[PATCH] net: mediatek: fix coding style of AN8855 switch driver
This patch fixed the following coding style suggested by checkpatch.pl: 1. Use tab instead of space 2. Use BIT() instead of << 3. Use mdelay for long time delay 4. Remove useless parenthesises
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/net/mtk_eth/an8855.c | 89 ++++++++++++++++++------------------ 1 file changed, 44 insertions(+), 45 deletions(-)
diff --git a/drivers/net/mtk_eth/an8855.c b/drivers/net/mtk_eth/an8855.c index 4bd7506a58b..25a98e0f935 100644 --- a/drivers/net/mtk_eth/an8855.c +++ b/drivers/net/mtk_eth/an8855.c @@ -22,7 +22,7 @@ #define AN8855_FORCE_MODE_LNK BIT(31) #define AN8855_FORCE_MODE 0xb31593f0
-#define AN8855_PORT_CTRL_BASE (0x10208000) +#define AN8855_PORT_CTRL_BASE 0x10208000 #define AN8855_PORT_CTRL_REG(p, r) (AN8855_PORT_CTRL_BASE + (p) * 0x200 + (r))
#define AN8855_PORTMATRIX_REG(p) AN8855_PORT_CTRL_REG(p, 0x44) @@ -46,7 +46,7 @@
#define AN8855_CKGCR 0x10213e1c
-#define AN8855_SCU_BASE 0x10000000 +#define AN8855_SCU_BASE 0x10000000 #define AN8855_RG_RGMII_TXCK_C (AN8855_SCU_BASE + 0x1d0) #define AN8855_RG_GPIO_LED_MODE (AN8855_SCU_BASE + 0x0054) #define AN8855_RG_GPIO_LED_SEL(i) (AN8855_SCU_BASE + (0x0058 + ((i) * 4))) @@ -66,23 +66,23 @@ #define AN8855_RG_HSGMII_PCS_CTROL_1 (AN8855_HSGMII_CSR_PCS_BASE + 0xa00) #define AN8855_RG_AN_SGMII_MODE_FORCE (AN8855_HSGMII_CSR_PCS_BASE + 0xa24)
-#define AN8855_MULTI_SGMII_CSR_BASE 0x10224000 -#define AN8855_SGMII_STS_CTRL_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x018) +#define AN8855_MULTI_SGMII_CSR_BASE 0x10224000 +#define AN8855_SGMII_STS_CTRL_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x018) #define AN8855_MSG_RX_CTRL_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x100) -#define AN8855_MSG_RX_LIK_STS_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x514) -#define AN8855_MSG_RX_LIK_STS_2 (AN8855_MULTI_SGMII_CSR_BASE + 0x51c) +#define AN8855_MSG_RX_LIK_STS_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x514) +#define AN8855_MSG_RX_LIK_STS_2 (AN8855_MULTI_SGMII_CSR_BASE + 0x51c) #define AN8855_PHY_RX_FORCE_CTRL_0 (AN8855_MULTI_SGMII_CSR_BASE + 0x520)
-#define AN8855_XFI_CSR_PCS_BASE 0x10225000 +#define AN8855_XFI_CSR_PCS_BASE 0x10225000 #define AN8855_RG_USXGMII_AN_CONTROL_0 (AN8855_XFI_CSR_PCS_BASE + 0xbf8)
#define AN8855_MULTI_PHY_RA_CSR_BASE 0x10226000 -#define AN8855_RG_RATE_ADAPT_CTRL_0 (AN8855_MULTI_PHY_RA_CSR_BASE + 0x000) +#define AN8855_RG_RATE_ADAPT_CTRL_0 (AN8855_MULTI_PHY_RA_CSR_BASE + 0x000) #define AN8855_RATE_ADP_P0_CTRL_0 (AN8855_MULTI_PHY_RA_CSR_BASE + 0x100) -#define AN8855_MII_RA_AN_ENABLE (AN8855_MULTI_PHY_RA_CSR_BASE + 0x300) +#define AN8855_MII_RA_AN_ENABLE (AN8855_MULTI_PHY_RA_CSR_BASE + 0x300)
