[PATCH] drivers: core: lists: fix for loop index type
From: Alexander Preißner fpga-garage@preissner-muc.de
* fixes the bug in function bind_drivers_pass that for CONFIG_CC_OPTIMIZE_FOR_SIZE=n and no entries in the driver_info list, i.e. n_ents == 0, the processor steps into the first loop iteration despite the loop condition being false. * the Xilinx Zynq-7000 device would eventually hang due to an attempted access to an invalid memory address * the bug is fixed by changing the type of idx from uint to int
Board: zynq-zybo Target: ARM Compiler: arm-none-eabi-gcc 9.2.1
Signed-off-by: Alexander Preissner fpga-garage@preissner-muc.de --- drivers/core/lists.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index 5d4f2ea0e3..d2e9dc5719 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -58,7 +58,7 @@ static int bind_drivers_pass(struct udevice *parent, bool pre_reloc_only) const int n_ents = ll_entry_count(struct driver_info, driver_info); bool missing_parent = false; int result = 0; - uint idx; + int idx;
/* * Do one iteration through the driver_info records. For of-platdata,
- fixes the bug in function bind_drivers_pass that for
- the Xilinx Zynq-7000 device would eventually hang due to an attempted
- the bug is fixed by changing the type of idx from uint to int
uint idx;
int idx; /* * Do one iteration through the driver_info records. For of-platdata,
-- 2.25.1
Acked-by: Simon Glass sjg@chromium.org Tested on sandbox: Tested-by: Simon Glass sjg@chromium.org
Applied to u-boot-dm/next, thanks!
