[U-Boot] [PATCH] ls102xa: fdt: Disable IFC in SD boot for QSPI
As QSPI/DSPI and IFC are pin multiplexed, IFC is disabled in SD boot for QSPI. This patch will add fdt support for this rule.
Signed-off-by: Alison Wang alison.wang@freescale.com --- arch/arm/cpu/armv7/ls102xa/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index e01d911..856abed 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -171,7 +171,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_compat_u32(blob, "fsl, ls1021a-flexcan", "clock-frequency", busclk / 2, 1);
-#ifdef CONFIG_QSPI_BOOT +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) off = fdt_node_offset_by_compat_reg(blob, FSL_IFC_COMPAT, CONFIG_SYS_IFC_ADDR); fdt_set_node_status(blob, off, FDT_STATUS_DISABLED, 0);
Applied to u-boot-fsl-qoriq. Awaiting upstream. Thanks.
York
Alison Wang
York Sun
