[v3, 00/11] mmc: fsl_esdhc: support eMMC HS200/HS400 modes
This patch-set is to support eMMC HS200 and HS400 speed modes for eSDHC, and enable them on LX2160ARDB board.
CI build link https://travis-ci.org/github/yangbolu1991/u-boot-test/builds/710977092
Changes for v2: - Added two patches to fix stability issue. Changes for v3: - Explained more in commit messages. - Added HS400 exit code for downgrade.
Yangbo Lu (11): mmc: add a reinit() API mmc: fsl_esdhc: add a reinit() callback mmc: fsl_esdhc: support tuning for eMMC HS200 mmc: fsl_esdhc: clean TBCTL[TB_EN] manually during init mmc: add a hs400_tuning flag mmc: add a mmc_hs400_prepare_ddr() interface mmc: fsl_esdhc: support eMMC HS400 mode mmc: fsl_esdhc: fix mmc->clock with actual clock mmc: fsl_esdhc: fix eMMC HS400 stability issue arm: dts: lx2160ardb: support eMMC HS400 mode configs: lx2160ardb: enable eMMC HS400 mode support
arch/arm/dts/fsl-lx2160a-rdb.dts | 2 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + drivers/mmc/fsl_esdhc.c | 176 ++++++++++++++++++++++++++- drivers/mmc/mmc-uclass.c | 30 +++++ drivers/mmc/mmc.c | 12 +- include/fsl_esdhc.h | 29 ++++- include/mmc.h | 26 +++- 9 files changed, 268 insertions(+), 10 deletions(-)
For DM_MMC, the controller re-initialization is needed to clear old configuration for mmc rescan.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - None. --- drivers/mmc/mmc-uclass.c | 15 +++++++++++++++ drivers/mmc/mmc.c | 8 ++++++-- include/mmc.h | 10 ++++++++++ 3 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index c5b7872..b9f0880 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -170,6 +170,21 @@ int mmc_deferred_probe(struct mmc *mmc) return dm_mmc_deferred_probe(mmc->dev); }
+int dm_mmc_reinit(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (ops->reinit) + return ops->reinit(dev); + + return 0; +} + +int mmc_reinit(struct mmc *mmc) +{ + return dm_mmc_reinit(mmc->dev); +} + int mmc_of_parse(struct udevice *dev, struct mmc_config *cfg) { int val; diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index f36d11d..a4c6153 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2818,13 +2818,17 @@ int mmc_get_op_cond(struct mmc *mmc) return err;
#if CONFIG_IS_ENABLED(DM_MMC) - /* The device has already been probed ready for use */ + /* + * Re-initialization is needed to clear old configuration for + * mmc rescan. + */ + err = mmc_reinit(mmc); #else /* made sure it's not NULL earlier */ err = mmc->cfg->ops->init(mmc); +#endif if (err) return err; -#endif mmc->ddr_mode = 0;
retry: diff --git a/include/mmc.h b/include/mmc.h index 8256219..161b8bc 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -422,6 +422,14 @@ struct dm_mmc_ops { */ int (*deferred_probe)(struct udevice *dev); /** + * reinit() - Re-initialization to clear old configuration for + * mmc rescan. + * + * @dev: Device to reinit + * @return 0 if Ok, -ve if error + */ + int (*reinit)(struct udevice *dev); + /** * send_cmd() - Send a command to the MMC device * * @dev: Device to receive the command @@ -518,6 +526,7 @@ int dm_mmc_execute_tuning(struct udevice *dev, uint opcode); int dm_mmc_wait_dat0(struct udevice *dev, int state, int timeout_us); int dm_mmc_host_power_cycle(struct udevice *dev); int dm_mmc_deferred_probe(struct udevice *dev); +int dm_mmc_reinit(struct udevice *dev); int dm_mmc_get_b_max(struct udevice *dev, void *dst, lbaint_t blkcnt);
/* Transition functions for compatibility */ @@ -529,6 +538,7 @@ int mmc_wait_dat0(struct mmc *mmc, int state, int timeout_us); int mmc_set_enhanced_strobe(struct mmc *mmc); int mmc_host_power_cycle(struct mmc *mmc); int mmc_deferred_probe(struct mmc *mmc); +int mmc_reinit(struct mmc *mmc); int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt);
#else
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes for v2:
- None.
