[U-Boot] [PATCH V2 1/2] EXYNOS5: Make all display related code dependent on CONFIG_LCD
u-boot compilation fails for smdk5250 when we deselect CONFIG_LCD from the main config file.
Following error was observed: drivers/video/libvideo.o: In function `exynos_lcd_init': /home/ajay/u-boot-samsung/drivers/video/exynos_fb.c:68: undefined reference to `lcd_set_flush_dcache'
This is because exynos video drivers have dependency on CONFIG_LCD.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: Add compilation error message to commit log.
board/samsung/smdk5250/smdk5250.c | 2 ++ include/configs/exynos5250-dt.h | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index 9c4bf9b..7a5f132 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -281,6 +281,7 @@ int board_early_init_f(void) } #endif
+#ifdef CONFIG_LCD void cfg_lcd_gpio(void) { struct exynos5_gpio_part1 *gpio1 = @@ -374,3 +375,4 @@ void init_panel_info(vidinfo_t *vid)
exynos_set_dp_platform_data(&dp_platform_data); } +#endif diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 07bca1d..298bae9 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -299,10 +299,12 @@
/* Display */ #define CONFIG_LCD +#ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP #define LCD_XRES 2560 #define LCD_YRES 1600 #define LCD_BPP LCD_COLOR16 +#endif
#endif /* __CONFIG_H */
We enable console multiplexing and use both serial and LCD for stdout/stderr. Initially, u-boot output console is observed via serial port. If you also have a DP panel connected onto your SMDK5250 board, you can switch to LCD console by typing "setenv stdout lcd". You can always switch back to serial using "setenv stdout serial". You can switch error console(stderr) as well, using similar commands.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: We use CONFIG_CONSOLE_MUX always. In V1, CONFIG_CONSOLE_MUX was enabled only when CONFIG_LCD is selected.
include/configs/exynos5250-dt.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 298bae9..6912936 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -77,6 +77,17 @@ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000
+/* Console configuration */ +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial,lcd\0" \ + "stderr=serial,lcd\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXYNOS_DEVICE_SETTINGS + #define TZPC_BASE_OFFSET 0x10000
/* SD/MMC configuration */
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Ajay Kumar
Minkyu Kang
