[PATCH 4/7] dt-bindings: clock: rk3588: Add binding header for rk3588
files origin from kernel tree.
Signed-off-by: Zhang Yubing yubing.zhang@rock-chips.com Signed-off-by: Elaine Zhang zhangqing@rock-chips.com --- include/dt-bindings/clock/rk3588-cru.h | 1494 ++++++++++++++++++++++ include/dt-bindings/power/rk3588-power.h | 69 + 2 files changed, 1563 insertions(+) create mode 100644 include/dt-bindings/clock/rk3588-cru.h create mode 100644 include/dt-bindings/power/rk3588-power.h
diff --git a/include/dt-bindings/clock/rk3588-cru.h b/include/dt-bindings/clock/rk3588-cru.h new file mode 100644 index 0000000000..87f35d8da5 --- /dev/null +++ b/include/dt-bindings/clock/rk3588-cru.h @@ -0,0 +1,1494 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2021 Rockchip Electronics Co. Ltd. + * Author: Elaine Zhang zhangqing@rock-chips.com + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3588_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3588_H + +/* cru-clocks indices */ + +/* cru plls */ +#define PLL_B0PLL 1 +#define PLL_B1PLL 2 +#define PLL_LPLL 3 +#define PLL_V0PLL 4 +#define PLL_AUPLL 5 +#define PLL_CPLL 6 +#define PLL_GPLL 7 +#define PLL_NPLL 8 +#define PLL_PPLL 9 +#define ARMCLK_L 10 +#define ARMCLK_B01 11 +#define ARMCLK_B23 12 + +/* cru clocks */ +#define PCLK_BIGCORE0_ROOT 20 +#define PCLK_BIGCORE0_PVTM 21 +#define PCLK_BIGCORE1_ROOT 22 +#define PCLK_BIGCORE1_PVTM 23 +#define PCLK_DSU_S_ROOT 24 +#define PCLK_DSU_ROOT 25 +#define PCLK_DSU_NS_ROOT 26 +#define PCLK_LITCORE_PVTM 27 +#define PCLK_DBG 28 +#define PCLK_DSU 29 +#define PCLK_S_DAPLITE 30 +#define PCLK_M_DAPLITE 31 +#define MBIST_MCLK_PDM1 32 +#define MBIST_CLK_ACDCDIG 33 +#define HCLK_I2S2_2CH 34 +#define HCLK_I2S3_2CH 35 +#define CLK_I2S2_2CH_SRC 36 +#define CLK_I2S2_2CH_FRAC 37 +#define CLK_I2S2_2CH 38 +#define MCLK_I2S2_2CH 39 +#define I2S2_2CH_MCLKOUT 40 +#define CLK_DAC_ACDCDIG 41 +#define CLK_I2S3_2CH_SRC 42 +#define CLK_I2S3_2CH_FRAC 43 +#define CLK_I2S3_2CH 44 +#define MCLK_I2S3_2CH 45 +#define I2S3_2CH_MCLKOUT 46 +#define PCLK_ACDCDIG 47 +#define HCLK_I2S0_8CH 48 +#define CLK_I2S0_8CH_TX_SRC 49 +#define CLK_I2S0_8CH_TX_FRAC 50 +#define MCLK_I2S0_8CH_TX 51 +#define CLK_I2S0_8CH_TX 52 +#define CLK_I2S0_8CH_RX_SRC 53 +#define CLK_I2S0_8CH_RX_FRAC 54 +#define MCLK_I2S0_8CH_RX 55 +#define CLK_I2S0_8CH_RX 56 +#define I2S0_8CH_MCLKOUT 57 +#define HCLK_PDM1 58 +#define MCLK_PDM1 59 +#define HCLK_AUDIO_ROOT 60 +#define PCLK_AUDIO_ROOT 61 +#define HCLK_SPDIF0 62 +#define CLK_SPDIF0_SRC 63 +#define CLK_SPDIF0_FRAC 64 +#define MCLK_SPDIF0 65 +#define CLK_SPDIF0 66 +#define CLK_SPDIF1 67 +#define HCLK_SPDIF1 68 +#define CLK_SPDIF1_SRC 69 +#define CLK_SPDIF1_FRAC 70 +#define MCLK_SPDIF1 71 +#define ACLK_AV1_ROOT 72 +#define ACLK_AV1 73 +#define PCLK_AV1_ROOT 74 +#define PCLK_AV1 75 +#define PCLK_MAILBOX0 76 +#define PCLK_MAILBOX1 77 +#define PCLK_MAILBOX2 78 +#define PCLK_PMU2 79 +#define PCLK_PMUCM0_INTMUX 80 +#define PCLK_DDRCM0_INTMUX 81 +#define PCLK_TOP 82 +#define PCLK_PWM1 83 +#define CLK_PWM1 84 +#define CLK_PWM1_CAPTURE 85 +#define PCLK_PWM2 86 +#define CLK_PWM2 87 +#define CLK_PWM2_CAPTURE 88 +#define PCLK_PWM3 89 +#define CLK_PWM3 90 +#define CLK_PWM3_CAPTURE 91 +#define PCLK_BUSTIMER0 92 +#define PCLK_BUSTIMER1 93 +#define CLK_BUS_TIMER_ROOT 94 +#define CLK_BUSTIMER0 95 +#define CLK_BUSTIMER1 96 +#define CLK_BUSTIMER2 97 +#define CLK_BUSTIMER3 98 +#define CLK_BUSTIMER4 99 +#define CLK_BUSTIMER5 100 +#define CLK_BUSTIMER6 101 +#define CLK_BUSTIMER7 102 +#define CLK_BUSTIMER8 103 +#define CLK_BUSTIMER9 104 +#define CLK_BUSTIMER10 105 +#define CLK_BUSTIMER11 106 +#define PCLK_WDT0 107 +#define TCLK_WDT0 108 +#define PCLK_CAN0 111 +#define CLK_CAN0 112 +#define PCLK_CAN1 113 +#define CLK_CAN1 114 +#define PCLK_CAN2 115 +#define CLK_CAN2 116 +#define ACLK_DECOM 117 +#define PCLK_DECOM 118 +#define DCLK_DECOM 119 +#define ACLK_DMAC0 120 +#define ACLK_DMAC1 121 +#define ACLK_DMAC2 122 +#define ACLK_BUS_ROOT 123 +#define ACLK_GIC 124 +#define PCLK_GPIO1 125 +#define DBCLK_GPIO1 126 +#define PCLK_GPIO2 127 +#define DBCLK_GPIO2 128 +#define PCLK_GPIO3 129 +#define DBCLK_GPIO3 130 +#define PCLK_GPIO4 131 +#define DBCLK_GPIO4 132 +#define PCLK_I2C1 133 +#define PCLK_I2C2 134 +#define PCLK_I2C3 135 +#define PCLK_I2C4 136 +#define PCLK_I2C5 137 +#define PCLK_I2C6 138 +#define PCLK_I2C7 139 +#define PCLK_I2C8 140 +#define CLK_I2C1 141 +#define CLK_I2C2 142 +#define CLK_I2C3 143 +#define CLK_I2C4 144 +#define CLK_I2C5 145 +#define CLK_I2C6 146 +#define CLK_I2C7 147 +#define CLK_I2C8 148 +#define PCLK_OTPC_NS 149 +#define CLK_OTPC_NS 150 +#define CLK_OTPC_ARB 151 +#define CLK_OTPC_AUTO_RD_G 152 +#define CLK_OTP_PHY_G 153 +#define PCLK_SARADC 156 +#define CLK_SARADC 157 +#define PCLK_SPI0 158 +#define PCLK_SPI1 159 +#define PCLK_SPI2 160 +#define PCLK_SPI3 161 +#define PCLK_SPI4 162 +#define CLK_SPI0 163 +#define CLK_SPI1 164 +#define CLK_SPI2 165 +#define CLK_SPI3 166 +#define CLK_SPI4 167 +#define ACLK_SPINLOCK 168 +#define PCLK_TSADC 169 +#define CLK_TSADC 170 +#define PCLK_UART1 171 +#define PCLK_UART2 172 +#define PCLK_UART3 173 +#define PCLK_UART4 174 +#define PCLK_UART5 175 +#define PCLK_UART6 176 +#define PCLK_UART7 177 +#define PCLK_UART8 178 +#define PCLK_UART9 179 +#define CLK_UART1_SRC 180 +#define CLK_UART1_FRAC 181 +#define CLK_UART1 182 +#define SCLK_UART1 183 +#define CLK_UART2_SRC 184 +#define CLK_UART2_FRAC 185 +#define CLK_UART2 186 +#define SCLK_UART2 187 +#define CLK_UART3_SRC 188 +#define CLK_UART3_FRAC 189 +#define CLK_UART3 190 +#define SCLK_UART3 191 +#define CLK_UART4_SRC 192 +#define CLK_UART4_FRAC 193 +#define CLK_UART4 194 +#define SCLK_UART4 195 +#define CLK_UART5_SRC 196 +#define CLK_UART5_FRAC 197 +#define CLK_UART5 198 +#define SCLK_UART5 199 +#define CLK_UART6_SRC 200 +#define CLK_UART6_FRAC 201 +#define CLK_UART6 202 +#define SCLK_UART6 