Changes for v3:
- None.
- struct dm_mmc_ops *ops = mmc_get_ops(dev);
- if (ops->reinit)
- return dm_mmc_reinit(mmc->dev);
* mmc rescan.
- err = mmc_reinit(mmc);
* mmc rescan.
- int (*reinit)(struct udevice *dev);
- send_cmd() - Send a command to the MMC device
- @dev: Device to receive the command
#else
Add a reinit() callback for mmc rescan.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - None. --- drivers/mmc/fsl_esdhc.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index f6e0d43..4fff7b5 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -946,6 +946,14 @@ static int fsl_esdhc_set_ios(struct udevice *dev) return esdhc_set_ios_common(priv, &plat->mmc); }
+static int fsl_esdhc_reinit(struct udevice *dev) +{ + struct fsl_esdhc_plat *plat = dev_get_platdata(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + + return esdhc_init_common(priv, &plat->mmc); +} + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, @@ -953,6 +961,7 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { #ifdef MMC_SUPPORTS_TUNING .execute_tuning = fsl_esdhc_execute_tuning, #endif + .reinit = fsl_esdhc_reinit, };
static const struct udevice_id fsl_esdhc_ids[] = {
Changes for v2:
- None.
Changes for v3:
- None.
- struct fsl_esdhc_plat *plat = dev_get_platdata(dev);
- struct fsl_esdhc_priv *priv = dev_get_priv(dev);
- return esdhc_init_common(priv, &plat->mmc);
- .reinit = fsl_esdhc_reinit,
Support tuning process for eMMC HS200 for eSDHC.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - Rebased. --- drivers/mmc/fsl_esdhc.c | 106 ++++++++++++++++++++++++++++++++++++++++++++++-- include/fsl_esdhc.h | 17 ++++++-- 2 files changed, 116 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 4fff7b5..fc9d0c9 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -60,7 +60,9 @@ struct fsl_esdhc { uint dmaerrattr; /* DMA error attribute register */ char reserved5[4]; /* reserved */ uint hostcapblt2; /* Host controller capabilities register 2 */ - char reserved6[756]; /* reserved */ + char reserved6[8]; /* reserved */ + uint tbctl; /* Tuning block control register */ + char reserved7[744]; /* reserved */ uint esdhcctl; /* eSDHC control register */ };
@@ -101,7 +103,9 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) if (data) { xfertyp |= XFERTYP_DPSEL; #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - xfertyp |= XFERTYP_DMAEN; + if (cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK && + cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK_HS200) + xfertyp |= XFERTYP_DMAEN; #endif if (data->blocks > 1) { xfertyp |= XFERTYP_MSBSEL; @@ -380,6 +384,10 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, esdhc_write32(®s->cmdarg, cmd->cmdarg); esdhc_write32(®s->xfertyp, xfertyp);
+ if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) + flags = IRQSTAT_BRR; + /* Wait for the command to complete */ start = get_timer(0); while (!(esdhc_read32(®s->irqstat) & flags)) { @@ -439,6 +447,11 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, #ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO esdhc_pio_read_write(priv, data); #else + flags = DATA_COMPLETE; + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) + flags = IRQSTAT_BRR; + do { irqstat = esdhc_read32(®s->irqstat);
@@ -451,7 +464,7 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, err = -ECOMM; goto out; } - } while ((irqstat & DATA_COMPLETE) != DATA_COMPLETE); + } while ((irqstat & flags) != flags);
/* * Need invalidate the dcache here again to avoid any @@ -555,6 +568,19 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) } }
+static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + + if (mode == MMC_HS_200) + esdhc_clrsetbits32(®s->autoc12err, UHSM_MASK, + UHSM_SDR104_HS200); + + esdhc_clock_control(priv, true); +} + static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) { struct fsl_esdhc *regs = priv->esdhc_regs; @@ -570,6 +596,9 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock);
+ /* Set timing */ + esdhc_set_timing(priv, mmc->selected_mode); + /* Set the bus width */ esdhc_clrbits32(®s->proctl, PROCTL_DTW_4 | PROCTL_DTW_8);
