[U-Boot] Please pull u-boot-mmc
Hi Tom,
CI build: https://travis-ci.org/MrVan/u-boot/builds/565839867 --------------------------------------------------------------------------------------------------- A new mmc/sd block test case Bug fixes for sdhci and mv_sdhci ---------------------------------------------------------------------------------------------------
Thanks, Peng.
The following changes since commit d0d07ba86afc8074d79e436b1ba4478fa0f0c1b5:
Prepare v2019.10-rc1 (2019-07-29 21:16:16 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-mmc.git tags/mmc-7-31
for you to fetch changes up to fea3939d31ccde5b8372bc5506a35ac169de03c8:
mmc: relocate code comment (2019-07-31 15:31:36 +0800)
---------------------------------------------------------------- Baruch Siach (3): mmc: mv_sdhci: fix uninitialized pointer deref on probe mmc: sdhci: fix chip detect gpio property name mmc: relocate code comment
Jean-Jacques Hiblot (1): test/py: add MMC/SD block write test
Weijie Gao (1): mmc: mtk-sd: add WATCHDOG_RESET() to prevent watchdog timeout
drivers/mmc/mmc.c | 2 +- drivers/mmc/mtk-sd.c | 3 +++ drivers/mmc/mv_sdhci.c | 6 +++--- drivers/mmc/sdhci.c | 2 +- test/py/tests/test_mmc_wr.py | 105 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 113 insertions(+), 5 deletions(-) create mode 100644 test/py/tests/test_mmc_wr.py
On Wed, Jul 31, 2019 at 12:16:56PM +0000, Peng Fan wrote:
Hi Tom,
Peng Fan
