[PATCH 0/1] Allow last block to be read
The last block could not be read by FreeBSD loader.efi (the gpt backup block)
Jesper Schmitz Mouridsen (1): Allow last block to be read
lib/efi_loader/efi_disk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
The last block is of size media->block_size --- lib/efi_loader/efi_disk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1f6b817dea..f77f465d20 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -148,7 +148,7 @@ static efi_status_t EFIAPI efi_disk_read_blocks(struct efi_block_io *this, (uintptr_t)buffer & (this->media->io_align - 1)) return EFI_INVALID_PARAMETER; if (lba * this->media->block_size + buffer_size > - this->media->last_block * this->media->block_size) + this->media->last_block * this->media->block_size + this->media->block_size) return EFI_INVALID_PARAMETER;
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER
From: Jesper Schmitz Mouridsen jesper@schmitz.computer
Signed-off-by: Jesper Schmitz Mouridsen jesper@schmitz.computer
Simplify expression. Apply same change to efi_disk_write_blocks().
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Add missing signed-off lign. Simplify expression. Apply same change to efi_disk_write_blocks(). --- lib/efi_loader/efi_disk.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1f6b817dea..307d5d759b 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -148,7 +148,7 @@ static efi_status_t EFIAPI efi_disk_read_blocks(struct efi_block_io *this, (uintptr_t)buffer & (this->media->io_align - 1)) return EFI_INVALID_PARAMETER; if (lba * this->media->block_size + buffer_size > - this->media->last_block * this->media->block_size) + (this->media->last_block + 1) * this->media->block_size) return EFI_INVALID_PARAMETER;
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER @@ -216,7 +216,7 @@ static efi_status_t EFIAPI efi_disk_write_blocks(struct efi_block_io *this, (uintptr_t)buffer & (this->media->io_align - 1)) return EFI_INVALID_PARAMETER; if (lba * this->media->block_size + buffer_size > - this->media->last_block * this->media->block_size) + (this->media->last_block + 1) * this->media->block_size) return EFI_INVALID_PARAMETER;
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER -- 2.30.0