@@ -954,6 +983,77 @@ static int fsl_esdhc_reinit(struct udevice *dev) return esdhc_init_common(priv, &plat->mmc); }
+#ifdef MMC_SUPPORTS_TUNING +static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 time_out; + + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); + + time_out = 20; + while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { + if (time_out == 0) { + printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); + break; + } + time_out--; + mdelay(1); + } +} + +static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, + bool en) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + if (en) + esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); + else + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_clock_control(priv, true); +} + +static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) +{ + struct fsl_esdhc_plat *plat = dev_get_platdata(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 val, irqstaten; + int i; + + esdhc_tuning_block_enable(priv, true); + esdhc_setbits32(®s->autoc12err, EXECUTE_TUNING); + + irqstaten = esdhc_read32(®s->irqstaten); + esdhc_write32(®s->irqstaten, IRQSTATEN_BRR); + + for (i = 0; i < MAX_TUNING_LOOP; i++) { + mmc_send_tuning(&plat->mmc, opcode, NULL); + mdelay(1); + + val = esdhc_read32(®s->autoc12err); + if (!(val & EXECUTE_TUNING)) { + if (val & SMPCLKSEL) + break; + } + } + + esdhc_write32(®s->irqstaten, irqstaten); + + if (i != MAX_TUNING_LOOP) + return 0; + + printf("fsl_esdhc: tuning failed!\n"); + esdhc_clrbits32(®s->autoc12err, SMPCLKSEL); + esdhc_clrbits32(®s->autoc12err, EXECUTE_TUNING); + esdhc_tuning_block_enable(priv, false); + return -ETIMEDOUT; +} +#endif + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 2615d1a..aaa5941 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -78,8 +78,10 @@ #define IRQSTATEN_TC (0x00000002) #define IRQSTATEN_CC (0x00000001)
+/* eSDHC control register */ #define ESDHCCTL 0x0002e40c #define ESDHCCTL_PCS (0x00080000) +#define ESDHCCTL_FAF (0x00040000)
#define PRSSTAT 0x0002e024 #define PRSSTAT_DAT0 (0x01000000) @@ -158,6 +160,12 @@ #define BLKATTR_SIZE(x) (x & 0x1fff) #define MAX_BLK_CNT 0x7fff /* so malloc will have enough room with 32M */
+/* Auto CMD error status register / system control 2 register */ +#define EXECUTE_TUNING 0x00400000 +#define SMPCLKSEL 0x00800000 +#define UHSM_MASK 0x00070000 +#define UHSM_SDR104_HS200 0x00030000 + /* Host controller capabilities register */ #define HOSTCAPBLT_VS18 0x04000000 #define HOSTCAPBLT_VS30 0x02000000 @@ -166,6 +174,11 @@ #define HOSTCAPBLT_DMAS 0x00400000 #define HOSTCAPBLT_HSS 0x00200000
+/* Tuning block control register */ +#define TBCTL_TB_EN 0x00000004 + +#define MAX_TUNING_LOOP 40 + struct fsl_esdhc_cfg { phys_addr_t esdhc_base; u32 sdhc_clk; @@ -207,10 +220,6 @@ struct fsl_esdhc_cfg { int fsl_esdhc_mmc_init(struct bd_info *bis); int fsl_esdhc_initialize(struct bd_info *bis, struct fsl_esdhc_cfg *cfg); void fdt_fixup_esdhc(void *blob, struct bd_info *bd); -#ifdef MMC_SUPPORTS_TUNING -static inline int fsl_esdhc_execute_tuning(struct udevice *dev, - uint32_t opcode) {return 0; } -#endif #else static inline int fsl_esdhc_mmc_init(struct bd_info *bis) { return -ENOSYS; } static inline void fdt_fixup_esdhc(void *blob, struct bd_info *bd) {}
Clean TBCTL[TB_EN] manually during init since it is not able to be reset by reset all operation.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - None. --- drivers/mmc/fsl_esdhc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index fc9d0c9..c52ab0f 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -637,6 +637,9 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) return -ETIMEDOUT; }
+ /* Clean TBCTL[TB_EN] which is not able to be reset by reset all */ + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_enable_cache_snooping(regs);
esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
Some controllers may have difference between HS200 tuning and HS400 tuning, such as different registers setting, different procedure, or different errata.