203 +#define CLK_UART7_SRC 204 +#define CLK_UART7_FRAC 205 +#define CLK_UART7 206 +#define SCLK_UART7 207 +#define CLK_UART8_SRC 208 +#define CLK_UART8_FRAC 209 +#define CLK_UART8 210 +#define SCLK_UART8 211 +#define CLK_UART9_SRC 212 +#define CLK_UART9_FRAC 213 +#define CLK_UART9 214 +#define SCLK_UART9 215 +#define ACLK_CENTER_ROOT 216 +#define ACLK_CENTER_LOW_ROOT 217 +#define HCLK_CENTER_ROOT 218 +#define PCLK_CENTER_ROOT 219 +#define ACLK_DMA2DDR 220 +#define ACLK_DDR_SHAREMEM 221 +#define ACLK_CENTER_S200_ROOT 222 +#define ACLK_CENTER_S400_ROOT 223 +#define FCLK_DDR_CM0_CORE 224 +#define CLK_DDR_TIMER_ROOT 225 +#define CLK_DDR_TIMER0 226 +#define CLK_DDR_TIMER1 227 +#define TCLK_WDT_DDR 228 +#define CLK_DDR_CM0_RTC 228 +#define PCLK_WDT 230 +#define PCLK_TIMER 231 +#define PCLK_DMA2DDR 232 +#define PCLK_SHAREMEM 233 +#define CLK_50M_SRC 234 +#define CLK_100M_SRC 235 +#define CLK_150M_SRC 236 +#define CLK_200M_SRC 237 +#define CLK_250M_SRC 238 +#define CLK_300M_SRC 239 +#define CLK_350M_SRC 240 +#define CLK_400M_SRC 241 +#define CLK_450M_SRC 242 +#define CLK_500M_SRC 243 +#define CLK_600M_SRC 244 +#define CLK_650M_SRC 245 +#define CLK_700M_SRC 246 +#define CLK_800M_SRC 247 +#define CLK_1000M_SRC 248 +#define CLK_1200M_SRC 249 +#define ACLK_TOP_M300_ROOT 250 +#define ACLK_TOP_M500_ROOT 251 +#define ACLK_TOP_M400_ROOT 252 +#define ACLK_TOP_S200_ROOT 253 +#define ACLK_TOP_S400_ROOT 254 +#define CLK_MIPI_CAMARAOUT_M0 255 +#define CLK_MIPI_CAMARAOUT_M1 256 +#define CLK_MIPI_CAMARAOUT_M2 257 +#define CLK_MIPI_CAMARAOUT_M3 258 +#define CLK_MIPI_CAMARAOUT_M4 259 +#define MCLK_GMAC0_OUT 260 +#define REFCLKO25M_ETH0_OUT 261 +#define REFCLKO25M_ETH1_OUT 262 +#define CLK_CIFOUT_OUT 263 +#define PCLK_MIPI_DCPHY0 264 +#define PCLK_MIPI_DCPHY1 265 +#define PCLK_CSIPHY0 268 +#define PCLK_CSIPHY1 269 +#define ACLK_TOP_ROOT 270 +#define PCLK_TOP_ROOT 271 +#define ACLK_LOW_TOP_ROOT 272 +#define PCLK_CRU 273 +#define PCLK_GPU_ROOT 274 +#define CLK_GPU_SRC 275 +#define CLK_GPU 276 +#define CLK_GPU_COREGROUP 277 +#define CLK_GPU_STACKS 278 +#define PCLK_GPU_PVTM 279 +#define CLK_GPU_PVTM 280 +#define CLK_CORE_GPU_PVTM 281 +#define PCLK_GPU_GRF 282 +#define ACLK_ISP1_ROOT 283 +#define HCLK_ISP1_ROOT 284 +#define CLK_ISP1_CORE 285 +#define CLK_ISP1_CORE_MARVIN 286 +#define CLK_ISP1_CORE_VICAP 287 +#define ACLK_ISP1 288 +#define HCLK_ISP1 289 +#define ACLK_NPU1 290 +#define HCLK_NPU1 291 +#define ACLK_NPU2 292 +#define HCLK_NPU2 293 +#define HCLK_NPU_CM0_ROOT 294 +#define FCLK_NPU_CM0_CORE 295 +#define CLK_NPU_CM0_RTC 296 +#define PCLK_NPU_PVTM 297 +#define PCLK_NPU_GRF 298 +#define CLK_NPU_PVTM 299 +#define CLK_CORE_NPU_PVTM 300 +#define ACLK_NPU0 301 +#define HCLK_NPU0 302 +#define HCLK_NPU_ROOT 303 +#define CLK_NPU_DSU0 304 +#define PCLK_NPU_ROOT 305 +#define PCLK_NPU_TIMER 306 +#define CLK_NPUTIMER_ROOT 307 +#define CLK_NPUTIMER0 308 +#define CLK_NPUTIMER1 309 +#define PCLK_NPU_WDT 310 +#define TCLK_NPU_WDT 311 +#define HCLK_EMMC 312 +#define ACLK_EMMC 313 +#define CCLK_EMMC 314 +#define BCLK_EMMC 315 +#define TMCLK_EMMC 316 +#define SCLK_SFC 317 +#define HCLK_SFC 318 +#define HCLK_SFC_XIP 319 +#define HCLK_NVM_ROOT 320 +#define ACLK_NVM_ROOT 321 +#define CLK_GMAC0_PTP_REF 322 +#define CLK_GMAC1_PTP_REF 323 +#define CLK_GMAC_125M 324 +#define CLK_GMAC_50M 325 +#define ACLK_PHP_GIC_ITS 326 +#define ACLK_MMU_PCIE 327 +#define ACLK_MMU_PHP 328 +#define ACLK_PCIE_4L_DBI 329 +#define ACLK_PCIE_2L_DBI 330 +#define ACLK_PCIE_1L0_DBI 331 +#define ACLK_PCIE_1L1_DBI 332 +#define ACLK_PCIE_1L2_DBI 333 +#define ACLK_PCIE_4L_MSTR 334 +#define ACLK_PCIE_2L_MSTR 335 +#define ACLK_PCIE_1L0_MSTR 336 +#define ACLK_PCIE_1L1_MSTR 337 +#define ACLK_PCIE_1L2_MSTR 338 +#define ACLK_PCIE_4L_SLV 339 +#define ACLK_PCIE_2L_SLV 340 +#define ACLK_PCIE_1L0_SLV 341 +#define ACLK_PCIE_1L1_SLV 342 +#define ACLK_PCIE_1L2_SLV 343 +#define PCLK_PCIE_4L 344 +#define PCLK_PCIE_2L 345 +#define PCLK_PCIE_1L0 347 +#define PCLK_PCIE_1L1 348 +#define PCLK_PCIE_1L2 349 +#define CLK_PCIE_AUX0 350 +#define CLK_PCIE_AUX1 351 +#define CLK_PCIE_AUX2 352 +#define CLK_PCIE_AUX3 353 +#define CLK_PCIE_AUX4 354 +#define CLK_PIPEPHY0_REF 355 +#define CLK_PIPEPHY1_REF 356 +#define CLK_PIPEPHY2_REF 357 +#define PCLK_PHP_ROOT 358 +#define PCLK_GMAC0 359 +#define PCLK_GMAC1 360 +#define ACLK_PCIE_ROOT 361 +#define ACLK_PHP_ROOT 362 +#define ACLK_PCIE_BRIDGE 363 +#define ACLK_GMAC0 364 +#define ACLK_GMAC1 365 +#define CLK_PMALIVE0 366 +#define CLK_PMALIVE1 367 +#define CLK_PMALIVE2 368 +#define ACLK_SATA0 369 +#define ACLK_SATA1 370 +#define ACLK_SATA2 371 +#define CLK_RXOOB0 372 +#define CLK_RXOOB1 373 +#define CLK_RXOOB2 374 +#define ACLK_USB3OTG2 375 +#define SUSPEND_CLK_USB3OTG2 376 +#define REF_CLK_USB3OTG2 377 +#define CLK_UTMI_OTG2 378 +#define CLK_PIPEPHY0_PIPE_G 379 +#define CLK_PIPEPHY1_PIPE_G 380 +#define CLK_PIPEPHY2_PIPE_G 381 +#define CLK_PIPEPHY0_PIPE_ASIC_G 382 +#define CLK_PIPEPHY1_PIPE_ASIC_G 383 +#define CLK_PIPEPHY2_PIPE_ASIC_G 384 +#define CLK_PIPEPHY2_PIPE_U3_G 385 +#define CLK_PCIE1L2_PIPE 386 +#define CLK_PCIE4L_PIPE 387 +#define CLK_PCIE2L_PIPE 388 +#define PCLK_PCIE_COMBO_PIPE_PHY0 389 +#define PCLK_PCIE_COMBO_PIPE_PHY1 390 +#define PCLK_PCIE_COMBO_PIPE_PHY2 391 +#define PCLK_PCIE_COMBO_PIPE_PHY 392 +#define HCLK_RGA3_1 393 +#define ACLK_RGA3_1 394 +#define CLK_RGA3_1_CORE 395 +#define ACLK_RGA3_ROOT 396 +#define HCLK_RGA3_ROOT 397 +#define ACLK_RKVDEC_CCU 398 +#define HCLK_RKVDEC0 399 +#define ACLK_RKVDEC0 400 +#define CLK_RKVDEC0_CA 401 +#define CLK_RKVDEC0_HEVC_CA 402 +#define CLK_RKVDEC0_CORE 403 +#define HCLK_RKVDEC1 404 +#define ACLK_RKVDEC1 405 +#define CLK_RKVDEC1_CA 406 +#define CLK_RKVDEC1_HEVC_CA 407 +#define CLK_RKVDEC1_CORE 408 +#define HCLK_SDIO 409 +#define CCLK_SRC_SDIO 410 +#define ACLK_USB_ROOT 411 +#define HCLK_USB_ROOT 412 +#define HCLK_HOST0 413 +#define