[U-Boot] [PATCH 1/1] mx51/mx53/mx6: add watchdog
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- arch/arm/cpu/armv7/imx-common/Makefile | 1 + arch/arm/cpu/armv7/imx-common/watchdog.c | 32 ++++++++++++++++++++++++++++++ 2 files changed, 33 insertions(+) create mode 100644 arch/arm/cpu/armv7/imx-common/watchdog.c
diff --git a/arch/arm/cpu/armv7/imx-common/Makefile b/arch/arm/cpu/armv7/imx-common/Makefile index 16fba8d..f3a8e22 100644 --- a/arch/arm/cpu/armv7/imx-common/Makefile +++ b/arch/arm/cpu/armv7/imx-common/Makefile @@ -30,6 +30,7 @@ LIB = $(obj)libimx-common.o COBJS-y = iomux-v3.o timer.o cpu.o speed.o COBJS-$(CONFIG_I2C_MXC) += i2c.o COBJS-$(CONFIG_CMD_BMODE) += cmd_bmode.o +COBJS-$(CONFIG_IMX_WATCHDOG) += watchdog.o COBJS := $(sort $(COBJS-y))
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/imx-common/watchdog.c b/arch/arm/cpu/armv7/imx-common/watchdog.c new file mode 100644 index 0000000..eadf3e8 --- /dev/null +++ b/arch/arm/cpu/armv7/imx-common/watchdog.c @@ -0,0 +1,32 @@ +/* + * watchdog.c - driver for i.mx on-chip watchdog + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <asm/io.h> +#include <watchdog.h> +#include <asm/arch/imx-regs.h> + +struct watchdog_regs { + u16 wcr; + u16 wsr; + u16 wrsr; + u16 wicr; + u16 wmcr; +}; + +void hw_watchdog_reset(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + writew(0x5555, &wdog->wsr); + writew(0xaaaa, &wdog->wsr); +} + +void hw_watchdog_init(void) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + writew(0xFF8F, &wdog->wcr); + hw_watchdog_reset(); +}
Hi Troy,
- watchdog.c - driver for i.mx on-chip watchdog
- Licensed under the GPL-2 or later.
- u16 wcr;
- u16 wsr;
- u16 wrsr;
- u16 wicr;
- u16 wmcr;
- struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR;
- writew(0x5555, &wdog->wsr);
- writew(0xaaaa, &wdog->wsr);
- writew(0xFF8F, &wdog->wcr);
we should use clrsetbit instead
Number of seconds is fix. Should be configurable ?
- hw_watchdog_reset();
I have understood that the watchdog is common on all i.MX. At the moment, quite the same implementation is in mainline for i.MX31, you can find it under arch/arm/cpu/arm1136/mx31/timer.c.
Then it is not a bad idea to have a watchdog driver in drivers/watchdog. Feel free to add a driver here and replacing the i.MX31 stuff.
Best regards, Stefano Babic
On 8/17/2012 3:00 AM, Stefano Babic wrote:
I have understood that the watchdog is common on all i.MX. At the moment, quite the same implementation is in mainline for i.MX31, you can find it under arch/arm/cpu/arm1136/mx31/timer.c. Then it is not a bad idea to have a watchdog driver in drivers/watchdog. Feel free to add a driver here and replacing the i.MX31 stuff. Best regards, Stefano Babic
Will do.
Thanks Troy
Stefano Babic
Troy Kisky
