen(lo.label, label_len16);
- label = malloc(label_len + 1);
- if (!label)
return;
- p = label;
- utf16_utf8_strncpy(&p, lo.label, label_len16);
- printf("Boot%04X:\n", id);
- printf("\tattributes: %c%c%c (0x%08x)\n",
/* ACTIVE */
/* HIDDEN */
lo.attributes);
- printf("\tlabel: %s\n", label);
- dp_str = efi_dp_str(lo.file_path);
- printf("\tfile_path: %ls\n", dp_str);
- efi_free_pool(dp_str);
- printf("\tdata: %s\n", lo.optional_data);
- free(label);
- char var_name[9];
- efi_guid_t guid;
- efi_uintn_t size;
- int ret;
- p = var_name16;
- size = 0;
- ret = efi_get_variable(var_name16, &guid, NULL, &size, NULL);
- if (ret == (int)EFI_BUFFER_TOO_SMALL) {
- if (ret == EFI_SUCCESS)
- else if (ret == EFI_NOT_FOUND)
- free(data);
- char regex[256];
- char * const regexlist[] = {regex};
- char *variables = NULL, *boot, *value;
- int len;
- int id;
- if (argc > 1)
- snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_Boot[0-9A-F]+");
- /* TODO: use GetNextVariableName? */
- len = hexport_r(&env_htab, '\n', H_MATCH_REGEX | H_MATCH_KEY,
- if (!len)
- if (len < 0)
- boot = variables;
- while (*boot) {
if (!*boot)
break;
boot++;
- free(variables);
- efi_guid_t guid;
- u16 *bootorder = NULL;
- efi_uintn_t size;
- int num, i;
- char var_name[9];
- u16 var_name16[9], *p16;
- void *data;
- char *label, *p;
- efi_status_t ret;
- size = 0;
- ret = efi_get_variable(L"BootOrder", &guid, NULL, &size, NULL);
bootorder);
goto out;
- } else if (ret != EFI_SUCCESS) {
goto out;
- num = size / sizeof(u16);
- for (i = 0; i < num; i++) {
p16 = var_name16;
size = 0;
continue;
if (!data) {
goto out;
free(data);
goto out;
if (!label) {
free(data);
goto out;
p = label;
free(label);
free(data);
+out:
- free(bootorder);
- return ret;
- u16 bootnext;
- efi_uintn_t size;
- char *endp;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc != 2)
- bootnext = (u16)simple_strtoul(argv[1], &endp, 16);
- if (*endp != '\0' || bootnext > 0xffff) {
goto out;
- size = sizeof(u16);
- ret = efi_set_variable(L"BootNext", &guid,
+out:
- return ret;
- efi_uintn_t size;
- int id, i;
- char *endp;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc == 1)
- argc--;
- argv++;
- size = argc * sizeof(u16);
- bootorder = malloc(size);
- if (!bootorder)
- for (i = 0; i < argc; i++) {
goto out;
- ret = efi_set_variable(L"BootOrder", &guid,
+out:
- free(bootorder);
- return ret;
- U_BOOT_CMD_MKENT(add, CONFIG_SYS_MAXARGS, 1, do_efi_boot_add, "", ""),
- U_BOOT_CMD_MKENT(rm, CONFIG_SYS_MAXARGS, 1, do_efi_boot_rm, "", ""),
- U_BOOT_CMD_MKENT(dump, CONFIG_SYS_MAXARGS, 1, do_efi_boot_dump, "", ""),
- U_BOOT_CMD_MKENT(next, CONFIG_SYS_MAXARGS, 1, do_efi_boot_next, "", ""),
- U_BOOT_CMD_MKENT(order, CONFIG_SYS_MAXARGS, 1, do_efi_boot_order,
- cmd_tbl_t *cp;
- if (argc < 2)
- argc--; argv++;
- cp = find_cmd_tbl(argv[0], cmd_efidebug_boot_sub,
- if (!cp)
- return cp->cmd(cmdtp, flag, argc, argv);
- U_BOOT_CMD_MKENT(boot, CONFIG_SYS_MAXARGS, 1, do_efi_boot_opt, "", ""),
- cmd_tbl_t *cp;
- efi_status_t r;
- if (argc < 2)
- argc--; argv++;
- /* Initialize UEFI drivers */
- r = efi_init_obj_list();
- if (r != EFI_SUCCESS) {
- cp = find_cmd_tbl(argv[0], cmd_efidebug_sub,
- if (!cp)
- " - UEFI Shell-like interface to configure UEFI environment\n"
- "\n"
- "efidebug boot add <bootid> <label> <interface> <device>[:<part>] <file path> [<load options>]\n"
- " - set UEFI BootXXXX variable\n"
- " <load options> will be passed to UEFI application\n"
- "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n"
- " - delete UEFI BootXXXX variables\n"
- "efidebug boot dump\n"
- " - show all UEFI BootXXXX variables\n"
- "efidebug boot next <bootid>\n"
- " - set UEFI BootNext variable\n"
- "efidebug boot order [<bootid#1> [<bootid#2> [<bootid#3> [...]]]]\n"
- " - set/show UEFI boot order\n"
- "\n";
+U_BOOT_CMD(
- efidebug, 10, 0, do_efidebug,
- "Configure UEFI environment",
- efidebug_help_text
It's not a problem. The real issue is that you don't have "mmc 0:1" on you system when typing this command.
This error take places because this command internally uses efi_dp_from_name(), hence blk_get_device_part_str(), which requires that a block device does exist and it can be accessible to see a partition table.
