[U-Boot] Bug in saveenv handling?
I just made this unpleasant observation while playing with u-boot:
On the u-boot CLI I changed an envvar and saved the env: setenv bootdelay 5 ; saveenv
Then I issued, just for fun, the command "scsi scan", but it crashed and rebooted the device. But this time on the display only the tuxx logo and the very first u-boot line is displayed, nothing else happens.
It seems u-boot has overwritten parts of itself on the storage medium (uSD with FAT boot partition).
I had this experience some more times in the past; after writing u-boot anew to the uSD it continued working again. Btw, I once even had the case where saveenv overwrote boot.cmd (but nothing else) with garbage (IIRC it was filled full with the char @ ).
I mention this just because it seems that there's maybe a bug in u-boot's saveenv handling (maybe data was not completely flushed, file handle was not closed, or maybe the fat write routine is buggy?...).
=> setenv bootdelay 5 ; saveenv Saving Environment to FAT... OK => printenv bootdelay bootdelay=5
=> scsi scan scanning bus for devices... data abort pc : [<7ef94f8e>] lr : [<7ef911a1>] reloc pc : [<4a01af8e>] lr : [<4a0171a1>] sp : 7af51bf8 ip : 0000001c fp : 000000c0 r10: 00000000 r9 : 7af59ed8 r8 : 00000000 r7 : 7af51e78 r6 : 7efd3f54 r5 : 7efdb9b8 r4 : 7efdb9b8 r3 : 00000000 r2 : 00000000 r1 : ea000016 r0 : 7efdb9b8 Flags: nZcv IRQs off FIQs off Mode SVC_32 Code: e92dbd10 f8d045f0 b0858080 1000f8d8 (f8d14604) Resetting CPU ...
resetting ...
this looks for me like the CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE is overlapping uboots code
can you post these values and position of uboot and its size for your device?
which env-storage do you use (EMV_IN_MMC or ENV_FAT)?
regards Frank
Gesendet: Dienstag, 09. April 2019 um 21:05 Uhr Von: "U.Mutlu" for-gmane@mutluit.com
Frank Wunderlich wrote on 04/09/2019 09:39 PM:
I looked up in the .config file:
# U-Boot 2019.04-rc4 Configuration
$ grep CONFIG_ENV_OFFSET .config CONFIG_ENV_OFFSET=0x88000
$ grep CONFIG_ENV_SIZE .config CONFIG_ENV_SIZE=0x20000
$ grep EMV_IN_MMC .config
$ grep ENV_FAT .config CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:auto" CONFIG_ENV_FAT_FILE="uboot.env"
I guess the uboot.env is a hidden file, but occassionally (esp. after saveenv & reboot) I see this file as a normal file in /, not hidden.
I used "Lamobo_R1_defconfig" as basis and made just a few irrelevant minor changes in make menuconfig. It's actually a Banana Pi R1 board. CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1"
Thx
U.Mutlu wrote on 04/09/2019 10:53 PM:
Maybe EMV_ is a typo and should rather be ENV_ ? $ grep -i EMV_ .config
$ grep -i ENV_ .config CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x88000 CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set # CONFIG_SPL_ENV_SUPPORT is not set CONFIG_CMD_ENV_EXISTS=y # CONFIG_CMD_ENV_CALLBACK is not set # CONFIG_CMD_ENV_FLAGS is not set # CONFIG_ENV_IS_IN_EEPROM is not set CONFIG_ENV_IS_IN_FAT=y # CONFIG_ENV_IS_IN_EXT4 is not set # CONFIG_ENV_IS_IN_FLASH is not set # CONFIG_ENV_IS_IN_MMC is not set # CONFIG_ENV_IS_IN_NAND is not set # CONFIG_ENV_IS_IN_NVRAM is not set # CONFIG_ENV_IS_IN_ONENAND is not set # CONFIG_ENV_IS_IN_REMOTE is not set # CONFIG_ENV_IS_IN_SPI_FLASH is not set # CONFIG_ENV_IS_IN_UBI is not set CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:auto" CONFIG_ENV_FAT_FILE="uboot.env" # CONFIG_USE_DEFAULT_ENV_FILE is not set # CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set
Thx
U.Mutlu wrote on 04/09/2019 11:01 PM:
$ ls -l u-boot-sunxi-with-spl.bin -rw-r--r-- 1 xy xy 479836 Apr 9 17:55 u-boot-sunxi-with-spl.bin
I used the following to write u-boot to the SD card (/dev/sdb):
# dd if=/dev/zero of=/dev/sdb bs=1k count=1023 seek=1 # dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8
If you need more data let me know pls.