HCLK_HOST_ARB0 414 +#define HCLK_HOST1 415 +#define HCLK_HOST_ARB1 416 +#define ACLK_USB3OTG0 417 +#define SUSPEND_CLK_USB3OTG0 418 +#define REF_CLK_USB3OTG0 419 +#define ACLK_USB3OTG1 420 +#define SUSPEND_CLK_USB3OTG1 421 +#define REF_CLK_USB3OTG1 422 +#define UTMI_OHCI_CLK48_HOST0 423 +#define UTMI_OHCI_CLK48_HOST1 424 +#define HCLK_IEP2P0 425 +#define ACLK_IEP2P0 426 +#define CLK_IEP2P0_CORE 427 +#define ACLK_JPEG_ENCODER0 428 +#define HCLK_JPEG_ENCODER0 429 +#define ACLK_JPEG_ENCODER1 430 +#define HCLK_JPEG_ENCODER1 431 +#define ACLK_JPEG_ENCODER2 432 +#define HCLK_JPEG_ENCODER2 433 +#define ACLK_JPEG_ENCODER3 434 +#define HCLK_JPEG_ENCODER3 435 +#define ACLK_JPEG_DECODER 436 +#define HCLK_JPEG_DECODER 437 +#define HCLK_RGA2 438 +#define ACLK_RGA2 439 +#define CLK_RGA2_CORE 440 +#define HCLK_RGA3_0 441 +#define ACLK_RGA3_0 442 +#define CLK_RGA3_0_CORE 443 +#define ACLK_VDPU_ROOT 444 +#define ACLK_VDPU_LOW_ROOT 445 +#define HCLK_VDPU_ROOT 446 +#define ACLK_JPEG_DECODER_ROOT 447 +#define ACLK_VPU 448 +#define HCLK_VPU 449 +#define HCLK_RKVENC0_ROOT 450 +#define ACLK_RKVENC0_ROOT 451 +#define HCLK_RKVENC0 452 +#define ACLK_RKVENC0 453 +#define CLK_RKVENC0_CORE 454 +#define HCLK_RKVENC1_ROOT 455 +#define ACLK_RKVENC1_ROOT 456 +#define HCLK_RKVENC1 457 +#define ACLK_RKVENC1 458 +#define CLK_RKVENC1_CORE 459 +#define ICLK_CSIHOST01 460 +#define ICLK_CSIHOST0 461 +#define ICLK_CSIHOST1 462 +#define PCLK_CSI_HOST_0 463 +#define PCLK_CSI_HOST_1 464 +#define PCLK_CSI_HOST_2 465 +#define PCLK_CSI_HOST_3 466 +#define PCLK_CSI_HOST_4 467 +#define PCLK_CSI_HOST_5 468 +#define ACLK_FISHEYE0 469 +#define HCLK_FISHEYE0 470 +#define CLK_FISHEYE0_CORE 471 +#define ACLK_FISHEYE1 472 +#define HCLK_FISHEYE1 473 +#define CLK_FISHEYE1_CORE 474 +#define CLK_ISP0_CORE 475 +#define CLK_ISP0_CORE_MARVIN 476 +#define CLK_ISP0_CORE_VICAP 477 +#define ACLK_ISP0 478 +#define HCLK_ISP0 479 +#define ACLK_VI_ROOT 480 +#define HCLK_VI_ROOT 481 +#define PCLK_VI_ROOT 482 +#define DCLK_VICAP 483 +#define ACLK_VICAP 484 +#define HCLK_VICAP 485 +#define PCLK_DP0 486 +#define PCLK_DP1 487 +#define PCLK_S_DP0 488 +#define PCLK_S_DP1 489 +#define CLK_DP0 490 +#define CLK_DP1 491 +#define HCLK_HDCP_KEY0 492 +#define ACLK_HDCP0 493 +#define HCLK_HDCP0 494 +#define PCLK_HDCP0 495 +#define HCLK_I2S4_8CH 496 +#define ACLK_TRNG0 497 +#define PCLK_TRNG0 498 +#define ACLK_VO0_ROOT 499 +#define HCLK_VO0_ROOT 500 +#define HCLK_VO0_S_ROOT 501 +#define PCLK_VO0_ROOT 502 +#define PCLK_VO0_S_ROOT 503 +#define PCLK_VO0GRF 504 +#define CLK_I2S4_8CH_TX_SRC 505 +#define CLK_I2S4_8CH_TX_FRAC 506 +#define MCLK_I2S4_8CH_TX 507 +#define CLK_I2S4_8CH_TX 508 +#define HCLK_I2S8_8CH 510 +#define CLK_I2S8_8CH_TX_SRC 511 +#define CLK_I2S8_8CH_TX_FRAC 512 +#define MCLK_I2S8_8CH_TX 513 +#define CLK_I2S8_8CH_TX 514 +#define HCLK_SPDIF2_DP0 516 +#define CLK_SPDIF2_DP0_SRC 517 +#define CLK_SPDIF2_DP0_FRAC 518 +#define MCLK_SPDIF2_DP0 519 +#define CLK_SPDIF2_DP0 520 +#define MCLK_SPDIF2 521 +#define HCLK_SPDIF5_DP1 522 +#define CLK_SPDIF5_DP1_SRC 523 +#define CLK_SPDIF5_DP1_FRAC 524 +#define MCLK_SPDIF5_DP1 525 +#define CLK_SPDIF5_DP1 526 +#define MCLK_SPDIF5 527 +#define PCLK_EDP0 528 +#define CLK_EDP0_24M 529 +#define CLK_EDP0_200M 530 +#define PCLK_EDP1 531 +#define CLK_EDP1_24M 532 +#define CLK_EDP1_200M 533 +#define HCLK_HDCP_KEY1 534 +#define ACLK_HDCP1 535 +#define HCLK_HDCP1 536 +#define PCLK_HDCP1 537 +#define ACLK_HDMIRX 538 +#define PCLK_HDMIRX 539 +#define CLK_HDMIRX_REF 540 +#define CLK_HDMIRX_AUD_SRC 541 +#define CLK_HDMIRX_AUD_FRAC 542 +#define CLK_HDMIRX_AUD 543 +#define CLK_HDMIRX_AUD_P_MUX 544 +#define PCLK_HDMITX0 545 +#define CLK_HDMITX0_EARC 546 +#define CLK_HDMITX0_REF 547 +#define PCLK_HDMITX1 548 +#define CLK_HDMITX1_EARC 549 +#define CLK_HDMITX1_REF 550 +#define CLK_HDMITRX_REFSRC 551 +#define ACLK_TRNG1 552 +#define PCLK_TRNG1 553 +#define ACLK_HDCP1_ROOT 554 +#define ACLK_HDMIRX_ROOT 555 +#define HCLK_VO1_ROOT 556 +#define HCLK_VO1_S_ROOT 557 +#define PCLK_VO1_ROOT 558 +#define PCLK_VO1_S_ROOT 559 +#define PCLK_S_EDP0 560 +#define PCLK_S_EDP1 561 +#define PCLK_S_HDMIRX 562 +#define HCLK_I2S10_8CH 563 +#define CLK_I2S10_8CH_RX_SRC 564 +#define CLK_I2S10_8CH_RX_FRAC 565 +#define CLK_I2S10_8CH_RX 566 +#define MCLK_I2S10_8CH_RX 567 +#define HCLK_I2S7_8CH 568 +#define CLK_I2S7_8CH_RX_SRC 569 +#define CLK_I2S7_8CH_RX_FRAC 570 +#define CLK_I2S7_8CH_RX 571 +#define MCLK_I2S7_8CH_RX 572 +#define HCLK_I2S9_8CH 574 +#define CLK_I2S9_8CH_RX_SRC 575 +#define CLK_I2S9_8CH_RX_FRAC 576 +#define CLK_I2S9_8CH_RX 577 +#define MCLK_I2S9_8CH_RX 578 +#define CLK_I2S5_8CH_TX_SRC 579 +#define CLK_I2S5_8CH_TX_FRAC 580 +#define CLK_I2S5_8CH_TX 581 +#define MCLK_I2S5_8CH_TX 582 +#define HCLK_I2S5_8CH 584 +#define CLK_I2S6_8CH_TX_SRC 585 +#define CLK_I2S6_8CH_TX_FRAC 586 +#define CLK_I2S6_8CH_TX 587 +#define MCLK_I2S6_8CH_TX 588 +#define CLK_I2S6_8CH_RX_SRC 589 +#define CLK_I2S6_8CH_RX_FRAC 590 +#define CLK_I2S6_8CH_RX 591 +#define MCLK_I2S6_8CH_RX 592 +#define I2S6_8CH_MCLKOUT 593 +#define HCLK_I2S6_8CH 594 +#define HCLK_SPDIF3 595 +#define CLK_SPDIF3_SRC 596 +#define CLK_SPDIF3_FRAC 597 +#define CLK_SPDIF3 598 +#define MCLK_SPDIF3 599 +#define HCLK_SPDIF4 600 +#define CLK_SPDIF4_SRC 601 +#define CLK_SPDIF4_FRAC 602 +#define CLK_SPDIF4 603 +#define MCLK_SPDIF4 604 +#define HCLK_SPDIFRX0 605 +#define MCLK_SPDIFRX0 606 +#define HCLK_SPDIFRX1 607 +#define MCLK_SPDIFRX1 608 +#define HCLK_SPDIFRX2 609 +#define MCLK_SPDIFRX2 610 +#define ACLK_VO1USB_TOP_ROOT 611 +#define HCLK_VO1USB_TOP_ROOT 612 +#define CLK_HDMIHDP0 613 +#define CLK_HDMIHDP1 614 +#define PCLK_HDPTX0 615 +#define PCLK_HDPTX1 616 +#define PCLK_USBDPPHY0 617 +#define PCLK_USBDPPHY1 618 +#define ACLK_VOP_ROOT 619 +#define ACLK_VOP_LOW_ROOT 620 +#define HCLK_VOP_ROOT 621 +#define PCLK_VOP_ROOT 622 +#define HCLK_VOP 623 +#define ACLK_VOP 624 +#define