I think that this is one of major issues in current device path implementation. We never know how to convert "mmc 0:1" to a device path without having the named device.
Anyhow, I will add some error message in such a case.
-Takahiro Akashi
Best regards
Heinrich
- default n
- help
- int id;
- char *endp;
- char var_name[9];
- efi_guid_t guid;
- u16 *label;
- efi_uintn_t size;
- int ret;
- p = var_name16;
- /* attributes */
- /* label */
- if (!label)
- /* file path */
&file_path);
goto out;
- if (!size) {
goto out;
+out:
- free(data);
- free(lo.label);
- return ret;
- efi_guid_t guid;
- int id, i;
- char *endp;
- char var_name[9];
- efi_status_t ret;
- if (argc == 1)
if (ret) {
- char *label, *p;
- u16 *dp_str;
- if (!label)
return;
- p = label;
/* ACTIVE */
/* HIDDEN */
lo.attributes);
- free(label);
- char var_name[9];
- efi_guid_t guid;
- efi_uintn_t size;
- int ret;
- p = var_name16;
- size = 0;
- free(data);
- char regex[256];
- int len;
- int id;
- if (argc > 1)
- if (!len)
- if (len < 0)
- boot = variables;
- while (*boot) {
if (!*boot)
break;
boot++;
- free(variables);
- efi_guid_t guid;
- efi_uintn_t size;
- int num, i;
- char var_name[9];
- void *data;
- char *label, *p;
- efi_status_t ret;
- size = 0;
bootorder);
goto out;
goto out;
p16 = var_name16;
size = 0;
continue;
if (!data) {
goto out;
free(data);
goto out;
if (!label) {
free(data);
goto out;
p = label;
free(label);
free(data);
+out:
- free(bootorder);
- return ret;
- u16 bootnext;
- efi_uintn_t size;
- char *endp;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc != 2)
goto out;
+out:
- return ret;
- efi_uintn_t size;
- int id, i;
- char *endp;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc == 1)
- argc--;
- argv++;
- if (!bootorder)
goto out;
+out:
- free(bootorder);
- return ret;
- cmd_tbl_t *cp;
- if (argc < 2)
- argc--; argv++;
- if (!cp)
- cmd_tbl_t *cp;
- efi_status_t r;
- if (argc < 2)
- argc--; argv++;
- if (!cp)
- "\n"
- "\n";
+U_BOOT_CMD(
-Takahiro Akashi
=> scsi scan scanning bus for devices... Target spinup took 0 ms. SATA link 1 timeout. SATA link 2 timeout. SATA link 3 timeout. SATA link 4 timeout. SATA link 5 timeout. AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode flags: 64bit ncq only Device 0: (0:0) Vendor: ATA Prod.: QEMU HARDDISK Rev: 2.5+ Type: Hard Disk Capacity: 128.9 MB = 0.1 GB (264190 x 512) => efidebug boot add 00AA 'fancy label' scsi 0:1 wonder.efi '--do-it' Scanning disk ahci_scsi.id0lun0... Found 2 disks e1000: 52:54:00:12:34:56
Warning: e1000#0 using MAC address from ROM => efidebug boot dump Boot00AA: attributes: A-- (0x00000001) label: fancy label file_path: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0)/HD(1,MBR,0xcc8b40b9,0x800,0x3fffe)/\wonder.efi data: --do-it => env print -e Boot00AA Boot00AA: BS|RT, DataSize = 0x8c 00000000: 01 00 00 00 66 00 66 00 61 00 6e 00 63 00 79 00 ....f.f.a.n.c.y. 00000010: 20 00 6c 00 61 00 62 00 65 00 6c 00 00 00 01 04 .l.a.b.e.l..... 00000020: 14 00 b9 73 1d e6 84 a3 cc 4a ae ab 82 e8 28 f3 ...s.....J....(. 00000030: 62 8b 03 02 08 00 00 00 00 00 04 01 2a 00 01 00 b...........*... 00000040: 00 00 00 08 00 00 00 00 00 00 fe ff 03 00 00 00 ................ 00000050: 00 00 b9 40 8b cc 00 00 00 00 00 00 00 00 00 00 ...@............ 00000060: 00 00 01 01 04 04 1c 00 5c 00 77 00 6f 00 6e 00 .........w.o.n. 00000070: 64 00 65 00 72 00 2e 00 65 00 66 00 69 00 00 00 d.e.r...e.f.i... 00000080: 7f ff 04 00 2d 2d 64 6f 2d 69 74 00 ....--do-it.
worked on qemu_arm64_config.
Yes, please, add the error message for an invalid device. That matches the behavior of the load command that will not work without prior device scanning.
Best regards
Heinrich
"devices" command prints all the uefi variables on the system.