#define AN8855_QP_DIG_CSR_BASE 0x1022a000 -#define AN8855_QP_CK_RST_CTRL_4 (AN8855_QP_DIG_CSR_BASE + 0x310) +#define AN8855_QP_CK_RST_CTRL_4 (AN8855_QP_DIG_CSR_BASE + 0x310) #define AN8855_QP_DIG_MODE_CTRL_0 (AN8855_QP_DIG_CSR_BASE + 0x324) #define AN8855_QP_DIG_MODE_CTRL_1 (AN8855_QP_DIG_CSR_BASE + 0x330)
@@ -90,7 +90,7 @@ #define AN8855_PON_RXFEDIG_CTRL_0 (AN8855_QP_PMA_TOP_BASE + 0x100) #define AN8855_PON_RXFEDIG_CTRL_9 (AN8855_QP_PMA_TOP_BASE + 0x124)
-#define AN8855_SS_LCPLL_PWCTL_SETTING_2 (AN8855_QP_PMA_TOP_BASE + 0x208) +#define AN8855_SS_LCPLL_PWCTL_SETTING_2 (AN8855_QP_PMA_TOP_BASE + 0x208) #define AN8855_SS_LCPLL_TDC_FLT_2 (AN8855_QP_PMA_TOP_BASE + 0x230) #define AN8855_SS_LCPLL_TDC_FLT_5 (AN8855_QP_PMA_TOP_BASE + 0x23c) #define AN8855_SS_LCPLL_TDC_PCW_1 (AN8855_QP_PMA_TOP_BASE + 0x248) @@ -101,7 +101,7 @@ #define AN8855_PLL_CTRL_3 (AN8855_QP_PMA_TOP_BASE + 0x40c) #define AN8855_PLL_CTRL_4 (AN8855_QP_PMA_TOP_BASE + 0x410) #define AN8855_PLL_CK_CTRL_0 (AN8855_QP_PMA_TOP_BASE + 0x414) -#define AN8855_RX_DLY_0 (AN8855_QP_PMA_TOP_BASE + 0x614) +#define AN8855_RX_DLY_0 (AN8855_QP_PMA_TOP_BASE + 0x614) #define AN8855_RX_CTRL_2 (AN8855_QP_PMA_TOP_BASE + 0x630) #define AN8855_RX_CTRL_5 (AN8855_QP_PMA_TOP_BASE + 0x63c) #define AN8855_RX_CTRL_6 (AN8855_QP_PMA_TOP_BASE + 0x640) @@ -118,7 +118,7 @@ #define AN8855_RG_QP_CDR_PR_CKREF_DIV1 (AN8855_QP_ANA_CSR_BASE + 0x18) #define AN8855_RG_QP_CDR_PR_KBAND_DIV_PCIE (AN8855_QP_ANA_CSR_BASE + 0x1c) #define AN8855_RG_QP_CDR_FORCE_IBANDLPF_R_OFF (AN8855_QP_ANA_CSR_BASE + 0x20) -#define AN8855_RG_QP_TX_MODE_16B_EN (AN8855_QP_ANA_CSR_BASE + 0x28) +#define AN8855_RG_QP_TX_MODE_16B_EN (AN8855_QP_ANA_CSR_BASE + 0x28) #define AN8855_RG_QP_PLL_IPLL_DIG_PWR_SEL (AN8855_QP_ANA_CSR_BASE + 0x3c) #define AN8855_RG_QP_PLL_SDM_ORD (AN8855_QP_ANA_CSR_BASE + 0x40)
@@ -135,49 +135,49 @@ #define PHY_SINGLE_LED_ON_DUR(i) (0x3e9 + ((i) * 2)) #define PHY_SINGLE_LED_BLK_DUR(i) (0x3ea + ((i) * 2))
-#define PHY_PMA_CTRL (0x340) +#define PHY_PMA_CTRL 0x340
#define PHY_DEV1F 0x1f
#define PHY_LED_ON_CTRL(i) (0x24 + ((i) * 2)) -#define LED_ON_EN (1 << 15) -#define LED_ON_POL (1 << 14) -#define LED_ON_EVT_MASK (0x7f) +#define LED_ON_EN BIT(15) +#define LED_ON_POL BIT(14) +#define LED_ON_EVT_MASK 0x7f
