[PATCH] riscv: Introduce configuration for 64bit version Microblaze V
The commit 7576ab2facae ("riscv: Add support for AMD/Xilinx MicroBlaze V") added support for 32bit version. 64bit version is also available that's why wire it up too. DT is providing description for generic QEMU target.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/riscv/dts/Makefile | 1 + arch/riscv/dts/xilinx-mbv64.dts | 99 ++++++++++++++++++++++++++++ configs/xilinx_mbv64_defconfig | 44 +++++++++++++ configs/xilinx_mbv64_smode_defconfig | 48 ++++++++++++++ 4 files changed, 192 insertions(+) create mode 100644 arch/riscv/dts/xilinx-mbv64.dts create mode 100644 configs/xilinx_mbv64_defconfig create mode 100644 configs/xilinx_mbv64_smode_defconfig
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index bf32ead01b03..de356584bf1e 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -10,6 +10,7 @@ dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb dtb-$(CONFIG_TARGET_STARFIVE_VISIONFIVE2) += jh7110-starfive-visionfive-2.dtb dtb-$(CONFIG_TARGET_TH1520_LPI4A) += th1520-lichee-pi-4a.dtb dtb-$(CONFIG_TARGET_XILINX_MBV) += xilinx-mbv32.dtb +dtb-$(CONFIG_TARGET_XILINX_MBV) += xilinx-mbv64.dtb dtb-$(CONFIG_TARGET_ASPEED_AST2700_IBEX) += ast2700-ibex.dtb
include $(srctree)/scripts/Makefile.dts diff --git a/arch/riscv/dts/xilinx-mbv64.dts b/arch/riscv/dts/xilinx-mbv64.dts new file mode 100644 index 000000000000..4d65d338ecb6 --- /dev/null +++ b/arch/riscv/dts/xilinx-mbv64.dts @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for AMD MicroBlaze V + * + * (C) Copyright 2023 - 2024, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +/dts-v1/; + +#include "binman.dtsi" + +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "AMD MicroBlaze V 64bit"; + compatible = "qemu,mbv", "amd,mbv"; + + cpus: cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <100000000>; + cpu_0: cpu@0 { + compatible = "amd,mbv64", "riscv"; + device_type = "cpu"; + reg = <0>; + riscv,isa = "rv64imafdc"; + i-cache-size = <32768>; + d-cache-size = <32768>; + clock-frequency = <100000000>; + cpu0_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + }; + + aliases { + serial0 = &uart0; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0 0x80000000 0 0x40000000>; + }; + + clk100: clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + axi: axi { + #address-cells = <2>; + #size-cells = <2>; + compatible = "simple-bus"; + ranges; + bootph-all; + + axi_intc: interrupt-controller@41200000 { + compatible = "xlnx,xps-intc-1.00.a"; + reg = <0 0x41200000 0 0x1000>; + interrupt-controller; + interrupt-parent = <&cpu0_intc>; + #interrupt-cells = <2>; + kind-of-intr = <0>; + }; + + xlnx_timer0: timer@41c00000 { + compatible = "xlnx,xps-timer-1.00.a"; + reg = <0 0x41c00000 0 0x1000>; + interrupt-parent = <&axi_intc>; + interrupts = <0 2>; + bootph-all; + xlnx,one-timer-only = <0>; + clock-names = "s_axi_aclk"; + clocks = <&clk100>; + }; + + uart0: serial@40600000 { + compatible = "xlnx,xps-uartlite-1.00.a"; + reg = <0 0x40600000 0 0x1000>; + interrupt-parent = <&axi_intc>; + interrupts = <1 2>; + bootph-all; + clocks = <&clk100>; + current-speed = <115200>; + xlnx,data-bits = <8>; + xlnx,use-parity = <0>; + }; + }; +}; diff --git a/configs/xilinx_mbv64_defconfig b/configs/xilinx_mbv64_defconfig new file mode 100644 index 000000000000..aad9c3f140b2 --- /dev/null +++ b/configs/xilinx_mbv64_defconfig @@ -0,0 +1,44 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0xe00000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x81200000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="xilinx-mbv64" +CONFIG_SPL_STACK=0x80200000 +CONFIG_SPL_BSS_START_ADDR=0x84000000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SYS_LOAD_ADDR=0x80200000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0x40600000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_SYS_CLK_FREQ=100000000 +CONFIG_BOOT_SCRIPT_OFFSET=0x0 +CONFIG_DEBUG_UART=y +CONFIG_TARGET_XILINX_MBV=y +CONFIG_ARCH_RV64I=y +# CONFIG_SPL_SMP is not set +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_BOARD_LATE_INIT is not set +CONFIG_SPL_MAX_SIZE=0x40000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +# CONFIG_CMD_MII is not set +CONFIG_CMD_TIMER=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_MTD=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_XILINX_UARTLITE=y +CONFIG_XILINX_TIMER=y +# CONFIG_BINMAN_FDT is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_GZIP=y diff --git a/configs/xilinx_mbv64_smode_defconfig b/configs/xilinx_mbv64_smode_defconfig new file mode 100644 index 000000000000..628e0ed5be2c --- /dev/null +++ b/configs/xilinx_mbv64_smode_defconfig @@ -0,0 +1,48 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0xe00000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x81200000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="xilinx-mbv64" +CONFIG_SPL_STACK=0x80200000 +CONFIG_SPL_BSS_START_ADDR=0x84000000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SYS_LOAD_ADDR=0x80200000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0x40600000 +CONFIG_DEBUG_UART_CLOCK=1000000 +CONFIG_SYS_CLK_FREQ=100000000 +CONFIG_BOOT_SCRIPT_OFFSET=0x0 +CONFIG_TARGET_XILINX_MBV=y +CONFIG_SPL_OPENSBI_LOAD_ADDR=0x80100000 +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +# CONFIG_SPL_SMP is not set +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_BOARD_LATE_INIT is not set +CONFIG_SPL_MAX_SIZE=0x40000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x2 +# CONFIG_CMD_MII is not set +CONFIG_CMD_TIMER=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_MTD=y +CONFIG_DEBUG_UART_UARTLITE=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_XILINX_UARTLITE=y +# CONFIG_RISCV_TIMER is not set +CONFIG_XILINX_TIMER=y +# CONFIG_BINMAN_FDT is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_GZIP=y