=> efi devices Scanning disk ahci_scsi.id0lun0... Scanning disk ahci_scsi.id1lun0... Found 4 disks Device Device Path ================ ==================== 000000007ef07ea0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 000000007ef00c10 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0) 000000007ef00dd0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0) 000000007ef07be0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(1,MBR,0x086246ba,0x800,0x40000) 000000007ef07510 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(2,MBR,0x086246ba,0x40800,0x3f800)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 102 ++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 101 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index d836576cf6e0..8a7f775b117a 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -15,6 +15,102 @@ #include <search.h> #include <linux/ctype.h>
+#define BS systab.boottime + +static int efi_get_handles_by_proto(efi_guid_t *guid, efi_handle_t **handlesp, + int *num) +{ + efi_handle_t *handles = NULL; + efi_uintn_t size = 0; + efi_status_t ret; + + if (guid) { + ret = BS->locate_handle(BY_PROTOCOL, guid, NULL, &size, + handles); + if (ret == EFI_BUFFER_TOO_SMALL) { + handles = calloc(1, size); + if (!handles) + return -1; + + ret = BS->locate_handle(BY_PROTOCOL, guid, NULL, &size, + handles); + } + if (ret != EFI_SUCCESS) { + free(handles); + return -1; + } + } else { + ret = BS->locate_handle(ALL_HANDLES, NULL, NULL, &size, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) { + handles = calloc(1, size); + if (!handles) + return -1; + + ret = BS->locate_handle(ALL_HANDLES, NULL, NULL, &size, + handles); + } + if (ret != EFI_SUCCESS) { + free(handles); + return -1; + } + } + + *handlesp = handles; + *num = size / sizeof(efi_handle_t); + + return 0; +} + +static int efi_get_device_handle_info(efi_handle_t handle, u16 **dev_path_text) +{ + struct efi_device_path *dp; + efi_status_t ret; + + ret = BS->open_protocol(handle, &efi_guid_device_path, + (void **)&dp, NULL /* FIXME */, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret == EFI_SUCCESS) { + *dev_path_text = efi_dp_str(dp); + return 0; + } else { + return -1; + } +} + +#define EFI_HANDLE_WIDTH ((int)sizeof(efi_handle_t) * 2) + +static const char spc[] = " "; +static const char sep[] = "================"; + +static int do_efi_show_devices(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_handle_t *handles; + u16 *dev_path_text; + int num, i; + + handles = NULL; + num = 0; + if (efi_get_handles_by_proto(NULL, &handles, &num)) + return CMD_RET_FAILURE; + + if (!num) + return CMD_RET_SUCCESS; + + printf("Device%.*s Device Path\n", EFI_HANDLE_WIDTH - 6, spc); + printf("%.*s ====================\n", EFI_HANDLE_WIDTH, sep); + for (i = 0; i < num; i++) { + if (!efi_get_device_handle_info(handles[i], &dev_path_text)) { + printf("%p %ls\n", handles[i], dev_path_text); + efi_free_pool(dev_path_text); + } + } + + free(handles); + + return CMD_RET_SUCCESS; +} + static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -406,6 +502,8 @@ static int do_efi_boot_opt(cmd_tbl_t *cmdtp, int flag,
static cmd_tbl_t cmd_efidebug_sub[] = { U_BOOT_CMD_MKENT(boot, CONFIG_SYS_MAXARGS, 1, do_efi_boot_opt, "", ""), + U_BOOT_CMD_MKENT(devices, CONFIG_SYS_MAXARGS, 1, do_efi_show_devices, + "", ""), };
/* Interpreter command to configure UEFI environment */ @@ -451,7 +549,9 @@ static char efidebug_help_text[] = " - set UEFI BootNext variable\n" "efidebug boot order [<bootid#1> [<bootid#2> [<bootid#3> [...]]]]\n" " - set/show UEFI boot order\n" - "\n"; + "\n" + "efidebug devices\n" + " - show uefi devices\n"; #endif
U_BOOT_CMD(
Please, add Sphinx style descriptions to all functions, their parameters, and return values.
Why do you need this function? Can't you call LocateHandleBuffer() which takes care of the allocation of the buffer?
int *num)
- efi_handle_t *handles = NULL;
- efi_uintn_t size = 0;
- efi_status_t ret;
- if (guid) {
handles);
This will not work on i386. Please, always use EFI_CALL when invoking a function which calls EFI_ENTRY().
if (!handles)
return -1;
handles);
free(handles);
The handles are not allocated by malloc(). Use FreePool() here.
return -1;
- } else {
if (!handles)
return -1;
handles);
free(handles);
Same here.
return -1;
- *handlesp = handles;
- *num = size / sizeof(efi_handle_t);
- struct efi_device_path *dp;
- efi_status_t ret;
- ret = BS->open_protocol(handle, &efi_guid_device_path,
- if (ret == EFI_SUCCESS) {
- } else {
return -1;
- efi_handle_t *handles;
- u16 *dev_path_text;
- int num, i;
- handles = NULL;
- num = 0;
- if (efi_get_handles_by_proto(NULL, &handles, &num))
- if (!num)
- printf("Device%.*s Device Path\n", EFI_HANDLE_WIDTH - 6, spc);
- printf("%.*s ====================\n", EFI_HANDLE_WIDTH, sep);
- free(handles);
FreePool()!
Best regards
Heinrich
- U_BOOT_CMD_MKENT(devices, CONFIG_SYS_MAXARGS, 1, do_efi_show_devices,
- "\n";
- "\n"
- "efidebug devices\n"
- " - show uefi devices\n";
#endif
U_BOOT_CMD(
int *num)
- efi_status_t ret;
- if (guid) {
handles);
if (!handles)
return -1;
handles);
free(handles);
Sorry I read this wrong. If you calloc(), free() is ok. But I would rather use LocateHandleBuffer() and FreePool() further down.
Regards
Heinrich
return -1;
- } else {
if (!handles)
return -1;
handles);
free(handles);
Same here.
return -1;
- efi_status_t ret;
- } else {
return -1;
- int num, i;
- handles = NULL;
- num = 0;
- if (!num)
- free(handles);
FreePool()!
Best regards
Heinrich
- "\n";
- "\n"
#endif
U_BOOT_CMD(
Sure, but please clearify what you mean by "all." Do you expect descriptions for exactly all the functions, even for some helper functions of a few lines of code?
int *num)
Right. I will use locate_handle_buffer here. But why does UEFI spec define functionally-duplicated functions, LocateHandle() and LocateHandleBuffer()?
