[PATCH v3 1/2] doc: board: j721e_evm: Add DM firmware steps
J721e needs DM firmware when using updated SYSFW. Add steps to fetch, build, and deploy the same.
Signed-off-by: Andrew Davis afd@ti.com ---
Changes from v2: - s/DM/DM Firmware
Changes from v1: - None
doc/board/ti/j721e_evm.rst | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/doc/board/ti/j721e_evm.rst b/doc/board/ti/j721e_evm.rst index 44dc316afd..8608373365 100644 --- a/doc/board/ti/j721e_evm.rst +++ b/doc/board/ti/j721e_evm.rst @@ -142,7 +142,11 @@ Sources: Tree: https://github.com/OP-TEE/optee_os.git Branch: master
-4. U-Boot: +4. DM Firmware: + Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git + Branch: ti-linux-firmware + +5. U-Boot: Tree: https://source.denx.de/u-boot/u-boot Branch: master
@@ -152,7 +156,7 @@ Build procedure:
.. code-block:: text
- $ make CROSS_COMPILE=arm-linux-gnueabihf- + $ make CROSS_COMPILE=arm-linux-gnueabihf- SOC=j721e
2. ATF:
@@ -172,15 +176,15 @@ Build procedure:
- $ make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=/tmp/r5 - $ make CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5 + $ make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=build/r5 + $ make CROSS_COMPILE=arm-linux-gnueabihf- O=build/r5
* 4.2 A72:
- $ make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=/tmp/a72 - $ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<path to DM firmware image> O=/tmp/a72 + $ make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=build/a72 + $ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<ATF dir>/build/k3/generic/release/bl31.bin TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<DM firmware>/ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f O=build/a72
Target Images --------------
* BASH code should be labeled as such. * Code blocks should be indented by 4 spaces.
Fix these here.
Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Andrew Davis afd@ti.com ---
Changes from v2: - None
Changes from v1: - New patch with fixes suggested by Heinrich
doc/board/ti/j721e_evm.rst | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/doc/board/ti/j721e_evm.rst b/doc/board/ti/j721e_evm.rst index 8608373365..ad70f15b7a 100644 --- a/doc/board/ti/j721e_evm.rst +++ b/doc/board/ti/j721e_evm.rst @@ -154,37 +154,37 @@ Build procedure: ---------------- 1. SYSFW:
-.. code-block:: text +.. code-block:: bash
- $ make CROSS_COMPILE=arm-linux-gnueabihf- SOC=j721e + make CROSS_COMPILE=arm-linux-gnueabihf- SOC=j721e
2. ATF:
- $ make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed + make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed
3. OPTEE:
- $ make PLATFORM=k3-j721e CFG_ARM64_core=y + make PLATFORM=k3-j721e CFG_ARM64_core=y
4. U-Boot:
* 4.1 R5:
- $ make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=build/r5 - $ make CROSS_COMPILE=arm-linux-gnueabihf- O=build/r5 + make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=build/r5 + make CROSS_COMPILE=arm-linux-gnueabihf- O=build/r5
* 4.2 A72:
- $ make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=build/a72 - $ make CROSS_COMPILE=aarch64-linux-gnu- ATF=<ATF dir>/build/k3/generic/release/bl31.bin TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<DM firmware>/ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f O=build/a72 + make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=build/a72 + make CROSS_COMPILE=aarch64-linux-gnu- ATF=<ATF dir>/build/k3/generic/release/bl31.bin TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<DM firmware>/ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f O=build/a72
On 11/9/22 18:30, Andrew Davis wrote:
- BASH code should be labeled as such.
- Code blocks should be indented by 4 spaces.
Fix these here.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Changes from v2:
- None
Changes from v1:
- SYSFW:
- ATF:
- OPTEE:
- U-Boot:
- 4.1 R5:
- 4.2 A72:
Target Images
Andrew Davis
