[U-Boot] [PATCH 2/5][v4] powerpc/mpc85xx: new SPL support for IFC NAND
Linker script is not able find start.o binary. So add its absolute path in u-boot-spl.lds. This change is similar to u-boot-nand.lds
common/Makefile: Avoid compiling unnecssary files
fsl_ifc_spl.c : It is is responsible for reading u-boot binary from NAND flash and copying into DDR. It also transfer cotrol from NAND SPL to u-boot image present in DDR.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master
Changes for v2: Sending as it is Changes for v3: Fix tools/checkpatch errors Changes for v4: Sending as it is
arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 2 +- board/freescale/common/Makefile | 10 ++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsl_ifc_spl.c | 258 +++++++++++++++++++++++++++++++ 4 files changed, 270 insertions(+), 1 deletion(-) create mode 100644 drivers/mtd/nand/fsl_ifc_spl.c
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index f2b7bff..cf6fa7c 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -60,7 +60,7 @@ SECTIONS #if defined(CONFIG_FSL_IFC) /* Restrict bootpg at 4K boundry for IFC */ .bootpg ADDR(.text) + 0x1000 : { - start.o (.bootpg) + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) } #define RESET_VECTOR_OFFSET 0x1ffc /* IFC has 8K sram */ #elif defined(CONFIG_FSL_ELBC) diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 75725b4..a4d521c 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -29,6 +29,15 @@ endif
LIB = $(obj)libfreescale.o
+MINIMAL= + +ifdef CONFIG_SPL_BUILD +ifdef CONFIG_SPL_INIT_MINIMAL +MINIMAL=y +endif +endif + +ifndef MINIMAL COBJS-$(CONFIG_FSL_CADMUS) += cadmus.o COBJS-$(CONFIG_FSL_VIA) += cds_via.o COBJS-$(CONFIG_FMAN_ENET) += fman.o @@ -62,6 +71,7 @@ SUBLIB-$(CONFIG_P3041DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P4080DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5020DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5040DS) += p_corenet/libp_corenet.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index c77c0c4..9d7deb8 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -82,6 +82,7 @@ COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o else # minimal SPL drivers
COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o
endif # drivers endif # nand diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c new file mode 100644 index 0000000..adfe7b1 --- /dev/null +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -0,0 +1,258 @@ +/* + * NAND boot for Freescale Integrated Flash Controller, NAND FCM + * + * Copyright 2011 Freescale Semiconductor, Inc. + * Author: Dipen Dudhat dipen.dudhat@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/fsl_ifc.h> +#include <linux/mtd/nand.h> + +static inline int is_blank(uchar *addr, int page_size) +{ + int i; + + for (i = 0; i < page_size; i++) { + if (__raw_readb(&addr[i]) != 0xff) + return 0; + } + + /* + * For the SPL, don't worry about uncorrectable errors + * where the main area is all FFs but shouldn't be. + */ + return 1; +} + +/* returns nonzero if entire page is blank */ +static inline int check_read_ecc(uchar *buf, u32 *eccstat, + unsigned int bufnum, int page_size) +{ + u32 reg = eccstat[bufnum / 4]; + int errors = (reg >> ((3 - bufnum % 4) * 8)) & 15; + + if (errors == 15) { /* uncorrectable */ + /* Blank pages fail hw ECC checks */ + if (is_blank(buf, page_size)) + return 1; + + puts("ecc error\n"); + for (;;) + ; + } + + return 0; +} + +static inline void nand_wait(uchar *buf, int bufnum, int page_size) +{ + struct fsl_ifc *ifc = IFC_BASE_ADDR; + u32 status; + u32 eccstat[4]; + int bufperpage = page_size / 512; + int bufnum_end, i; + + bufnum *= bufperpage; + bufnum_end = bufnum + bufperpage - 1; + + do { + status = in_be32(&ifc->ifc_nand.nand_evter_stat); + } while (!