- efi_status_t ret;
- if (guid) {
handles);
OK, but let me make sure. We don't have to use EFI_CALL() for any of (internal) efi_xxx() functions, say, efi_add_protocol(). Right?
if (!handles)
return -1;
handles);
free(handles);
Will take care of that along with the change above.
-Takahiro Akashi
return -1;
- } else {
if (!handles)
return -1;
handles);
free(handles);
Same here.
return -1;
- efi_status_t ret;
- } else {
return -1;
- int num, i;
- handles = NULL;
- num = 0;
- if (!num)
- free(handles);
FreePool()!
Best regards
Heinrich
- "\n";
- "\n"
#endif
U_BOOT_CMD(
int *num)
- efi_status_t ret;
- if (guid) {
handles);
EFI_ENTRY() and EFI_EXIT() change the content of the register to which gd is mapped and executes an assert. So only functions starting with EFI_ENTRY() should be called via EFI_CALL. Please, do not call other functions via EFI_CALL().
Please, check that efi_save_gd() is called (e.g. via efi_init_obj_list()) before the first EFI_CALL().
To get rid of the systab.boottime dereference it might be preferable to change static functions to global once.
Best regards
Heinrich
if (!handles)
return -1;
handles);
free(handles);
-Takahiro Akashi
return -1;
- } else {
if (!handles)
return -1;
handles);
free(handles);
Same here.
return -1;
- efi_status_t ret;
- } else {
return -1;
- int num, i;
- handles = NULL;
- num = 0;
- if (!num)
- free(handles);
FreePool()!
Best regards
Heinrich
- "\n";
- "\n"
#endif
U_BOOT_CMD(
int *num)
- efi_status_t ret;
- if (guid) {
handles);
Thank you for explanation.
I didn't notice that.
Can you please leave some document about this kind of usage so that future UEFI developers be aware of it.
Do you mean, for example, we should call efi_open_protocol() instead of BS->open_protocol()? I hesitate to agree with you as we should try to call exported *API's* wherever possible, in particular, in EFI-application-like code, like efidebug.
-Takahiro Akashi
Best regards
Heinrich
if (!handles)
return -1;
handles);
free(handles);
-Takahiro Akashi
return -1;
- } else {
if (!handles)
return -1;
handles);
free(handles);
Same here.
return -1;
- efi_status_t ret;
- } else {
return -1;
- int num, i;
- handles = NULL;
- num = 0;
- if (!num)
- free(handles);
FreePool()!
Best regards
Heinrich
- "\n";
- "\n"
#endif
U_BOOT_CMD(
"drivers" command prints all the uefi drivers on the system.
=> efi drivers Driver Name Image Path ================ ==================== ==================== 000000007ef003d0 <NULL> <built-in>
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 80 +++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 79 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 8a7f775b117a..1b788c76a895 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -111,6 +111,80 @@ static int do_efi_show_devices(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static int efi_get_driver_handle_info(efi_handle_t handle, u16 **driver_name, + u16 **image_path) +{ + struct efi_handler *handler; + struct efi_loaded_image *image; + efi_status_t ret; + + /* + * driver name + * TODO: support EFI_COMPONENT_NAME2_PROTOCOL + */ + *driver_name = NULL; + + /* image name */ + ret = efi_search_protocol(handle, &efi_guid_loaded_image, &handler); + if (ret != EFI_SUCCESS) { + *image_path = NULL; + return 0; + } + + image = handler->protocol_interface; + *image_path = efi_dp_str(image->file_path); + + return 0; +} + +static int do_efi_show_drivers(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_handle_t *handles = NULL, *handle; + efi_uintn_t size = 0; + u16 *driver_name, *image_path_text; + efi_status_t ret; + int i; + + ret = BS->locate_handle(BY_PROTOCOL, &efi_guid_driver_binding_protocol, + NULL, &size, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) { + handles = calloc(1, size); + if (!handles) + return CMD_RET_FAILURE; + + ret = BS->locate_handle(BY_PROTOCOL, + &efi_guid_driver_binding_protocol, + NULL, &size, handles); + } + if (ret != EFI_SUCCESS) { + free(handles); + return CMD_RET_FAILURE; + } + + printf("Driver%.*s Name Image Path\n", + EFI_HANDLE_WIDTH - 6, spc); + printf("%.*s ==================== ====================\n", + EFI_HANDLE_WIDTH, sep); + handle = handles; + for (i = 0; i < size / sizeof(*handle); i++) { + if (!efi_get_driver_handle_info(*handle, &driver_name, + &image_path_text)) { + if (image_path_text) + printf("%p %-20ls %ls\n", + *handle, driver_name, image_path_text); + else + printf("%p %-20ls <built-in>\n", + *handle, driver_name); + efi_free_pool(driver_name); + efi_free_pool(image_path_text); + } + handle++; + } + + return CMD_RET_SUCCESS; +} + static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -504,6 +578,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { U_BOOT_CMD_MKENT(boot, CONFIG_SYS_MAXARGS, 1, do_efi_boot_opt, "", ""), U_BOOT_CMD_MKENT(devices, CONFIG_SYS_MAXARGS, 1, do_efi_show_devices, "", ""), + U_BOOT_CMD_MKENT(drivers, CONFIG_SYS_MAXARGS, 1, do_efi_show_drivers, + "", ""), };
/* Interpreter command to configure UEFI environment */ @@ -551,7 +627,9 @@ static char efidebug_help_text[] = " - set/show UEFI boot order\n" "\n" "efidebug devices\n" - " - show uefi devices\n"; + " - show uefi devices\n" + "efidebug drivers\n" + " - show uefi drivers\n"; #endif
U_BOOT_CMD(
u16 **image_path)
- struct efi_handler *handler;
- struct efi_loaded_image *image;
- efi_status_t ret;
* driver name
- *driver_name = NULL;
- /* image name */
- ret = efi_search_protocol(handle, &efi_guid_loaded_image, &handler);
*image_path = NULL;
- image = handler->protocol_interface;
- *image_path = efi_dp_str(image->file_path);
- efi_handle_t *handles = NULL, *handle;
- u16 *driver_name, *image_path_text;
- efi_status_t ret;
- int i;
You are duplicating the logic of LocateHandleBuffer(). Why?