This patch is to add a hs400_tuning flag to identify the tuning for HS400 mode.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - Explained more in commit messages. --- drivers/mmc/mmc.c | 2 ++ include/mmc.h | 1 + 2 files changed, 3 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a4c6153..f020a8e 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1981,7 +1981,9 @@ static int mmc_select_hs400(struct mmc *mmc) mmc_set_clock(mmc, mmc->tran_speed, false);
/* execute tuning if needed */ + mmc->hs400_tuning = 1; err = mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200); + mmc->hs400_tuning = 0; if (err) { debug("tuning failed\n"); return err; diff --git a/include/mmc.h b/include/mmc.h index 161b8bc..2399cc2 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -707,6 +707,7 @@ struct mmc { * accessing the boot partitions */ u32 quirks; + u8 hs400_tuning; };
struct mmc_hwpart_conf {
Changes for v2:
- None.
Changes for v3:
- mmc->hs400_tuning = 1; err = mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200);
- mmc->hs400_tuning = 0;
It seems that it's fsl_esdhc specific flag. Is it need to set to 0?
- u8 hs400_tuning;
Hi Jaehoon,
-----Original Message----- From: Jaehoon Chung jh80.chung@samsung.com Sent: Tuesday, August 25, 2020 6:54 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; Priyanka Jain priyanka.jain@nxp.com Subject: Re: [v3, 05/11] mmc: add a hs400_tuning flag
Changes for v2:
- None.
Changes for v3:
From mmc driver, both HS200 and HS400 tuning are through mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200). But as I commented in commit message, "Some controllers may have difference between HS200 tuning and HS400 tuning, such as different registers setting, different procedure, or different errata." So we could use such flag to indicate the tuning in progress is for HS400. Set it before tuning and clean after tuning. By now, only fsl_esdhc is using it. I can't predict whether there will be other controllers use it, but at least we need a method to identify HS400 tuning to support eSDHC HS400 currently. There are also errata for eSDHC HS400 tuning. I will send patches in the future. Thanks.
- u8 hs400_tuning;
Add a mmc_hs400_prepare_ddr() interface for controllers which needs preparation before switching to DDR mode for HS400 mode.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - None. --- drivers/mmc/mmc-uclass.c | 15 +++++++++++++++ drivers/mmc/mmc.c | 2 ++ include/mmc.h | 15 ++++++++++++++- 3 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index b9f0880..240b205 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -141,6 +141,21 @@ int mmc_set_enhanced_strobe(struct mmc *mmc) } #endif
+int dm_mmc_hs400_prepare_ddr(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (ops->hs400_prepare_ddr) + return ops->hs400_prepare_ddr(dev); + + return 0; +} + +int mmc_hs400_prepare_ddr(struct mmc *mmc) +{ + return dm_mmc_hs400_prepare_ddr(mmc->dev); +} + int dm_mmc_host_power_cycle(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev); diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index f020a8e..935fa72 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1992,6 +1992,8 @@ static int mmc_select_hs400(struct mmc *mmc) /* Set back to HS */ mmc_set_card_speed(mmc, MMC_HS, true);
+ mmc_hs400_prepare_ddr(mmc); + err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BUS_WIDTH, EXT_CSD_BUS_WIDTH_8 | EXT_CSD_DDR_FLAG); if (err) diff --git a/include/mmc.h b/include/mmc.h index 2399cc2..659df75 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -513,6 +513,14 @@ struct dm_mmc_ops { * @return maximum number of blocks for this transfer */ int (*get_b_max)(struct udevice *dev, void *dst, lbaint_t blkcnt); + + /** + * hs400_prepare_ddr - prepare to switch to DDR mode + * + * @dev: Device to check + * @return 0 if success, -ve on error + */ + int (*hs400_prepare_ddr)(struct udevice *dev); };
#define mmc_get_ops(dev) ((struct dm_mmc_ops *)(dev)->driver->ops) @@ -540,7 +548,7 @@ int mmc_host_power_cycle(struct mmc *mmc); int mmc_deferred_probe(struct mmc *mmc); int mmc_reinit(struct mmc *mmc); int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt); - +int mmc_hs400_prepare_ddr(struct mmc *mmc); #else struct mmc_ops { int (*send_cmd)(struct mmc *mmc, @@ -552,6 +560,11 @@ struct mmc_ops { int (*host_power_cycle)(struct mmc *mmc); int (*get_b_max)(struct mmc *mmc, void *dst, lbaint_t blkcnt); }; + +static inline int mmc_hs400_prepare_ddr(struct mmc *mmc) +{ + return 0; +} #endif
struct mmc_config {
Changes for v2:
- None.
