[PATCH 1/2] board: rockchip: Add support for rk3588s based Cool Pi 4B
CoolPi 4B is a rk3588s based SBC.
Specification: - Rockchip RK3588S - LPDDR4 2/4/8/16 GB - TF scard slot - eMMC 8/32/64/128 GB module - SPI Nor 8MB - Gigabit ethernet drived by PCIE with RTL8111HS - HDMI Type D out - Mini DP out - USB 2.0 Host x 2 - USB 3.0 OTG x 1 - USB 3.0 Host x 1 - WIFI/BT module AIC8800 - 40 pin header
The dts is from linux-6.8 rc1.
Signed-off-by: Andy Yan andyshrk@163.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi | 30 + arch/arm/dts/rk3588s-coolpi-4b.dts | 813 +++++++++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 7 + configs/coolpi-4b-rk3588s_defconfig | 105 +++ 5 files changed, 956 insertions(+) create mode 100644 arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-coolpi-4b.dts create mode 100644 configs/coolpi-4b-rk3588s_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b5c588c3363..a3d0cad3471 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -189,6 +189,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \ rk3568-rock-3a.dtb
dtb-$(CONFIG_ROCKCHIP_RK3588) += \ + rk3588s-coolpi-4b.dts \ rk3588-edgeble-neu6a-io.dtb \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ diff --git a/arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi b/arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi new file mode 100644 index 00000000000..6b69ff424fa --- /dev/null +++ b/arch/arm/dts/rk3588s-coolpi-4b-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; +}; + +&fspim2_pins { + bootph-all; +}; + +&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + status = "okay"; + + flash@0 { + bootph-pre-ram; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; diff --git a/arch/arm/dts/rk3588s-coolpi-4b.dts b/arch/arm/dts/rk3588s-coolpi-4b.dts new file mode 100644 index 00000000000..a15c8e8fa6d --- /dev/null +++ b/arch/arm/dts/rk3588s-coolpi-4b.dts @@ -0,0 +1,813 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Rockchip Electronics Co., Ltd. + * + * https://cool-pi.com/topic/130/coolpi-4b-product-spec-introduction + * + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3588s.dtsi" + +/ { + model = "RK3588S CoolPi 4 Model B"; + compatible = "coolpi,pi-4b", "rockchip,rk3588s"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdio; + mmc2 = &sdmmc; + serial2 = &uart2; + }; + + analog-sound { + compatible = "audio-graph-card"; + dais = <&i2s0_8ch_p0>; + label = "rk3588-es8316"; + routing = "MIC2", "Mic Jack", + "Headphones", "HPOL", + "Headphones", "HPOR"; + widgets = "Microphone", "Mic Jack", + "Headphone", "Headphones"; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + leds: leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&gpio_leds>; + + led0: led-green { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio0 RK_PD0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + led1: led-red { + color = <LED_COLOR_ID_RED>; + default-state = "off"; + function = LED_FUNCTION_WLAN; + gpios = <&gpio0 RK_PC4 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "phy0tx"; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&hym8563>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + post-power-on-delay-ms = <200>; + reset-gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_LOW>; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usbdcin: vcc5v0-usbdcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usbdcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usbdcin>; + }; + + avdd0v85_pcie20: avdd0v85-pcie20-regulator { + compatible = "regulator-fixed"; + regulator-name = "avdd0v85_pcie20"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + vin-supply = <&vdd_0v85_s0>; + }; + + avdd1v8_pcie20: avdd1v8-pcie20-regulator { + compatible = "regulator-fixed"; + regulator-name = "avdd1v8_pcie20"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&avcc_1v8_s0>; + }; + + vcc3v3_mipi: vcc3v3-mipi-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_mipi"; + regulator-boot-on; + regulator-always-on; + vin-supply = <&vcc_3v3_s3>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_otg: vcc5v0-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_u3host_en>; + regulator-name = "vcc5v0_otg"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc_1v1_nldo_s3: vcc-1v1-nldo-s3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v1_nldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&i2c0 { + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + pinctrl-0 = <&i2c6m3_xfer>; + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + }; +}; + +&i2c7 { + pinctrl-0 = <&i2c7m0_xfer>; + status = "okay"; + + es8316: audio-codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; +}; + +&i2s0_8ch { + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&pcie2x1l2 { + pinctrl-names = "default"; + pinctrl-0 = <&rtl8111_isolate>; + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + led { + gpio_leds: gpio-leds { + rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_down>, + <0 RK_PD0 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + rtl8111 { + rtl8111_isolate: rtl8111-isolate { + rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>, + <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vcc5v0_u3host_en: vcc5v0-u3host-en { + rockchip,pins = <3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wireless-bluetooth { + bt_reset_gpio: bt-reset-pin { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_gpio: bt-wake-pin { + rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_host_irq: bt-wake-host-irq { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + wireless-wlan { + wifi_host_wake_irq: wifi-host-wake-irq { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + wifi_poweren_pin: wifi-poweren-pin { + rockchip,pins = <1 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm2 { + pinctrl-0 = <&pwm2m1_pins>; + status = "okay"; +}; + +&pwm13 { + pinctrl-names = "active"; + pinctrl-0 = <&pwm13m2_pins>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + no-sdio; + no-sd; + non-removable; + status = "okay"; +}; + +&sdio { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + disable-wp; + keep-power-in-suspend; + max-frequency = <150000000>; + mmc-pwrseq = <&sdio_pwrseq>; + no-sd; + no-mmc; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdiom1_pins>,<&wifi_poweren_pin>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + max-frequency = <150000000>; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&spi2 { + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + status = "okay"; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc5v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcc5v0_sys>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: vdd_gpu_mem_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: vdd_cpu_lit_mem_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-name = "vdd_log_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: vdd_vdenc_mem_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-name = "vcc_1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-name = "avcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: pldo-reg2 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avdd_1v2_s0: pldo-reg3 { + regulator-name = "avdd_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: pldo-reg4 { + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdd_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + avdd_0v75_s0: nldo-reg3 { + regulator-name = "avdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg4 { + regulator-name = "vdd_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy3_host { + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +/* bt */ +&uart9 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&uart9m2_xfer &uart9m2_ctsn>; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS index 2bd44bc5872..1604229759d 100644 --- a/board/rockchip/evb_rk3588/MAINTAINERS +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -1,3 +1,10 @@ +COOLPI-4B-RK3588S +M: Andy Yan andyshrk@163.com +S: Maintained +F: configs/coolpi-4b-rk3588s_defconfig +F: arch/arm/dts/rk3588s-coolpi-4b.dts +F: arch/arm/dts/rk3588s-coolpi-u-boot.dtsi + EVB-RK3588 M: Kever Yang kever.yang@rock-chips.com S: Maintained diff --git a/configs/coolpi-4b-rk3588s_defconfig b/configs/coolpi-4b-rk3588s_defconfig new file mode 100644 index 00000000000..3e3e5abc860 --- /dev/null +++ b/configs/coolpi-4b-rk3588s_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588s-coolpi-4b" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-coolpi-4b.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y
Cool Pi CM5 EVB works as a mother board connect with CM5.
