[PATCH v3 0/6] cmd: provide command to display SMBIOS information
U-Boot may supply an SMBIOS table or they may be copied from QEMU.
Provide a command to display the SMBIOS information.
Currently only type 1 and 2 are translated to human readable text. Other types may be added later. Currently only a hexdump and the list of strings is provided for these.
The following prerequisite had to be fixed:
* The definition of SMBIOS type 2 lacked a field.
v3: enable smbios command only on sandbox and qemu_arm64_defconfig v2: for generic boards we only can assume that a type 127 table exists email address updated
Heinrich Schuchardt (6): smbios: type2: contained object handles cmd: provide command to display SMBIOS information doc: man-page for smbios command test: unit test for smbios command configs: enable smbios command on sandbox configs: enable smbios command on qemu_arm64_defconfig
cmd/Kconfig | 6 ++ cmd/Makefile | 1 + cmd/smbios.c | 191 +++++++++++++++++++++++++++++++++++ configs/qemu_arm64_defconfig | 1 + configs/sandbox_defconfig | 1 + doc/usage/cmd/smbios.rst | 93 +++++++++++++++++ doc/usage/index.rst | 1 + include/smbios.h | 1 + test/py/tests/test_smbios.py | 41 ++++++++ 9 files changed, 336 insertions(+) create mode 100644 cmd/smbios.c create mode 100644 doc/usage/cmd/smbios.rst create mode 100644 test/py/tests/test_smbios.py
The type 2 structure must include information about the contained objects. It is fine to set the number of contained object handles to 0.
Add the missing field.
Fixes: 721e992a8af5 ("x86: Add SMBIOS table support") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v3: no change v2: email address updated --- include/smbios.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/smbios.h b/include/smbios.h index b507b9d9d72..98bb9e52cdf 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -139,6 +139,7 @@ struct __packed smbios_type2 { u8 chassis_location; u16 chassis_handle; u8 board_type; + u8 number_contained_objects; char eos[SMBIOS_STRUCT_EOS_BYTES]; };
U-Boot can either generated an SMBIOS table or copy it from a prior boot stage, e.g. QEMU.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v3: do not enable the command by default v2: email address updated --- cmd/Kconfig | 6 ++ cmd/Makefile | 1 + cmd/smbios.c | 191 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 198 insertions(+) create mode 100644 cmd/smbios.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 58ab357c707..435bb04e551 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -232,6 +232,12 @@ config CMD_SBI help Display information about the SBI implementation.
+config CMD_SMBIOS + bool "smbios" + depends on SMBIOS + help + Display the SMBIOS information. + endmenu
menu "Boot commands" diff --git a/cmd/Makefile b/cmd/Makefile index e2a2b16ab25..87133cc27a8 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -168,6 +168,7 @@ obj-$(CONFIG_CMD_SETEXPR) += setexpr.o obj-$(CONFIG_CMD_SETEXPR_FMT) += printf.o obj-$(CONFIG_CMD_SPI) += spi.o obj-$(CONFIG_CMD_STRINGS) += strings.o +obj-$(CONFIG_CMD_SMBIOS) += smbios.o obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o obj-$(CONFIG_CMD_STACKPROTECTOR_TEST) += stackprot_test.o diff --git a/cmd/smbios.c b/cmd/smbios.c new file mode 100644 index 00000000000..feebf930b79 --- /dev/null +++ b/cmd/smbios.c @@ -0,0 +1,191 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * The 'smbios' command displays information from the SMBIOS table. + * + * Copyright (c) 2023, Heinrich Schuchardt heinrich.schuchardt@canonical.com + */ + +#include <command.h> +#include <hexdump.h> +#include <mapmem.h> +#include <smbios.h> +#include <tables_csum.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * smbios_get_string() - get SMBIOS string from table + * + * @table: SMBIOS table + * @index: index of the string + * Return: address of string, may point to empty string + */ +static const char *smbios_get_string(void *table, int index) +{ + const char *str = (char *)table + + ((struct smbios_header *)table)->length; + + if (!