[PATCH] mtd: spinand: Add support for XTX SPI NAND
Add support for XTX XT26G0xA and XT26xxxD,the driver is ported from linux-6.7.1. --- drivers/mtd/nand/spi/Makefile | 2 +- drivers/mtd/nand/spi/core.c | 1 + drivers/mtd/nand/spi/xtx.c | 265 ++++++++++++++++++++++++++++++++++ include/linux/mtd/spinand.h | 1 + 4 files changed, 268 insertions(+), 1 deletion(-) create mode 100755 drivers/mtd/nand/spi/xtx.c
diff --git a/drivers/mtd/nand/spi/Makefile b/drivers/mtd/nand/spi/Makefile index f172f4787f..65b836b34c 100644 --- a/drivers/mtd/nand/spi/Makefile +++ b/drivers/mtd/nand/spi/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0
spinand-objs := core.o esmt.o gigadevice.o macronix.o micron.o paragon.o -spinand-objs += toshiba.o winbond.o +spinand-objs += toshiba.o winbond.o xtx.o obj-$(CONFIG_MTD_SPI_NAND) += spinand.o diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 8ca33459f9..62c28aa422 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -829,6 +829,7 @@ static const struct spinand_manufacturer *spinand_manufacturers[] = { &toshiba_spinand_manufacturer, &winbond_spinand_manufacturer, &esmt_c8_spinand_manufacturer, + &xtx_spinand_manufacturer, };
static int spinand_manufacturer_match(struct spinand_device *spinand, diff --git a/drivers/mtd/nand/spi/xtx.c b/drivers/mtd/nand/spi/xtx.c new file mode 100755 index 0000000000..dde0564c56 --- /dev/null +++ b/drivers/mtd/nand/spi/xtx.c @@ -0,0 +1,265 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Author: + * Felix Matouschekfelix@matouschek.org + */ + +#include <linux/bitfield.h> +#ifndef __UBOOT__ +#include <linux/device.h> +#include <linux/kernel.h> +#endif +#include <linux/mtd/spinand.h> + +#define SPINAND_MFR_XTX 0x0B + +#define XT26G0XA_STATUS_ECC_MASK GENMASK(5, 2) +#define XT26G0XA_STATUS_ECC_NO_DETECTED (0 << 2) +#define XT26G0XA_STATUS_ECC_8_CORRECTED (3 << 4) +#define XT26G0XA_STATUS_ECC_UNCOR_ERROR (2 << 4) + +#define XT26XXXD_STATUS_ECC3_ECC2_MASK GENMASK(7, 6) +#define XT26XXXD_STATUS_ECC_NO_DETECTED (0) +#define XT26XXXD_STATUS_ECC_1_7_CORRECTED (1) +#define XT26XXXD_STATUS_ECC_8_CORRECTED (3) +#define XT26XXXD_STATUS_ECC_UNCOR_ERROR (2) + +static SPINAND_OP_VARIANTS(read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_QUADIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_DUALIO_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(write_cache_variants, + SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), + SPINAND_PROG_LOAD(true, 0, NULL, 0)); + +static SPINAND_OP_VARIANTS(update_cache_variants, + SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), + SPINAND_PROG_LOAD(false, 0, NULL, 0)); + +static int xt26g0xa_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + region->offset = 48; + region->length = 16; + + return 0; +} + +static int xt26g0xa_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + region->offset = 1; + region->length = 47; + + return 0; +} + +static const struct mtd_ooblayout_ops xt26g0xa_ooblayout = { + .ecc = xt26g0xa_ooblayout_ecc, + .rfree = xt26g0xa_ooblayout_free, +}; + +static int xt26g0xa_ecc_get_status(struct spinand_device *spinand, + u8 status) +{ + status = status & XT26G0XA_STATUS_ECC_MASK; + + switch (status) { + case XT26G0XA_STATUS_ECC_NO_DETECTED: + return 0; + case XT26G0XA_STATUS_ECC_8_CORRECTED: + return 8; + case XT26G0XA_STATUS_ECC_UNCOR_ERROR: + return -EBADMSG; + default: + break; + } + + /* At this point values greater than (2 << 4) are invalid */ + if (status > XT26G0XA_STATUS_ECC_UNCOR_ERROR) + return -EINVAL; + + /* (1 << 2) through (7 << 2) are 1-7 corrected errors */ + return status >> 2; +} + +static int xt26xxxd_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + region->offset = mtd->oobsize / 2; + region->length = mtd->oobsize / 2; + + return 0; +} + +static int xt26xxxd_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + if (section) + return -ERANGE; + + region->offset = 2; + region->length = mtd->oobsize / 2 - 2; + + return 0; +} + +static const struct mtd_ooblayout_ops xt26xxxd_ooblayout = { + .ecc = xt26xxxd_ooblayout_ecc, + .rfree = xt26xxxd_ooblayout_free, +}; + +static int xt26xxxd_ecc_get_status(struct spinand_device *spinand, + u8 status) +{ + switch (FIELD_GET(STATUS_ECC_MASK, status)) { + case XT26XXXD_STATUS_ECC_NO_DETECTED: + return 0; + case XT26XXXD_STATUS_ECC_UNCOR_ERROR: + return -EBADMSG; + case XT26XXXD_STATUS_ECC_1_7_CORRECTED: + return 4 + FIELD_GET(XT26XXXD_STATUS_ECC3_ECC2_MASK, status); + case XT26XXXD_STATUS_ECC_8_CORRECTED: + return 8; + default: + break; + } + + return -EINVAL; +} +static const struct spinand_info xtx_spinand_table[] = { + SPINAND_INFO("XT26G01A", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xE1), + NAND_MEMORG(1, 2048, 64, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&xt26g0xa_ooblayout, + xt26g0xa_ecc_get_status)), + SPINAND_INFO("XT26G02A", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xE2), + NAND_MEMORG(1, 2048, 64, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&xt26g0xa_ooblayout, + xt26g0xa_ecc_get_status)), + SPINAND_INFO("XT26G04A", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xE3), + NAND_MEMORG(1, 2048, 64, 128, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + SPINAND_HAS_QE_BIT, + SPINAND_ECCINFO(&xt26g0xa_ooblayout, + xt26g0xa_ecc_get_status)), + SPINAND_INFO("XT26G01D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x31), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26G11D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x34), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26Q01D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x51), + NAND_MEMORG(1, 2048, 128, 64, 1024, 20, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26G02D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x32), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26G12D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x35), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26Q02D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x52), + NAND_MEMORG(1, 2048, 128, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26G04D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x33), + NAND_MEMORG(1, 4096, 256, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), + SPINAND_INFO("XT26Q04D", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x53), + NAND_MEMORG(1, 4096, 256, 64, 2048, 40, 1, 1, 1), + NAND_ECCREQ(8, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&xt26xxxd_ooblayout, + xt26xxxd_ecc_get_status)), +}; + +static const struct spinand_manufacturer_ops xtx_spinand_manuf_ops = { +}; + +const struct spinand_manufacturer xtx_spinand_manufacturer = { + .id = SPINAND_MFR_XTX, + .name = "XTX", + .chips = xtx_spinand_table, + .nchips = ARRAY_SIZE(xtx_spinand_table), + .ops = &xtx_spinand_manuf_ops, +}; diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 6f479fa5ad..13b5a52f8b 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -251,6 +251,7 @@ extern const struct spinand_manufacturer paragon_spinand_manufacturer; extern const struct spinand_manufacturer toshiba_spinand_manufacturer; extern const struct spinand_manufacturer winbond_spinand_manufacturer; extern const struct spinand_manufacturer esmt_c8_spinand_manufacturer; +extern const struct spinand_manufacturer xtx_spinand_manufacturer;
/** * struct spinand_op_variants - SPI NAND operation variants -- 2.34.1
Hi Bruce,
This patch is missing your Signed-off-by tag. And it seems to be formatted incorrectly. At least I can't apply it to master or nand-next.
How do you create the patch? Can you please make sure to use 'git format-patch' and/or 'git send-email' properly?
And also please use scripts/checkpatch.pl on your patch before sending it.
Thanks Frieder
Bruce Sun
Frieder Schrempf