/* LED ON Event */ -#define LED_ON_EVT_FORCE (1 << 6) -#define LED_ON_EVT_LINK_HD (1 << 5) -#define LED_ON_EVT_LINK_FD (1 << 4) -#define LED_ON_EVT_LINK_DOWN (1 << 3) -#define LED_ON_EVT_LINK_10M (1 << 2) -#define LED_ON_EVT_LINK_100M (1 << 1) -#define LED_ON_EVT_LINK_1000M (1 << 0) +#define LED_ON_EVT_FORCE BIT(6) +#define LED_ON_EVT_LINK_HD BIT(5) +#define LED_ON_EVT_LINK_FD BIT(4) +#define LED_ON_EVT_LINK_DOWN BIT(3) +#define LED_ON_EVT_LINK_10M BIT(2) +#define LED_ON_EVT_LINK_100M BIT(1) +#define LED_ON_EVT_LINK_1000M BIT(0)
#define PHY_LED_BLK_CTRL(i) (0x25 + ((i) * 2)) -#define LED_BLK_EVT_MASK (0x3ff) +#define LED_BLK_EVT_MASK 0x3ff /* LED Blinking Event */ -#define LED_BLK_EVT_FORCE (1 << 9) -#define LED_BLK_EVT_10M_RX_ACT (1 << 5) -#define LED_BLK_EVT_10M_TX_ACT (1 << 4) -#define LED_BLK_EVT_100M_RX_ACT (1 << 3) -#define LED_BLK_EVT_100M_TX_ACT (1 << 2) -#define LED_BLK_EVT_1000M_RX_ACT (1 << 1) -#define LED_BLK_EVT_1000M_TX_ACT (1 << 0) +#define LED_BLK_EVT_FORCE BIT(9) +#define LED_BLK_EVT_10M_RX_ACT BIT(5) +#define LED_BLK_EVT_10M_TX_ACT BIT(4) +#define LED_BLK_EVT_100M_RX_ACT BIT(3) +#define LED_BLK_EVT_100M_TX_ACT BIT(2) +#define LED_BLK_EVT_1000M_RX_ACT BIT(1) +#define LED_BLK_EVT_1000M_TX_ACT BIT(0)
#define PHY_LED_BCR (0x21) -#define LED_BCR_EXT_CTRL (1 << 15) -#define LED_BCR_CLK_EN (1 << 3) -#define LED_BCR_TIME_TEST (1 << 2) -#define LED_BCR_MODE_MASK (3) -#define LED_BCR_MODE_DISABLE (0) +#define LED_BCR_EXT_CTRL BIT(15) +#define LED_BCR_CLK_EN BIT(3) +#define LED_BCR_TIME_TEST BIT(2) +#define LED_BCR_MODE_MASK 3 +#define LED_BCR_MODE_DISABLE 0
-#define PHY_LED_ON_DUR (0x22) -#define LED_ON_DUR_MASK (0xffff) +#define PHY_LED_ON_DUR 0x22 +#define LED_ON_DUR_MASK 0xffff
-#define PHY_LED_BLK_DUR (0x23) -#define LED_BLK_DUR_MASK (0xffff) +#define PHY_LED_BLK_DUR 0x23 +#define LED_BLK_DUR_MASK 0xffff
-#define PHY_LED_BLINK_DUR_CTRL (0x720) +#define PHY_LED_BLINK_DUR_CTRL 0x720
/* Definition of LED */ #define LED_ON_EVENT (LED_ON_EVT_LINK_1000M | \ @@ -993,7 +993,7 @@ static int an8855_setup(struct mtk_eth_switch_priv *swpriv)
/* Switch soft reset */ an8855_reg_write(priv, AN8855_SYS_CTRL_REG, AN8855_SW_SYS_RST); - udelay(100000); + mdelay(100);
an8855_reg_read(priv, AN8855_PKG_SEL, &val); if ((val & 0x7) == PAG_SEL_AN8855H) { @@ -1003,8 +1003,7 @@ static int an8855_setup(struct mtk_eth_switch_priv *swpriv) /* Invert for LED activity change */ an8855_reg_read(priv, AN8855_RG_GPIO_L_INV, &val); for (id = 0; id < ARRAY_SIZE(led_cfg); id++) { - if ((led_cfg[id].pol == LED_HIGH) && - (led_cfg[id].en == 1)) + if (led_cfg[id].pol == LED_HIGH && led_cfg[id].en == 1) val |= 0x1 << id; } an8855_reg_write(priv, AN8855_RG_GPIO_L_INV, (val | 0x1));
Weijie Gao