Thx
please stay on list...i'm no expert in fat-environment, only have some experience on out-of-partition environment-storage (env on mmc). This seems not your case...
i don't know if env_offset is used on fat (makes no sense in my eyes) and env_is_on_mmc is disabled
where did your fat-partition start? if it starts after 1M offset uboot should not overwrite itself with saveenv.
following your dd starts at 8k-offset and have which size (typically <1M)? your erase before cleans first 1M (except first 1k where partitiontable is located). why do you think the target-file should be hidden? imho it is a normal file on mmc 0 and maybe first fat-partition (auto-flag) named "uboot.env". you found the file on /?? this should not be a fat-partition. linux imho needs a partiton with permission-options (extx,reiser,...). i guess you mean additional fat-partition, maybe mounted to /boot.
maybe you can add some debug-messages in saveenv for fat (env/fat.c env_fat_save, fs/fat/fat_write.c file_fat_write)
regards Frank
Gesendet: Dienstag, 09. April 2019 um 23:21 Uhr Von: "U.Mutlu" for-gmane@mutluit.com $ ls -l u-boot-sunxi-with-spl.bin -rw-r--r-- 1 xy xy 479836 Apr 9 17:55 u-boot-sunxi-with-spl.bin
Hi Frank,
as said, the error happened in the last -rc4 version, but does not happen in the current release version (2019.04).
/dev/mmcblk0p1 on the SD card is my boot partition (FAT16 LBA) and uses default settings. Hope the following info answers your questions. (yes, the SD card capacity is 16GB, but intentionally only the 1st 1.4GB or so is in use yet; this is to keep the .img size small).
Regarding the environment file (uboot.env): I can't say whether it should be a hidden file or not as I saw it only recently pop-up in the /, after I used saveenv.
root@xy:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 465.8G 0 disk └─sda1 8:1 0 457.8G 0 part / mmcblk0 179:0 0 14.5G 0 disk ├─mmcblk0p2 179:2 0 1.4G 0 part └─mmcblk0p1 179:1 0 32M 0 part /boot
root@xy:~# fdisk -l /dev/mmcblk0 Disk /dev/mmcblk0: 14.5 GiB, 15523119104 bytes, 30318592 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xdccc2266 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 * 2048 67583 65536 32M e W95 FAT16 (LBA) /dev/mmcblk0p2 67584 3071999 3004416 1.4G 83 Linux
root@xy:~# fdisk -l /dev/mmcblk0p1 Disk /dev/mmcblk0p1: 32 MiB, 33554432 bytes, 65536 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000
root@xy:~# minfo -i /dev/mmcblk0p1 :: device information: =================== filename="/dev/mmcblk0p1" sectors per track: 32 heads: 64 cylinders: 32 mformat command line: mformat -t 32 -i /dev/mmcblk0p1 -h 64 -s 32 -H 2048 :: bootsector information ====================== banner:"mkfs.fat" sector size: 512 bytes cluster size: 4 sectors reserved (boot) sectors: 1 fats: 2 max available root directory slots: 512 small size: 0 sectors media descriptor byte: 0xf8 sectors per fat: 64 sectors per track: 32 heads: 64 hidden sectors: 2048 big size: 65536 sectors physical drive id: 0x80 reserved=0x0 dos4=0x29 serial number: F7D2F904 disk label="NO NAME " disk type="FAT16 "
Frank Wunderlich wrote on 04/10/2019 10:00 AM:
regards Frank >
So, -rc4 has a bug that the final release does not, on this platform. Please try the v2019.04 release first and then if you see the problem still, continue reporting and also make sure to Cc Jagan, thanks!
Tom Rini wrote on 04/09/2019 11:09 PM:
# U-Boot 2019.04 Configuration
Yes, I too can confirm now that the problem of saveenv overwriting u-boot doesn't happen in the 2019.04 release version.
But the said crash when issuing the command "scsi scan" is still present, but this maybe has some other reasons.
Thx.
Frank Wunderlich
U.Mutlu