DCLK_VOP0_SRC 625 +#define DCLK_VOP1_SRC 626 +#define DCLK_VOP2_SRC 627 +#define DCLK_VOP0 628 +#define DCLK_VOP1 629 +#define DCLK_VOP2 630 +#define DCLK_VOP3 631 +#define PCLK_DSIHOST0 632 +#define PCLK_DSIHOST1 633 +#define CLK_DSIHOST0 634 +#define CLK_DSIHOST1 635 +#define CLK_VOP_PMU 636 +#define ACLK_VOP_DOBY 637 +#define ACLK_VOP_SUB_SRC 638 +#define CLK_USBDP_PHY0_IMMORTAL 639 +#define CLK_USBDP_PHY1_IMMORTAL 640 +#define CLK_PMU0 641 +#define PCLK_PMU0 642 +#define PCLK_PMU0IOC 643 +#define PCLK_GPIO0 644 +#define DBCLK_GPIO0 645 +#define PCLK_I2C0 646 +#define CLK_I2C0 647 +#define HCLK_I2S1_8CH 648 +#define CLK_I2S1_8CH_TX_SRC 649 +#define CLK_I2S1_8CH_TX_FRAC 650 +#define CLK_I2S1_8CH_TX 651 +#define MCLK_I2S1_8CH_TX 652 +#define CLK_I2S1_8CH_RX_SRC 653 +#define CLK_I2S1_8CH_RX_FRAC 654 +#define CLK_I2S1_8CH_RX 655 +#define MCLK_I2S1_8CH_RX 656 +#define I2S1_8CH_MCLKOUT 657 +#define CLK_PMU1_50M_SRC 658 +#define CLK_PMU1_100M_SRC 659 +#define CLK_PMU1_200M_SRC 660 +#define CLK_PMU1_300M_SRC 661 +#define CLK_PMU1_400M_SRC 662 +#define HCLK_PMU1_ROOT 663 +#define PCLK_PMU1_ROOT 664 +#define PCLK_PMU0_ROOT 665 +#define HCLK_PMU_CM0_ROOT 666 +#define PCLK_PMU1 667 +#define CLK_DDR_FAIL_SAFE 668 +#define CLK_PMU1 669 +#define HCLK_PDM0 670 +#define MCLK_PDM0 671 +#define HCLK_VAD 672 +#define FCLK_PMU_CM0_CORE 673 +#define CLK_PMU_CM0_RTC 674 +#define PCLK_PMU1_IOC 675 +#define PCLK_PMU1PWM 676 +#define CLK_PMU1PWM 677 +#define CLK_PMU1PWM_CAPTURE 678 +#define PCLK_PMU1TIMER 679 +#define CLK_PMU1TIMER_ROOT 680 +#define CLK_PMU1TIMER0 681 +#define CLK_PMU1TIMER1 682 +#define CLK_UART0_SRC 683 +#define CLK_UART0_FRAC 684 +#define CLK_UART0 685 +#define SCLK_UART0 686 +#define PCLK_UART0 687 +#define PCLK_PMU1WDT 688 +#define TCLK_PMU1WDT 689 +#define CLK_CR_PARA 690 +#define CLK_GMAC0 691 +#define CLK_GMAC1 692 +#define CLK_USB2PHY_HDPTXRXPHY_REF 693 +#define CLK_USBDPPHY_MIPIDCPPHY_REF 694 +#define CLK_REF_PIPE_PHY0_OSC_SRC 695 +#define CLK_REF_PIPE_PHY1_OSC_SRC 696 +#define CLK_REF_PIPE_PHY2_OSC_SRC 697 +#define CLK_REF_PIPE_PHY0_PLL_SRC 698 +#define CLK_REF_PIPE_PHY1_PLL_SRC 699 +#define CLK_REF_PIPE_PHY2_PLL_SRC 700 +#define CLK_REF_PIPE_PHY0 701 +#define CLK_REF_PIPE_PHY1 702 +#define CLK_REF_PIPE_PHY2 703 +#define SCLK_SDIO_DRV 704 +#define SCLK_SDIO_SAMPLE 705 +#define SCLK_SDMMC_DRV 706 +#define SCLK_SDMMC_SAMPLE 707 +#define CLK_PCIE1L0_PIPE 708 +#define CLK_PCIE1L1_PIPE 709 +#define CLK_BIGCORE0_PVTM 710 +#define CLK_CORE_BIGCORE0_PVTM 711 +#define CLK_BIGCORE1_PVTM 712 +#define CLK_CORE_BIGCORE1_PVTM 713 +#define CLK_LITCORE_PVTM 714 +#define CLK_CORE_LITCORE_PVTM 715 +#define CLK_AUX16M_0 716 +#define CLK_AUX16M_1 717 + +#define CLK_NR_CLKS (CLK_AUX16M_1 + 1) + +/********Name=SOFTRST_CON01,Offset=0xA04********/ +#define SRST_A_TOP_BIU 19 +#define SRST_P_TOP_BIU 20 +#define SRST_P_CSIPHY0 22 +#define SRST_CSIPHY0 23 +#define SRST_P_CSIPHY1 24 +#define SRST_CSIPHY1 25 +#define SRST_A_TOP_M500_BIU 31 +/********Name=SOFTRST_CON02,Offset=0xA08********/ +#define SRST_A_TOP_M400_BIU 32 +#define SRST_A_TOP_S200_BIU 33 +#define SRST_A_TOP_S400_BIU 34 +#define SRST_A_TOP_M300_BIU 35 +#define SRST_USBDP_COMBO_PHY0_INIT 40 +#define SRST_USBDP_COMBO_PHY0_CMN 41 +#define SRST_USBDP_COMBO_PHY0_LANE 42 +#define SRST_USBDP_COMBO_PHY0_PCS 43 +#define SRST_USBDP_COMBO_PHY1_INIT 47 +/********Name=SOFTRST_CON03,Offset=0xA0C********/ +#define SRST_USBDP_COMBO_PHY1_CMN 48 +#define SRST_USBDP_COMBO_PHY1_LANE 49 +#define SRST_USBDP_COMBO_PHY1_PCS 50 +#define SRST_DCPHY0 59 +#define SRST_P_MIPI_DCPHY0 62 +#define SRST_P_MIPI_DCPHY0_GRF 63 +/********Name=SOFTRST_CON04,Offset=0xA10********/ +#define SRST_DCPHY1 64 +#define SRST_P_MIPI_DCPHY1 67 +#define SRST_P_MIPI_DCPHY1_GRF 68 +#define SRST_P_APB2ASB_SLV_CDPHY 69 +#define SRST_P_APB2ASB_SLV_CSIPHY 70 +#define SRST_P_APB2ASB_SLV_VCCIO3_5 71 +#define SRST_P_APB2ASB_SLV_VCCIO6 72 +#define SRST_P_APB2ASB_SLV_EMMCIO 73 +#define SRST_P_APB2ASB_SLV_IOC_TOP 74 +#define SRST_P_APB2ASB_SLV_IOC_RIGHT 75 +/********Name=SOFTRST_CON05,Offset=0xA14********/ +#define SRST_P_CRU 80 +#define SRST_A_CHANNEL_SECURE2VO1USB 87 +#define SRST_A_CHANNEL_SECURE2CENTER 88 +#define SRST_H_CHANNEL_SECURE2VO1USB 94 +#define SRST_H_CHANNEL_SECURE2CENTER 95 +/********Name=SOFTRST_CON06,Offset=0xA18********/ +#define SRST_P_CHANNEL_SECURE2VO1USB 96 +#define SRST_P_CHANNEL_SECURE2CENTER 97 +/********Name=SOFTRST_CON07,Offset=0xA1C********/ +#define SRST_H_AUDIO_BIU 114 +#define SRST_P_AUDIO_BIU 115 +#define SRST_H_I2S0_8CH 116 +#define SRST_M_I2S0_8CH_TX 119 +#define SRST_M_I2S0_8CH_RX 122 +#define SRST_P_ACDCDIG 123 +#define SRST_H_I2S2_2CH 124 +#define SRST_H_I2S3_2CH 125 +/********Name=SOFTRST_CON08,Offset=0xA20********/ +#define SRST_M_I2S2_2CH 128 +#define SRST_M_I2S3_2CH 131 +#define SRST_DAC_ACDCDIG 132 +#define SRST_H_SPDIF0 142 +/********Name=SOFTRST_CON09,Offset=0xA24********/ +#define SRST_M_SPDIF0 145 +#define SRST_H_SPDIF1 146 +#define SRST_M_SPDIF1 149 +#define SRST_H_PDM1 150 +#define SRST_PDM1 151 +/********Name=SOFTRST_CON10,Offset=0xA28********/ +#define SRST_A_BUS_BIU 161 +#define SRST_P_BUS_BIU 162 +#define SRST_A_GIC 163 +#define SRST_A_GIC_DBG 164 +#define SRST_A_DMAC0 165 +#define SRST_A_DMAC1 166 +#define SRST_A_DMAC2 167 +#define SRST_P_I2C1 168 +#define SRST_P_I2C2 169 +#define SRST_P_I2C3 170 +#define SRST_P_I2C4 171 +#define SRST_P_I2C5 172 +#define SRST_P_I2C6 173 +#define SRST_P_I2C7 174 +#define SRST_P_I2C8 175 +/********Name=SOFTRST_CON11,Offset=0xA2C********/ +#define SRST_I2C1 176 +#define SRST_I2C2 177 +#define SRST_I2C3 178 +#define SRST_I2C4 179 +#define SRST_I2C5 180 +#define SRST_I2C6 181 +#define SRST_I2C7 182 +#define SRST_I2C8 183 +#define SRST_P_CAN0 184 +#define SRST_CAN0 185 +#define SRST_P_CAN1 186 +#define SRST_CAN1 187 +#define SRST_P_CAN2 188 +#define SRST_CAN2 189 +#define SRST_P_SARADC 190 +/********Name=SOFTRST_CON12,Offset=0xA30********/ +#define SRST_P_TSADC 192 +#define SRST_TSADC 193 +#define SRST_P_UART1 194 +#define SRST_P_UART2 195 +#define SRST_P_UART3 196 +#define SRST_P_UART4 197 +#define SRST_P_UART5 198 +#define SRST_P_UART6 199 +#define SRST_P_UART7 200 +#define SRST_P_UART8 201 +#define SRST_P_UART9 202 +#define SRST_S_UART1 205 +/********Name=SOFTRST_CON13,Offset=0xA34********/ +#define SRST_S_UART2 208 +#define SRST_S_UART3 211 +#define SRST_S_UART4 214 +#define SRST_S_UART5 217 +#define SRST_S_UART6 220 +#define SRST_S_UART7 223 +/********Name=SOFTRST_CON14,Offset=0xA38********/ +#define SRST_S_UART8 226 +#define SRST_S_UART9 229 +#define SRST_P_SPI0 230 +#define SRST_P_SPI1 231 +#define SRST_P_SPI2 232 +#define SRST_P_SPI3 233 +#define SRST_P_SPI4 234 +#define SRST_SPI0 235 +#define SRST_SPI1 236 +#define SRST_SPI2 237 +#define SRST_SPI3 238 +#define SRST_SPI4 239 +/********Name=SOFTRST_CON15,Offset=0xA3C********/ +#define SRST_P_WDT0 240 +#define SRST_T_WDT0 241 +#define SRST_P_SYS_GRF 242 +#define SRST_P_PWM1 243 +#define SRST_PWM1 244 +#define SRST_P_PWM2 246 +#define SRST_PWM2 247 +#define SRST_P_PWM3 249 +#define SRST_PWM3 250 +#define SRST_P_BUSTIMER0 252 +#define SRST_P_BUSTIMER1 253 +#define SRST_BUSTIMER0 255 +/********Name=SOFTRST_CON16,Offset=0xA40********/ +#define SRST_BUSTIMER1 256 +#define SRST_BUSTIMER2 257 +#define SRST_BUSTIMER3 258 +#define SRST_BUSTIMER4 259 +#define SRST_BUSTIMER5 260 +#define SRST_BUSTIMER6 261 +#define SRST_BUSTIMER7 262 +#define SRST_BUSTIMER8 263 +#define SRST_BUSTIMER9 264 +#define SRST_BUSTIMER10 265 +#define SRST_BUSTIMER11 266 +#define SRST_P_MAILBOX0 267 +#define SRST_P_MAILBOX1 268 +#define SRST_P_MAILBOX2 269 +#define SRST_P_GPIO1 270 +#define SRST_GPIO1 271 +/********Name=SOFTRST_CON17,Offset=0xA44********/ +#define SRST_P_GPIO2 272 +#define SRST_GPIO2 273 +#define SRST_P_GPIO3 274 +#define SRST_GPIO3 275 +#define SRST_P_GPIO4 276 +#define SRST_GPIO4 277 +#define SRST_A_DECOM 278 +#define SRST_P_DECOM 279 +#define SRST_D_DECOM 280 +#define SRST_P_TOP 281 +#define SRST_A_GICADB_GIC2CORE_BUS 283 +#define SRST_P_DFT2APB 284 +#define SRST_P_APB2ASB_MST_TOP 285 +#define SRST_P_APB2ASB_MST_CDPHY 286 +#define SRST_P_APB2ASB_MST_BOT_RIGHT 287 +/********Name=SOFTRST_CON18,Offset=0xA48********/ +#define SRST_P_APB2ASB_MST_IOC_TOP 288 +#define SRST_P_APB2ASB_MST_IOC_RIGHT 289 +#define SRST_P_APB2ASB_MST_CSIPHY 290 +#define SRST_P_APB2ASB_MST_VCCIO3_5 291 +#define SRST_P_APB2ASB_MST_VCCIO6 292 +#define SRST_P_APB2ASB_MST_EMMCIO 293 +#define SRST_A_SPINLOCK 294 +#define SRST_P_OTPC_NS 297 +#define SRST_OTPC_NS 298 +#define SRST_OTPC_ARB 299 +/********Name=SOFTRST_CON19,Offset=0xA4C********/ +#define SRST_P_BUSIOC 304 +#define SRST_P_PMUCM0_INTMUX 308 +#define SRST_P_DDRCM0_INTMUX 309 +/********Name=SOFTRST_CON20,Offset=0xA50********/ +#define SRST_P_DDR_DFICTL_CH0 320 +#define SRST_P_DDR_MON_CH0 321 +#define SRST_P_DDR_STANDBY_CH0 322 +#define SRST_P_DDR_UPCTL_CH0 323 +#define SRST_TM_DDR_MON_CH0 324 +#define SRST_P_DDR_GRF_CH01 325 +#define SRST_DFI_CH0 326 +#define SRST_SBR_CH0 327 +#define SRST_DDR_UPCTL_CH0 328 +#define SRST_DDR_DFICTL_CH0 329 +#define SRST_DDR_MON_CH0 330 +#define SRST_DDR_STANDBY_CH0 331 +#define SRST_A_DDR_UPCTL_CH0 332 +#define SRST_P_DDR_DFICTL_CH1 333 +#define SRST_P_DDR_MON_CH1 334 +#define SRST_P_DDR_STANDBY_CH1 335 +/********Name=SOFTRST_CON21,Offset=0xA54********/ +#define SRST_P_DDR_UPCTL_CH1 336 +#define SRST_TM_DDR_MON_CH1 337 +#define SRST_DFI_CH1 338 +#define SRST_SBR_CH1 339 +#define SRST_DDR_UPCTL_CH1 340 +#define SRST_DDR_DFICTL_CH1 341 +#define SRST_DDR_MON_CH1 342 +#define SRST_DDR_STANDBY_CH1 343 +#define SRST_A_DDR_UPCTL_CH1 344 +#define SRST_A_DDR01_MSCH0 349 +#define SRST_A_DDR01_RS_MSCH0 350 +#define SRST_A_DDR01_FRS_MSCH0 351 +/********Name=SOFTRST_CON22,Offset=0xA58********/ +#define SRST_A_DDR01_SCRAMBLE0 352 +#define SRST_A_DDR01_FRS_SCRAMBLE0 353 +#define SRST_A_DDR01_MSCH1 354 +#define SRST_A_DDR01_RS_MSCH1 355 +#define SRST_A_DDR01_FRS_MSCH1 356 +#define SRST_A_DDR01_SCRAMBLE1 357 +#define SRST_A_DDR01_FRS_SCRAMBLE1 358 +#define SRST_P_DDR01_MSCH0 359 +#define SRST_P_DDR01_MSCH1 360 +/********Name=SOFTRST_CON23,Offset=0xA5C********/ +#define SRST_P_DDR_DFICTL_CH2 368 +#define SRST_P_DDR_MON_CH2 369 +#define SRST_P_DDR_STANDBY_CH2 370 +#define SRST_P_DDR_UPCTL_CH2 371 +#define SRST_TM_DDR_MON_CH2 372 +#define SRST_P_DDR_GRF_CH23 373 +#define SRST_DFI_CH2 374 +#define SRST_SBR_CH2 375 +#define SRST_DDR_UPCTL_CH2 376 +#define SRST_DDR_DFICTL_CH2 377 +#define SRST_DDR_MON_CH2 378 +#define SRST_DDR_STANDBY_CH2 379 +#define SRST_A_DDR_UPCTL_CH2 380 +#define SRST_P_DDR_DFICTL_CH3 381 +#define SRST_P_DDR_MON_CH3 382 +#define SRST_P_DDR_STANDBY_CH3 383 +/********Name=SOFTRST_CON24,Offset=0xA60********/ +#define SRST_P_DDR_UPCTL_CH3 384 +#define SRST_TM_DDR_MON_CH3 385 +#define SRST_DFI_CH3 386 +#define SRST_SBR_CH3 387 +#define SRST_DDR_UPCTL_CH3 388 +#define SRST_DDR_DFICTL_CH3 389 +#define SRST_DDR_MON_CH3 390 +#define SRST_DDR_STANDBY_CH3 391 +#define SRST_A_DDR_UPCTL_CH3 392 +#define SRST_A_DDR23_MSCH2 397 +#define SRST_A_DDR23_RS_MSCH2 398 +#define SRST_A_DDR23_FRS_MSCH2 399 +/********Name=SOFTRST_CON25,Offset=0xA64********/ +#define SRST_A_DDR23_SCRAMBLE2 400 +#define SRST_A_DDR23_FRS_SCRAMBLE2 401 +#define SRST_A_DDR23_MSCH3 402 +#define SRST_A_DDR23_RS_MSCH3 403 +#define SRST_A_DDR23_FRS_MSCH3 404 +#define SRST_A_DDR23_SCRAMBLE3 405 +#define SRST_A_DDR23_FRS_SCRAMBLE3 406 +#define SRST_P_DDR23_MSCH2 407 +#define SRST_P_DDR23_MSCH3 408 +/********Name=SOFTRST_CON26,Offset=0xA68********/ +#define SRST_ISP1 419 +#define SRST_ISP1_VICAP 420 +#define SRST_A_ISP1_BIU 422 +#define SRST_H_ISP1_BIU 424 +/********Name=SOFTRST_CON27,Offset=0xA6C********/ +#define SRST_A_RKNN1 432 +#define