- ret = BS->locate_handle(BY_PROTOCOL, &efi_guid_driver_binding_protocol,
NULL, &size, NULL);
if (!handles)
free(handles);
- printf("Driver%.*s Name Image Path\n",
- printf("%.*s ==================== ====================\n",
- handle = handles;
- for (i = 0; i < size / sizeof(*handle); i++) {
else
handle++;
You are leaking 'handles' here.
Best regards
Heinrich
- U_BOOT_CMD_MKENT(drivers, CONFIG_SYS_MAXARGS, 1, do_efi_show_drivers,
- "efidebug drivers\n"
- " - show uefi drivers\n";
#endif
U_BOOT_CMD(
u16 **image_path)
- efi_status_t ret;
* driver name
- /* image name */
*image_path = NULL;
- efi_status_t ret;
- int i;
Will fix.
NULL, &size, NULL);
if (!handles)
free(handles);
- handle = handles;
else
handle++;
Will fix.
Best regards
Heinrich
#endif
U_BOOT_CMD(
"dh" command prints all the uefi handles used in the system.
=> efi dh 7ef3bfa0: Device Path, Device Path To Text, Device Path Utilities, Unicode Collation 2 7ef31d30: Driver Binding 7ef31da0: Simple Text Output 7ef31e10: Simple Text Input, Simple Text Input Ex 7ef3cca0: Block IO, Device Path 7ef3d070: Block IO, Device Path 7ef3d1b0: Block IO, Device Path, Simple File System 7ef3d3e0: Block IO, Device Path, Simple File System
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 122 ++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 121 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 1b788c76a895..a1852e8ea4b9 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -185,6 +185,122 @@ static int do_efi_show_drivers(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static const struct { + const char *text; + const efi_guid_t guid; +} guid_list[] = { + { + "Device Path", + DEVICE_PATH_GUID, + }, + { + "Device Path To Text", + EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID, + }, + { + "Device Path Utilities", + EFI_DEVICE_PATH_UTILITIES_PROTOCOL_GUID, + }, + { + "Unicode Collation 2", + EFI_UNICODE_COLLATION_PROTOCOL2_GUID, + }, + { + "Driver Binding", + EFI_DRIVER_BINDING_PROTOCOL_GUID, + }, + { + "Simple Text Input", + EFI_SIMPLE_TEXT_INPUT_PROTOCOL_GUID, + }, + { + "Simple Text Input Ex", + EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL_GUID, + }, + { + "Simple Text Output", + EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL_GUID, + }, + { + "Block IO", + BLOCK_IO_GUID, + }, + { + "Simple File System", + EFI_SIMPLE_FILE_SYSTEM_PROTOCOL_GUID, + }, + { + "Loaded Image", + LOADED_IMAGE_PROTOCOL_GUID, + }, + { + "GOP", + EFI_GOP_GUID, + }, +}; + +static const char *get_guid_text(const efi_guid_t *guid) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(guid_list); i++) + if (!guidcmp(&guid_list[i].guid, guid)) + break; + + if (i != ARRAY_SIZE(guid_list)) + return guid_list[i].text; + else + return NULL; +} + +static int do_efi_show_handles(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_handle_t *handles; + efi_guid_t **guid; + efi_uintn_t count; + const char *guid_text; + int num, i, j; + efi_status_t ret; + + handles = NULL; + num = 0; + if (efi_get_handles_by_proto(NULL, &handles, &num)) + return CMD_RET_FAILURE; + + if (!num) + return CMD_RET_SUCCESS; + + printf("Handle%.*s Protocols\n", EFI_HANDLE_WIDTH - 6, spc); + printf("%.*s ====================\n", EFI_HANDLE_WIDTH, sep); + for (i = 0; i < num; i++) { + printf("%p", handles[i]); + ret = BS->protocols_per_handle(handles[i], &guid, &count); + if (ret || !count) { + putc('\n'); + continue; + } + + for (j = 0; j < count; j++) { + if (j) + printf(", "); + else + putc(' '); + + guid_text = get_guid_text(guid[j]); + if (guid_text) + puts(guid_text); + else + printf("%pUl", guid[j]); + } + putc('\n'); + } + + free(handles); + + return CMD_RET_SUCCESS; +} + static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -580,6 +696,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { "", ""), U_BOOT_CMD_MKENT(drivers, CONFIG_SYS_MAXARGS, 1, do_efi_show_drivers, "", ""), + U_BOOT_CMD_MKENT(dh, CONFIG_SYS_MAXARGS, 1, do_efi_show_handles, + "", ""), };
/* Interpreter command to configure UEFI environment */ @@ -629,7 +747,9 @@ static char efidebug_help_text[] = "efidebug devices\n" " - show uefi devices\n" "efidebug drivers\n" - " - show uefi drivers\n"; + " - show uefi drivers\n" + "efidebug dh\n" + " - show uefi handles\n"; #endif
U_BOOT_CMD(
"images" command prints loaded images-related information.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index a1852e8ea4b9..81ab3654f746 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -301,6 +301,14 @@ static int do_efi_show_handles(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static int do_efi_show_images(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_print_image_infos(NULL); + + return CMD_RET_SUCCESS; +} + static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -698,6 +706,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { "", ""), U_BOOT_CMD_MKENT(dh, CONFIG_SYS_MAXARGS, 1, do_efi_show_handles, "", ""), + U_BOOT_CMD_MKENT(images, CONFIG_SYS_MAXARGS, 1, do_efi_show_images, + "", ""), };
/* Interpreter command to configure UEFI environment */ @@ -749,7 +759,9 @@ static char efidebug_help_text[] = "efidebug drivers\n" " - show uefi drivers\n" "efidebug dh\n" - " - show uefi handles\n"; + " - show uefi handles\n" + "efidebug images\n" + " - show loaded images\n"; #endif
U_BOOT_CMD(
- efi_print_image_infos(NULL);
Where does this function get defined?
