[PATCH] ARC: HSDK: permit to build out-of-tree
When building with out of tree source, make fail with: uboot bin file not exists: /usr/src/uboot/u-boot.bin
This is due to obj files searched in srctree instead of objtree.
Fixes: 9ddcfef6d425 ("ARC: HSDK: Add tool and make target to generate bsp") Signed-off-by: Corentin Labbe clabbe@baylibre.com --- board/synopsys/hsdk/config.mk | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/synopsys/hsdk/config.mk b/board/synopsys/hsdk/config.mk index def944aad2..778a4283db 100644 --- a/board/synopsys/hsdk/config.mk +++ b/board/synopsys/hsdk/config.mk @@ -9,11 +9,11 @@ PLATFORM_CPPFLAGS += -mcpu=hs38_linux -mlittle-endian -matomic -mll64 \
bsp-generate: u-boot u-boot.bin $(Q)python3 $(srctree)/board/$(BOARDDIR)/headerize-hsdk.py \ - --arc-id 0x52 --image $(srctree)/u-boot.bin \ - --elf $(srctree)/u-boot + --arc-id 0x52 --image $(objtree)/u-boot.bin \ + --elf $(objtree)/u-boot $(Q)tools/mkimage -T script -C none -n 'uboot update script' \ - -d $(srctree)/u-boot-update.txt \ - $(srctree)/u-boot-update.scr &> /dev/null + -d $(objtree)/u-boot-update.txt \ + $(objtree)/u-boot-update.scr &> /dev/null endif
ifdef CONFIG_BOARD_HSDK_4XD @@ -23,9 +23,9 @@ PLATFORM_CPPFLAGS += -mcpu=hs4x_rel31 -mlittle-endian -matomic -mll64 \
bsp-generate: u-boot u-boot.bin $(Q)python3 $(srctree)/board/$(BOARDDIR)/headerize-hsdk.py \ - --arc-id 0x54 --image $(srctree)/u-boot.bin \ - --elf $(srctree)/u-boot + --arc-id 0x54 --image $(objtree)/u-boot.bin \ + --elf $(objtree)/u-boot $(Q)tools/mkimage -T script -C none -n 'uboot update script' \ - -d $(srctree)/u-boot-update.txt \ - $(srctree)/u-boot-update.scr &> /dev/null + -d $(objtree)/u-boot-update.txt \ + $(objtree)/u-boot-update.scr &> /dev/null endif
Corentin Labbe
