[U-Boot] [PATCH] net: sh_eth: Remove SH_ETH_PHY_DELAY
SH_ETH_PHY_DELAY is not used.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 995e249..0871575 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -44,8 +44,6 @@ #define flush_cache_wback(...) #endif
-#define SH_ETH_PHY_DELAY 50000 - int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) { struct sh_eth_dev *eth = dev->priv;
EDMR_INIT_CNT holds the check count of initialization. Since there were more same values (1000), this collected as TIMEOUT_CNT.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 9 +++++---- 1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 0871575..1bc44a8 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -44,6 +44,8 @@ #define flush_cache_wback(...) #endif
+#define TIMEOUT_CNT 1000 + int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) { struct sh_eth_dev *eth = dev->priv; @@ -78,7 +80,7 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) outl(EDTRR_TRNS, EDTRR(port));
/* Wait until packet is transmitted */ - timeout = 1000; + timeout = TIMEOUT_CNT; while (port_info->tx_desc_cur->td0 & TD_TACT && timeout--) udelay(100);
@@ -134,7 +136,6 @@ int sh_eth_recv(struct eth_device *dev) return len; }
-#define EDMR_INIT_CNT 1000 static int sh_eth_reset(struct sh_eth_dev *eth) { int port = eth->port; @@ -146,13 +147,13 @@ static int sh_eth_reset(struct sh_eth_dev *eth)
/* Perform a software reset and wait for it to complete */ outl(EDMR_SRST, EDMR(port)); - for (i = 0; i < EDMR_INIT_CNT; i++) { + for (i = 0; i < TIMEOUT_CNT ; i++) { if (!(inl(EDMR(port)) & EDMR_SRST)) break; udelay(1000); }
- if (i == EDMR_INIT_CNT) { + if (i == TIMEOUT_CNT) { printf(SHETHER_NAME ": Software reset timeout\n"); ret = -EIO; }
--- drivers/net/sh_eth.c | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 1bc44a8..8d3dac2 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -94,7 +94,6 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) if (port_info->tx_desc_cur >= port_info->tx_desc_base + NUM_TX_DESC) port_info->tx_desc_cur = port_info->tx_desc_base;
- return ret; err: return ret; }
SH7734 has one channel ethernet device. This support 10/100/1000Base, and RMII/MII/GMII. And this has the same structure as SH7763.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 17 +++++----- drivers/net/sh_eth.h | 85 ++++++++++++++++++++++++++++++++++++++------------ 2 files changed, 74 insertions(+), 28 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 8d3dac2..c1abe7c 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -59,7 +59,7 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) }
/* packet must be a 4 byte boundary */ - if ((int)packet & (4 - 1)) { + if ((int)packet & 3) { printf(SHETHER_NAME ": %s: packet not 4 byte alligned\n", __func__); ret = -EFAULT; goto err; @@ -138,7 +138,7 @@ int sh_eth_recv(struct eth_device *dev) static int sh_eth_reset(struct sh_eth_dev *eth) { int port = eth->port; -#if defined(CONFIG_CPU_SH7763) +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) int ret = 0, i;
/* Start e-dmac transmitter and receiver */ @@ -208,7 +208,7 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) /* Point the controller to the tx descriptor list. Must use physical addresses */ outl(ADDR_TO_PHY(port_info->tx_desc_base), TDLAR(port)); -#if defined(CONFIG_CPU_SH7763) +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(ADDR_TO_PHY(port_info->tx_desc_base), TDFAR(port)); outl(ADDR_TO_PHY(cur_tx_desc), TDFXR(port)); outl(0x01, TDFFR(port));/* Last discriptor bit */ @@ -276,7 +276,7 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth)
/* Point the controller to the rx descriptor list */ outl(ADDR_TO_PHY(port_info->rx_desc_base), RDLAR(port)); -#if defined(CONFIG_CPU_SH7763) +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(ADDR_TO_PHY(port_info->rx_desc_base), RDFAR(port)); outl(ADDR_TO_PHY(cur_rx_desc), RDFXR(port)); outl(RDFFR_RDLF, RDFFR(port)); @@ -346,7 +346,8 @@ static int sh_eth_phy_config(struct sh_eth_dev *eth) struct eth_device *dev = port_info->dev; struct phy_device *phydev;