Alex
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index a1852e8ea4b9..81ab3654f746 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -301,6 +301,14 @@ static int do_efi_show_handles(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; } +static int do_efi_show_images(cmd_tbl_t *cmdtp, int flag,
in efi_image_loader.c by Heinrich.
-Takahiro Akashi
Alex
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- U_BOOT_CMD_MKENT(images, CONFIG_SYS_MAXARGS, 1, do_efi_show_images,
- "efidebug images\n"
- " - show loaded images\n";
#endif
U_BOOT_CMD(
"memmap" command prints uefi-specific memory map information. => efi memmap Type Start End Attributes ================ ================ ================ ========== CONVENTIONAL 0000000040000000-000000007de27000 WB RUNTIME DATA 000000007de27000-000000007de28000 WB|RT RESERVED 000000007de28000-000000007de2a000 WB RUNTIME DATA 000000007de2a000-000000007de2b000 WB|RT RESERVED 000000007de2b000-000000007de2c000 WB RUNTIME DATA 000000007de2c000-000000007de2d000 WB|RT LOADER DATA 000000007de2d000-000000007ff37000 WB RUNTIME CODE 000000007ff37000-000000007ff38000 WB|RT LOADER DATA 000000007ff38000-0000000080000000 WB
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 100 ++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 99 insertions(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 81ab3654f746..39398669e18f 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -309,6 +309,100 @@ static int do_efi_show_images(cmd_tbl_t *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static const char * const efi_mem_type_string[] = { + [EFI_RESERVED_MEMORY_TYPE] = "RESERVED", + [EFI_LOADER_CODE] = "LOADER CODE", + [EFI_LOADER_DATA] = "LOADER DATA", + [EFI_BOOT_SERVICES_CODE] = "BOOT CODE", + [EFI_BOOT_SERVICES_DATA] = "BOOT DATA", + [EFI_RUNTIME_SERVICES_CODE] = "RUNTIME CODE", + [EFI_RUNTIME_SERVICES_DATA] = "RUNTIME DATA", + [EFI_CONVENTIONAL_MEMORY] = "CONVENTIONAL", + [EFI_UNUSABLE_MEMORY] = "UNUSABLE MEM", + [EFI_ACPI_RECLAIM_MEMORY] = "ACPI RECLAIM MEM", + [EFI_ACPI_MEMORY_NVS] = "ACPI NVS", + [EFI_MMAP_IO] = "IO", + [EFI_MMAP_IO_PORT] = "IO PORT", + [EFI_PAL_CODE] = "PAL", +}; + +static const struct efi_mem_attrs { + const u64 bit; + const char *text; +} efi_mem_attrs[] = { + {EFI_MEMORY_UC, "UC"}, + {EFI_MEMORY_UC, "UC"}, + {EFI_MEMORY_WC, "WC"}, + {EFI_MEMORY_WT, "WT"}, + {EFI_MEMORY_WB, "WB"}, + {EFI_MEMORY_UCE, "UCE"}, + {EFI_MEMORY_WP, "WP"}, + {EFI_MEMORY_RP, "RP"}, + {EFI_MEMORY_XP, "WP"}, + {EFI_MEMORY_NV, "NV"}, + {EFI_MEMORY_MORE_RELIABLE, "REL"}, + {EFI_MEMORY_RO, "RO"}, + {EFI_MEMORY_RUNTIME, "RT"}, +}; + +static void print_memory_attributes(u64 attributes) +{ + int sep, i; + + for (sep = 0, i = 0; i < ARRAY_SIZE(efi_mem_attrs); i++) + if (attributes & efi_mem_attrs[i].bit) { + if (sep) { + putc('|'); + } else { + putc(' '); + sep = 1; + } + puts(efi_mem_attrs[i].text); + } +} + +static int do_efi_show_memmap(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct efi_mem_desc *memmap = NULL, *map; + efi_uintn_t map_size = 0; + const char *type; + int i; + efi_status_t ret; + + ret = efi_get_memory_map(&map_size, memmap, NULL, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) { + memmap = malloc(map_size); + if (!memmap) + return CMD_RET_FAILURE; + ret = efi_get_memory_map(&map_size, memmap, NULL, NULL, NULL); + } + if (ret != EFI_SUCCESS) { + free(memmap); + return CMD_RET_FAILURE; + } + + printf("Type Start%.*s End%.*s Attributes\n", + EFI_HANDLE_WIDTH - 5, spc, EFI_HANDLE_WIDTH - 3, spc); + printf("================ %.*s %.