*str) + ++str; + for (--index; *str && index; --index) + str += strlen(str) + 1; + + return str; +} + +static struct smbios_header *next_table(struct smbios_header *table) +{ + const char *str; + + if (table->type == SMBIOS_END_OF_TABLE) + return NULL; + + str = smbios_get_string(table, 0); + return (struct smbios_header *)(++str); +} + +static void smbios_print_generic(struct smbios_header *table) +{ + char *str = (char *)table + table->length; + + if (CONFIG_IS_ENABLED(HEXDUMP)) { + printf("Header and Data:\n"); + print_hex_dump("\t", DUMP_PREFIX_OFFSET, 16, 1, + table, table->length, false); + } + if (*str) { + printf("Strings:\n"); + for (int index = 1; *str; ++index) { + printf("\tString %u: %s\n", index, str); + str += strlen(str) + 1; + } + } +} + +void smbios_print_str(const char *label, void *table, u8 index) +{ + printf("\t%s: %s\n", label, smbios_get_string(table, index)); +} + +static void smbios_print_type1(struct smbios_type1 *table) +{ + printf("System Information\n"); + smbios_print_str("Manufacturer", table, table->manufacturer); + smbios_print_str("Product Name", table, table->product_name); + smbios_print_str("Version", table, table->version); + smbios_print_str("Serial Number", table, table->serial_number); + if (table->length >= 0x19) { + printf("\tUUID %pUl\n", table->uuid); + smbios_print_str("Wake Up Type", table, table->serial_number); + } + if (table->length >= 0x1b) { + smbios_print_str("Serial Number", table, table->serial_number); + smbios_print_str("SKU Number", table, table->sku_number); + } +} + +static void smbios_print_type2(struct smbios_type2 *table) +{ + u16 *handle; + + printf("Base Board Information\n"); + smbios_print_str("Manufacturer", table, table->manufacturer); + smbios_print_str("Product Name", table, table->product_name); + smbios_print_str("Version", table, table->version); + smbios_print_str("Serial Number", table, table->serial_number); + smbios_print_str("Asset Tag", table, table->asset_tag_number); + printf("\tFeature Flags: 0x%2x\n", table->feature_flags); + smbios_print_str("Chassis Location", table, table->chassis_location); + printf("\tChassis Handle: 0x%2x\n", table->chassis_handle); + smbios_print_str("Board Type", table, table->board_type); + printf("\tContained Object Handles: "); + handle = (void *)table->eos; + for (int i = 0; i < table->number_contained_objects; ++i) + printf("0x%04x ", handle[i]); + printf("\n"); +} + +static void smbios_print_type127(struct smbios_type127 *table) +{ + printf("End Of Table\n"); +} + +static int do_smbios(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + ulong addr; + void *entry; + u32 size; + char version[12]; + struct smbios_header *table; + static const char smbios_sig[] = "_SM_"; + static const char smbios3_sig[] = "_SM3_"; + size_t count = 0; + u32 max_struct_size; + + addr = gd_smbios_start(); + if (!addr) { + log_warning("SMBIOS not available\n"); + return CMD_RET_FAILURE; + } + entry = map_sysmem(addr, 0); + if (!memcmp(entry, smbios3_sig, sizeof(smbios3_sig) - 1)) { + struct smbios3_entry *entry3 = entry; + + table = (void *)(uintptr_t)entry3->struct_table_address; + snprintf(version, sizeof(version), "%d.%d.%d", + entry3->major_ver, entry3->minor_ver, entry3->doc_rev); + table = (void *)(uintptr_t)entry3->struct_table_address; + size = entry3->length; + max_struct_size = entry3->max_struct_size; + } else if (!memcmp(entry, smbios_sig, sizeof(smbios_sig) - 1)) { + struct smbios_entry *entry2 = entry; + + snprintf(version, sizeof(version), "%d.%d", + entry2->major_ver, entry2->minor_ver); + table = (void *)(uintptr_t)entry2->struct_table_address; + size = entry2->length; + max_struct_size = entry2->max_struct_size; + } else { + log_err("Unknown SMBIOS anchor format\n"); + return CMD_RET_FAILURE; + } + if (table_compute_checksum(entry, size)) { + log_err("Invalid anchor checksum\n"); + return CMD_RET_FAILURE; + } + printf("SMBIOS %s present.