SRST_A_RKNN1_BIU 433 +#define SRST_H_RKNN1 434 +#define SRST_H_RKNN1_BIU 435 +/********Name=SOFTRST_CON28,Offset=0xA70********/ +#define SRST_A_RKNN2 448 +#define SRST_A_RKNN2_BIU 449 +#define SRST_H_RKNN2 450 +#define SRST_H_RKNN2_BIU 451 +/********Name=SOFTRST_CON29,Offset=0xA74********/ +#define SRST_A_RKNN_DSU0 467 +#define SRST_P_NPUTOP_BIU 469 +#define SRST_P_NPU_TIMER 470 +#define SRST_NPUTIMER0 472 +#define SRST_NPUTIMER1 473 +#define SRST_P_NPU_WDT 474 +#define SRST_T_NPU_WDT 475 +#define SRST_P_NPU_PVTM 476 +#define SRST_P_NPU_GRF 477 +#define SRST_NPU_PVTM 478 +/********Name=SOFTRST_CON30,Offset=0xA78********/ +#define SRST_NPU_PVTPLL 480 +#define SRST_H_NPU_CM0_BIU 482 +#define SRST_F_NPU_CM0_CORE 483 +#define SRST_T_NPU_CM0_JTAG 484 +#define SRST_A_RKNN0 486 +#define SRST_A_RKNN0_BIU 487 +#define SRST_H_RKNN0 488 +#define SRST_H_RKNN0_BIU 489 +/********Name=SOFTRST_CON31,Offset=0xA7C********/ +#define SRST_H_NVM_BIU 498 +#define SRST_A_NVM_BIU 499 +#define SRST_H_EMMC 500 +#define SRST_A_EMMC 501 +#define SRST_C_EMMC 502 +#define SRST_B_EMMC 503 +#define SRST_T_EMMC 504 +#define SRST_S_SFC 505 +#define SRST_H_SFC 506 +#define SRST_H_SFC_XIP 507 +/********Name=SOFTRST_CON32,Offset=0xA80********/ +#define SRST_P_GRF 513 +#define SRST_P_DEC_BIU 514 +#define SRST_P_PHP_BIU 517 +#define SRST_A_PCIE_GRIDGE 520 +#define SRST_A_PHP_BIU 521 +#define SRST_A_GMAC0 522 +#define SRST_A_GMAC1 523 +#define SRST_A_PCIE_BIU 524 +#define SRST_PCIE0_POWER_UP 525 +#define SRST_PCIE1_POWER_UP 526 +#define SRST_PCIE2_POWER_UP 527 +/********Name=SOFTRST_CON33,Offset=0xA84********/ +#define SRST_PCIE3_POWER_UP 528 +#define SRST_PCIE4_POWER_UP 529 +#define SRST_P_PCIE0 540 +#define SRST_P_PCIE1 541 +#define SRST_P_PCIE2 542 +#define SRST_P_PCIE3 543 +/********Name=SOFTRST_CON34,Offset=0xA88********/ +#define SRST_P_PCIE4 544 +#define SRST_A_PHP_GIC_ITS 550 +#define SRST_A_MMU_PCIE 551 +#define SRST_A_MMU_PHP 552 +#define SRST_A_MMU_BIU 553 +/********Name=SOFTRST_CON35,Offset=0xA8C********/ +#define SRST_A_USB3OTG2 567 +/********Name=SOFTRST_CON37,Offset=0xA94********/ +#define SRST_PMALIVE0 596 +#define SRST_PMALIVE1 597 +#define SRST_PMALIVE2 598 +#define SRST_A_SATA0 599 +#define SRST_A_SATA1 600 +#define SRST_A_SATA2 601 +#define SRST_RXOOB0 602 +#define SRST_RXOOB1 603 +#define SRST_RXOOB2 604 +#define SRST_ASIC0 605 +#define SRST_ASIC1 606 +#define SRST_ASIC2 607 +/********Name=SOFTRST_CON40,Offset=0xAA0********/ +#define SRST_A_RKVDEC_CCU 642 +#define SRST_H_RKVDEC0 643 +#define SRST_A_RKVDEC0 644 +#define SRST_H_RKVDEC0_BIU 645 +#define SRST_A_RKVDEC0_BIU 646 +#define SRST_RKVDEC0_CA 647 +#define SRST_RKVDEC0_HEVC_CA 648 +#define SRST_RKVDEC0_CORE 649 +/********Name=SOFTRST_CON41,Offset=0xAA4********/ +#define SRST_H_RKVDEC1 658 +#define SRST_A_RKVDEC1 659 +#define SRST_H_RKVDEC1_BIU 660 +#define SRST_A_RKVDEC1_BIU 661 +#define SRST_RKVDEC1_CA 662 +#define SRST_RKVDEC1_HEVC_CA 663 +#define SRST_RKVDEC1_CORE 664 +/********Name=SOFTRST_CON42,Offset=0xAA8********/ +#define SRST_A_USB_BIU 674 +#define SRST_H_USB_BIU 675 +#define SRST_A_USB3OTG0 676 +#define SRST_A_USB3OTG1 679 +#define SRST_H_HOST0 682 +#define SRST_H_HOST_ARB0 683 +#define SRST_H_HOST1 684 +#define SRST_H_HOST_ARB1 685 +#define SRST_A_USB_GRF 686 +#define SRST_C_USB2P0_HOST0 687 +/********Name=SOFTRST_CON43,Offset=0xAAC********/ +#define SRST_C_USB2P0_HOST1 688 +#define SRST_HOST_UTMI0 689 +#define SRST_HOST_UTMI1 690 +/********Name=SOFTRST_CON44,Offset=0xAB0********/ +#define SRST_A_VDPU_BIU 708 +#define SRST_A_VDPU_LOW_BIU 709 +#define SRST_H_VDPU_BIU 710 +#define SRST_A_JPEG_DECODER_BIU 711 +#define SRST_A_VPU 712 +#define SRST_H_VPU 713 +#define SRST_A_JPEG_ENCODER0 714 +#define SRST_H_JPEG_ENCODER0 715 +#define SRST_A_JPEG_ENCODER1 716 +#define SRST_H_JPEG_ENCODER1 717 +#define SRST_A_JPEG_ENCODER2 718 +#define SRST_H_JPEG_ENCODER2 719 +/********Name=SOFTRST_CON45,Offset=0xAB4********/ +#define SRST_A_JPEG_ENCODER3 720 +#define SRST_H_JPEG_ENCODER3 721 +#define SRST_A_JPEG_DECODER 722 +#define SRST_H_JPEG_DECODER 723 +#define SRST_H_IEP2P0 724 +#define SRST_A_IEP2P0 725 +#define SRST_IEP2P0_CORE 726 +#define SRST_H_RGA2 727 +#define SRST_A_RGA2 728 +#define SRST_RGA2_CORE 729 +#define SRST_H_RGA3_0 730 +#define SRST_A_RGA3_0 731 +#define SRST_RGA3_0_CORE 732 +/********Name=SOFTRST_CON47,Offset=0xABC********/ +#define SRST_H_RKVENC0_BIU 754 +#define SRST_A_RKVENC0_BIU 755 +#define SRST_H_RKVENC0 756 +#define SRST_A_RKVENC0 757 +#define SRST_RKVENC0_CORE 758 +/********Name=SOFTRST_CON48,Offset=0xAC0********/ +#define SRST_H_RKVENC1_BIU 770 +#define SRST_A_RKVENC1_BIU 771 +#define SRST_H_RKVENC1 772 +#define SRST_A_RKVENC1 773 +#define SRST_RKVENC1_CORE 774 +/********Name=SOFTRST_CON49,Offset=0xAC4********/ +#define SRST_A_VI_BIU 787 +#define SRST_H_VI_BIU 788 +#define SRST_P_VI_BIU 789 +#define SRST_D_VICAP 790 +#define SRST_A_VICAP 791 +#define SRST_H_VICAP 792 +#define SRST_ISP0 794 +#define SRST_ISP0_VICAP 795 +/********Name=SOFTRST_CON50,Offset=0xAC8********/ +#define SRST_FISHEYE0 800 +#define SRST_FISHEYE1 803 +#define SRST_P_CSI_HOST_0 804 +#define SRST_P_CSI_HOST_1 805 +#define SRST_P_CSI_HOST_2 806 +#define SRST_P_CSI_HOST_3 807 +#define SRST_P_CSI_HOST_4 808 +#define SRST_P_CSI_HOST_5 809 +/********Name=SOFTRST_CON51,Offset=0xACC********/ +#define SRST_CSIHOST0_VICAP 820 +#define SRST_CSIHOST1_VICAP 821 +#define SRST_CSIHOST2_VICAP 822 +#define SRST_CSIHOST3_VICAP 823 +#define SRST_CSIHOST4_VICAP 824 +#define SRST_CSIHOST5_VICAP 825 +#define SRST_CIFIN 829 +/********Name=SOFTRST_CON52,Offset=0xAD0********/ +#define SRST_A_VOP_BIU 836 +#define SRST_A_VOP_LOW_BIU 837 +#define SRST_H_VOP_BIU 838 +#define SRST_P_VOP_BIU 839 +#define SRST_H_VOP 840 +#define SRST_A_VOP 841 +#define SRST_D_VOP0 845 +#define SRST_D_VOP2HDMI_BRIDGE0 846 +#define SRST_D_VOP2HDMI_BRIDGE1 847 +/********Name=SOFTRST_CON53,Offset=0xAD4********/ +#define SRST_D_VOP1 848 +#define SRST_D_VOP2 849 +#define SRST_D_VOP3 850 +#define SRST_P_VOPGRF 851 +#define SRST_P_DSIHOST0 852 +#define SRST_P_DSIHOST1 853 +#define SRST_DSIHOST0 854 +#define SRST_DSIHOST1 855 +#define SRST_VOP_PMU 856 +#define SRST_P_VOP_CHANNEL_BIU 857 +/********Name=SOFTRST_CON55,Offset=0xADC********/ +#define SRST_H_VO0_BIU 885 +#define SRST_H_VO0_S_BIU 886 +#define SRST_P_VO0_BIU 887 +#define SRST_P_VO0_S_BIU 888 +#define SRST_A_HDCP0_BIU 889 +#define SRST_P_VO0GRF 890 +#define SRST_H_HDCP_KEY0 891 +#define SRST_A_HDCP0 892 +#define SRST_H_HDCP0 893 +#define SRST_HDCP0 895 +/********Name=SOFTRST_CON56,Offset=0xAE0********/ +#define SRST_P_TRNG0 897 +#define SRST_DP0 904 +#define SRST_DP1 905 +#define SRST_H_I2S4_8CH 906 +#define SRST_M_I2S4_8CH_TX 909 +#define SRST_H_I2S8_8CH 910 +/********Name=SOFTRST_CON57,Offset=0xAE4********/ +#define SRST_M_I2S8_8CH_TX 913 +#define SRST_H_SPDIF2_DP0 914 +#define SRST_M_SPDIF2_DP0 918 +#define SRST_H_SPDIF5_DP1 919 +#define SRST_M_SPDIF5_DP1 923 +/********Name=SOFTRST_CON59,Offset=0xAEC********/ +#define SRST_A_HDCP1_BIU 950 +#define SRST_A_VO1_BIU 952 +#define SRST_H_VOP1_BIU 953 +#define SRST_H_VOP1_S_BIU 954 +#define SRST_P_VOP1_BIU 955 +#define SRST_P_VO1GRF 956 +#define SRST_P_VO1_S_BIU 957 +/********Name=SOFTRST_CON60,Offset=0xAF0********/ +#define SRST_H_I2S7_8CH 960 +#define SRST_M_I2S7_8CH_RX 963 +#define SRST_H_HDCP_KEY1 964 +#define SRST_A_HDCP1 965 +#define SRST_H_HDCP1 966 +#define SRST_HDCP1 968 +#define SRST_P_TRNG1 970 +#define SRST_P_HDMITX0 971 +/********Name=SOFTRST_CON61,Offset=0xAF4********/ +#define SRST_HDMITX0_REF 976 +#define SRST_P_HDMITX1 978 +#define SRST_HDMITX1_REF 983 +#define SRST_A_HDMIRX 985 +#define SRST_P_HDMIRX 986 +#define SRST_HDMIRX_REF 987 +/********Name=SOFTRST_CON62,Offset=0xAF8********/ +#define SRST_P_EDP0 992 +#define SRST_EDP0_24M 993 +#define SRST_P_EDP1 995 +#define SRST_EDP1_24M 996 +#define SRST_M_I2S5_8CH_TX 1000 +#define SRST_H_I2S5_8CH 1004 +#define SRST_M_I2S6_8CH_TX 1007 +/********Name=SOFTRST_CON63,Offset=0xAFC********/ +#define SRST_M_I2S6_8CH_RX 1010 +#define SRST_H_I2S6_8CH 1011 +#define SRST_H_SPDIF3 1012 +#define SRST_M_SPDIF3 1015 +#define SRST_H_SPDIF4 1016 +#define SRST_M_SPDIF4 1019 +#define SRST_H_SPDIFRX0 1020 +#define SRST_M_SPDIFRX0 1021 +#define SRST_H_SPDIFRX1 1022 +#define SRST_M_SPDIFRX1 1023 +/********Name=SOFTRST_CON64,Offset=0xB00********/ +#define SRST_H_SPDIFRX2 1024 +#define SRST_M_SPDIFRX2 1025 +#define SRST_LINKSYM_HDMITXPHY0 1036 +#define SRST_LINKSYM_HDMITXPHY1 1037 +#define SRST_VO1_BRIDGE0 1038 +#define SRST_VO1_BRIDGE1 1039 +/********Name=SOFTRST_CON65,Offset=0xB04********/ +#define SRST_H_I2S9_8CH 1040 +#define SRST_M_I2S9_8CH_RX 1043 +#define SRST_H_I2S10_8CH 1044 +#define SRST_M_I2S10_8CH_RX 1047 +#define SRST_P_S_HDMIRX 1048 +/********Name=SOFTRST_CON66,Offset=0xB08********/ +#define SRST_GPU 1060 +#define SRST_SYS_GPU 1061 +#define SRST_A_S_GPU_BIU 1064 +#define SRST_A_M0_GPU_BIU 1065 +#define SRST_A_M1_GPU_BIU 1066 +#define SRST_A_M2_GPU_BIU 1067 +#define SRST_A_M3_GPU_BIU 1068 +#define SRST_P_GPU_BIU 1070 +#define SRST_P_GPU_PVTM 1071 +/********Name=SOFTRST_CON67,Offset=0xB0C********/ +#define SRST_GPU_PVTM 1072 +#define SRST_P_GPU_GRF 1074 +#define SRST_GPU_PVTPLL 1075 +#define SRST_GPU_JTAG 1076 +/********Name=SOFTRST_CON68,Offset=0xB10********/ +#define SRST_A_AV1_BIU 1089 +#define SRST_A_AV1 1090 +#define SRST_P_AV1_BIU 1092 +#define SRST_P_AV1 1093 +/********Name=SOFTRST_CON69,Offset=0xB14********/ +#define SRST_A_DDR_BIU 1108 +#define SRST_A_DMA2DDR 1109 +#define SRST_A_DDR_SHAREMEM 1110 +#define SRST_A_DDR_SHAREMEM_BIU 1111 +#define SRST_A_CENTER_S200_BIU 1114 +#define SRST_A_CENTER_S400_BIU 1115 +#define SRST_H_AHB2APB 1116 +#define SRST_H_CENTER_BIU 1117 +#define SRST_F_DDR_CM0_CORE 1118 +/********Name=SOFTRST_CON70,Offset=0xB18********/ +#define SRST_DDR_TIMER0 1120 +#define SRST_DDR_TIMER1 1121 +#define SRST_T_WDT_DDR 1122 +#define SRST_T_DDR_CM0_JTAG 1123 +#define SRST_P_CENTER_GRF 1125 +#define SRST_P_AHB2APB 1126 +#define SRST_P_WDT 1127 +#define SRST_P_TIMER 1128 +#define SRST_P_DMA2DDR 1129 +#define SRST_P_SHAREMEM 1130 +#define SRST_P_CENTER_BIU 1131 +#define SRST_P_CENTER_CHANNEL_BIU 1132 +/********Name=SOFTRST_CON72,Offset=0xB20********/ +#define SRST_P_USBDPGRF0 1153 +#define SRST_P_USBDPPHY0 1154 +#define SRST_P_USBDPGRF1 1155 +#define SRST_P_USBDPPHY1 1156 +#define SRST_P_HDPTX0 1157 +#define SRST_P_HDPTX1 1158 +#define SRST_P_APB2ASB_SLV_BOT_RIGHT 1159 +#define SRST_P_USB2PHY_U3_0_GRF0 1160 +#define SRST_P_USB2PHY_U3_1_GRF0 1161 +#define SRST_P_USB2PHY_U2_0_GRF0 1162 +#define SRST_P_USB2PHY_U2_1_GRF0 1163 +#define SRST_HDPTX0_ROPLL 1164 +#define SRST_HDPTX0_LCPLL 1165 +#define SRST_HDPTX0 1166 +#define SRST_HDPTX1_ROPLL 1167 +/********Name=SOFTRST_CON73,Offset=0xB24********/ +#define SRST_HDPTX1_LCPLL 1168 +#define SRST_HDPTX1 1169 +#define SRST_HDPTX0_HDMIRXPHY_SET 1170 +#define SRST_USBDP_COMBO_PHY0 1171 +#define SRST_USBDP_COMBO_PHY0_LCPLL 1172 +#define SRST_USBDP_COMBO_PHY0_ROPLL 1173 +#define SRST_USBDP_COMBO_PHY0_PCS_HS 1174 +#define SRST_USBDP_COMBO_PHY1 1175 +#define SRST_USBDP_COMBO_PHY1_LCPLL 1176 +#define SRST_USBDP_COMBO_PHY1_ROPLL 1177 +#define SRST_USBDP_COMBO_PHY1_PCS_HS 1178 +#define SRST_HDMIHDP0 1180 +#define SRST_HDMIHDP1 1181 +/********Name=SOFTRST_CON74,Offset=0xB28********/ +#define SRST_A_VO1USB_TOP_BIU 1185 +#define SRST_H_VO1USB_TOP_BIU 1187 +/********Name=SOFTRST_CON75,Offset=0xB2C********/ +#define SRST_H_SDIO_BIU 1201 +#define SRST_H_SDIO 1202 +#define SRST_SDIO 1203 +/********Name=SOFTRST_CON76,Offset=0xB30********/ +#define SRST_H_RGA3_BIU 1218 +#define SRST_A_RGA3_BIU 1219 +#define SRST_H_RGA3_1 1220 +#define SRST_A_RGA3_1 1221 +#define SRST_RGA3_1_CORE 1222 +/********Name=SOFTRST_CON77,Offset=0xB34********/ +#define SRST_REF_PIPE_PHY0 1238 +#define SRST_REF_PIPE_PHY1 1239 +#define SRST_REF_PIPE_PHY2 1240 + +/********Name=PHPTOPSOFTRST_CON0,Offset=0x8A00********/ +#define SRST_P_PHPTOP_CRU 131073 +#define SRST_P_PCIE2_GRF0 131074 +#define SRST_P_PCIE2_GRF1 131075 +#define SRST_P_PCIE2_GRF2 131076 +#define SRST_P_PCIE2_PHY0 131077 +#define SRST_P_PCIE2_PHY1 131078 +#define SRST_P_PCIE2_PHY2 131079 +#define SRST_P_PCIE3_PHY 131080 +#define SRST_P_APB2ASB_SLV_CHIP_TOP 131081 +#define SRST_PCIE30_PHY 131082 + +/********Name=PMU1SOFTRST_CON00,Offset=0x30A00********/ +#define SRST_H_PMU1_BIU 786442 +#define SRST_P_PMU1_BIU 786443 +#define SRST_H_PMU_CM0_BIU 786444 +#define SRST_F_PMU_CM0_CORE 786445 +#define SRST_T_PMU1_CM0_JTAG 786446 + +/********Name=PMU1SOFTRST_CON01,Offset=0x30A04********/ +#define SRST_DDR_FAIL_SAFE 786449 +#define SRST_P_CRU_PMU1 786450 +#define SRST_P_PMU1_GRF 786452 +#define SRST_P_PMU1_IOC 786453 +#define SRST_P_PMU1WDT 786454 +#define SRST_T_PMU1WDT 786455 +#define SRST_P_PMU1TIMER 786456 +#define SRST_PMU1TIMER0 786458 +#define SRST_PMU1TIMER1 786459 +#define SRST_P_PMU1PWM 786460 +#define SRST_PMU1PWM 786461 + +/********Name=PMU1SOFTRST_CON02,Offset=0x30A08********/ +#define SRST_P_I2C0 786465 +#define SRST_I2C0 786466 +#define SRST_S_UART0 786469 +#define SRST_P_UART0 786470 +#define SRST_H_I2S1_8CH 786471 +#define SRST_M_I2S1_8CH_TX 786474 +#define SRST_M_I2S1_8CH_RX 786477 +#define SRST_H_PDM0 786478 +#define SRST_PDM0 786479 + +/********Name=PMU1SOFTRST_CON03,Offset=0x30A0C********/ +#define SRST_H_VAD 786480 +#define SRST_HDPTX0_INIT 786491 +#define SRST_HDPTX0_CMN 786492 +#define SRST_HDPTX0_LANE 786493 +#define SRST_HDPTX1_INIT 786495 + +/********Name=PMU1SOFTRST_CON04,Offset=0x30A10********/ +#define SRST_HDPTX1_CMN 786496 +#define SRST_HDPTX1_LANE 786497 +#define SRST_M_MIPI_DCPHY0 786499 +#define SRST_S_MIPI_DCPHY0 786500 +#define SRST_M_MIPI_DCPHY1 786501 +#define SRST_S_MIPI_DCPHY1 786502 +#define SRST_OTGPHY_U3_0 786503 +#define SRST_OTGPHY_U3_1 786504 +#define SRST_OTGPHY_U2_0 786505 +#define SRST_OTGPHY_U2_1 786506 + +/********Name=PMU1SOFTRST_CON05,Offset=0x30A14********/ +#define SRST_P_PMU0GRF 786515 +#define SRST_P_PMU0IOC 786516 +#define SRST_P_GPIO0 786517 +#define SRST_GPIO0 786518 + +/* scmi-clocks indices */ + +#define SCMI_CLK_CPUL 0 +#define SCMI_CLK_DSU 1 +#define SCMI_CLK_CPUB01 2 +#define SCMI_CLK_CPUB23 3 +#define SCMI_CLK_DDR 4 +#define SCMI_CLK_GPU 5 +#define SCMI_CLK_NPU 6 +#define SCMI_CLK_SBUS 7 +#define SCMI_PCLK_SBUS 8 +#define SCMI_CCLK_SD 9 +#define SCMI_DCLK_SD 10 +#define SCMI_ACLK_SECURE_NS 11 +#define SCMI_HCLK_SECURE_NS 12 +#define SCMI_TCLK_WDT 13 +#define SCMI_KEYLADDER_CORE 14 +#define SCMI_KEYLADDER_RNG 15 +#define SCMI_ACLK_SECURE_S 16 +#define SCMI_HCLK_SECURE_S 17 +#define SCMI_PCLK_SECURE_S 18 +#define SCMI_CRYPTO_RNG 19 +#define SCMI_CRYPTO_CORE 20 +#define SCMI_CRYPTO_PKA 21 +#define SCMI_SPLL 22 +#define SCMI_HCLK_SD 23 + +/********Name=SECURE_SOFTRST_CON00,Offset=0xA00********/ +#define SRST_A_SECURE_NS_BIU 10 +#define SRST_H_SECURE_NS_BIU 11 +#define SRST_A_SECURE_S_BIU 12 +#define SRST_H_SECURE_S_BIU 13 +#define SRST_P_SECURE_S_BIU 14 +#define SRST_CRYPTO_CORE 15 +/********Name=SECURE_SOFTRST_CON01,Offset=0xA04********/ +#define SRST_CRYPTO_PKA 16 +#define SRST_CRYPTO_RNG 17 +#define SRST_A_CRYPTO 18 +#define SRST_H_CRYPTO 19 +#define SRST_KEYLADDER_CORE 25 +#define SRST_KEYLADDER_RNG 26 +#define SRST_A_KEYLADDER 27 +#define SRST_H_KEYLADDER 28 +#define SRST_P_OTPC_S 29 +#define SRST_OTPC_S 30 +#define SRST_WDT_S 31 +/********Name=SECURE_SOFTRST_CON02,Offset=0xA08********/ +#define SRST_T_WDT_S 32 +#define SRST_H_BOOTROM 33 +#define SRST_A_DCF 34 +#define SRST_P_DCF 35 +#define SRST_H_BOOTROM_NS 37 +#define SRST_P_KEYLADDER 46 +#define SRST_H_TRNG_S 47 +/********Name=SECURE_SOFTRST_CON03,Offset=0xA0C********/ +#define SRST_H_TRNG_NS 48 +#define SRST_D_SDMMC_BUFFER 49 +#define SRST_H_SDMMC 50 +#define SRST_H_SDMMC_BUFFER 51 +#define SRST_SDMMC 52 +#define SRST_P_TRNG_CHK 53 +#define SRST_TRNG_S 54 + +#endif diff --git a/include/dt-bindings/power/rk3588-power.h b/include/dt-bindings/power/rk3588-power.h new file mode 100644 index 0000000000..69f7e90602 --- /dev/null +++ b/include/dt-bindings/power/rk3588-power.h @@ -0,0 +1,69 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3588_POWER_H__ +#define __DT_BINDINGS_POWER_RK3588_POWER_H__ + +/* VD_LITDSU */ +#define RK3588_PD_CPU_0 0 +#define RK3588_PD_CPU_1 1 +#define RK3588_PD_CPU_2 2 +#define RK3588_PD_CPU_3 3 + +/* VD_BIGCORE0 */ +#define RK3588_PD_CPU_4 4 +#define RK3588_PD_CPU_5 5 + +/* VD_BIGCORE1 */ +#define RK3588_PD_CPU_6 6 +#define RK3588_PD_CPU_7 7 + +/* VD_NPU */ +#define RK3588_PD_NPU 8 +#define RK3588_PD_NPUTOP 9 +#define RK3588_PD_NPU1 10 +#define RK3588_PD_NPU2 11 + +/* VD_GPU */ +#define RK3588_PD_GPU 12 + +/* VD_VCODEC */ +#define RK3588_PD_VCODEC 13 +#define RK3588_PD_RKVDEC0 14 +#define RK3588_PD_RKVDEC1 15 +#define RK3588_PD_VENC0 16 +#define RK3588_PD_VENC1 17 + +/* VD_DD01 */ +#define RK3588_PD_DDR01 18 + +/* VD_DD23 */ +#define RK3588_PD_DDR23 19 + +/* VD_LOGIC */ +#define RK3588_PD_CENTER 20 +#define RK3588_PD_VDPU 21 +#define RK3588_PD_RGA30 22 +#define RK3588_PD_AV1 23 +#define RK3588_PD_VOP 24 +#define RK3588_PD_VO0 25 +#define RK3588_PD_VO1 26 +#define RK3588_PD_VI 27 +#define RK3588_PD_ISP1 28 +#define RK3588_PD_FEC 29 +#define RK3588_PD_RGA31 30 +#define RK3588_PD_USB 31 +#define RK3588_PD_PHP 32 +#define RK3588_PD_GMAC 33 +#define RK3588_PD_PCIE 34 +#define RK3588_PD_NVM 35 +#define RK3588_PD_NVM0 36 +#define RK3588_PD_SDIO 37 +#define RK3588_PD_AUDIO 38 +#define RK3588_PD_SECURE 39 +#define RK3588_PD_SDMMC 40 +#define RK3588_PD_CRYPTO 41 +#define RK3588_PD_BUS 42 + +/* VD_PMU */ +#define RK3588_PD_PMU1 43 + +#endif
fatorangecat@189.cn
