Issue with mmc command set
Hi All,
I working on a T1042 based custom board that has an on-board eMMC (8GB, GLS85VM1008A-M-I-LFWE-ND202). I have successfully booted uboot 2019.07 on my board.
I'm facing an issue with mmc command set, when I issue an 'mmc list' command once the board boots up it lists " FSL_SDHC: 0 " and 'mmc info' lists the details of my eMMC.
Once I issue 'mmc dev 0 0' command, then nothing is printed on my console. After this when I issue 'mmc info' it also prints nothing on the console. But 'mmc list' still lists the " FSL_SDHC: 0 ".
Why is it so? Am I doing something wrong?
Please the below u-boot log for detail.
Regards, Amarnath MB
U-Boot 2019.07 (Dec 13 2019 - 21:37:11 +0530)
CPU0: T1042E, Version: 1.1, (0x85280211) Core: e5500, Version: 2.1, (0x80241021) Clock Configuration: CPU0:1200 MHz, CPU1:1200 MHz, CPU2:1200 MHz, CPU3:1200 MHz, CCB:500 MHz, DDR:533.333 MHz (1066.667 MT/s data rate) (Asynchronous), IFC:250 MHz QE :250 MHz FMAN1: 500 MHz QMAN: 250 MHz PME: 250 MHz L1: D-cache 32 KiB enabled I-cache 32 KiB enabled Reset Configuration Word (RCW): 00000000: 0a10000c 0c000000 00000000 00000000 00000010: 06000002 c0000002 ec027000 01000000 00000020: 00000000 00010001 60000000 00028000 00000030: 00000200 00165005 00000000 00000000 Board: T1042 I2C: ready DRAM: Initializing DDR.... Configuring DDR for 1066.667 MT/s data rate Setting DDR register values... Setting DDR register values finished... 2 GiB left unmapped SDRAM test phase 1: SDRAM test phase 2: SDRAM test passed. 2 GiB (DDR4, 64-bit, CL=11, ECC on) Flash: 512 MiB L2: 256 KiB enabled Corenet Platform Cache: 256 KiB enabled Using SERDES1 Protocol: 6 (0x6) Enabling all cpus MMC: FSL_SDHC: 0 Loading User and Factory Environments...
*** Warning - FACTORY ENVIRONMENT bad CRC, using default factory environment
Firmware 'Microcode version 0.0.1 for T1040 r1.0' for 1040 V1.0 QE: uploading microcode 'Microcode for T1040 r1.0' version 0.0.1 In: serial Out: serial Err: serial SERDES Reference : 0x6 Temperature init Done
*** Warning - U-boot image is Updated
Net: Initializing Fman Fman1: Uploading microcode version 106.4.18 FM1@DTSEC4, FM1@DTSEC5 [PRIME] POST vid Perform VMON POST au16Voltage[0] = 0xcc6 = 997350 µV au16Voltage[1] = 0xcc9 = 998265 µV au16Voltage[2] = 0xf63 = 1201395 µV au16Voltage[3] = 0x115d = 1355725 µV au16Voltage[4] = 0x1716 = 1802550 µV au16Voltage[5] = 0x1fe8 = 2491240 µV au16Voltage[6] = 0x2a80 = 3318400 µV au16Voltage[7] = 0x7c6 = 606950 µV PASSED POST i2c PASSED POST rtc Sun Jan 1 2020 00:00:00 PASSED POST ethernet PASSED POST flash PASSED Hit any key to stop autoboot: 0 T1042 # T1042 # mmc list FSL_SDHC: 0 T1042 # mmc info Device: FSL_SDHC Manufacturer ID: f8 OEM: 100 Name: VM010 Bus Speed: 52000000 Mode: MMC High Speed (52MHz) Rd Block Len: 512 MMC version 4.4.1 High Capacity: Yes Capacity: 7.3 GiB Bus Width: 4-bit Erase Group Size: 4 MiB Enhanced Mode: Disabled HC WP Group Size: 8 MiB User Capacity: 7.3 GiB Boot Capacity: 512 KiB ENH RPMB Capacity: 512 KiB ENH T1042 # T1042 # mmc part ## Unknown partition table type 0 T1042 # mmc dev 0 0 T1042 # mmc info T1042 # mmc list FSL_SDHC: 0 T1042 #
Amarnath MB
