[U-Boot] [PATCH 2/4] x86: Document irq router device tree bindings
Describe all required properties needed by the irq router device tree.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
doc/device-tree-bindings/misc/intel,irq-router.txt | 50 ++++++++++++++++++++++ 1 file changed, 50 insertions(+) create mode 100644 doc/device-tree-bindings/misc/intel,irq-router.txt
diff --git a/doc/device-tree-bindings/misc/intel,irq-router.txt b/doc/device-tree-bindings/misc/intel,irq-router.txt new file mode 100644 index 0000000..54112f4 --- /dev/null +++ b/doc/device-tree-bindings/misc/intel,irq-router.txt @@ -0,0 +1,50 @@ +Intel Interrupt Router Device Binding +===================================== + +The device tree node which describes the operation of the Intel Interrupt Router +device is as follows: + +Required properties : +- reg : Specifies the interrupt router's PCI configuration space address as + defined by the Open Firmware spec. +- compatible = "intel,irq-router" +- intel,pirq-config : Specifies the IRQ routing register programming mechanism. + Valid values are: + "pci": IRQ routing is controlled by PCI configuraiton registers + "ibase": IRQ routing is in the memory-mapped IBASE register block +- intel,ibase-offset : IBASE register offset in the interrupt router's PCI + configuration space, required only if intel,pirq-config = "ibase". +- intel,pirq-link : Specifies the PIRQ link information with two cells. The + first cell is the register offset that controls the first PIRQ link routing. + The second cell is the total number of PIRQ links the router supports. +- intel,pirq-mask : Specifies the IRQ mask reprenting the 16 IRQs in 8259 PIC. + Bit N is 1 means IRQ N is available to be routed. +- intel,pirq-routing : Specifies all PCI devices' IRQ routing information, + encoded as 3 cells a group for a device. The first cell is the device's PCI + bus number, device number and function number encoding with PCI_BDF() macro. + The second cell is the PCI interrupt pin used by this device. The last cell + is which PIRQ line the PCI interrupt pin is routed to. + + +Example +------- + +#include <dt-bindings/interrupt-router/intel-irq.h> + + irq-router@1f,0 { + reg = <0x0000f800 0 0 0 0>; + compatible = "intel,irq-router"; + intel,pirq-config = "pci"; + intel,pirq-link = <0x60 8>; + intel,pirq-mask = <0xdef8>; + intel,pirq-routing = < + PCI_BDF(0, 2, 0) INTA PIRQA + PCI_BDF(0, 3, 0) INTA PIRQB + PCI_BDF(0, 8, 0) INTA PIRQC + PCI_BDF(0, 8, 1) INTB PIRQD + PCI_BDF(1, 6, 0) INTA PIRQE + PCI_BDF(1, 6, 1) INTB PIRQF + PCI_BDF(1, 6, 2) INTC PIRQG + PCI_BDF(1, 6, 3) INTD PIRQH + >; + };
Andy Pont
Bin Meng
