[U-Boot] [PATCH] ARM: imx6q_logic: Correct phy fixup for broken ethernet
The Ethernet has been broken for some time. This patch unifies this board with a few others that use a similar approach to enabling phy. This fixes ar8031 Ethernet controller so it works.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index cda76a8084..eb4849117d 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -60,57 +60,6 @@ static iomux_v3_cfg_t const uart3_pads[] = { MX6_PAD_EIM_EB3__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#ifndef CONFIG_SPL_BUILD -static void fixup_enet_clock(void) -{ - struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct gpio_desc nint; - struct gpio_desc reset; - int ret; - - /* Set Ref Clock to 50 MHz */ - enable_fec_anatop_clock(0, ENET_50MHZ); - - /* Set GPIO_16 as ENET_REF_CLK_OUT */ - setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_ENET_CLK_SEL_MASK); - - /* Request GPIO Pins to reset Ethernet with new clock */ - ret = dm_gpio_lookup_name("GPIO4_7", &nint); - if (ret) { - printf("Unable to lookup GPIO4_7\n"); - return; - } - - ret = dm_gpio_request(&nint, "eth0_nInt"); - if (ret) { - printf("Unable to request eth0_nInt\n"); - return; - } - - /* Ensure nINT is input or PHY won't startup */ - dm_gpio_set_dir_flags(&nint, GPIOD_IS_IN); - - ret = dm_gpio_lookup_name("GPIO4_9", &reset); - if (ret) { - printf("Unable to lookup GPIO4_9\n"); - return; - } - - ret = dm_gpio_request(&reset, "eth0_reset"); - if (ret) { - printf("Unable to request eth0_reset\n"); - return; - } - - /* Reset LAN8710A PHY */ - dm_gpio_set_dir_flags(&reset, GPIOD_IS_OUT); - dm_gpio_set_value(&reset, 0); - udelay(150); - dm_gpio_set_value(&reset, 1); - mdelay(50); -} -#endif - static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); @@ -141,8 +90,33 @@ static void setup_nand_pins(void) imx_iomux_v3_setup_multiple_pads(nand_pads, ARRAY_SIZE(nand_pads)); }
+static int ar8031_phy_fixup(struct phy_device *phydev) +{ + unsigned short val; + + /* To enable AR8031 output a 125MHz clk from CLK_25M */ + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); + + val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); + val &= 0xffe3; + val |= 0x18; + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); + + /* introduce tx clock delay */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); + val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); + val |= 0x0100; + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); + + return 0; +} + int board_phy_config(struct phy_device *phydev) { + ar8031_phy_fixup(phydev); + if (phydev->drv->config) phydev->drv->config(phydev);
@@ -160,9 +134,6 @@ int overwrite_console(void)
int board_early_init_f(void) { -#ifndef CONFIG_SPL_BUILD - fixup_enet_clock(); -#endif setup_iomux_uart(); setup_nand_pins(); return 0;
The Ethernet has been broken for some time. This patch unifies this board with a few others that use a similar approach to enabling phy. This fixes ar8031 Ethernet controller so it works. Signed-off-by: Adam Ford aford173@gmail.com diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index cda76a8084..eb4849117d 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -60,57 +60,6 @@ static iomux_v3_cfg_t const uart3_pads[] = { MX6_PAD_EIM_EB3__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), };
- int ret;
- if (ret) {
return;
- if (ret) {
return;
- if (ret) {
return;
- if (ret) {
return;
- udelay(150);
- mdelay(50);
-} -#endif
- unsigned short val;
- /* To enable AR8031 output a 125MHz clk from CLK_25M */
- phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7);
- phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016);
- phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007);
- val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe);
- val &= 0xffe3;
- val |= 0x18;
- phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val);
- /* introduce tx clock delay */
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5);
- val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e);
- val |= 0x0100;
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val);
- ar8031_phy_fixup(phydev);
- if (phydev->drv->config) phydev->drv->config(phydev);
Best regards, Stefano Babic
Hi Adam,
int ret;
I just wonder why the fec working w/o ene_ref set rate to 50MHz, any idea?
On Tue, Apr 2, 2019 at 11:58 PM Jagan Teki jagan@amarulasolutions.com wrote:
Hi Adam,
int ret;
The original source was setup for a different ethernet controller 100Mb instead of 1000Mb. I got a bit ahead of myself when I pushed the original board to U-Boot, but I thought it was going to market sooner. That revision of the board was never released, and eventually Logic PD migrated to the AR8031 controller, so the original code was completely wrong. The patch you're referencing was to make the AR8031 controller actually work. Since the older hardware was never released, I didn't mention it in the commit.
adam
Adam Ford
Jagan Teki
sbabic@denx.de