*s ==========\n", + EFI_HANDLE_WIDTH, sep, EFI_HANDLE_WIDTH, sep); + for (i = 0, map = memmap; i < map_size / sizeof(*map); map++, i++) { + if (map->type < EFI_MAX_MEMORY_TYPE) + type = efi_mem_type_string[map->type]; + else + type = "(unknown)"; + printf("%-16s %016llx-%016llx", type, map->physical_start, + map->physical_start + map->num_pages * EFI_PAGE_SIZE); + + print_memory_attributes(map->attribute); + putc('\n'); + } + + free(memmap); + + return CMD_RET_SUCCESS; +} + static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -708,6 +802,8 @@ static cmd_tbl_t cmd_efidebug_sub[] = { "", ""), U_BOOT_CMD_MKENT(images, CONFIG_SYS_MAXARGS, 1, do_efi_show_images, "", ""), + U_BOOT_CMD_MKENT(memmap, CONFIG_SYS_MAXARGS, 1, do_efi_show_memmap, + "", ""), };
/* Interpreter command to configure UEFI environment */ @@ -761,7 +857,9 @@ static char efidebug_help_text[] = "efidebug dh\n" " - show uefi handles\n" "efidebug images\n" - " - show loaded images\n"; + " - show loaded images\n" + "efidebug memmap\n" + " - show uefi memory map\n"; #endif
U_BOOT_CMD(
On qemu_arm_defconfig I got this ouptut:
=> efidebug memmap Type Start End Attributes ================ ======== ======== ========== CONVENTIONAL 0000000040000000-000000007ddf8000 WB BOOT DATA 000000007ddf8000-000000007ddfd000 WB RUNTIME DATA 000000007ddfd000-000000007ddfe000 WB|RT RESERVED 000000007ddfe000-000000007ddff000 WB RUNTIME DATA 000000007ddff000-000000007de00000 WB|RT LOADER DATA 000000007de00000-000000007ff42000 WB RUNTIME CODE 000000007ff42000-000000007ff43000 WB|RT LOADER DATA 000000007ff43000-0000000080000000 WB
Something is wrong with you format codes.
- [EFI_RESERVED_MEMORY_TYPE] = "RESERVED",
- [EFI_LOADER_CODE] = "LOADER CODE",
- [EFI_LOADER_DATA] = "LOADER DATA",
- [EFI_BOOT_SERVICES_CODE] = "BOOT CODE",
- [EFI_BOOT_SERVICES_DATA] = "BOOT DATA",
- [EFI_RUNTIME_SERVICES_CODE] = "RUNTIME CODE",
- [EFI_RUNTIME_SERVICES_DATA] = "RUNTIME DATA",
- [EFI_CONVENTIONAL_MEMORY] = "CONVENTIONAL",
- [EFI_UNUSABLE_MEMORY] = "UNUSABLE MEM",
- [EFI_ACPI_RECLAIM_MEMORY] = "ACPI RECLAIM MEM",
- [EFI_ACPI_MEMORY_NVS] = "ACPI NVS",
- [EFI_MMAP_IO] = "IO",
- [EFI_MMAP_IO_PORT] = "IO PORT",
- [EFI_PAL_CODE] = "PAL",
- const u64 bit;
- const char *text;
- {EFI_MEMORY_UC, "UC"},
- {EFI_MEMORY_WC, "WC"},
- {EFI_MEMORY_WT, "WT"},
- {EFI_MEMORY_WB, "WB"},
- {EFI_MEMORY_UCE, "UCE"},
- {EFI_MEMORY_WP, "WP"},
- {EFI_MEMORY_RP, "RP"},
- {EFI_MEMORY_XP, "WP"},
- {EFI_MEMORY_NV, "NV"},
- {EFI_MEMORY_MORE_RELIABLE, "REL"},
- {EFI_MEMORY_RO, "RO"},
- {EFI_MEMORY_RUNTIME, "RT"},
- int sep, i;
- for (sep = 0, i = 0; i < ARRAY_SIZE(efi_mem_attrs); i++)
if (sep) {
putc('|');
} else {
putc(' ');
sep = 1;
- struct efi_mem_desc *memmap = NULL, *map;
- efi_uintn_t map_size = 0;
- const char *type;
- int i;
- efi_status_t ret;
- ret = efi_get_memory_map(&map_size, memmap, NULL, NULL, NULL);
if (!memmap)
free(memmap);
- printf("Type Start%.*s End%.*s Attributes\n",
- printf("================ %.*s %.*s ==========\n",
- for (i = 0, map = memmap; i < map_size / sizeof(*map); map++, i++) {
else
type = "(unknown)";
Width 16 is ok on 64bit systems but not on 32bit ones.
Best regards
Heinrich
putc('\n');
- free(memmap);
- U_BOOT_CMD_MKENT(memmap, CONFIG_SYS_MAXARGS, 1, do_efi_show_memmap,
- "efidebug memmap\n"
- " - show uefi memory map\n";
#endif
U_BOOT_CMD(
- const u64 bit;
- const char *text;
- int sep, i;
if (sep) {
putc('|');
} else {
putc(' ');
sep = 1;
- const char *type;
- int i;
- efi_status_t ret;
if (!memmap)
free(memmap);
else
type = "(unknown)";
It sounds reasonable, but the reality is not so trivial. In struct efi_mem_desc, physical_start is defined as efi_physical_addr_t, and efi_physical_addr_t is defined as u64 whatever the arch is.
So how do we know the system has 64-bit address space?
There is a config, CONFIG_PHYS_64BIT, but it is never defined on x86(_64).
