[PATCH] rpi: Copy properties from firmware dtb to the loaded dtb
The RPI firmware adjusts several property values in the dtb it passes to u-boot depending on the board/SoC revision. Inherit some of these when u-boot loads a dtb itself. Specificaly copy:
* /model: The firmware provides a more specific string * /memreserve: The firmware defines a reserved range, better keep it * emmc2bus and pcie0 dma-ranges: The C0T revision of the bcm2711 Soc (as present on rpi 400 and some rpi 4B boards) has different values for these then the B0T revision. So these need to be adjusted to boot on these boards * blconfig: The firmware defines the memory area where the blconfig stored. Copy those over so it can be enabled. * /chosen/kaslr-seed: The firmware generates a kaslr seed, take advantage of that.
Signed-off-by: Sjoerd Simons sjoerd@collabora.com ---
board/raspberrypi/rpi/rpi.c | 47 +++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index df52a4689f..d9467f4bda 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -495,8 +495,55 @@ void *board_fdt_blob_setup(void) return (void *)fw_dtb_pointer; }
+int copy_property(void *dst, void *src, char *path, char *property) +{ + int dst_offset, src_offset; + const fdt32_t *prop; + int len; + + src_offset = fdt_path_offset(src, path); + dst_offset = fdt_path_offset(dst, path); + + if (src_offset < 0 || dst_offset < 0) + return -1; + + prop = fdt_getprop(src, src_offset, property, &len); + if (!prop) + return -1; + + return fdt_setprop(dst, dst_offset, property, prop, len); +} + +/* Copy tweaks from the firmware dtb to the loaded dtb */ +void update_fdt_from_fw(void *fdt, void *fw_fdt) +{ + /* Using dtb from firmware directly; leave it alone */ + if (fdt == fw_fdt) + return; + + /* The firmware provides a more precie model; so copy that */ + copy_property(fdt, fw_fdt, "/", "model"); + + /* memory reserve as suggested by the firmware */ + copy_property(fdt, fw_fdt, "/", "memreserve"); + + /* Adjust dma-ranges for the SD card and PCI bus as they can depend on + * the SoC revision + */ + copy_property(fdt, fw_fdt, "emmc2bus", "dma-ranges"); + copy_property(fdt, fw_fdt, "pcie0", "dma-ranges"); + + /* Bootloader configuration template exposes as nvmem */ + if (copy_property(fdt, fw_fdt, "blconfig", "reg") == 0) + copy_property(fdt, fw_fdt, "blconfig", "status"); + + /* kernel address randomisation seed as provided by the firmware */ + copy_property(fdt, fw_fdt, "/chosen", "kaslr-seed"); +} + int ft_board_setup(void *blob, struct bd_info *bd) { + update_fdt_from_fw(blob, (void *)fw_dtb_pointer); /* * For now, we simply always add the simplefb DT node. Later, we * should be more intelligent, and e.g. only do this if no enabled DT
Hi Sjoerd,
Overall this looks great.
- /model: The firmware provides a more specific string
- /memreserve: The firmware defines a reserved range, better keep it
- emmc2bus and pcie0 dma-ranges: The C0T revision of the bcm2711 Soc (as present on rpi 400 and some rpi 4B boards) has different values for these then the B0T revision. So these need to be adjusted to boot on these boards
- blconfig: The firmware defines the memory area where the blconfig stored. Copy those over so it can be enabled.
- /chosen/kaslr-seed: The firmware generates a kaslr seed, take advantage of that.
There's also a random seed provided by the RNG_IPROC200 in U-Boot itself, maybe if this seed provides for all generations of the rpi it might be a better option, also usedul if this would update the seed in U-Boot for things like the UEFI seed.
It would also likely be useful to deal with a few other pieces that the RPi firmware provides like CMA and whether or not the serial UART is enabled for console so it can be adjusted in U-Boot whether it takes control of the uart. There's been a few reports over time where U-Boot clobbers the serial port when people are trying to use it for other things.
I'll give this a test in the next few days.
Peter
int len;
return -1;
if (!prop)
return -1;
if (fdt == fw_fdt)
return;
* the SoC revision
-- 2.33.0
Peter Robinson
Sjoerd Simons
