[PATCH v2] cmd: pxe_utils: sysboot: replace cls command by video_clear in PXE parser
Since the commit bfaa51dd4adf ("cmd: add serial console support for the cls command") the cls command is not enough to clear the video display when ANSI console is activated.
This patch clears the video device with the video_clear() API before to display the bitmap used for the PXE background.
This patch avoids to display the LOGO, activated by default with commit 7a8555d87136 ("video: Show the U-Boot logo by default").
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com --- I let a patman warning:
boot/pxe_utils.c:1520: warning: Use 'if (IS_ENABLED(CONFIG...))' instead of '#if or #ifdef' where possible
To avoid parameter issue for video_clear(dev) function: no parameter dev when CONFIG_DM_VIDEO is deactivated.
Changes in v2: - move #include <dm.h> to avoid compilation issue when CONFIG_DM_RNG is not activated for uclass_first_device_err - Avoid error too many arguments to function 'video_clear' when CONFIG_DM_VIDEO is not activated, use: #if defined(CONFIG_DM_VIDEO)
boot/pxe_utils.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index 0c24becae3..b08aee9896 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -6,6 +6,7 @@
#include <common.h> #include <command.h> +#include <dm.h> #include <env.h> #include <image.h> #include <log.h> @@ -14,6 +15,7 @@ #include <lcd.h> #include <net.h> #include <fdt_support.h> +#include <video.h> #include <linux/libfdt.h> #include <linux/string.h> #include <linux/ctype.h> @@ -21,7 +23,6 @@ #include <linux/list.h>
#ifdef CONFIG_DM_RNG -#include <dm.h> #include <rng.h> #endif
@@ -1516,8 +1517,13 @@ void handle_pxe_menu(struct pxe_context *ctx, struct pxe_menu *cfg) /* display BMP if available */ if (cfg->bmp) { if (get_relfile(ctx, cfg->bmp, image_load_addr, NULL)) { - if (CONFIG_IS_ENABLED(CMD_CLS)) - run_command("cls", 0); +#if defined(CONFIG_DM_VIDEO) + struct udevice *dev; + + err = uclass_first_device_err(UCLASS_VIDEO, &dev); + if (!err) + video_clear(dev); +#endif bmp_display(image_load_addr, BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); } else {
Hi Patrick
Changes in v2:
if (!err)
video_clear(dev);
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Patrice CHOTARD
Patrick Delaunay
