[U-Boot] [PATCH] mmc: omap_hsmmc: Make DM_GPIO calls dependent on DM_GPIO
The getcd and getwp functions when DM_MMC is enabled are assumming the DM_GPIO is enabled. In cases (like SPL) where DM_GPIO may not be enabled, wrap these calls in an #ifdef
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index caaa914604..4d171f457e 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -1365,9 +1365,10 @@ static int omap_hsmmc_set_ios(struct udevice *dev) static int omap_hsmmc_getcd(struct udevice *dev) { struct omap_hsmmc_data *priv = dev_get_priv(dev); - int value; - + int value = -1; +#if CONFIG_IS_ENABLED(DM_GPIO) value = dm_gpio_get_value(&priv->cd_gpio); +#endif /* if no CD return as 1 */ if (value < 0) return 1; @@ -1379,10 +1380,11 @@ static int omap_hsmmc_getcd(struct udevice *dev)
static int omap_hsmmc_getwp(struct udevice *dev) { + int value = 0; +#if CONFIG_IS_ENABLED(DM_GPIO) struct omap_hsmmc_data *priv = dev_get_priv(dev); - int value; - value = dm_gpio_get_value(&priv->wp_gpio); +#endif /* if no WP return as 0 */ if (value < 0) return 0; @@ -1901,9 +1903,11 @@ static int omap_hsmmc_probe(struct udevice *dev) device_get_supply_regulator(dev, "pbias-supply", &priv->pbias_supply); #endif -#if defined(OMAP_HSMMC_USE_GPIO) && CONFIG_IS_ENABLED(OF_CONTROL) +#if defined(OMAP_HSMMC_USE_GPIO) +#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(DM_GPIO) gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); +#endif #endif
mmc->dev = dev;
Adam Ford
