[U-Boot] ARMv8: Use U-Boot to boot Xen?
are there any U-Boot examples/patches to boot Xen on an ARMv8/aarch64 system?
I've found
http://lists.denx.de/pipermail/u-boot/2015-October/230077.html
what might be helpful.
But maybe I missed anything else?
Many thanks
Dirk
Hi Dirk,
I've found
I'm aware of these:
http://lists.denx.de/pipermail/u-boot/2015-April/211789.html
http://events.linuxfoundation.org/sites/events/files/slides/U-Boot%20FIT%20f...
Many thanks
Dirk _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Dirk,
Cc Ian xen experts.
I've found
I guess you are asking steps how to boot xen using uboot?
You may need to take this: http://wiki.xen.org/wiki/Xen_ARM_with_Virtualization_Extensions
Regards, Peng.
Many thanks
On Fri, 2016-01-29 at 12:04 +0800, Peng Fan wrote:
Hi Dirk,
Cc Ian xen experts.
I've found
Indeed.
In addition one AArch64 system which uses u-boot and which has concrete instructions is the APM X-Gene/Mustang: http://wiki.xen.org/wiki/Xen_ARM_with_Virtualization_Extensions/APMXGeneMust... which would likely be helpful. There are other ARMv7 systems linked from the main page which would have other examples, but for 32-bit.
Ian.
Hi Dirk,
Cc Ian xen experts.
I've found
Indeed.
Yes, that page is very helpful, thanks!
But I think it misses one information, or most probably the configuration on that board is different. Above page just do a 'run xen_run' which in the end does the necessary tftp loading and finally the bootm to start Xen.
So I'd assume that on that board U-Boot runs at EL3 or EL2 (?).
In my environment, U-Boot runs at EL1. I.e. after loading Xen by tftp I somehow need to switch to EL2 to be able to start Xen.
And this is what I think I miss. How to switch from U-Boot running at EL1 to hypervisor mode EL2? Therefore I'd think that
might be helpful.
Best regards
Dirk
Hi Dirk,
Cc Ian xen experts.
I've found
Indeed.
In addition one AArch64 system which uses u-boot and which has concrete instructions is the APM X-Gene/Mustang: http://wiki.xen.org/wiki/Xen_ARM_with_Virtualization_Extensions/AP MXGeneMustang which would likely be helpful.
Once you are in EL1 you cannot get back to EL2 (or EL3) without support from a lower level firmware running in those exception levels. If you have no such underlying firmware then you should arrange for u-boot to run at EL3.
You need to arrange for U-boot to run in EL3 and enter the "kernel" (Xen in this case) in NS EL2. This likely means implementing the PSCI interface for the kernel to use to manage CPUs.
If you were running on a 32-bit system I would direct you towards the CONFIG_ARMV7_PSCI, CONFIG_ARMV7_NONSEC and ARMV7_VIRT u-boot options (which in turn would require your platform code to provide some support). I'm not sure what the equivalent for 64-bit is, sorry.
The link you post is, AFAICT, about the other end i.e. allowing u-boot to talk to an existing secure world firmware beneath it.
Ian.
Dirk Behme
Ian Campbell
Peng Fan