CM5 Specification: - Rockchip RK3588 - LPDDR4 2/4/8/16 GB - TF scard slot - eMMC 8/32/64/128 GB module - SPI Nor 8MB - Gigabit ethernet x 1 with PHY YT8531 - Gigabit ethernet x 1 drived by PCIE with YT6801S
CM5 EVB Specification: - HDMI Type A out x 2 - HDMI Type D in x 1 - USB 2.0 Host x 2 - USB 3.0 OTG x 1 - USB 3.0 Host x 1 - PCIE M.2 E Key for Wireless connection - PCIE M.2 M Key for NVME connection - 40 pin header
.../arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi | 30 + arch/arm/dts/rk3588-coolpi-cm5-evb.dts | 214 ++++++ arch/arm/dts/rk3588-coolpi-cm5.dtsi | 650 ++++++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 8 + configs/coolpi-cm5-evb-rk3588_defconfig | 105 +++ 5 files changed, 1007 insertions(+) create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-evb.dts create mode 100644 arch/arm/dts/rk3588-coolpi-cm5.dtsi create mode 100644 configs/coolpi-cm5-evb-rk3588_defconfig
diff --git a/arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi b/arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi new file mode 100644 index 00000000000..6b69ff424fa --- /dev/null +++ b/arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; +}; + +&fspim2_pins { + bootph-all; +}; + +&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + status = "okay"; + + flash@0 { + bootph-pre-ram; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; diff --git a/arch/arm/dts/rk3588-coolpi-cm5-evb.dts b/arch/arm/dts/rk3588-coolpi-cm5-evb.dts new file mode 100644 index 00000000000..d4c70835e0f --- /dev/null +++ b/arch/arm/dts/rk3588-coolpi-cm5-evb.dts @@ -0,0 +1,214 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Rockchip Electronics Co., Ltd. + * + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include "rk3588-coolpi-cm5.dtsi" + +/ { + model = "RK3588 CoolPi CM5 EVB"; + compatible = "coolpi,pi-cm5-evb", "coolpi,pi-cm5", "rockchip,rk3588"; + + backlight: backlight { + compatible = "pwm-backlight"; + enable-gpios = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en>; + power-supply = <&vcc12v_dcin>; + pwms = <&pwm2 0 25000 0>; + }; + + leds: leds { + compatible = "gpio-leds"; + + green_led: led-0 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc3v3_lcd: vcc3v3-lcd-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_lcd"; + enable-active-high; + gpio = <&gpio1 RK_PC4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcdpwr_en>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc5v0_usb30_host: vcc5v0-usb30-host-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_host_pwren>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb30_otg: vcc5v0-usb30-otg-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_otg"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_otg_pwren>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +/* M.2 E-Key */ +&pcie2x1l1 { + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron &bt_pwron>; + status = "okay"; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x2 { + reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + status = "okay"; +}; + +/* M.2 M-Key ssd */ +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + status = "okay"; +}; + +&pinctrl { + lcd { + lcdpwr_en: lcdpwr-en { + rockchip,pins = <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bl_en: bl-en { + rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + usb_host_pwren: usb-host-pwren { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + usb_otg_pwren: usb-otg-pwren { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + bt_pwron: bt-pwron { + rockchip,pins = <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_clkreq: pcie-clkreq { + rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_rst: pcie-rst { + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + wifi_pwron: wifi-pwron { + rockchip,pins = <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_wake: pcie-wake { + rockchip,pins = <4 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm2 { + status = "okay"; +}; + +&sata1 { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_usb30_host>; + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb30_host>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-coolpi-cm5.dtsi b/arch/arm/dts/rk3588-coolpi-cm5.dtsi new file mode 100644 index 00000000000..0b02f4d6e00 --- /dev/null +++ b/arch/arm/dts/rk3588-coolpi-cm5.dtsi @@ -0,0 +1,650 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Rockchip Electronics Co., Ltd. + * + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3588.dtsi" + +/ { + compatible = "coolpi,pi-cm5", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdio; + mmc2 = &sdmmc; + serial2 = &uart2; + }; + + analog-sound { + compatible = "audio-graph-card"; + dais = <&i2s0_8ch_p0>; + label = "rk3588-es8316"; + routing = "MIC2", "Mic Jack", + "Headphones", "HPOL", + "Headphones", "HPOR"; + widgets = "Microphone", "Mic Jack", + "Headphone", "Headphones"; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + avdd0v85_pcie20: avdd0v85-pcie20-regulator { + compatible = "regulator-fixed"; + regulator-name = "avdd0v85_pcie20"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + vin-supply = <&vdd_0v85_s0>; + }; + + avdd1v8_pcie20: avdd1v8-pcie20-regulator { + compatible = "regulator-fixed"; + regulator-name = "avdd1v8_pcie20"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&avcc_1v8_s0>; + }; + + avdd0v75_pcie30: avdd0v75-pcie30-regulator { + compatible = "regulator-fixed"; + regulator-name = "avdd0v75_pcie30"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + vin-supply = <&avdd_0v75_s0>; + }; + + pcie30_avdd1v8: avdd1v8-pcie30-regulator { + compatible = "regulator-fixed"; + regulator-name = "pcie30_avdd1v8"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&avcc_1v8_s0>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy1_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac0 { + clock_in_out = "output"; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii-rxid"; + pinctrl-0 = <&gmac0_miim + &gmac0_tx_bus2 + &gmac0_rx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus>; + pinctrl-names = "default"; + rx_delay = <0x00>; + tx_delay = <0x43>; + status = "okay"; +}; + +&i2c0 { + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD4 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + wakeup-source; + }; +}; + +&i2c7 { + pinctrl-0 = <&i2c7m0_xfer>; + status = "okay"; + + es8316: audio-codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; +}; + +&i2s0_8ch { + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&mdio0 { + rgmii_phy: ethernet-phy@1 { + /* YT8531C/H */ + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x1>; + pinctrl-names = "default"; + pinctrl-0 = <&yt8531_rst>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; + }; +}; + +/* ethernet */ +&pcie2x1l2 { + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&yt6801_isolate>; + status = "okay"; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + yt6801 { + yt6801_isolate: yt6801-isolate { + rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + yt8531 { + yt8531_rst: yt8531-rst { + rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&vcc_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + no-sdio; + no-sd; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + max-frequency = <150000000>; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&spi2 { + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + status = "okay"; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc5v0_sys>; + vcc13-supply = <&vcc_2v0_pldo_s3>; + vcc14-supply = <&vcc_2v0_pldo_s3>; + vcca-supply = <&vcc5v0_sys>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: vdd_gpu_mem_s0: dcdc-reg1 { + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_gpu_s0"; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: vdd_cpu_lit_mem_s0: dcdc-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_cpu_lit_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_log_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: vdd_vdenc_mem_s0: dcdc-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_vdenc_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_ddr_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vdd2_ddr_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + regulator-name = "vdd_2v0_pldo_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_3v3_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vddq_ddr_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "avcc_1v8_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: pldo-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avdd_1v2_s0: pldo-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "avdd_1v2_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: pldo-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + regulator-name = "vcc_3v3_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + regulator-name = "vccio_sd_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "pldo6_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "vdd_0v75_s3"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-name = "vdd_ddr_pll_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + avdd_0v75_s0: nldo-reg3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "avdd_0v75_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-name = "vdd_0v85_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-name = "vdd_0v75_s0"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS index 1604229759d..8ab58e3ce9d 100644 --- a/board/rockchip/evb_rk3588/MAINTAINERS +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -5,6 +5,14 @@ F: configs/coolpi-4b-rk3588s_defconfig F: arch/arm/dts/rk3588s-coolpi-4b.dts F: arch/arm/dts/rk3588s-coolpi-u-boot.dtsi
+COOLPI-CM5-EVB-RK3588 +M: Andy Yan andyshrk@163.com +S: Maintained +F: configs/coolpi-cm5-evb-rk3588_defconfig +F: arch/arm/dts/rk3588-coolpi-cm5.dtsi +F: arch/arm/dts/rk3588-coolpi-cm5-evb.dts +F: arch/arm/dts/rk3588-coolpi-cm5-evb-u-boot.dtsi + EVB-RK3588 M: Kever Yang kever.yang@rock-chips.com S: Maintained diff --git a/configs/coolpi-cm5-evb-rk3588_defconfig b/configs/coolpi-cm5-evb-rk3588_defconfig new file mode 100644 index 00000000000..debd9b64f9c --- /dev/null +++ b/configs/coolpi-cm5-evb-rk3588_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-coolpi-cm5-evb" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-coolpi-cm5-evb.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y
CM5 Specification:
- Rockchip RK3588
- TF scard slot
- SPI Nor 8MB
- USB 2.0 Host x 2
- USB 3.0 OTG x 1
- USB 3.0 Host x 1
- 40 pin header
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- chosen {
+&fspim2_pins {
- bootph-all;
+&sfc {
- bootph-pre-ram;
- u-boot,spl-sfc-no-dma;
- pinctrl-names = "default";
- pinctrl-0 = <&fspim2_pins>;
- status = "okay";
- flash@0 {
bootph-pre-ram;
reg = <0>;
- Copyright (c) 2023 Rockchip Electronics Co., Ltd.