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
From: Simek, Michal michal.simek@amd.com Sent: Friday, November 1, 2024 3:21 PM To: u-boot@lists.denx.de; git@xilinx.com Cc: Chia-Wei Wang chiawei_wang@aspeedtech.com; Conor Dooley conor.dooley@microchip.com; Kongyang Liu seashell11234455@gmail.com; Leo ycliang@andestech.com; Marek Vasut marex@denx.de; Begari, Padmarao Padmarao.Begari@amd.com; Rick Chen rick@andestech.com; Sumit Garg sumit.garg@linaro.org; Tom Rini trini@konsulko.com Subject: [PATCH] riscv: Introduce configuration for 64bit version Microblaze V
Reviewed-by: Padmarao Begari padmarao.begari@amd.com
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index bf32ead01b03..de356584bf1e 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -10,6 +10,7 @@ dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix- bit.dtb dtb-$(CONFIG_TARGET_STARFIVE_VISIONFIVE2) += jh7110-starfive- visionfive-2.dtb dtb-$(CONFIG_TARGET_TH1520_LPI4A) += th1520-lichee-pi-4a.dtb dtb-$(CONFIG_TARGET_XILINX_MBV) += xilinx-mbv32.dtb +dtb-$(CONFIG_TARGET_XILINX_MBV) += xilinx-mbv64.dtb dtb-$(CONFIG_TARGET_ASPEED_AST2700_IBEX) += ast2700-ibex.dtb
- dts file for AMD MicroBlaze V
- (C) Copyright 2023 - 2024, Advanced Micro Devices, Inc.
- Michal Simek michal.simek@amd.com
+/dts-v1/;
- #address-cells = <2>;
- #size-cells = <2>;
- model = "AMD MicroBlaze V 64bit";
- compatible = "qemu,mbv", "amd,mbv";
- cpus: cpus {
#size-cells = <0>;
cpu_0: cpu@0 {
reg = <0>;
- aliases {
serial0 = &uart0;
- chosen {
- memory@80000000 {
- clk100: clock {
#clock-cells = <0>;
- axi: axi {
#size-cells = <2>;
ranges;
bootph-all;
kind-of-intr = <0>;
interrupts = <0 2>;
bootph-all;
clocks = <&clk100>;
interrupts = <1 2>;
bootph-all;
clocks = <&clk100>;
+}; diff --git a/configs/xilinx_mbv64_defconfig b/configs/xilinx_mbv64_defconfig new file mode 100644 index 000000000000..aad9c3f140b2 --- /dev/null +++ b/configs/xilinx_mbv64_defconfig @@ -0,0 +1,44 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0xe00000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x81200000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="xilinx-mbv64" +CONFIG_SPL_STACK=0x80200000 +CONFIG_SPL_BSS_START_ADDR=0x84000000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SYS_LOAD_ADDR=0x80200000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0x40600000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_SYS_CLK_FREQ=100000000 +CONFIG_BOOT_SCRIPT_OFFSET=0x0 +CONFIG_DEBUG_UART=y +CONFIG_TARGET_XILINX_MBV=y +CONFIG_ARCH_RV64I=y +# CONFIG_SPL_SMP is not set +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_BOARD_LATE_INIT is not set +CONFIG_SPL_MAX_SIZE=0x40000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +# CONFIG_CMD_MII is not set +CONFIG_CMD_TIMER=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_MTD=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_XILINX_UARTLITE=y +CONFIG_XILINX_TIMER=y +# CONFIG_BINMAN_FDT is not set +CONFIG_PANIC_HANG=y +CONFIG_SPL_GZIP=y diff --git a/configs/xilinx_mbv64_smode_defconfig b/configs/xilinx_mbv64_smode_defconfig new file mode 100644 index 000000000000..628e0ed5be2c --- /dev/null +++ b/configs/xilinx_mbv64_smode_defconfig @@ -0,0 +1,48 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0xe00000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x81200000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="xilinx-mbv64" +CONFIG_SPL_STACK=0x80200000 +CONFIG_SPL_BSS_START_ADDR=0x84000000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SYS_LOAD_ADDR=0x80200000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0x40600000 +CONFIG_DEBUG_UART_CLOCK=1000000 +CONFIG_SYS_CLK_FREQ=100000000 +CONFIG_BOOT_SCRIPT_OFFSET=0x0 +CONFIG_TARGET_XILINX_MBV=y +CONFIG_SPL_OPENSBI_LOAD_ADDR=0x80100000 +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +# CONFIG_SPL_SMP is not set +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_BOARD_LATE_INIT is not set +CONFIG_SPL_MAX_SIZE=0x40000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x2 +# CONFIG_CMD_MII is not set +CONFIG_CMD_TIMER=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_MTD=y +CONFIG_DEBUG_UART_UARTLITE=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_XILINX_UARTLITE=y +# CONFIG_RISCV_TIMER is not set +CONFIG_XILINX_TIMER=y +# CONFIG_BINMAN_FDT is not set +CONFIG_PANIC_HANG=y
+CONFIG_SPL_GZIP=y
2.43.0
Begari, Padmarao
Leo Liang
Michal Simek