- phydev = phy_connect(miiphy_get_dev_by_name(dev->name), + phydev = phy_connect( + miiphy_get_dev_by_name(dev->name), port_info->phy_addr, dev, PHY_INTERFACE_MODE_MII); port_info->phydev = phydev; phy_config(phydev); @@ -398,7 +399,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl(APR_AP, APR(port)); outl(MPR_MP, MPR(port)); #endif -#if defined(CONFIG_CPU_SH7763) +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(TPAUSER_TPAUSE, TPAUSER(port)); #elif defined(CONFIG_CPU_SH7757) outl(TPAUSER_UNLIMITED, TPAUSER(port)); @@ -418,7 +419,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) /* Set the transfer speed */ if (phy->speed == 100) { printf(SHETHER_NAME ": 100Base/"); -#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(GECMR_100B, GECMR(port)); #elif defined(CONFIG_CPU_SH7757) outl(1, RTRATE(port)); @@ -427,7 +428,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) #endif } else if (phy->speed == 10) { printf(SHETHER_NAME ": 10Base/"); -#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(GECMR_10B, GECMR(port)); #elif defined(CONFIG_CPU_SH7757) outl(0, RTRATE(port)); diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 27fde05..1f646e2 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -188,13 +188,51 @@ struct sh_eth_dev { #define TPAUSER(port) (BASE_IO_ADDR + 0x0164) #define MAHR(port) (BASE_IO_ADDR + 0x01c0) #define MALR(port) (BASE_IO_ADDR + 0x01c8) + +#elif defined(CONFIG_CPU_SH7734) +#define BASE_IO_ADDR 0xFEE00000 + +#define EDSR(port) (BASE_IO_ADDR) + +#define TDLAR(port) (BASE_IO_ADDR + 0x0010) +#define TDFAR(port) (BASE_IO_ADDR + 0x0014) +#define TDFXR(port) (BASE_IO_ADDR + 0x0018) +#define TDFFR(port) (BASE_IO_ADDR + 0x001c) +#define RDLAR(port) (BASE_IO_ADDR + 0x0030) +#define RDFAR(port) (BASE_IO_ADDR + 0x0034) +#define RDFXR(port) (BASE_IO_ADDR + 0x0038) +#define RDFFR(port) (BASE_IO_ADDR + 0x003c) + +#define EDMR(port) (BASE_IO_ADDR + 0x0400) +#define EDTRR(port) (BASE_IO_ADDR + 0x0408) +#define EDRRR(port) (BASE_IO_ADDR + 0x0410) +#define EESR(port) (BASE_IO_ADDR + 0x0428) +#define EESIPR(port) (BASE_IO_ADDR + 0x0430) +#define TRSCER(port) (BASE_IO_ADDR + 0x0438) +#define TFTR(port) (BASE_IO_ADDR + 0x0448) +#define FDR(port) (BASE_IO_ADDR + 0x0450) +#define RMCR(port) (BASE_IO_ADDR + 0x0458) +#define RPADIR(port) (BASE_IO_ADDR + 0x0460) +#define FCFTR(port) (BASE_IO_ADDR + 0x0468) +#define ECMR(port) (BASE_IO_ADDR + 0x0500) +#define RFLR(port) (BASE_IO_ADDR + 0x0508) +#define ECSIPR(port) (BASE_IO_ADDR + 0x0518) +#define PIR(port) (BASE_IO_ADDR + 0x0520) +#define PIPR(port) (BASE_IO_ADDR + 0x052c) +#define APR(port) (BASE_IO_ADDR + 0x0554) +#define MPR(port) (BASE_IO_ADDR + 0x0558) +#define TPAUSER(port) (BASE_IO_ADDR + 0x0564) +#define GECMR(port) (BASE_IO_ADDR + 0x05b0) +#define MAHR(port) (BASE_IO_ADDR + 0x05C0) +#define MALR(port) (BASE_IO_ADDR + 0x05C8) + #endif
/* * Register's bits * Copy from Linux driver source code */ -#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined (CONFIG_CPU_SH7734) /* EDSR */ enum EDSR_BIT { EDSR_ENT = 0x01, EDSR_ENR = 0x02, @@ -205,11 +243,11 @@ enum EDSR_BIT { /* EDMR */ enum DMAC_M_BIT { EDMR_DL1 = 0x20, EDMR_DL0 = 0x10, -#ifdef CONFIG_CPU_SH7763 - EDMR_SRST = 0x03, +#if defined(CONFIG_CPU_SH7763) || defined (CONFIG_CPU_SH7734) + EDMR_SRST = 0x03, /* Receive/Send reset */ EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ -#elif defined(CONFIG_CPU_SH7757) ||defined (CONFIG_CPU_SH7724) +#elif defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7724) EDMR_SRST = 0x01, EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ @@ -223,7 +261,7 @@ enum DMAC_M_BIT {
/* EDTRR */ enum DMAC_T_BIT { -#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) EDTRR_TRNS = 0x03, #else EDTRR_TRNS = 0x01, @@ -262,7 +300,8 @@ enum PHY_STATUS_BIT { PHY_ST_LINK = 0x01, };
