[U-Boot] [PATCH] mx6: Enable L2 cache support
Add L3 cache support and enable it by default.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 22 ++++++++++++++++++++++ include/configs/mx6_common.h | 5 +++++ 2 files changed, 27 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 0208cba..5e1e5e9 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -8,6 +8,8 @@ */
#include <common.h> +#include <asm/armv7.h> +#include <asm/pl310.h> #include <asm/errno.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> @@ -336,3 +338,23 @@ void imx_setup_hdmi(void) writel(reg, &mxc_ccm->chsccdr); } #endif + +#ifndef CONFIG_SYS_L2CACHE_OFF +#define L2CACHE 1 +void v7_outer_cache_enable(void) +{ + struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; + + setbits_le32(&pl310->pl310_ctrl, L2CACHE); + +} + +void v7_outer_cache_disable(void) +{ + struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; + + clrbits_le32(&pl310->pl310_ctrl, L2CACHE); +} +#endif /* !CONFIG_SYS_L2CACHE_OFF */ diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 514d634..993eca1 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -22,4 +22,9 @@ #define CONFIG_ARM_ERRATA_751472 #define CONFIG_BOARD_POSTCLK_INIT
+#ifndef CONFIG_SYS_L2CACHE_OFF +#define CONFIG_SYS_L2_PL310 +#define CONFIG_SYS_PL310_BASE 0x00A02000 +#endif + #endif
Fabio Estevam
