[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit bd23b22badadcdc414a900828253961fc5ec6c39:
Merge branch 'agust@denx.de-next' of git://git.denx.de/u-boot-staging (2012-10-15 13:37:22 -0700)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 01968b96a24414ff8f0735111907cbb750c7af43:
MX5: fix warning in clock.c (2012-10-26 16:11:32 +0200)
---------------------------------------------------------------- Benoît Thébaudeau (4): mx35: Clean up lowlevel_init mx35: Fix eSDHC clocks mxc: Fix SDHC multi-instance clock mx25: Clean up imx-regs.h
Dirk Behme (1): mx6qsabrelite: enable DCache and MMC bounce buffer
Eric Nelson (7): i.MX: iomux: input pad array can be const i.MX: declare iomux_v3_cfg_t arrays as const i.MX video: struct fb_videomode can be const i.MX: ipufb: add const to fb_videomode declarations i.MX6: set drive strength for parallel RGB pads i.MX6: add HDMI transmitter register declarations from kernel WIP. i.MX6: mx6qsabrelite: Add splash screen support
Fabio Estevam (11): mx6qsabreauto: Pass the board revision to the kernel mx5: lowlevel_init.S: Split init_clock macro mx5: lowlevel_init.S: Fix PLL settings for mx53 mx53loco: Adapt the IPU clock configs: mx53loco: Remove CONFIG_HAS_ETH1 configs: mx51evk: Remove CONFIG_HAS_ETH1 configs: mx53evk: Remove CONFIG_HAS_ETH1 mx5: Add workaround for ARM erratum ID 468414 mx25pdk: Use internal RAM for stack pointer mx6qsabre_common: Enable DCACHE and CONFIG_MMC_BOUNCE_BUFFER
Otavio Salvador (1): mx6qsabreauto: Change mmcroot so it works out of box
Stefano Babic (1): MX5: fix warning in clock.c
Troy Kisky (7): imximage: check dcd_len as entries added imximage: remove redundant setting of app_dest_ptr imximage: move flash_offset check to common location imximage: fix size of image to load. imximage: delay setting of image size imximage: change parameters to set_imx_hdr imximage: make set_imx_hdr_v1/v2 easier to read
arch/arm/cpu/arm1136/mx35/generic.c | 14 +- arch/arm/cpu/armv7/mx5/clock.c | 2 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 158 +++- arch/arm/imx-common/iomux-v3.c | 5 +- arch/arm/include/asm/arch-mx25/imx-regs.h | 6 +- arch/arm/include/asm/arch-mx35/clock.h | 4 +- arch/arm/include/asm/arch-mx35/lowlevel_macro.S | 191 ++-- arch/arm/include/asm/arch-mx5/imx-regs.h | 4 + arch/arm/include/asm/arch-mx6/imx-regs.h | 6 + arch/arm/include/asm/arch-mx6/mx6x_pins.h | 58 +- arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 1053 +++++++++++++++++++++++ arch/arm/include/asm/imx-common/iomux-v3.h | 3 +- board/CarMediaLab/flea3/lowlevel_init.S | 41 - board/esg/ima3-mx53/ima3-mx53.c | 1 + board/freescale/mx35pdk/lowlevel_init.S | 119 +-- board/freescale/mx35pdk/mx35pdk.c | 2 + board/freescale/mx35pdk/mx35pdk.h | 25 - board/freescale/mx51evk/mx51evk.c | 6 +- board/freescale/mx53ard/mx53ard.c | 4 + board/freescale/mx53evk/mx53evk.c | 4 + board/freescale/mx53loco/mx53loco.c | 5 +- board/freescale/mx53smd/mx53smd.c | 3 + board/freescale/mx6qarm2/mx6qarm2.c | 12 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 55 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 350 +++++++- board/freescale/mx6qsabresd/mx6qsabresd.c | 7 +- board/genesi/mx51_efikamx/efikamx.c | 20 +- board/ttcontrol/vision2/vision2.c | 4 +- drivers/mmc/fsl_esdhc.c | 5 +- drivers/video/mxc_ipuv3_fb.c | 8 +- include/configs/mx25pdk.h | 11 +- include/configs/mx51evk.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 3 +- include/configs/mx6qarm2.h | 3 +- include/configs/mx6qsabre_common.h | 5 +- include/configs/mx6qsabreauto.h | 3 +- include/configs/mx6qsabrelite.h | 18 +- include/configs/mx6qsabresd.h | 1 + include/fsl_esdhc.h | 1 + include/ipu_pixfmt.h | 4 +- tools/imximage.c | 102 +-- tools/imximage.h | 6 +- 43 files changed, 1853 insertions(+), 481 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mxc_hdmi.h
Hi Stefano,
On Fri, 26 Oct 2012 16:30:53 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