+/dts-v1/;
- model = "RK3588 CoolPi CM5 EVB";
- compatible = "coolpi,pi-cm5-evb", "coolpi,pi-cm5", "rockchip,rk3588";
- backlight: backlight {
- leds: leds {
green_led: led-0 {
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcc3v3_lcd: vcc3v3-lcd-regulator {
enable-active-high;
- vcc5v0_usb30_host: vcc5v0-usb30-host-regulator {
regulator-boot-on;
enable-active-high;
- vcc5v0_usb30_otg: vcc5v0-usb30-otg-regulator {
regulator-boot-on;
enable-active-high;
- reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_sys>;
- pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron &bt_pwron>;
- status = "okay";
+&pcie30phy {
- status = "okay";
+&pcie3x2 {
- reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_HIGH>;
- status = "okay";
- reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- lcd {
bl_en: bl-en {
- usb {
- wifi {
+&pwm2 {
- status = "okay";
+&sata1 {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_usb30_host>;
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+/dts-v1/;
- compatible = "coolpi,pi-cm5", "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdio;
mmc2 = &sdmmc;
serial2 = &uart2;
- analog-sound {
- chosen {
- avdd0v85_pcie20: avdd0v85-pcie20-regulator {
regulator-boot-on;
- avdd1v8_pcie20: avdd1v8-pcie20-regulator {
regulator-boot-on;
- avdd0v75_pcie30: avdd0v75-pcie30-regulator {
regulator-boot-on;
- pcie30_avdd1v8: avdd1v8-pcie30-regulator {
regulator-boot-on;
+&combphy0_ps {
- status = "okay";
+&combphy1_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_big0_s0>;
+&cpu_b1 {
+&cpu_b2 {
- cpu-supply = <&vdd_cpu_big1_s0>;
+&cpu_b3 {
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_lit_s0>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&gmac0 {
- clock_in_out = "output";
- phy-handle = <&rgmii_phy>;
- phy-mode = "rgmii-rxid";
- pinctrl-0 = <&gmac0_miim
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- rx_delay = <0x00>;
- tx_delay = <0x43>;
- status = "okay";
+&i2c0 {
- pinctrl-0 = <&i2c0m2_xfer>;
- status = "okay";
- vdd_cpu_big0_s0: regulator@42 {
reg = <0x42>;
regulator-boot-on;
- vdd_cpu_big1_s0: regulator@43 {
reg = <0x43>;
regulator-boot-on;
+&i2c2 {
- status = "okay";
- vdd_npu_s0: regulator@42 {
reg = <0x42>;
regulator-boot-on;
+&i2c6 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2c7 {
- pinctrl-0 = <&i2c7m0_xfer>;
- status = "okay";
- es8316: audio-codec@11 {
reg = <0x11>;
port {
+&i2s0_8ch {
- pinctrl-0 = <&i2s0_lrck
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
- i2s0_8ch_p0: port {
dai-format = "i2s";
mclk-fs = <256>;
+&mdio0 {
- rgmii_phy: ethernet-phy@1 {
/* YT8531C/H */
reg = <0x1>;
- reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>;
- pinctrl-0 = <&yt6801_isolate>;
- status = "okay";
+&pinctrl {
- hym8563 {
- yt6801 {
- yt8531 {
+&saradc {
- vref-supply = <&vcc_1v8_s0>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- max-frequency = <200000000>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- no-sdio;
- no-sd;
- non-removable;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- max-frequency = <150000000>;
- no-sdio;
- no-mmc;
- sd-uhs-sdr104;
- vqmmc-supply = <&vccio_sd_s0>;
- status = "okay";
+&spi2 {