/* EESR */ enum EESR_BIT { -#ifndef CONFIG_CPU_SH7763 + +#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) EESR_TWB = 0x40000000, #else EESR_TWB = 0xC0000000, @@ -272,14 +311,14 @@ enum EESR_BIT { #endif EESR_TABT = 0x04000000, EESR_RABT = 0x02000000, EESR_RFRMER = 0x01000000, -#ifndef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) EESR_ADE = 0x00800000, #endif EESR_ECI = 0x00400000, EESR_FTC = 0x00200000, EESR_TDE = 0x00100000, EESR_TFE = 0x00080000, EESR_FRC = 0x00040000, EESR_RDE = 0x00020000, EESR_RFE = 0x00010000, -#ifndef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7724) && !defined(CONFIG_CPU_SH7757) EESR_CND = 0x00000800, #endif EESR_DLC = 0x00000400, @@ -291,7 +330,7 @@ enum EESR_BIT { };
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) # define TX_CHECK (EESR_TC1 | EESR_FTC) # define EESR_ERR_CHECK (EESR_TWB | EESR_TABT | EESR_RABT | EESR_RDE \ | EESR_RFRMER | EESR_TFE | EESR_TDE | EESR_ECI) @@ -352,7 +391,7 @@ enum FCFTR_BIT { /* Transfer descriptor bit */ enum TD_STS_BIT { #if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7757) \ - || defined(CONFIG_CPU_SH7724) + || defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7734) TD_TACT = 0x80000000, #else TD_TACT = 0x7fffffff, @@ -368,7 +407,7 @@ enum TD_STS_BIT { enum RECV_RST_BIT { RMCR_RST = 0x01, }; /* ECMR */ enum FELIC_MODE_BIT { -#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) ECMR_TRCCM=0x04000000, ECMR_RCSC= 0x00800000, ECMR_DPAD= 0x00200000, ECMR_RZPF = 0x00100000, #endif @@ -383,7 +422,7 @@ enum FELIC_MODE_BIT {
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) #define ECMR_CHG_DM (ECMR_TRCCM | ECMR_RZPF | ECMR_ZPF | ECMR_PFR | ECMR_RXF | \ ECMR_TXF | ECMR_MCT) #elif CONFIG_CPU_SH7757 @@ -396,14 +435,14 @@ enum FELIC_MODE_BIT {
/* ECSR */ enum ECSR_STATUS_BIT { -#ifndef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) ECSR_BRCRX = 0x20, ECSR_PSRTO = 0x10, #endif ECSR_LCHNG = 0x04, ECSR_MPD = 0x02, ECSR_ICD = 0x01, };
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) # define ECSR_INIT (ECSR_ICD | ECSIPR_MPDIP) #else # define ECSR_INIT (ECSR_BRCRX | ECSR_PSRTO | \ @@ -412,14 +451,20 @@ enum ECSR_STATUS_BIT {
/* ECSIPR */ enum ECSIPR_STATUS_MASK_BIT { -#ifndef CONFIG_CPU_SH7763 - ECSIPR_BRCRXIP = 0x20, ECSIPR_PSRTOIP = 0x10, -#endif +#if defined(CONFIG_CPU_SH7724) + ECSIPR_PSRTOIP = 0x10, + ECSIPR_LCHNGIP = 0x04, + ECSIPR_ICDIP = 0x01, +#elif defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) + ECSIPR_PSRTOIP = 0x10, + ECSIPR_PHYIP = 0x08, ECSIPR_LCHNGIP = 0x04, - ECSIPR_MPDIP = 0x02, ECSIPR_ICDIP = 0x01, + ECSIPR_MPDIP = 0x02, + ECSIPR_ICDIP = 0x01, +#endif };
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) # define ECSIPR_INIT (ECSIPR_LCHNGIP | ECSIPR_ICDIP | ECSIPR_MPDIP) #else # define ECSIPR_INIT (ECSIPR_BRCRXIP | ECSIPR_PSRTOIP | ECSIPR_LCHNGIP | \ @@ -458,7 +503,7 @@ enum RPADIR_BIT { RPADIR_PADR = 0x0003f, };
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) # define RPADIR_INIT (0x00) #else # define RPADIR_INIT (RPADIR_PADS1)
Hi, Joe.
I have not noticed that inaugurated as you at the maintainer of net. Could you apply this patch to your u-boot-net repository?
Best regards, Nobuhiro
2012/2/3 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:
- if ((int)packet & 3) {
- miiphy_get_dev_by_name(dev->name),
#endif
- EDMR_SRST = 0x03,
- EDMR_SRST = 0x03, /* Receive/Send reset */
- || defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7734)
- ECSIPR_PSRTOIP = 0x10,
- ECSIPR_LCHNGIP = 0x04,
- ECSIPR_ICDIP = 0x01,
- ECSIPR_PHYIP = 0x08,
+#endif };
-#ifdef CONFIG_CPU_SH7763 +#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) # define RPADIR_INIT (0x00) #else # define RPADIR_INIT (RPADIR_PADS1) -- 1.7.7.3
Ping. Please pickup 'net: sh-eth: Add support Gigabit of SH7734' too.
2012/5/9 Nobuhiro Iwamatsu iwamatsu@nigauri.org:
Hi, Joe.
#endif
- EDMR_SRST = 0x03,
+#endif };
-- Nobuhiro Iwamatsu iwamatsu at {nigauri.org / debian.org} GPG ID: 40AD1FA6
Hi Nobuhiro Iwamatsu,
On Fri, Feb 3, 2012 at 1:28 AM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
In the future, please run tools/checkpatch.pl on your patches before submitting. I fixed 2 failures for you.
Applied, thanks.
-Joe
Joe Hershberger さんは書きました:
Applied, thanks.
sorry and thanks!
Joe Hershberger
Nobuhiro Iwamatsu
Nobuhiro Iwamatsu