\n", version); + + for (struct smbios_header *pos = table; pos; pos = next_table(pos)) + ++count; + printf("%zd structures occupying %d bytes\n", count, max_struct_size); + printf("Table at 0x%llx\n", (unsigned long long)map_to_sysmem(table)); + + for (struct smbios_header *pos = table; pos; pos = next_table(pos)) { + printf("\nHandle 0x%04x, DMI type %d, %d bytes at 0x%llx\n", + pos->handle, pos->type, pos->length, + (unsigned long long)map_to_sysmem(pos)); + switch (pos->type) { + case 1: + smbios_print_type1((struct smbios_type1 *)pos); + break; + case 2: + smbios_print_type2((struct smbios_type2 *)pos); + break; + case 127: + smbios_print_type127((struct smbios_type127 *)pos); + break; + default: + smbios_print_generic(pos); + break; + } + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_LONGHELP(smbios, "- display SMBIOS information"); + +U_BOOT_CMD(smbios, 1, 0, do_smbios, "display SMBIOS information", + smbios_help_text);
Provide a man-page for the smbios command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v3: no change v2: no change --- doc/usage/cmd/smbios.rst | 93 ++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 94 insertions(+) create mode 100644 doc/usage/cmd/smbios.rst
diff --git a/doc/usage/cmd/smbios.rst b/doc/usage/cmd/smbios.rst new file mode 100644 index 00000000000..1ffd706d7de --- /dev/null +++ b/doc/usage/cmd/smbios.rst @@ -0,0 +1,93 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later: + +smbios command +============== + +Synopsis +-------- + +:: + + smbios + +Description +----------- + +The smbios command displays information from the SMBIOS tables. + +Examples +-------- + +The example below shows an example output of the smbios command. + +:: + + => smbios + SMBIOS 2.8.0 present. + 8 structures occupying 81 bytes + Table at 0x6d35018 + + Handle 0x0100, DMI type 1, 27 bytes at 0x6d35018 + System Information + Manufacturer: QEMU + Product Name: Standard PC (i440FX + PIIX, 1996) + Version: pc-i440fx-2.5 + Serial Number: + UUID 00000000-0000-0000-0000-000000000000 + Wake Up Type: + Serial Number: + SKU Number: + + Handle 0x0300, DMI type 3, 22 bytes at 0x6d35069 + Header and Data: + 00000000: 03 16 00 03 01 01 02 00 00 03 03 03 02 00 00 00 + 00000010: 00 00 00 00 00 00 + Strings: + String 1: QEMU + String 2: pc-i440fx-2.5 + + Handle 0x0400, DMI type 4, 42 bytes at 0x6d35093 + Header and Data: + 00000000: 04 2a 00 04 01 03 01 02 63 06 00 00 fd ab 81 07 + 00000010: 03 00 00 00 d0 07 d0 07 41 01 ff ff ff ff ff ff + 00000020: 00 00 00 01 01 01 02 00 01 00 + Strings: + String 1: CPU 0 + String 2: QEMU + String 3: pc-i440fx-2.5 + + Handle 0x1000, DMI type 16, 23 bytes at 0x6d350d7 + Header and Data: + 00000000: 10 17 00 10 01 03 06 00 00 02 00 fe ff 01 00 00 + 00000010: 00 00 00 00 00 00 00 + + Handle 0x1100, DMI type 17, 40 bytes at 0x6d350f0 + Header and Data: + 00000000: 11 28 00 11 00 10 fe ff ff ff ff ff 80 00 09 00 + 00000010: 01 00 07 02 00 00 00 02 00 00 00 00 00 00 00 00 + 00000020: 00 00 00 00 00 00 00 00 + Strings: + String 1: DIMM 0 + String 2: QEMU + + Handle 0x1300, DMI type 19, 31 bytes at 0x6d35125 + Header and Data: + 00000000: 13 1f 00 13 00 00 00 00 ff ff 01 00 00 10 01 00 + 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 + + Handle 0x2000, DMI type 32, 11 bytes at 0x6d35146 + Header and Data: + 00000000: 20 0b 00 20 00 00 00 00 00 00 00 + + Handle 0x7f00, DMI type 127, 4 bytes at 0x6d35153 + End Of Table + +Configuration +------------- + +The command is only available if CONFIG_CMD_SMBIOS=y. + +Return value +------------ + +The return value $? is 0 (true) on success, 1 (false) otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index c171c029b80..0d174eefaa5 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -103,6 +103,7 @@ Shell commands cmd/size cmd/sleep cmd/sm + cmd/smbios cmd/sound cmd/source cmd/temperature
Provide a unit test for the smbios command.