So workable but ugly solution to meet your requirement would be a) if (sizeof(phys_addr_t) >= 8) printf("%-16s %016llx-%016llx", ...); else printf("%-16s %08llx-%08llx", ...); or b) printf("%-16s %p-%p", type, (void *)map->physical_start, ...); (I don't think "void *" always reflects *physical* bit width on LPAE arch though.)
Which do you like better?
Best regards
Heinrich
putc('\n');
- free(memmap);
#endif
U_BOOT_CMD(
- const u64 bit;
- const char *text;
- int sep, i;
if (sep) {
putc('|');
} else {
putc(' ');
sep = 1;
- const char *type;
- int i;
- efi_status_t ret;
if (!memmap)
free(memmap);
else
type = "(unknown)";
Please, use the same constant for both the header line and the list output.
The UEFI spec uses typedef UINT64 EFI_PHYSICAL_ADDRESS;
So it would be appropriate to always print 16 characters.
Best regards
Heinrich
Best regards
Heinrich
putc('\n');
- free(memmap);
#endif
U_BOOT_CMD(
- const u64 bit;
- const char *text;
- int sep, i;
if (sep) {
putc('|');
} else {
putc(' ');
sep = 1;
- const char *type;
- int i;
- efi_status_t ret;
if (!memmap)
free(memmap);
else
type = "(unknown)";
Okay, so you changed your mind.
-Takahiro Akashi
Best regards
Heinrich
Best regards
Heinrich
putc('\n');
- free(memmap);
#endif
U_BOOT_CMD(
This patch set is a collection of patches to enhance efi user interfaces /commands. It will help improve user experience on efi boot and make it more usable *without* edk2's shell utility.
Let's see how it works: => efidebug boot add 1 SHELL scsi 1:1 /Shell.efi "" => efidebug boot add 2 HELLO scsi 1:1 /hello.efi "" => efidebug boot dump Boot0001: attributes: A-- (0x00000001) label: SHELL file_path: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(1,MBR,0x086246ba,0x800,0x40000)/\Shell.efi data: Boot0002: attributes: A-- (0x00000001) label: HELLO file_path: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(1,0)/HD(1,MBR,0x086246ba,0x800,0x40000)/\hello.efi data:
=> efidebug boot order 1 2 => efidebug boot order 1: Boot0001: SHELL 2: Boot0002: HELLO
=> run -e Boot0002 (or bootefi bootmgr - 2) ; '-' means no dtb specified WARNING: booting without device tree Booting: HELLO ## Starting EFI application at 000000007db8b040 ... Hello, world! ## Application terminated, r = 0
=> env set -e PlatformLang en ; important! => env print -e Boot0001: BS|RT, DataSize = 0x79 00000000: 01 00 00 00 66 00 53 00 48 00 45 00 4c 00 4c 00 ....f.S.H.E.L.L. 00000010: 00 00 01 04 14 00 b9 73 1d e6 84 a3 cc 4a ae ab .......s.....J.. 00000020: 82 e8 28 f3 62 8b 03 02 08 00 01 00 00 00 04 01 ..(.b........... 00000030: 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 *............... 00000040: 04 00 00 00 00 00 ba 46 62 08 00 00 00 00 00 00 .......Fb....... 00000050: 00 00 00 00 00 00 01 01 04 04 1c 00 5c 00 5c 00 .............. 00000060: 53 00 68 00 65 00 6c 00 6c 00 2e 00 65 00 66 00 S.h.e.l.l...e.f. 00000070: 69 00 00 00 7f ff 04 00 00 i........ Boot0002: BS|RT, DataSize = 0x79 00000000: 01 00 00 00 66 00 48 00 45 00 4c 00 4c 00 4f 00 ....f.H.E.L.L.O. 00000010: 00 00 01 04 14 00 b9 73 1d e6 84 a3 cc 4a ae ab .......s.....J.. 00000020: 82 e8 28 f3 62 8b 03 02 08 00 01 00 00 00 04 01 ..(.b........... 00000030: 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 *............... 00000040: 04 00 00 00 00 00 ba 46 62 08 00 00 00 00 00 00 .......Fb....... 00000050: 00 00 00 00 00 00 01 01 04 04 1c 00 5c 00 5c 00 .............. 00000060: 68 00 65 00 6c 00 6c 00 6f 00 2e 00 65 00 66 00 h.e.l.l.o...e.f. 00000070: 69 00 00 00 7f ff 04 00 00 i........ BootOrder: BS|RT, DataSize = 0x4 00000000: 01 00 02 00 .... PlatformLang: BS|RT, DataSize = 0x2 00000000: 65 6e en
=> run -e Boot0001 or bootefi bootmgr
(UEFI shell ...)
"env set" command now supports UEFI shell-like syntax:
=> env set -e foo =S"akashi" =0x012345 =Habcdef => env print -e foo foo: BS|RT, DataSize = 0xd 00000000: 61 6b 61 73 68 69 45 23 01 00 ab cd ef akashiE#.....
Other useful sub commands are: => efidebug devices ; print uefi devices => efidebug drivers ; print uefi drivers => efidebug dh ; print uefi handles => efidebug images ; print loaded images => efidebug memmap ; dump uefi memory map
Enjoy!
Did this patch set successfully pass Travis tests? Could you please point me to the results?
Thanks,
Alex
Alex,
(UEFI shell ...)
Enjoy!
Not yet, probably next time? It may take some time for me to set up travis.
-Takahiro Akashi
Thanks,
Alex
AKASHI Takahiro
Alexander Graf