Changes for v3:
- None.
- if (ops->hs400_prepare_ddr)
- return dm_mmc_hs400_prepare_ddr(mmc->dev);
- mmc_hs400_prepare_ddr(mmc);
not need to get the return value? you have defined mmc_hs400_prepare_ddr() as int return type.
- err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BUS_WIDTH, EXT_CSD_BUS_WIDTH_8 | EXT_CSD_DDR_FLAG); if (err)
- int (*hs400_prepare_ddr)(struct udevice *dev);
+} #endif
struct mmc_config {
Hi Jaehoon,
-----Original Message----- From: Jaehoon Chung jh80.chung@samsung.com Sent: Tuesday, August 25, 2020 6:54 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; Priyanka Jain priyanka.jain@nxp.com Subject: Re: [v3, 06/11] mmc: add a mmc_hs400_prepare_ddr() interface
Changes for v2:
- None.
Changes for v3:
- None.
I will add returning checking. Thanks!
EXT_CSD_BUS_WIDTH,
+} #endif
struct mmc_config {
The process for eMMC HS400 mode for eSDHC is,
1. Perform the Tuning Process at the HS400 target operating frequency. Latched the clock division value. 2. if read transaction, then set the SDTIMNGCTL[FLW_CTL_BG]. 3. Switch to High Speed mode and then set the card clock frequency to a value not greater than 52Mhz 4. Clear TBCTL[TB_EN],tuning block enable bit. 5. Change to 8 bit DDR Mode 6. Switch the card to HS400 mode. 7. Set TBCTL[TB_EN], tuning block enable bit. 8. Clear SYSCTL[SDCLKEN] 9. Wait for PRSSTAT[SDSTB] to be set 10. Change the clock division to latched value.Set TBCTL[HS 400 mode] and Set SDCLKCTL[CMD_CLK_CTRL] 11. Set SYSCTL[SDCLKEN] 12. Wait for PRSSTAT[SDSTB] to be set 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 14. Wait for delay chain to lock. 15. Set TBCTL[HS400_WNDW_ADJUST] 16. Again clear SYSCTL[SDCLKEN] 17. Wait for PRSSTAT[SDSTB] to be set 18. Set ESDHCCTL[FAF] 19. Wait for ESDHCCTL[FAF] to be cleared 20. Set SYSCTL[SDCLKEN] 21. Wait for PRSSTAT[SDSTB] to be set.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - Added HS400 exit code for downgrade. --- drivers/mmc/fsl_esdhc.c | 120 ++++++++++++++++++++++++++++++++++-------------- include/fsl_esdhc.h | 12 +++++ 2 files changed, 98 insertions(+), 34 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index c52ab0f..f2ab75c 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -62,7 +62,12 @@ struct fsl_esdhc { uint hostcapblt2; /* Host controller capabilities register 2 */ char reserved6[8]; /* reserved */ uint tbctl; /* Tuning block control register */ - char reserved7[744]; /* reserved */ + char reserved7[32]; /* reserved */ + uint sdclkctl; /* SD clock control register */ + uint sdtimingctl; /* SD timing control register */ + char reserved8[20]; /* reserved */ + uint dllcfg0; /* DLL config 0 register */ + char reserved9[680]; /* reserved */ uint esdhcctl; /* eSDHC control register */ };
@@ -568,16 +573,80 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) } }
+static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 time_out; + + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); + + time_out = 20; + while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { + if (time_out == 0) { + printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); + break; + } + time_out--; + mdelay(1); + } +} + +static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, + bool en) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + if (en) + esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); + else + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_clock_control(priv, true); +} + +static void esdhc_exit_hs400(struct fsl_esdhc_priv *priv) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clrbits32(®s->sdtimingctl, FLW_CTL_BG); + esdhc_clrbits32(®s->sdclkctl, CMD_CLK_CTL); + + esdhc_clock_control(priv, false); + esdhc_clrbits32(®s->tbctl, HS400_MODE); + esdhc_clock_control(priv, true); + + esdhc_clrbits32(®s->dllcfg0, DLL_FREQ_SEL | DLL_ENABLE); + esdhc_clrbits32(®s->tbctl, HS400_WNDW_ADJUST); + + esdhc_tuning_block_enable(priv, false); +} + static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) { struct fsl_esdhc *regs = priv->esdhc_regs;
