[U-Boot] [Patch V3] i2c: mxc: add a condition in case the parameter is NULL
This could avoid executing the code that only applies to i.MX platforms.
The bus_i2c_init() is called before relocation and will assgin value to a static variable. If U-Boot is then still running in a flash device, it's theoretically not allowed to write data to flash without an erasing operation. For i.MX platforms, the U-Boot is always running in DDR.
Actually it causes asynchronous error when the ARM64 system error report is enabled and the flash write protect is set.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V3: - Sorry..Remove an unrelated line in other file.
drivers/i2c/mxc_i2c.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index fa4c82f..b2d15c9 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -581,8 +581,16 @@ void bus_i2c_init(int index, int speed, int unused, return; }
- mxc_i2c_buses[index].idle_bus_fn = idle_bus_fn; - mxc_i2c_buses[index].idle_bus_data = idle_bus_data; + /* + * Warning: Be careful to allow the assignment to a static + * variable here. This function could be called while U-Boot is + * still running in flash memory. So such assignment is equal + * to write data to flash without erasing. + */ + if (idle_bus_fn) + mxc_i2c_buses[index].idle_bus_fn = idle_bus_fn; + if (idle_bus_data) + mxc_i2c_buses[index].idle_bus_data = idle_bus_data;
ret = enable_i2c_clk(1, index); if (ret < 0) {
Hello Gong Qianyu,
added Stefano Babic to cc as he is the imx maintainer.
Am 18.12.2015 um 10:38 schrieb Gong Qianyu:
V3:
Ok, from my side, but it would be better to switch your board(s) to support DM and get rid of this old stuff from this driver.
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
if (idle_bus_fn)
if (idle_bus_data)
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Friday, December 18, 2015 6:24 PM To: Gong Qianyu-B52263 Cc: u-boot@lists.denx.de; Stefano Babic Subject: Re: [U-Boot] [Patch V3] i2c: mxc: add a condition in case the parameter is NULL
Hello Gong Qianyu,
V3:
bye, Heiko
Thanks. But I have no control over this driver. Maybe they are considering to convert it later.
Regards, Qianyu
if (idle_bus_fn)
if (idle_bus_data)
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hi Stefano,
Could you please help to merge this patch? Thanks very much.
Regards, Qianyu
-----Original Message----- From: Qianyu Gong Sent: Monday, December 21, 2015 1:42 PM To: hs@denx.de; Gong Qianyu-B52263 Qianyu.Gong@freescale.com Cc: u-boot@lists.denx.de; Stefano Babic sbabic@denx.de Subject: RE: [U-Boot] [Patch V3] i2c: mxc: add a condition in case the parameter is NULL
Hello Gong Qianyu,
V3:
bye, Heiko
Regards, Qianyu
if (idle_bus_fn)
if (idle_bus_data)
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Gong Qianyu
Heiko Schocher
Qianyu Gong
Stefano Babic