Provide different test functions for QEMU, sandbox, and other systems.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v3: no change v2: for generic boards we only can assume that a type 127 table exists email address updated --- test/py/tests/test_smbios.py | 41 ++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+) create mode 100644 test/py/tests/test_smbios.py
diff --git a/test/py/tests/test_smbios.py b/test/py/tests/test_smbios.py new file mode 100644 index 00000000000..82b0b689830 --- /dev/null +++ b/test/py/tests/test_smbios.py @@ -0,0 +1,41 @@ +# SPDX-License-Identifier: GPL-2.0-or-later + +"""Test smbios command""" + +import pytest + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.notbuildconfigspec('qfw_smbios') +@pytest.mark.notbuildconfigspec('sandbox') +def test_cmd_smbios(u_boot_console): + """Run the smbios command""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 127,' in output + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.buildconfigspec('qfw_smbios') +@pytest.mark.notbuildconfigspec('sandbox') +# TODO: +# QEMU v8.2.0 lacks SMBIOS support for RISC-V +# Once support is available in our Docker image we can remove the constraint. +@pytest.mark.notbuildconfigspec('riscv') +def test_cmd_smbios_qemu(u_boot_console): + """Run the smbios command on QEMU""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 1,' in output + assert 'Manufacturer: QEMU' in output + assert 'DMI type 127,' in output + +@pytest.mark.buildconfigspec('cmd_smbios') +@pytest.mark.buildconfigspec('sandbox') +def test_cmd_smbios_sandbox(u_boot_console): + """Run the smbios command on the sandbox""" + output = u_boot_console.run_command('smbios') + assert 'DMI type 0,' in output + assert 'String 1: U-Boot' in output + assert 'DMI type 1,' in output + assert 'Manufacturer: sandbox' in output + assert 'DMI type 2,' in output + assert 'DMI type 3,' in output + assert 'DMI type 4,' in output + assert 'DMI type 127,' in output
To make use of the Python smbios test we need the smbios command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v3: new patch --- configs/sandbox_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ea4e2c1ec39..a8df5e635b2 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -42,6 +42,7 @@ CONFIG_STACKPROTECTOR=y CONFIG_ANDROID_AB=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y +CONFIG_CMD_SMBIOS=y CONFIG_CMD_BOOTM_PRE_LOAD=y CONFIG_CMD_BOOTZ=y CONFIG_BOOTM_OPENRTOS=y
On Thu, 25 Jan 2024 at 17:55, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
v3: new patch
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ea4e2c1ec39..a8df5e635b2 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -42,6 +42,7 @@ CONFIG_STACKPROTECTOR=y CONFIG_ANDROID_AB=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y +CONFIG_CMD_SMBIOS=y CONFIG_CMD_BOOTM_PRE_LOAD=y CONFIG_CMD_BOOTZ=y CONFIG_BOOTM_OPENRTOS=y -- 2.43.0
v3: new patch
We should do sandbox64 too I think? Ilias was saying something I believe about testing one path via sandbox and another via sandbox64 (since they have different base dts files, putting stuff for one code path in one and stuff for the other in the other).
v3: new patch
Currently the test asserts nothing that would be sandbox64 specific:
assert 'DMI type 0,' in output assert 'String 1: U-Boot' in output assert 'DMI type 1,' in output assert 'Manufacturer: sandbox' in output assert 'DMI type 2,' in output assert 'DMI type 3,' in output assert 'DMI type 4,' in output assert 'DMI type 127,' in output
In a future series we might check more and then adding sandbox64_defconfig may make sense.
Probably this would also require providing text output for other SMBIOS table types.
Best regards
Heinrich
On Thu, 25 Jan 2024 at 18:26, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
v3: new patch
I plan to use sandbox to parse the smbios table provided by the sysinfo specific DT entry and sanbbox64 for the fallback code we added. I'll enable it as part of my patchseries
Cheers /Ilias
Best regards
Heinrich
We have a Python test the copying of SMBIOS tables from QEMU. To make use of the test we need the smbios command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v3: no change --- configs/qemu_arm64_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 5100e193be6..631d8866f62 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -27,6 +27,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_PCI_INIT_R=y +CONFIG_CMD_SMBIOS=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y
v3: no change
diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 5100e193be6..631d8866f62 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -27,6 +27,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_PCI_INIT_R=y +CONFIG_CMD_SMBIOS=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y -- 2.43.0
Ilias Apalodimas