- assigned-clocks = <&cru CLK_SPI2>;
- assigned-clock-rates = <200000000>;
- num-cs = <1>;
- pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
gpio-controller;
#gpio-cells = <2>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&uart2 {
- pinctrl-0 = <&uart2m0_xfer>;
- status = "okay";
- EVB-RK3588 M: Kever Yang kever.yang@rock-chips.com S: Maintained
Specification:
- Rockchip RK3588S
- TF scard slot
- SPI Nor 8MB
- HDMI Type D out
- Mini DP out
- USB 2.0 Host x 2
- USB 3.0 OTG x 1
- USB 3.0 Host x 1
- 40 pin header
Thanks, - Kever
- rk3588s-coolpi-4b.dts \ rk3588-edgeble-neu6a-io.dtb \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \
- chosen {
+&fspim2_pins {
- bootph-all;
+&sfc {
- bootph-pre-ram;
- status = "okay";
- flash@0 {
bootph-pre-ram;
reg = <0>;
+/dts-v1/;
- model = "RK3588S CoolPi 4 Model B";
- compatible = "coolpi,pi-4b", "rockchip,rk3588s";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdio;
mmc2 = &sdmmc;
serial2 = &uart2;
- analog-sound {
- chosen {
- leds: leds {
led0: led-green {
led1: led-red {
- sdio_pwrseq: sdio-pwrseq {
regulator-boot-on;
regulator-boot-on;
- vcc5v0_usbdcin: vcc5v0-usbdcin-regulator {
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vcc3v3_mipi: vcc3v3-mipi-regulator {
enable-active-high;
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
regulator-boot-on;
- vcc5v0_otg: vcc5v0-otg-regulator {
enable-active-high;
regulator-boot-on;
- vcc_1v1_nldo_s3: vcc-1v1-nldo-s3-regulator {
regulator-boot-on;
+&combphy0_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_l0 {
+&cpu_b0 {
+&cpu_b2 {
+&i2c0 {
- status = "okay";
reg = <0x42>;
regulator-boot-on;
reg = <0x43>;
regulator-boot-on;
+&i2c2 {
- status = "okay";
reg = <0x42>;
regulator-boot-on;
+&i2c6 {
- pinctrl-0 = <&i2c6m3_xfer>;
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
+&i2c7 {
- status = "okay";
reg = <0x11>;
port {
+&i2s0_8ch {
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
dai-format = "i2s";
mclk-fs = <256>;
+&pcie2x1l2 {
- pinctrl-0 = <&rtl8111_isolate>;
- status = "okay";
+&pinctrl {
- hym8563 {
- led {
- rtl8111 {
- sdio-pwrseq {
- usb {
- wireless-bluetooth {
- wireless-wlan {
+&pwm2 {
- pinctrl-0 = <&pwm2m1_pins>;
- status = "okay";
+&pwm13 {
- pinctrl-names = "active";
- pinctrl-0 = <&pwm13m2_pins>;
- status = "okay";
+&saradc {
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- no-sdio;
- no-sd;
- non-removable;
- status = "okay";
+&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- disable-wp;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- no-sd;
- no-mmc;
- non-removable;
- pinctrl-0 = <&sdiom1_pins>,<&wifi_poweren_pin>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- no-sdio;
- no-mmc;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3_s3>;
- status = "okay";
+&spi2 {
- num-cs = <1>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
gpio-controller;
#gpio-cells = <2>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_host>;
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&uart2 {
- status = "okay";
+/* bt */ +&uart9 {
- status = "okay";
- pinctrl-0 = <&uart9m2_xfer &uart9m2_ctsn>;
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
Andy Yan
Kever Yang