+ /* Exit HS400 mode before setting any other mode */ + if (esdhc_read32(®s->tbctl) & HS400_MODE && + mode != MMC_HS_400) + esdhc_exit_hs400(priv); + esdhc_clock_control(priv, false);
if (mode == MMC_HS_200) esdhc_clrsetbits32(®s->autoc12err, UHSM_MASK, UHSM_SDR104_HS200); + if (mode == MMC_HS_400) { + esdhc_setbits32(®s->tbctl, HS400_MODE); + esdhc_setbits32(®s->sdclkctl, CMD_CLK_CTL); + esdhc_clock_control(priv, true);
+ esdhc_setbits32(®s->dllcfg0, DLL_ENABLE | DLL_FREQ_SEL); + esdhc_setbits32(®s->tbctl, HS400_WNDW_ADJUST); + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + } esdhc_clock_control(priv, true); }
@@ -592,6 +661,9 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) esdhc_clock_control(priv, true); }
+ if (mmc->selected_mode == MMC_HS_400) + esdhc_tuning_block_enable(priv, true); + /* Set the clock speed */ if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock); @@ -987,38 +1059,6 @@ static int fsl_esdhc_reinit(struct udevice *dev) }
#ifdef MMC_SUPPORTS_TUNING -static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) -{ - struct fsl_esdhc *regs = priv->esdhc_regs; - u32 time_out; - - esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); - - time_out = 20; - while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { - if (time_out == 0) { - printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); - break; - } - time_out--; - mdelay(1); - } -} - -static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, - bool en) -{ - struct fsl_esdhc *regs = priv->esdhc_regs; - - esdhc_clock_control(priv, false); - esdhc_flush_async_fifo(priv); - if (en) - esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); - else - esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); - esdhc_clock_control(priv, true); -} - static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) { struct fsl_esdhc_plat *plat = dev_get_platdata(dev); @@ -1046,8 +1086,11 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode)
- if (i != MAX_TUNING_LOOP) + if (i != MAX_TUNING_LOOP) { + if (plat->mmc.hs400_tuning) + esdhc_setbits32(®s->sdtimingctl, FLW_CTL_BG); return 0; + }
printf("fsl_esdhc: tuning failed!\n"); esdhc_clrbits32(®s->autoc12err, SMPCLKSEL); @@ -1057,6 +1100,14 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) } #endif
+int fsl_esdhc_hs400_prepare_ddr(struct udevice *dev) +{ + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + + esdhc_tuning_block_enable(priv, false); + return 0; +} + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, @@ -1065,6 +1116,7 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { .execute_tuning = fsl_esdhc_execute_tuning, #endif .reinit = fsl_esdhc_reinit, + .hs400_prepare_ddr = fsl_esdhc_hs400_prepare_ddr, };
static const struct udevice_id fsl_esdhc_ids[] = { diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index aaa5941..b35ef0c 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -176,6 +176,18 @@
/* Tuning block control register */ #define TBCTL_TB_EN 0x00000004 +#define HS400_MODE 0x00000010 +#define HS400_WNDW_ADJUST 0x00000040 + +/* SD clock control register */ +#define CMD_CLK_CTL 0x00008000 + +/* SD timing control register */ +#define FLW_CTL_BG 0x00008000 + +/* DLL config 0 register */ +#define DLL_ENABLE 0x80000000 +#define DLL_FREQ_SEL 0x08000000
Fix mmc->clock with actual clock which is divided by the controller, and record it with priv->clock which was removed accidentally.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Added this patch. Changes for v3: - None. --- drivers/mmc/fsl_esdhc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index f2ab75c..716f53e 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -523,6 +523,9 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) while (sdhc_clk / (div * pre_div) > clock && div < 16) div++;
+ mmc->clock = sdhc_clk / pre_div / div; + priv->clock = mmc->clock; + pre_div >>= 1; div -= 1;
There was a fix-up for eMMC HS400 stability issue in Linux.
