[PATCH v1 0/1] support rsa3072
support rsa3072
Jamin Lin (1): support rsa3072
common/image-sig.c | 7 +++++++ include/u-boot/rsa.h | 1 + 2 files changed, 8 insertions(+)
This patch set support rsa3072.
Signed-off-by: Jamin Lin jamin_lin@aspeedtech.com --- common/image-sig.c | 7 +++++++ include/u-boot/rsa.h | 1 + 2 files changed, 8 insertions(+)
diff --git a/common/image-sig.c b/common/image-sig.c index e4bbac55c1..c94854ef8b 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -85,6 +85,13 @@ struct crypto_algo crypto_algos[] = { .add_verify_data = rsa_add_verify_data, .verify = rsa_verify, }, + { + .name = "rsa3072", + .key_len = RSA3072_BYTES, + .sign = rsa_sign, + .add_verify_data = rsa_add_verify_data, + .verify = rsa_verify, + }, { .name = "rsa4096", .key_len = RSA4096_BYTES, diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 2d3024d8b7..d561e5f8ca 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -135,6 +135,7 @@ static inline int padding_pss_verify(struct image_sign_info *info, #define RSA_DEFAULT_PADDING_NAME "pkcs-1.5"
#define RSA2048_BYTES (2048 / 8) +#define RSA3072_BYTES (3072 / 8) #define RSA4096_BYTES (4096 / 8)
/* This is the minimum/maximum key size we support, in bits */
.name = "rsa3072",
.sign = rsa_sign,
- }, { .name = "rsa4096", .key_len = RSA4096_BYTES,
For both of these patches, please expand the commit message and header so it's clear where you're adding the support to. Perhaps they should be squashed in to a single patch as the tooling needs to support it when the binary also supports it?
.name = "rsa3072",
.sign = rsa_sign,
-- Tom
Hi Tom Thanks for your review. I sent v2 patch and waiting for your review. Thanks
Jamin Lin