(status & IFC_NAND_EVTER_STAT_OPC)); + + if (status & IFC_NAND_EVTER_STAT_FTOER) { + puts("flash time out error\n"); + for (;;) + ; + } + + for (i = bufnum / 4; i <= bufnum_end / 4; i++) + eccstat[i] = in_be32(&ifc->ifc_nand.nand_eccstat[i]); + + for (i = bufnum; i <= bufnum_end; i++) { + if (check_read_ecc(buf, eccstat, i, page_size)) + break; + } + + out_be32(&ifc->ifc_nand.nand_evter_stat, status); +} + +static inline int bad_block(uchar *marker, int port_size) +{ + if (port_size == 8) + return __raw_readb(marker) != 0xff; + else + return __raw_readw((u16 *)marker) != 0xffff; +} + +static void nand_load(unsigned int offs, int uboot_size, uchar *dst) +{ + struct fsl_ifc *ifc = IFC_BASE_ADDR; + uchar *buf = (uchar *)CONFIG_SYS_NAND_BASE; + int page_size; + int port_size; + int pages_per_blk; + int blk_size; + int bad_marker = 0; + int bufnum_mask, bufnum; + + int csor, cspr; + int pos = 0; + int j = 0; + + int sram_addr; + int pg_no; + + /* Get NAND Flash configuration */ + csor = CONFIG_SYS_NAND_CSOR; + cspr = CONFIG_SYS_NAND_CSPR; + + port_size = (cspr & CSPR_PORT_SIZE_16) ? 16 : 8; + + if (csor & CSOR_NAND_PGS_4K) { + page_size = 4096; + bufnum_mask = 1; + } else if (csor & CSOR_NAND_PGS_2K) { + page_size = 2048; + bufnum_mask = 3; + } else { + page_size = 512; + bufnum_mask = 15; + + if (port_size == 8) + bad_marker = 5; + } + + pages_per_blk = + 32 << ((csor & CSOR_NAND_PB_MASK) >> CSOR_NAND_PB_SHIFT); + + blk_size = pages_per_blk * page_size; + + /* Open Full SRAM mapping for spare are access */ + out_be32(&ifc->ifc_nand.ncfgr, 0x0); + + /* Clear Boot events */ + out_be32(&ifc->ifc_nand.nand_evter_stat, 0xffffffff); + + /* Program FIR/FCR for Large/Small page */ + if (page_size > 512) { + out_be32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_CMD1 << IFC_NAND_FIR0_OP3_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP4_SHIFT)); + out_be32(&ifc->ifc_nand.nand_fir1, 0x0); + + out_be32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT) | + (NAND_CMD_READSTART << IFC_NAND_FCR0_CMD1_SHIFT)); + } else { + out_be32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_CA0 << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_RA0 << IFC_NAND_FIR0_OP2_SHIFT) | + (IFC_FIR_OP_BTRD << IFC_NAND_FIR0_OP3_SHIFT)); + out_be32(&ifc->ifc_nand.nand_fir1, 0x0); + + out_be32(&ifc->ifc_nand.nand_fcr0, + NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT); + } + + /* Program FBCR = 0 for full page read */ + out_be32(&ifc->ifc_nand.nand_fbcr, 0); + + /* Read and copy u-boot on SDRAM from NAND device, In parallel + * check for Bad block if found skip it and read continue to + * next Block + */ + while (pos < uboot_size) { + int i = 0; + do { + pg_no = offs / page_size; + bufnum = pg_no & bufnum_mask; + sram_addr = bufnum * page_size * 2; + + out_be32(&ifc->ifc_nand.row0, pg_no); + out_be32(&ifc->ifc_nand.col0, 0); + /* start read */ + out_be32(&ifc->ifc_nand.nandseq_strt, + IFC_NAND_SEQ_STRT_FIR_STRT); + + /* wait for read to complete */ + nand_wait(&buf[sram_addr], bufnum, page_size); + + /* + * If either of the first two pages are marked bad, + * continue to the next block. + */ + if (i++ < 2 && + bad_block(&buf[sram_addr + page_size + bad_marker], + port_size)) { + puts("skipping\n"); + offs = (offs + blk_size) & ~(blk_size - 1); + pos &= ~(blk_size - 1); + break; + } + + for (j = 0; j < page_size; j++) + dst[pos + j] = __raw_readb(&buf[sram_addr + j]); + + pos += page_size; + offs += page_size; + } while ((offs & (blk_size - 1)) && (pos < uboot_size)); + } +} + +/* + * Main entrypoint for NAND Boot. It's necessary that SDRAM is already + * configured and available since this code loads the main U-boot image + * from NAND into SDRAM and starts from there. + */ +void nand_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + /* + * Load U-Boot image from NAND into RAM + */ + nand_load(CONFIG_SYS_NAND_U_BOOT_OFFS, CONFIG_SYS_NAND_U_BOOT_SIZE, + (uchar *)CONFIG_SYS_NAND_U_BOOT_DST); + +#ifdef CONFIG_NAND_ENV_DST + nand_load(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_NAND_ENV_DST); + +#ifdef CONFIG_ENV_OFFSET_REDUND + nand_load(CONFIG_ENV_OFFSET_REDUND, CONFIG_ENV_SIZE, + (uchar *)CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE); +#endif +#endif + /* + * Jump to U-Boot image + */ +#ifdef CONFIG_SPL_FLUSH_IMAGE + /* + * Clean d-cache and invalidate i-cache, to + * make sure that no stale data is executed. + */ + flush_cache(CONFIG_SYS_NAND_U_BOOT_DST, CONFIG_SYS_NAND_U_BOOT_SIZE); +#endif + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; + uboot(); +}
Prabhakar Kushwaha