Patch link: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/ commit/?id=58d0bf843b49fa99588ac9f85178bd8dfd651b53
Description: Currently only LX2160A eSDHC supports eMMC HS400. According to a large number of tests, eMMC HS400 failed to work at 150MHz, and for a few boards failed to work at 175MHz. But eMMC HS400 worked fine on 200MHz. We hadn't found the root cause but setting eSDHC_DLLCFG0[DLL_FREQ_SEL] = 0 using slow delay chain seemed to resovle this issue. Let's use this as fixup for now.
Introduce the fix-up in u-boot since the issue could be reproduced in u-boot too.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Added this patch. Changes for v3: - None. --- drivers/mmc/fsl_esdhc.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 716f53e..20e3ff9 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -644,7 +644,10 @@ static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) esdhc_setbits32(®s->sdclkctl, CMD_CLK_CTL); esdhc_clock_control(priv, true);
- esdhc_setbits32(®s->dllcfg0, DLL_ENABLE | DLL_FREQ_SEL); + if (priv->clock == 200000000) + esdhc_setbits32(®s->dllcfg0, DLL_FREQ_SEL); + + esdhc_setbits32(®s->dllcfg0, DLL_ENABLE); esdhc_setbits32(®s->tbctl, HS400_WNDW_ADJUST);
Add properties related to eMMC HS400 mode.
mmc-hs400-1_8v; bus-width = <8>;
They had been already in kernel dts file since the first lx2160ardb dts patch.
b068890 arm64: dts: add LX2160ARDB board support
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - Explained more in commit message. --- arch/arm/dts/fsl-lx2160a-rdb.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/fsl-lx2160a-rdb.dts b/arch/arm/dts/fsl-lx2160a-rdb.dts index d787778..5fbdd90 100644 --- a/arch/arm/dts/fsl-lx2160a-rdb.dts +++ b/arch/arm/dts/fsl-lx2160a-rdb.dts @@ -80,6 +80,8 @@ &esdhc1 { status = "okay"; mmc-hs200-1_8v; + mmc-hs400-1_8v; + bus-width = <8>; };
&fspi {
Enable eMMC HS400 mode support on LX2160ARDB.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. Changes for v3: - None. --- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 12e224f..6c65853 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index a5c78d2..a5c60c8 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index e97c9b0..869d4e2 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y
Any commets on the v3 patch-set. Thanks!
Best regards, Yangbo Lu
-----Original Message----- From: Yangbo Lu yangbo.lu@nxp.com Sent: Thursday, July 23, 2020 12:30 PM To: u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: [v3, 00/11] mmc: fsl_esdhc: support eMMC HS200/HS400 modes
CI build link https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftravis-ci .org%2Fgithub%2Fyangbolu1991%2Fu-boot-test%2Fbuilds%2F710977092&a mp;data=02%7C01%7Cyangbo.lu%40nxp.com%7Cad44ad82358841b1750d08 d82ec207a0%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63731 0758167126235&sdata=u8fiHRayfKhk%2FiFGjXItjlHmyWWk9MMqbWHz WeId60c%3D&reserved=0
Changes for v2:
Changes for v3:
-- 2.7.4
Hi Yangbo,
Sorry for late. I will test with your patch on my target. Today, i will reply about your patch.
CI build link https://protect2.fireeye.com/v1/url?k=035d63a4-5e936277-035ce8eb-000babff317... .org%2Fgithub%2Fyangbolu1991%2Fu-boot-test%2Fbuilds%2F710977092&a mp;data=02%7C01%7Cyangbo.lu%40nxp.com%7Cad44ad82358841b1750d08 d82ec207a0%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63731 0758167126235&sdata=u8fiHRayfKhk%2FiFGjXItjlHmyWWk9MMqbWHz WeId60c%3D&reserved=0
Changes for v2:
Changes for v3:
-- 2.7.4
Jaehoon Chung
Y.b. Lu
Yangbo Lu
